VẼ DẦM (BV xây dựng)
#1 mrphuocvie
mrphuocvie
  • 50 Bài viết
Đã gửi 16 December 2014 - 09:40 PM
Chào mọi người!
Tình hình là em có vấn đề về autolisp nhờ mọi người giúp đỡ!Trong lúc tìm hiểu cách viết lisp thì có thằng bạn nó đang làm đồ án, muốn viết cho nó vẽ đỡ vất vả mà chưa đủ level, mong mọi người viết tiếp giúp em!
(defun C:BEAM()
; Chon va set cac diem thuoc dam
	(setq p1 (getpoint "\nChon diem dau tren ben trai dam: ")
		x1 (car p1)
		y1 (cadr p1))
	(setq p4 (getpoint p1 "\nChon diem dau tren ben phai dam: ")
		x4 (car p4))
	(setq p4 (list x4 y1))
	(setq x0T (+ x1 (* (- x4 x1) 0.5)))
	(setq p0T (list x0T y1))
	(setq p0 (getpoint p0T "\nChon diem dat dim tren: "))
	(setq L4 (* (- x4 x1) 0.25))
	(if (> L4 (float(* (fix (/ L4 100)) 100))) (setq L4 (* (+ (fix (/ L4 100)) 1) 100)))
	(setq x2 (+ x1 L4))
	(setq p2 (list x2 y1))
	(setq x3 (- x4 L4))
	(setq p3 (list x3 y1))
	(setq p5 (getpoint "\nChon diem dau duoi ben trai dam: ")
		x5 (car p5)
		y5 (cadr p5))
	(setq p8 (getpoint p5 "\nChon diem dau duoi ben phai dam: ")
		x8 (car p8))
	(setq p8 (list x8 y5))
	(setq x0D (+ x5 (* (- x8 x5) 0.5)))
	(setq y0D y5)
	(setq p0D (list x0D y0D))
	(setq p0DD (getpoint p0D "\nChon diem dat dim tren: "))
	(setq L6 (/ (- x8 x5) 6))
	(setq L6 (* (fix (/ L6 100)) 100))
	(setq x6 (+ x5 L6))
	(setq p6 (list x6 y5))
	(setq x7 (- x8 L6))
	(setq p7 (list x7 y5))
; Nhap chieu day lop be tong bao ve
	(if (not abv0) (setq abv0 40))
	(setq abv (getreal (strcat "\nChieu day BTBV <" (rtos abv0) ">:")))
	(if abv (setq abv abv0))
	(setq y9 (- y1 abv))
	(setq p9 (list x1 y9))
	(setq p10 (list x2 y9))
	(setq p11 (list x3 y9))
	(setq p12 (list x4 y9))
	(setq y13 (+ y5 abv))
	(setq p13 (list x5 y13))
	(setq p14 (list x6 y13))
	(setq p15 (list x7 y13))
	(setq p16 (list x8 y13))
	(setq p100 (list (- x2 60) (- y9 30)))
	(setq p110 (list (+ x3 60) (- y9 30)))
	(setq p140 (list (+ x6 60) (+ y13 30)))
	(setq p150 (list (- x7 60) (+ y13 30)))
; Ve cot doc
(if (= (cdr(assoc 2 (tblsearch "layer" "Rebar"))) nil)(COMMAND "LAYER" "M" "Rebar" "C" "1" "" ""))
	(setvar "clayer" "Rebar")
	(command "line" p9 p12 "")
	(command "line" p10 p100 "")
	(command "line" p11 p110 "")
	(command "line" p13 p16 "")
	(command "line" p140 p14 "")
	(command "line" p150 p15 "")
; Ve cot dai
	(if (= (cdr(assoc 2 (tblsearch "layer" "Stirrups"))) nil)(COMMAND "LAYER" "M" "Stirrups" "C" "4" "" ""))
	(setvar "clayer" "Stirrups")
	;Dau dam ben trai
	(setq x-ag (+ x1 50))
	(repeat (fix (/ L4 100))
		(setq pG1 (list x-ag y9))
		(setq pG2 (list x-ag y13))
		(setq x-ag (+ 100 x-ag))
		(command "LINE" pG1 pG "")
	;Doan giua dam
	(setq x-ag x2)
	(repeat (fix (/ L4 200))
		(setq x-ag (+ 200 x-ag))
	;Dau dam ben phai
	(setq x-ag (- x4 50))
		(setq x-ag (- 100 x-ag))
; Chi cac thong tin ve thep
	;Tao layer Text2.5 dung cho ghi chu
	(if (= (cdr(assoc 2 (tblsearch "layer" "Text2.5"))) nil)(COMMAND "LAYER" "M" "Text2.5" "C" "2" "" ""))
	;Chua biet viet tiep, nho cac cao thu tiep suc!!!
;Dim cac thong so dam
	(if (= (cdr(assoc 2 (tblsearch "layer" "Dim"))) nil)(COMMAND "LAYER" "M" "Dim" "C" "7" "" ""))
	(setvar "clayer" "Dim")
	(command "dimlinear" p5 p6 p0DD)
	(command "dimlinear" p6 p7 p0DD)
	(command "dimlinear" p7 p8 p0DD)
	(command "dimlinear" p1 p2 p0)
	(setq dim_obj (entlast))
	(setq str "8a100")
	(if (= str "") (setq str "8a100"))
	(command ".Dim1" "New" (strcat "<>\\X%%C" str) dim_obj "")
	(command "dimlinear" p2 p3 p0)
	(setq str "8a200")
	(if (= str "") (setq str "8a200"))
	(command "dimlinear" p3 p4 p0)
	(setq str "8a100")
Trong lúc viết thì em nhận ra một số lỗi mà em chưa hiểu tại sao, mong các cao thủ hỗ trợ:
1. Phần vẽ cốt dọc: tại sao em set tọa độ điểm P9(x1-50, y1-abv) và P12(x1-50, y5+abv) mà tại sao khi vẽ line từ P9 đến P12, nó cứ vẽ từ P1 đến P4 và tương tự cho các điểm còn lại.
2. Phần vẽ cốt đai: em muốn sử dụng lệnh repeat để vẽ trong từng đoạn xong dường như nó không hiểu!
3. Và cuối dùng em muốn ghi chú như hình vẽ (mang tính minh họa).
Cho em gửi kèm file .dwg: http://www.cadviet.c...2006_141216.dwg
Cảm ơn!
3. Và cuối dùng em muốn ghi chú như hình vẽ.
#2 Tue_NV
  • 4298 Bài viết
Đã gửi 17 December 2014 - 08:26 AM
1. Trong lisp bạn chưa có đoạn mã tắt chế độ bắt điểm nên mới "em set tọa độ điểm P9(x1-50, y1-abv) và P12(x1-50, y5+abv) mà tại sao khi vẽ line từ P9 đến P12, nó cứ vẽ từ P1 đến P4 và tương tự cho các điểm còn lại."
#3 lyky
lyky
  • 70 Bài viết
Điểm đánh giá: 126 (tàm tạm)
Đã gửi 17 December 2014 - 09:32 AM
Hoan nghênh và trân trọng một ý tưởng!
Mình xin có một số ý kiến
1. Chương trình của bạn, cần tương đối nhiều dữ kiện đầu vào - mình nên mần cái Dialog (DCL) để được thuận tiện.
2. Nhìn sơ lược mình thấy bạn viết theo kiểu set điểm tường minh... cách này căn bản - dễ hiểu - nhưng, chỉ thích hợp cho những trường hợp đơn giản... Nếu muốn xây dựng một chương trình thực sự (?!) Bạn - có lẽ sẽ nên thay đổi quan niệm một chút đó, ví dụ như: Thay vì set từng điểm từng điểm một, mình có thể chỉ cần set một điểm đầu tiên thôi - sau đó trong lúc vẽ mình sẽ viết thêm một public function để set gián tiếp chương trình sẽ gọn, dễ đọc, dễ gỡ lỗi hơn - kiểm soát và sữa chữa cũng đuợc thuận tiện nữa.
3. Một điều nữa, với mức độ mà bạn vừa trình bày, thì điều tôi sắp nói không cần thiết - nhưng nếu như bạn muốn phát triển tiếp, tất nhiên vẽ mặt cắt dọc như vậy, rồi phải vẽ luôn mặt cắt ngang nữa chứ... gia công thép nữa chứ... thống kê nữa chứ... nhiều thứ lắm. Trước tiên, bạn phải bố cục môi trường vẽ cái đã, rùi mới vẽ ha!
4. Rãi thép (ý tôi đang nói cốt đai đó mà) theo bước và chiều dài cho trước - mình cũng nên viết một public function chuyên làm việc này, tất nhiên là chạy vòng lặp để vẽ chứ ha!
Một số lỗi:
(if (not abv) (setq abv abv0))
; Ve cot doc
(setq oldos (getvar "OSMODE"))
(command "LINE" pG1 pG2 "") ;;; Ba vị tri
(setq x-ag (-  x-ag 100)) ;;; dao vi tri
(setvar "osmode" oldos)
Một số ý kiến thôi - có trái ý thì mong các đồng chí tha lỗi - nhiều lời!
#4 mrphuocvie
mrphuocvie
  • 50 Bài viết
Đã gửi 17 December 2014 - 01:08 PM
Trước hết, em cảm ơn anh Tue_NV, đúng bệnh luôn! hihi.
Cảm ơn lyky đã định hướng giúp em và chỉ ra một số lỗi sai. Và có thời gian em sẽ tìm hiểu thêm phần anh nói, nếu có gì khó khăn mong mọi người giúp đỡ!
Trân trọng cảm ơn! Em sẽ tự viết phần còn lại!
