* * * * * 1 Bình chọn
Hot: download autocad 2000-2010
70 replies to this topic
#41 timlai_blt
timlai_blt
Đã gửi 28 December 2010 - 11:33 PM
cai link cua autocad 2010 file 13 bi hu rui do Bac
nếu bạn có File 10 chạy đc thì post lên giúp với pạn
#42 codered8x
codered8x
  • 119 Bài viết
Điểm đánh giá: 18 (tàm tạm)
Đã gửi 29 December 2010 - 08:31 AM
Autodesk AutoCad 2011 - X86/x64 - 1 GIG LINKS
Mình đã down bản này và dùng ok, link mega bạn chỉ phải đợi 25s ( chỉ có 3 links)và down tốc độ maxspeed như mf, bonus thêm 1 Ebook và Training hướng dẫn tiếng Anh.
[RS/HF/MU/FS]Autodesk AutoCad 2011 - X86/x64 - 1 GIG LINKS
Encludes 4 E-Books, Training - X86/x64- Multilanguage
I have edited the ISO, with no loss to the product, so you can burn to one disk..
A 32 bit disk and A 64 bit disk.
I tested this by burning to disk and loading that way. What I have found is this works for some.
If this will not work for you, extract all the files to a folder and setup from there.
I have not tested this as a mount.
My testing was done with a ISO disk for the 64(x64) bit system.
I use Power ISO, Power ISO is a great program for this, and I always burn software at 4x speed.
http://www.rapidshare.com/files/415225121/POWER.rar
Run Setup.exe and install Autodesk Autocad
Select I have my product information
Use there serial Number provided with the patches
In the instructions text
You must download the patches to get the serial numbers
Enter the serial numbers and product key as shown in the photo
Begin Installation
Yes for default
Loading....
Finish the installation and close autodesk
Restart Autodesk Product
Before clicking on Activate
Disconnect from the internet
Click on Activate
Pick "I have an activation code from Autodesk"
This will give you a request code, copy and paste(ctrl+c) to notepad. You will need this to get
your activation code
Example none working code.
qgcz z512 jq4d joy6 q95q 4r99 doky gezy
Open the crack folder you have minimized,
start XFORCE Keygen 32bits version if you are installing a 32bits application and
64bits if you are installing a 64bits application.
Click on Mem Patch (you should see successfully patched)
Copy the request code into the keygen and press generate
This will give you a group of numbers and digits, 56 in all
A1B2C3D4E5F6G7H8I9J1K2L3M4N5O6P7Q8R9S1T2U3V4W5X6Y7Z1A2B3
Now copy the activation code, all 56, into box #1. This will fill the boxes with the codes.
Run the Keygen as administrator and with UAC off in Vista or Windows7
Help, to copy (ctrl+c) to paste (ctrl+v)
You must download the patches seperate to get the serial numbers
X86 (32 Bit) Patch
http://rapidshare.com/files/397657371/A_ACAD_32_PATCH.rar
X64 (64 Bit) Patch
http://rapidshare.com/files/397657431/A_ACAD_64_PATCH.rar
X86 (32 Bit)
http://www.megaupload.com/?d=KV8D0U7V
http://www.megaupload.com/?d=79GF79L5
http://www.megaupload.com/?d=E21F5OYB
X64 (64 Bit)
http://www.megaupload.com/?d=Q3ODD3SG
http://www.megaupload.com/?d=2A806RV0
http://www.megaupload.com/?d=8WNREJML
E-Books, 4 in all. Training Manuals
Autocad 2011 ebooks 4 Books
Autocad 2011 ebooks
English | Publisher: Sybex | ISBN-13: 978-0470621974 | 1248 pages | PDF | 115 MB
AutoCADis the leading drawing software used by design and drafting professionals to create 2D and 3D technical drawings. Mastering AutoCAD and AutoCAD LT guides you through AutoCAD essentials using concise explanations, focused examples, step-by-step instructions, and hands-on projects for both AutoCAD and AutoCAD LT.
1.Autocad 2011 for dummies.
2.Introduction to Autocad 2011.
3. AutoCAD 2011 and AutoCAD LT 2011 – No Experience Required.
4. Mastering AutoCAD 2011 and AutoCAD LT 2011.
http://www.rapidshare.com/files/437819738/AutoCAD_2011_E-Books.rar
#43 fire_eagle86
fire_eagle86
Đã gửi 13 January 2011 - 03:14 AM
các bác ơi em download về, giải nén part o1 ra rồi, mình thấy có file ".daa" thì pahỉ làm thế nào đây, thank các bác nhiều
A ơi cho e hỏi chút là khi cài Cad 08 được 1 lúc thì nó đòi "Please insert the disk Autocad labeled disk 2" thì làm tiếp thế nào đây?Mong a đã thương thì thương cho trót,hướng dẫn cụ thể cho bọn đàn em này chutss.
Dưới đây là hình của nó
http://www.cadviet.c...untitled_42.jpg
#44 fire_eagle86
fire_eagle86
Đã gửi 13 January 2011 - 03:22 AM
Trước hết mình xin cảm ơn bạn,
Mình đã down Acad 08 về, burn ra DVD, dung lượng là 1.26 GB. Installation tốt hết (DViewer, Mdac) , tuy nhiên tới lúc cài thằng Autocad thì nó kêu bỏ đĩa 2 vô. Mình tìm hoài ko thấy. Mình down qua link mediafire mà bạn cung cấp. Mình cũng thử chạy setup riêng của autocad nhưng nó van báo là cần đĩa 2. Bạn giúp mình dc ko? Mình đang rất cân Acad.
Thanks
Mình cũng bị vướng cái đoạn cài như bạn Macky này,dưới đây là hình ảnh post lên nhờ ông anh chủ topic giúp đỡ chút.
http://www.cadviet.c...untitled_43.jpg
#45 kiuctinhyeu
kiuctinhyeu
Đã gửi 15 January 2011 - 04:19 PM
ai có link down bản Cad mechanical 2010 win 64 bit ko làm ơn cho xin với.Torrent hay mediafire nhé .Mình cài bản 2011 mà crack chưa dc.Giờ cứ bật lên nó vào rồi tắt lun k hiện phần điền key nữa.Gỡ ra cài lại rồi mà không được.Hix bạn nào có link down cho xin với.Tìm hoài k thấy
#46 cauchuyen_tinhyeu_alhp
  • 17 Bài viết
Đã gửi 01 February 2011 - 08:41 PM
mình có autocad 2010 full crack...đã bẻ crack...nếu tốc độ download ở mạng của bạn là 80kb/giây thì bạn mất 1h30phút để download hết bản cài autocad2010 sau
http://www.mediafire...2bit.part01.exe
http://www.mediafire...2bit.part02.rar
http://www.mediafire...2bit.part03.rar
http://www.mediafire...2bit.part04.rar
http://www.mediafire...2bit.part05.rar
http://www.mediafire...2bit.part06.rar
http://www.mediafire...2bit.part07.rar
http://www.mediafire...2bit.part08.rar
http://www.mediafire...2bit.part09.rar
http://www.mediafire...2bit.part10.rar
http://www.mediafire...2bit.part11.rar
http://www.mediafire...2bit.part12.rar
http://www.mediafire...2bit.part13.rar
http://www.mediafire...2bit.part14.rar
http://www.mediafire...2bit.part15.rar
http://www.mediafire...mmzyz2/Licsence for CAD 2010.rar
bạn có thể chạy 6 IDM để download liền lúc 6 file nén.
chúc bạn thành công!!!
tại sao mình vào đường linh nhưng không thể download được
bạn có thể kiểm tra lại đường linh này xem có lỗi gì không
#47 cauchuyen_tinhyeu_alhp
  • 17 Bài viết
Đã gửi 02 February 2011 - 01:03 PM
Đã search trên diễn đàn,Củng có người post các bản cad,Nhưng nhiều link không phải là media,nên post bài này để anh em cần thì download về dùng.Tổng hợp các bản cũ và mới,ai thích dùng cái nào thì down
1.Autocad 2000
Download here
pass:
www.tnctr.com
2.Autocad 2002
Download here
pass:
www.romaniainedit.tk
3.Autocad 2004
Download here
Pass:
congtruongit.com
4.Autocad 2006
Download here
5.Autocad 2007
Download here
6.Autocad 2008
Download here
hoặc ở đây
7.Autocad 2009
Download here
Crack: download crack
8.Autocad 2010
Download here
Pass unlock media:
update24h.com
St: update24h.com
bạn ơi bản www.update24h.com_cad-010.part10.com bị lỗi rồi
bạn có thể cho mình đường link khác được không
#48 KassandraNimonn
KassandraNimonn
Đã gửi 17 February 2011 - 09:07 PM
Hello,
I just made a new community and I find this very useful.
#49 TraiTimSat
TraiTimSat
    biết lệnh move
  • 129 Bài viết
Điểm đánh giá: 49 (tàm tạm)
Đã gửi 09 March 2011 - 03:42 PM
cad 2006-2008 dùng là ổn định nhất!
#50 thhieu1
thhieu1
  • 7 Bài viết
Đã gửi 29 March 2011 - 01:16 PM
Có bác nào biết tại sao khi e cài cad2008 thì không thể tìm được các khung tên mẫu trong template vd như a2,a3,a4.. mà trong cad2007 e vẫn tìm bình thường mà. Hay do crack nên một số chức năng bị hạn chế
#51 dangdangkhoa
dangdangkhoa
  • 7 Bài viết
Đã gửi 03 April 2011 - 02:01 PM
nè link mới 100% full crack lun
http://www.megaupload.com/?d=8E7IB5RI
http://www.megaupload.com/?d=WRBTTHIE
http://www.megaupload.com/?d=T3ATZ3SF
http://www.megaupload.com/?d=4JJLDAKW
http://www.megaupload.com/?d=NHUI6RJP
http://www.megaupload.com/?d=73JDWN7U
http://www.megaupload.com/?d=DQVN8ZB6
http://www.megaupload.com/?d=LYFAGBYD
http://www.megaupload.com/?d=I1S2S18O
http://www.megaupload.com/?d=XSEYJ10V
http://www.megaupload.com/?d=DCR3Y3MH
http://www.megaupload.com/?d=M8PFUFFE
http://www.megaupload.com/?d=0B7VYZJM
http://www.megaupload.com/?d=DB4GGYEX
#52 dangdangkhoa
dangdangkhoa
  • 7 Bài viết
Đã gửi 03 April 2011 - 02:09 PM
mới lun nè 100% dùng được cho x64 lan x86
#53 dangdangkhoa
dangdangkhoa
  • 7 Bài viết
Đã gửi 22 April 2011 - 09:09 AM
mới nè
http://www.filesonic...6285944/AutoCad 2010.part01.rar
http://www.filesonic...6268334/AutoCad 2010.part02.rar
http://www.filesonic...6286054/AutoCad 2010.part03.rar
http://www.filesonic...6268694/AutoCad 2010.part04.rar
http://www.filesonic...6286434/AutoCad 2010.part05.rar
http://www.filesonic...6266344/AutoCad 2010.part06.rar
http://www.filesonic...6286284/AutoCad 2010.part07.rar
http://www.filesonic...6289604/AutoCad 2010.part08.rar
http://www.filesonic...6266304/AutoCad 2010.part09.rar
http://www.filesonic...6267564/AutoCad 2010.part10.rar
http://www.filesonic...6293541/AutoCad 2010.part11.rar
http://www.filesonic...6306561/AutoCad 2010.part12.rar
http://www.filesonic...6293501/AutoCad 2010.part13.rar
http://www.filesonic...6287281/AutoCad 2010.part14.rar
#54 dangdangkhoa
dangdangkhoa
  • 7 Bài viết
Đã gửi 23 April 2011 - 08:31 AM
mới nè
x64
http://www.filesonic...ygen-64bits.exe
http://www.filesonic...354/AutoCad2010 64bit.zip.002
http://www.filesonic...044/AutoCad2010 64bit.zip.003
http://www.filesonic...411/AutoCad2010 64bit.zip.004
http://www.filesonic...711/AutoCad2010 64bit.zip.005
http://www.filesonic...564/AutoCad2010 64bit.zip.007
http://www.filesonic...994/AutoCad2010 64bit.zip.008
http://www.filesonic...034/AutoCad2010 64bit.zip.011
http://www.filesonic...964/AutoCad2010 64bit.zip.012
http://www.filesonic...004/AutoCad2010 64bit.zip.013
http://www.filesonic...721/AutoCad2010 64bit.zip.014
http://www.filesonic...954/AutoCad2010 64bit.zip.015
http://www.filesonic...754/AutoCad2010 64bit.zip.016
http://www.filesonic...601/AutoCad2010 64bit.zip.017
http://www.filesonic...164/AutoCad2010 64bit.zip.018
http://www.filesonic...0_64bit.zip.001
http://www.filesonic...0_64bit.zip.006
http://www.filesonic...0_64bit.zip.009
http://www.filesonic...0_64bit.zip.010
x86
#55 duongdang2011
duongdang2011
  • 10 Bài viết
Đã gửi 24 April 2011 - 12:28 PM
thank - chia sẻ đầy đủ cho ae
#56 TonyThai
TonyThai
Đã gửi 13 May 2011 - 10:04 AM
hix, em down xong 3file của Cad2002 rồi, xin giúp dùm cái pass.
em đã thử dùng "www.cadviet.com" & "wWw.Update24h.Com" "cadviet.com" vẫn ko được.
Xin được giúp đỡ, em là newbie!
#57 tvgtyb08
tvgtyb08
    biết vẽ spline
  • 94 Bài viết
Điểm đánh giá: 10 (tàm tạm)
Đã gửi 01 July 2011 - 07:09 PM
Mình Down phiên bản 2008 về giải nén trong có:
+ 1 Folder : POWER ISO 3.8 + Keygen
+ 1 File : Autodesk_Autocad_2008__(full_version_with_crack).daa
Không biết cài kểu gì.
File *.daa là loại File gì lần đầu tiên mình thấy,
Ai biết chỉ giùm với.
#58 tvgtyb08
tvgtyb08
    biết vẽ spline
  • 94 Bài viết
Đã gửi 01 July 2011 - 07:29 PM
Ah, tui biết rùi, dùng POWER ISO 3.8 để chuyển đổi.
#59 manfred177
manfred177
Đã gửi 11 August 2011 - 10:08 PM
download 2008 về có 1 file bung ra cài ổ ảo chạy thì bảo kêu Insert disk #1 là sao?????Hic chủ thớt fix dùm 2 ngày nay mới down load xong thì ngăm kho tiêu
#60 hunghacity
hunghacity
Đã gửi 27 October 2011 - 08:52 PM
1.Autocad 2000
Download here
pass:
www.tnctr.com
2.Autocad 2002
Download here
pass:
3.Autocad 2004
Download here
Pass:
congtruongit.com
4.Autocad 2006
Download here
5.Autocad 2007
Download here
6.Autocad 2008
Download here
hoặc ở đây
7.Autocad 2009
Download here
8.Autocad 2010
Download here
Pass unlock media:
update24h.com
minh da down cad 2010 ve rui nhung khi den muc giai nen thi pass k dc?
minh cug co su dung cad 2012 lan trc khi dung thi dc nhug bjo sau khi nang cap o cung va them ram thi k the nao cai dc, ly do cu bat udate net .4 mai ma k lam sao dc, ban nao co cak khac phuc mong dc chi jum?
St: update24h.com
trong AUTOCAD 2010 phần thứ 10 bị lỗi rối bạn gởi lai phần 10 lên diễn đàn cho hoàn chỉnh bạn nha(tên file lỗi nè www.update24h.com_cad-010.part10)
