[ Yêu cầu ] Sửa lisp tự động extend và trim các đường Pline
#1 hoacomay70
hoacomay70
  • 30 Bài viết
Đã gửi 05 December 2014 - 09:53 AM
Em tìm được trên mạng lisp sau tự động extend và trim các đường Pline
auto-trim-extend.gif?w=640
;;; Touch.LSP *
;;; Small routine to align endpoints of lines to an edge. *
;;; The edge have to be a line. *
;;; The routine works by calculating the point of inter- *
;;; section and change the nearest endpoint to that point *
;;; 2001 Stig Madsen, no rights reserved *
;;; modified by qjchen, the edge line can be line or polyline *
;GREAT for PROJECTING LINES FOR ELEVATIONS !!!!!!!!!!!
(defun C:Ttt (/ cmd ent entl spt ept sset a lent lentl lspt lept lint)
(setq cmd (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(command "UNDO" "Begin")
(while (not ent)
(setq ent (car (entsel "Select edge line: ")))
(if ent
    (setq entl (entget ent))
(if ent
(redraw ent 3)
(prompt "\nSelect lines to touch edge: ")
(setq sset (ssget '((0 . "LINE")))
     a 0
(if sset
    (repeat (sslength sset)
     (setq lentl (entget (setq lent (ssname sset a)))
        lspt (cdr (assoc 10 lentl))
        lept (cdr (assoc 11 lentl))
     (setq entttt (ssname sset a))
     (setq lint (nth 0 (x_intlst ent entttt acExtendOtherEntity)))
     (if lint
     (if (< (distance lint lspt) (distance lint lept))
        (entmod (subst
             (cons 10 lint)
             (assoc 10 lentl)
             lentl
        (entmod (subst
             (cons 11 lint)
             (assoc 11 lentl)
             lentl
     (setq a (1+ a))
    (princ "\nNo objects found")
(redraw ent 4)
(princ "\nNo edge selected")
(setvar "CMDECHO" cmd)
(command "UNDO" "End")
;;; by kuangdao at xdcad
(defun x_intlst (obj1 obj2 param / intlst1 intlst2 ptlst)
(if (= 'ENAME (type obj1))
(setq obj1 (vlax-ename->vla-object obj1))
(if (= 'ENAME (type obj2))
(setq obj2 (vlax-ename->vla-object obj2))
(setq intlst1 (vlax-variant-value (vla-intersectwith obj1 obj2 param)))
(if (< 0 (vlax-safearray-get-u-bound intlst1 1))
(setq intlst2 (vlax-safearray->list intlst1))
(while (> (length intlst2) 0)
    (setq ptlst (cons (list (car intlst2) (cadr intlst2) (caddr intlst2))
             ptlst
     intlst2 (cdddr intlst2)
ptlst
Tuy nhiên như trên lisp chỉ chọn được 1 đường Pline màu xanh, sau đó còn quét chọn tất cả các đường khác lại là đường Line. Em muốn nhờ sửa để lisp có thể chọn được nhiều đường Pline, sau đó quét chọn những đường còn lại cũng là đường Pline để tự động  extend và trim như hình dưới đây.
Lisp sẽ yêu cầu chọn các đường Pline cho trước màu xanh, sau đó quét hết các các đường trên bản vẽ, các đường Pline màu đỏ sẽ tự động extend và trim với đường Pline màu xanh gần nó nhất.
Em xin cảm ơn.
#2 hoacomay70
hoacomay70
  • 30 Bài viết
Đã gửi 12 December 2014 - 02:09 PM
Hic có cao thủ nào giúp em với.
#3 bach1212
bach1212
    biết lệnh trim
  • 190 Bài viết
Đã gửi 07 July 2015 - 04:29 PM
Yêu cầu của bạn sẽ rất hữu ích cho công việc. Mong các bác siêu lisp giúp đỡ!  :D
Ít nhất thì sửa được cho lisp chọn cả đối tượng là Pline.
#4 thanhduan2407
thanhduan2407
  • 1001 Bài viết
Điểm đánh giá: 223 (khá)
Đã gửi 08 July 2015 - 09:18 AM
Vấn đề này không khó. Tuy nhiên các Pline phải dời dạc và cách nhau một khoảng cách nhất định.
Nếu như sửa thì sẽ chỉ cần thao tác quét chọn Pline. Sẽ dựa vào kích thước của Pline mà có vùng chọn nhất định để bao các Line xung quanh. Như vậy vấn đề sẽ được giải quyết.
#5 thanhduan2407
thanhduan2407
  • 1001 Bài viết
Đã gửi 08 July 2015 - 09:47 AM
Bạn thử xem nhé!
(defun C:TTT (   /  LTSPLINE X)
  (defun *error* (msg)
    (if	Olmode
      (setvar 'osmode Olmode)
    (if	(not (member msg '("*BREAK,*CANCEL*,*EXIT*")))
  (setq Olmode (getvar "OSMODE"))
  (setq LtsPline (CV:ss-to-list (ssget (list (cons 0 "*LWPOLYLINE,POLYLINE"))) nil))
  (command "Zoom" "e")
  (mapcar '(lambda(x)(Ttt1 x)) LtsPline)
(setvar "OSMODE" Olmode)
(defun Ttt1 (ent  / A  CMD ENTTTT HV KC12 LENT LENTL LEPT LINT LSPT P1 P2 PNT_D PNT_T SSET TV)
  (setvar "OSMODE" 0)
;;;  (while (not ent)
;;;    (setq ent (car (entsel "Select edge line: ")))
;;;    (if	ent
;;;      (progn
;;;	(setq entl (entget ent))
  (if ent
      (redraw ent 3)
      (setq a 0)
      (setq HV (LM:ssboundingbox (CV:List-to-ss (list ent))))
      (setq P1 (car HV))
      (setq P2 (cadr HV))
      (setq KC12 (distance P1 P2))
      (setq TV (list (/ (+ (car P1) (car P2)) 2) (/ (+ (cadr P1) (cadr P2)) 2)))
      (setq Pnt_T (list (- (car TV) (/ KC12 2)) (+ (cadr TV) (/ KC12 2))))
      (setq Pnt_D (list (+ (car TV) (/ KC12 2)) (- (cadr TV) (/ KC12 2))))
      (setq sset (ssget "W" Pnt_T Pnt_D (list (cons 0 "LINE"))))
      (if sset
	  (if lint
		(entmod	(subst
			  (cons 10 lint)
			  (assoc 10 lentl)
			  lentl
		(entmod	(subst
			  (cons 11 lint)
			  (assoc 11 lentl)
			  lentl
	  (setq a (1+ a))
      (redraw ent 4)
			    ptlst
  ptlst
(defun LM:ssboundingbox ( s / a b i m n o )
    (repeat (setq i (sslength s))
        (if
            (and
                (setq o (vlax-ename->vla-object (ssname s (setq i (1- i)))))
                (vlax-method-applicable-p o 'getboundingbox)
                (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list o 'a 'b))))
            (setq m (cons (vlax-safearray->list a) m)
                  n (cons (vlax-safearray->list b) n)
    (if (and m n)
        (mapcar '(lambda ( a b ) (apply 'mapcar (cons a b))) '(min max) (list m n))
(defun CV:List-to-ss (lst / ss)
(setq ss (ssadd))
(foreach item lst
  (or (= (type item ) 'Ename)
   (setq item (vlax-vla-object->ename  item)))
  (setq ss (ssadd item ss))
ss
(defun CV:ss-to-list (ss vla / n e l)
  (setq n (sslength ss))
  (while (setq e (ssname ss (setq n (1- n))))
	(setq l (cons (if vla (vlax-ename->vla-object e) e) l))
#6 hoacomay70
hoacomay70
  • 30 Bài viết
Đã gửi 14 July 2015 - 10:52 AM
Bạn thử xem nhé!
    (if	Olmode
  (setvar "OSMODE" 0)
;;;    (if	ent
;;;      (progn
  (if ent
      (redraw ent 3)
      (setq a 0)
      (setq P1 (car HV))
      (setq P2 (cadr HV))
      (if sset
	  (if lint
		(entmod	(subst
			  (cons 10 lint)
			  (assoc 10 lentl)
			  lentl
		(entmod	(subst
			  (cons 11 lint)
			  (assoc 11 lentl)
			  lentl
	  (setq a (1+ a))
      (redraw ent 4)
			    ptlst
  ptlst
        (if
            (and
    (if (and m n)
(setq ss (ssadd))
(foreach item lst
ss
Bac oi minh chi duoc quet chon doi tuong mot lan thoi a? Cach dung the nao vay a. Em quet chon thi khong thay gi ca. Bac xem giup em duoc khong. Cam on bac rat nhieu.
#7 thanhduan2407
thanhduan2407
  • 1001 Bài viết
Đã gửi 14 July 2015 - 10:46 PM
Bạn thử xem nhé!
    (if	Olmode
  (setvar "OSMODE" 0)
;;;    (if	ent
;;;      (progn
  (if ent
      (redraw ent 3)
      (setq a 0)
      (setq P1 (car HV))
      (setq P2 (cadr HV))
      (if sset
	  (if lint
		(entmod	(subst
			  (cons 10 lint)
			  (assoc 10 lentl)
			  lentl
		(entmod	(subst
			  (cons 11 lint)
			  (assoc 11 lentl)
			  lentl
	  (setq a (1+ a))
      (redraw ent 4)
			    ptlst
  ptlst
        (if
            (and
    (if (and m n)
(setq ss (ssadd))
(foreach item lst
ss
Chỉ cần quét Pline thôi bạn à
