vndesperados
Scale đối tượng một chiều
Đây là đọan code scale đối tượng một chiều
Lệnh là XSC hoặc XSCALE
;Scale the mot chieu
(DEFUN EXCUTE()
 (setq oldvalue (getvar "CMDECHO"))
 (setvar "CMDECHO" 0)
 (princ "Chon doi tuong can scale: ")
 (setq ss (ssget))
 (setq P0 (getpoint "\nChon diem goc: "))
 (initget 1 "X Y X S")
 (setq C (getkword "\nScale theo [X,Y,Z,Scale]? :"))
 (setq hs (getreal "Cho biet he so scale: "))
 (DELBLOCK "vkc_temp")
 (CREATEBLOCK ss P0)
 (Command "-Insert" "vkc_temp" C hs P0 "")
 (setq dt (entlast))
 (Command "Explode" dt)
 (setvar "CMDECHO" oldvalue)
(DEFUN CREATEBLOCK(ss P)
 (command "-Block" "vkc_temp" P ss "")
(DEFUN DELBLOCK (bname)
 (if (IsExistBlock bname)
(Command "-Purge" "B" bname "Y" "Y")
(DEFUN IsExistBlock(bname / kq)
 (setq kq Nil)
 (setq n (length LiBlk))
 (setq i 0)
 (while (< i n)
(if (= bname (nth i LiBlk))
(setq i n)
(setq kq T)
(setq i (1+ i))
 kq
(DEFUN CREALIBLK (/ NL)
 (setq LiBlk (List))
 (setq NL (tblnext "BLOCK" T))
 (while NL
(setq LiBlk (append LiBlk (list (cdr (assoc 2 NL)))))
(setq NL (tblnext "BLOCK"))
 (setq LiBlk (Acad_strlsort LiBlk))
(DEFUN C:XSCALE()
 (CREALIBLK)
 (EXCUTE)
(DEFUN C:XSC()
 (CREALIBLK)
 (EXCUTE)
  • Vote tăng 5
(DEFUN EXCUTE()
 (setq ss (ssget))
 (CREATEBLOCK ss P0)
 (setq dt (entlast))
 (setq kq Nil)
 (setq i 0)
 (while (< i n)
(setq i n)
(setq kq T)
(setq i (1+ i))
 kq
 (setq LiBlk (List))
 (while NL
(DEFUN C:XSCALE()
 (CREALIBLK)
 (EXCUTE)
(DEFUN C:XSC()
 (CREALIBLK)
 (EXCUTE)
tôi gặp lỗi khi sử dụng: lần 1 scale theo phương X = ok, sau đó cũng các block này nếu tiếp tục scale theo phương khác thì gặp lỗi :
Command: XSC Chon doi tuong can scale:
Select objects: Specify opposite corner: 5 found
Select objects:
Chon diem goc:
Scale theo [X,Y,Z,Scale]?<X/Y/Z/S> :Y
Cho biet he so scale: 2
Command:
Select objects: P
5 found
Select objects:
Chon diem goc:
Scale theo [X,Y,Z,Scale]?<X/Y/Z/S> :X Cho biet he so scale: 5
Unknown command "-PURGE". Press F1 for help.
Unknown command "B". Press F1 for help.
Unknown command "VKC_TEMP". Press F1 for help.
Unknown command "Y". Press F1 for help.
Yes or No, please.
; error: Function cancelled
Redefine it? [Yes/No] <N>:
nhờ vndesperados xwm lại giúp. Thanks
Select objects:
Chon diem goc:
Command:
Select objects: P
5 found
Select objects:
Chon diem goc:
Yes or No, please.
Test mãi cũng không ra lỗi này nên cũng không biết sửa sao nữa
Bác nào dùng mà gặp lỗi này thì POST lại giùm nhé
Mình có hai máy tính thôi nên không test ra hết các trường hợp, hehehehheh
Lổi xảy ra khi thực hiện lệnh PUGE theo em nghĩ hai bác dùng hai phiên bản CAD khác nhau nên mới thế. (Chỉ nghỉ vậy thôi chứ chưa thử không biết đúng không)
Bạn cho mình hỏi phần này có hỗ trợ vẽ được scale chiều x bằng 1 đoạn cho trước ko? Cad bình thường có. Mình đã thử nhưng ko đc.
Bạn có thể mô ta rõ hơn không???
Lỗi ở đây nè (màu đỏ).
Scale the mot chieu
(DEFUN EXCUTE()
(setq ss (ssget))
(setq C (getkword "\nScale theo [X,Y,Z,Scale]?<X/Y/Z/S> :"))
(CREATEBLOCK ss P0)
(setq dt (entlast))
(setq kq Nil)
(setq i 0)
(while (< i n)
(setq i n)
(setq kq T)
(setq i (1+ i))
kq
(setq LiBlk (List))
(while NL
(DEFUN C:XSCALE()
(CREALIBLK)
(EXCUTE)
(DEFUN C:XSC()
(CREALIBLK)
(EXCUTE)
Ví dụ tớ có một cái bơm chiều dài 1570 , muốn giữ nguyên chiều cao, scale chiều dài ra thành 2547 thì ko đc. Bạn có cách nào làm đc ko?
Dùng 'cal... 2547/1570...
Tôi cũng gặp lỗi khi scale theo trục Y như sau:
Command: xsc Chon doi tuong can scale:
Select objects: 1 found
Select objects:
Chon diem goc:
Scale theo [X,Y,Z,Scale]?<X/Y/Z/S> :y Cho biet he so scale: 0.9615
No unreferenced blocks found.
Yes or No, please.
Nhờ bác xem giúp. Tôi đang dùng cad 2004, winXP SP2
Select objects:
Chon diem goc:
Yes or No, please.
Cái này tôi vẫn làm việc bình thường, tôi dùng AboutAutolisp1.2 , Cad2004,2007, win vista, Xp đều Ok
Quái thiệt, giờ thì cả scale theo trục X cũng bị lỗi tương tự luôn, không hiểu có điều gì bất ổn với cái PC của tôi nữa?! :)
Select objects: Specify opposite corner: 33 found
Select objects:
Chon diem goc:
Scale theo [X,Y,Z,Scale]?<X/Y/Z/S> :x
Yes or No, please.
Help me, please!
Select objects:
Chon diem goc:
Yes or No, please.
Help me, please!
Bạn đã sửa dòng lệnh như bác "nô thiên" chưa? Mình chạy lisp này vẫn ngon, chưa thấy lổi gì
Cần gấp xin giúp :
Mình cũng dùng Scale 1 chiều công trình cao 32m, Scale theo trục Y, nhưng chỉ Scale được 2/3 công trình, fần còn lại chương trình đòi CODE ( command : CHO CODE ), không điền code được thi không cho Scale và bản vẽ báo lỗi,exit luôn.
mình copy nội dung file Scale 1 chiều vào Autocad2004.doc để chạy.
Cần gấp xin giúp :
chương trình nào vậy bạn?
Cảm ơn Bạn!
Mình đang nói về lisp Scale một chiều của topic này.
Sory , mình nói cho rõ tí :
Công trình cần Scale mình chia ra làm 3 khối, vì để 1 khối thì Scale không được
sau đó mình Scale 1 chiều từng khối, Scale được 2 khối rồi, đến khối thứ 3 thì Lisp đòi CODE , mình không biết Code là gì cả. Sau đó không thể tiếp tục công việc được.
thấy các bro thao luận sôi nổi quá, nhưng tôi thấy việc scale theo 2 phương khác nhau chi cần tạo block, sau đó insert và chọn tỷ lệ theo 2 phương khác nhau là ok. có thể nhập tỷ lệ theo dạng phân số a/b trong hộp thoại insert
Cảm ơn Bạn!
lisp nào đòi code?
Trên cadviet, toàn bộ lisp là free mà?
Chưa hẳn đâu bạn ơi. Bạn test nhiều trường hợp xen sao, block có chứa đủ loại text, rec, circle...
Cad 2009 đã có lệnh Scale XY
http://www.cadviet.com/forum/index.php?showtopic=3474
(DEFUN EXCUTE()
 (CREATEBLOCK ss P0)
 (setq dt (entlast))
(DEFUN C:XSC()
 (CREALIBLK)
 (EXCUTE)
Trường hợp trên bản vẽ có Block name vkc_temp thì hàm DELBLOCK sẽ không có tác dụng--> báo lỗi,
do đó Vndesperados nên đặt tên Block theo cách khác.
