Nhờ sửa Lisp Copy Text Cad sang Excel
26 replies to this topic
#21 Tot77
Tot77
  • 993 Bài viết
Điểm đánh giá: 499 (tốt)
Đã gửi 23 October 2014 - 10:02 AM
Bạn dùng cái này. Lúc chạy lần đầu nó có hỏi chọn layer, bạn pick 3 cái text để lấy 3 layer.
(defun batdau ()
  (defun dxf (id v) (cdr (assoc id (entget v))))
  (setq xlApp   (vlax-get-or-create-object "Excel.Application")
            xlCells (vlax-get-property
                      (vlax-get-property
                        (vlax-get-property
                          (vlax-invoke-method
                            (vlax-get-property xlApp "Workbooks")
                            "Add") "Sheets") "Item" 1) "Cells"))
   (vla-put-visible xlApp :vlax-true)
   (if (not tlayer1)
    (progn (alert "Hay chon Layer")
      (setq tlayer1 (dxf 8 (car (entsel "\nChon text thuoc layer 1:")))
 tlayer2 (dxf 8 (car (entsel "\nChon text thuoc layer 2:")))
 tlayer3 (dxf 8 (car (entsel "\nChon text thuoc layer 3:")))))
  (setq row1 0 row2 0 row3 0)
  (setq col1 1 col2 5 col3 9)
(defun ghi (tlayer row col dau / ss1 ss0 y i iPt)
    (setq ss1 (vl-remove-if-not '(lambda (x) (= (dxf 8 x) tlayer)) ss)
 ss1 (mapcar '(lambda (x) (list (vlax-get (vlax-ename->vla-object x) 'InsertionPoint)
 (vlax-ename->vla-object x))) ss1)
 cao (vla-get-Height (last (car ss1))))
    (while ss1
(setq  ss1 (vl-sort ss1 '(lambda (x y) (dau (cadr (car x)) (cadr (car y)))))
      ss0 (vl-remove-if-not '(lambda (x) (equal (cadr (caar ss1)) (cadr (car x)) cao)) ss1)
      ss0 (vl-sort ss0 '(lambda (x y) (< (caar x) (caar y))))
      ss1 (vl-remove-if '(lambda (x) (member x ss0)) ss1)
(foreach z ss0
          (setq iPt (car z)
y (list (vla-get-TextString (last z))  (rtos (car iPt) 2 2)  (rtos (cadr iPt) 2 2) (rtos (caddr iPt) 2 2))
          (setq i -1 row (1+ row))
          (mapcar '(lambda (x) (vlax-put-property xlCells "Item" row  (+ col (setq i (1+ i))) x)) y)
  row
(defun c:ttx  (/ ss ss1 y xlApp xlCells row col i iPt)
  (batdau) (prompt "\nChon text")
  (if (setq ss (ssget '((0 . "*TEXT"))))
      (setq ss (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
      (setq row1 (ghi tlayer1 row1 col1 <))
      (setq row2 (ghi tlayer2 row2 col2 <))
      (setq row3 (ghi tlayer3 row3 col3 <))
  (mapcar 'vlax-release-object (list xlApp xlCells))
(defun c:tty (/ ss xlApp xlCells row1 row2 row3)
  (while (setq ss (ssget '((0 . "TEXT"))))
    (setq row1 (ghi tlayer1 row1 col1 >))
    (setq row2 (ghi tlayer2 row2 col2 >))
    (setq row3 (ghi tlayer3 row3 col3 >))
@tientracdia : cái này chỉ đỡ hơn ở chỗ không cần chọn text mà chỉ cần chọn khung pline, nhưng không quét và sắp xếp theo thứ tự mà bạn phải pick từng cái thôi, thứ tự do bạn chọn.
(defun c:tta (/ ss sst ssc ssd pl oo txt xlApp xlCells row col i lst area)
  (defun inside(pt l)
    (defun tgoc(a b c) (abs (- pi (abs (- (angle b c) (angle a b))))))
    (equal 6.28319 (apply '+ (mapcar '(lambda(x y) (tgoc x pt y)) l (append (cdr l) (list (car l))))) 0.001)
                      (vlax-get-property
                        (vlax-get-property
                          (vlax-invoke-method
                            "Add") "Sheets") "Item" 1) "Cells") row 0 col 1)
  (setq ss (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget "X" '((0 . "TEXT"))))))
sst (vl-remove-if-not '(lambda (x) (distof (vla-get-TextString (vlax-ename->vla-object x)))) ss)
ssc (vl-remove-if '(lambda (x) (member x sst)) ss)
sst (mapcar '(lambda (x) (list (vlax-get (vlax-ename->vla-object x) 'TextAlignmentPoint)
 (vla-get-TextString (vlax-ename->vla-object x)))) sst)
  (prompt "\nChon khung pline:")
  (while (setq pl (ssget ":E:S" '((0 . "LWPOLYLINE"))))
    (setq pl (ssname pl 0)) (redraw pl 3)
    (setq ssd (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 10 (car x))) (entget pl)))
 oo (vl-remove-if-not '(lambda (x) (inside (vlax-get (vlax-ename->vla-object x) 'TextAlignmentPoint) ssd)) ssc))
    (if oo
(setq oo (car oo)
     ssc (vl-remove oo ssc)
     lst (list (vla-get-TextString (vlax-ename->vla-object oo))))
        (foreach pt ssd
          (setq txt (car (vl-sort sst '(lambda (x y) (< (distance (car x) pt) (distance (car y) pt)))))
       lst (append lst (list (last txt)))
        (setq area (rtos (* 0.000001 (vla-get-Area (vlax-ename->vla-object pl))) 2 2)
     i -1 row (1+ row))
        (mapcar '(lambda (x) (vlax-put-property xlCells "Item" row  (+ col (setq i (1+ i))) x)) lst)
        (vlax-put-property xlCells "Item" row 9 area)
  (mapcar '(lambda (x) (redraw x 4)) (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget "X")))))
  (redraw)
#22 huaductiep
huaductiep
  • 85 Bài viết
Đã gửi 23 October 2014 - 02:49 PM
Mình chạy lisp ttx tty với 3 layer thì ok. Nhưng thử thay đổi sang 2 layer, ko chọn layer thứ 3 thì lỗi vì lisp buộc phải chọn 3 text thuộc 3 layer khác nhau. Còn nếu có 4 hoặc nhiều layer hơn thì chưa có tùy chọn. Bác có thể sửa lisp sao cho có thể có tùy chọn số lượng layer được không (có thể lên tới 10 layer hoặc hơn nữa…). Cám ơn bác !
#23 tientracdia
tientracdia
    biết lệnh scale
  • 147 Bài viết
Điểm đánh giá: -11 (hơi kém)
Đã gửi 23 October 2014 - 04:53 PM
Rất hay, xin cám ơn Bạn
 Mình có ý muốn bạn giúp thêm, vì số lượng lớn, sau khi làm xong đợt 1 , muốn làm tiếp đợi 2, mình muốn ghi nối tiếp và file trước chứ không mổi lần mở book mới.
Mong bạn giúp thêm
#24 huunhantvxdts
huunhantvxdts
    biết dimedit
  • 398 Bài viết
Điểm đánh giá: 61 (tàm tạm)
Đã gửi 23 October 2014 - 05:33 PM
Cái này cũng gần giống cái trên.
(defun c:tty  (/ ss ss1 y xlApp xlCells row col i iPt)
                      (vlax-get-property
                        (vlax-get-property
                          (vlax-invoke-method
  (while (setq ss (ssget '((0 . "*TEXT"))))
      (setq ss (mapcar '(lambda (x) (list (vlax-get (vlax-ename->vla-object x) 'InsertionPoint)
      (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
      (while ss
(setq  ss (vl-sort ss '(lambda (x y) (> (cadr (car x)) (cadr (car y)))))
      ss1 (vl-remove-if-not '(lambda (x) (equal (cadr (caar ss)) (cadr (car x)) 0.2)) ss)
      ss1 (vl-sort ss1 '(lambda (x y) (< (caar x) (caar y))))
      ss (vl-remove-if '(lambda (x) (member x ss1)) ss)
(foreach z ss1
          (setq iPt (car z)
          (if (> row 65536) (setq col 5))
Bạn Tot có thể chỉnh lại cho mình xuất theo hàng không và cột được không (Bên cad thế nào xuất qua excel thế nấy, muốn xuất bảng khối lượng trong cad qua excel)
#25 Tot77
Tot77
  • 993 Bài viết
Đã gửi 23 October 2014 - 08:01 PM
@huunhan : bạn thử cái này http://www.cadviet.c...cad-sang-excel/
@tien:  cứ để file excel mở song song với file cad, chừng nào không nhập nữa thì hãy save và tắt excel.
(defun c:tta (/ ss sst ssc ssd pl oo txt i lst area *error*)
  (defun inside(pt l)
  (if (not xlApp)
                      (vlax-get-property
                        (vlax-get-property
                          (vlax-invoke-method
row 0 col 1
         xtmp (vla-put-visible xlApp :vlax-true)
    (if oo
(setq oo (car oo)
        (foreach pt ssd
     i -1 row (1+ row))
  (redraw)
@huaductiep: để lúc nào rảnh tôi sửa theo yêu cầu cuả bạn, lúc này hơi bị "ngán" cái đề tài này.
#26 huunhantvxdts
huunhantvxdts
    biết dimedit
  • 398 Bài viết
Đã gửi 23 October 2014 - 08:13 PM
  (defun inside(pt l)
  (if (not xlApp)
                      (vlax-get-property
                        (vlax-get-property
                          (vlax-invoke-method
row 0 col 1
    (if oo
(setq oo (car oo)
        (foreach pt ssd
     i -1 row (1+ row))
  (redraw)
 Cám ơn Ban Tot nhiều
#27 buithengan1
buithengan1
  • 23 Bài viết
Đã gửi 06 November 2014 - 04:16 PM
Bạn dùng cái này thử xem.
Chọn 1 khung pline rồi chọn cái tên khung (ô-..), chọn tới đâu xuất excel tới đó.
Phần diện tích k biết lấy đơn vị là gì.
(defun c:tta (/ ss ss1 y xlApp xlCells row col i iPt)
                      (vlax-get-property
                        (vlax-get-property
                          (vlax-invoke-method
    (setq oo (car (entsel "\nChon ten cua khung:")))  (redraw pl 4) (redraw oo 3)
    (foreach pt ssd
    (setq lst (append lst (list (vla-get-Area (vlax-ename->vla-object pl))))
 i -1 row (1+ row))
  (redraw)
ban tot77 oi cái  lisp của bạn chỉ sử dụng được với text nằm ngang thôi còn với các text  khác 0 độ thì ko được bạn có thể sửa lại hộ mình được không cảm ơn bạn.
