có pác nào giúp em sửa đoạn code voi
#1 unlucky12
unlucky12
Đã gửi 15 December 2009 - 10:57 PM
đoạn code em dùng để thông kê cốt thép load vào CAD rồi nhưng vẫn chưa hoàn thiện :( :rolleyes:
CODE:
Sub THONGKETHEP()
Dim plineObj As AcadLWPolyline
Dim points(0 To 55) As Double
points(0) = 0: points(1) = 0
points(2) = 14: points(3) = 0
points(4) = 14: points(5) = 16
points(6) = 0: points(7) = 16
points(8) = 0: points(9) = 0
points(10) = 0: points(11) = 15
points(12) = 14: points(13) = 15
points(14) = 14: points(15) = 10
points(16) = 0: points(17) = 10
points(18) = 0: points(19) = 5
points(20) = 14: points(21) = 5
points(22) = 14: points(23) = 0
points(24) = 2: points(25) = 0
points(26) = 2: points(27) = 16
points(28) = 3: points(29) = 16
points(30) = 3: points(31) = 0
points(32) = 6: points(33) = 0
points(34) = 6: points(35) = 16
points(36) = 7: points(37) = 16
points(38) = 7: points(39) = 0
points(40) = 9: points(41) = 0
points(42) = 9: points(43) = 16
points(44) = 10: points(45) = 16
points(46) = 10: points(47) = 0
points(48) = 12: points(49) = 0
points(50) = 12: points(51) = 15.5
points(52) = 10: points(53) = 15.5
points(54) = 14: points(55) = 15.5
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
ThisDrawing.Application.ZoomAll
plineObj.color = acMagenta
Dim textObj As AcadText
Dim textString As String
Dim insertionPoint(0 To 2) As Double
Dim height As Double
textString = "TEN-CK"
insertionPoint(0) = 0.4
insertionPoint(1) = 15.5
insertionPoint(2) = 0
height = 0.2
Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
textObj.Update
textString = "SO"
insertionPoint(0) = 2.3
insertionPoint(1) = 15.6
height = 0.2
textObj.Update
textString = "HIEU"
insertionPoint(0) = 2.2
insertionPoint(1) = 15.2
height = 0.2
textObj.Update
textString = "HINH DANG"
insertionPoint(0) = 3.5
height = 0.2
textObj.Update
textString = "KICH THUOC"
height = 0.2
textObj.Update
textString = "%%C"
insertionPoint(0) = 6.5
height = 0.2
textObj.Update
textString = "(mm)"
insertionPoint(0) = 6.2
height = 0.2
textObj.Update
textString = "CHIEU DAI"
insertionPoint(0) = 7.2
height = 0.2
textObj.Update
textString = "(mm)"
insertionPoint(0) = 7.7
height = 0.2
textObj.Update
textString = "SO"
insertionPoint(0) = 9.3
height = 0.2
textObj.Update
textString = "LUONG"
insertionPoint(0) = 9.05
height = 0.2
textObj.Update
textString = "TONG"
insertionPoint(0) = 11.6
insertionPoint(1) = 15.65
height = 0.2
textObj.Update
textString = "CHIEUDAI(M)"
insertionPoint(0) = 10.05
insertionPoint(1) = 15.105
height = 0.2
textObj.Update
textString = "KL(KG)"
insertionPoint(0) = 12.4
height = 0.2
textObj.Update
End Sub
Sub HD1()
Dim points(0 To 5) As Double
points(0) = 3.3: points(1) = 14.3
points(2) = 3.3: points(3) = 14.6
points(4) = 5.8: points(5) = 14.6
plineObj.color = acRed
End Sub
Sub HD2()
Dim points(0 To 7) As Double
points(0) = 3.3: points(1) = 13.3
points(2) = 3.3: points(3) = 13.5
points(4) = 5.8: points(5) = 13.5
points(6) = 5.8: points(7) = 13.3
End Sub
Sub HD3()
Dim points(0 To 9) As Double
points(0) = 5.9: points(1) = 12.3
points(2) = 3.3: points(3) = 12.3
points(4) = 3.3: points(5) = 12.6
points(6) = 5.8: points(7) = 12.6
points(8) = 5.8: points(9) = 12.2
End Sub
Sub HD4()
Dim points(0 To 3) As Double
points(0) = 3.3: points(1) = 11.5
points(2) = 5.8: points(3) = 11.5
End Sub
Sub HD5()
points(0) = 5.9: points(1) = 10.3
points(2) = 3.3: points(3) = 10.3
points(4) = 3.3: points(5) = 10.6
points(6) = 5.8: points(7) = 10.6
points(8) = 5.8: points(9) = 10.2
End Sub
Sub HD6()
points(0) = 3.3: points(1) = 9.5
points(2) = 5.8: points(3) = 9.5
Dim numberOfRows As Long
Dim numberOfColumns As Long
Dim numberOfLevels As Long
Dim distanceBwtnRows As Double
Dim distanceBwtnColumns As Double
Dim distanceBwtnLevels As Double
numberOfRows = 2
numberOfColumns = 1
numberOfLevels = 1
distanceBwtnRows = -5
distanceBwtnColumns = 0
distanceBwtnLevels = 1
Dim retObj As Variant
retObj = plineObj.ArrayRectangular(numberOfRows, numberOfColumns, numberOfLevels, distanceBwtnRows, distanceBwtnColumns, distanceBwtnLevels)
MsgBox "Rectangular array completed.", , "Array Rectangular Example"
End Sub
Public Sub Rectang(FirstPoint() As Double, EndPoint() As Double)
Dim point(0 To 7) As Double
points(0) = FirstPoint(0): points(1) = FirstPoint(1)
points(2) = EndPoint(0): points(3) = FirstPoint(1)
points(4) = EndPoint(0): points(5) = EndPoint(1)
points(6) = First(0): points(7) = EndPoint(1)
plineObj.colosed = Tru
ThisDrawing.Regen (Tru)
Dim FirstPoint(2) As Double
Dim EndPoint(2) As Double
FirstPoint(0) = 0: FirstPoint(1) = 0: FirstPoint(2) = 0
EndPoint(0) = 20: FirstPoint(1) = 15: FirstPoint(2) = 0
Call Rectang(FirstPoint, EndPoint)
ZoomAll
End Sub
Sub HD7()
points(0) = 5.9: points(1) = 8.3
points(2) = 3.3: points(3) = 8.3
points(4) = 3.3: points(5) = 8.6
points(6) = 5.8: points(7) = 8.6
points(8) = 5.8: points(9) = 8.2
numberOfRows = 2
numberOfColumns = 1
numberOfLevels = 1
distanceBwtnRows = -6
End Sub
Sub HD8()
points(0) = 4.3: points(1) = 7.1
points(2) = 4.3: points(3) = 7.2
points(4) = 4.4: points(5) = 7.2
points(6) = 4.4: points(7) = 7.1
points(8) = 4.3: points(9) = 7.1
numberOfRows = 5
numberOfColumns = 5
numberOfLevels = 2
distanceBwtnRows = 0.1
distanceBwtnColumns = 0.1
distanceBwtnLevels = 0.1
End Sub
Sub HD9()
Dim points(0 To 15) As Double
points(0) = 4: points(1) = 6.8
points(2) = 4.3: points(3) = 6.2
points(4) = 4.4: points(5) = 6.7
points(6) = 4.5: points(7) = 6.3
points(8) = 4.6: points(9) = 6.6
points(10) = 4.7: points(11) = 6.4
points(12) = 4.8: points(13) = 6.5
points(14) = 4.9: points(15) = 6.5
numberOfRows = 2
numberOfColumns = 1
numberOfLevels = 1
End Sub
Sub HD10()
points(0) = 5.5: points(1) = 5.1
points(2) = 3.7: points(3) = 5.1
points(4) = 3.7: points(5) = 5.9
points(6) = 5.5: points(7) = 5.9
points(8) = 5.5: points(9) = 5.1
End Sub
Sub HD11()
points(0) = 4: points(1) = 0.3
points(2) = 3.7: points(3) = 0.2
points(4) = 4.3: points(5) = 0.2
points(6) = 4.3: points(7) = 0.7
ZoomAll
Dim point1(0 To 2) As Double
Dim Point2(0 To 2) As Double
point1(0) = 4.5: point1(1) = 0.2: point1(2) = 0
Point2(0) = 4.5: Point2(1) = 0.5: Point2(2) = 0
Dim mirrorObj As AcadLWPolyline
Set mirrorObj = plineObj.Mirror(point1, Point2)
mirrorObj.color = acRed
ZoomAll
End Sub
Sub CT()
Dim objArc As AcadArc
Dim varCtrPt As Variant
Dim dblRadius As Double
Dim dblStartAngle As Double
Dim dblEndAngle As Double
varCtrPt = ThisDrawing.Utility.GetPoint(, vbCrLf & "Center point:")
dblStartAngle = ThisDrawing.Utility.GetAngle(varCtrPt, vbCrLf & "Start angle")
dblEndAngle = ThisDrawing.Utility.GetAngle(varCtrPt, vbCrLf & "End angle")
dblRadius = ThisDrawing.Utility.GetReal(vbCrLf & "Radius:")
Set objArc = ThisDrawing.ModelSpace.AddArc(varCtrPt, dblRadius, dblStartAngle, dblEndAngle)
objArc.Update
objArc.color = acRed
End Sub
Sub TEXT()
Dim objMtext As AcadMText
Dim varInsPt As Variant
Dim dblWidth As Double
Dim strText As String
varInsPt = ThisDrawing.Utility.GetPoint(, vbCrLf & "Start point:")
dblWidth = ThisDrawing.Utility.GetReal(vbCrLf & "Width:")
strText = ThisDrawing.Utility.GetStringt(True, vbCrLf & "Text:")
Set objMtext = ThisDrawing.ModelSpace.AddText(varInsPt, dblWidth, strText)
objMtext.Update
End Sub
Sub TEXAA()
Dim mtextObj As AcadMText
Dim insertPoint(0 To 2) As Double
Dim Width As Double
insertPoint(0) = 4.3: insertPoint(1) = 14.8: insertPoint(2) = 0
Width = 14
textString = "2100"
Set objMtext = ThisDrawing.ModelSpace.AddMText(insertPoint, Width, textString)
ZoomAll
insertPoint(0) = 3.4: insertPoint(1) = 14.5: insertPoint(2) = 0
Width = 14
textString = "250"
ZoomAll
insertPoint(0) = 4.3: insertPoint(1) = 13.8: insertPoint(2) = 0
Width = 14
textString = "1750"
ZoomAll
insertPoint(0) = 3.4: insertPoint(1) = 13.4: insertPoint(2) = 0
Width = 14
textString = "750"
ZoomAll
insertPoint(0) = 5.3: insertPoint(1) = 13.4: insertPoint(2) = 0
Width = 14
textString = "750"
ZoomAll
insertPoint(0) = 4.3: insertPoint(1) = 12.8: insertPoint(2) = 0
Width = 14
textString = "540"
ZoomAll
insertPoint(0) = 3.3: insertPoint(1) = 12.5: insertPoint(2) = 0
Width = 14
textString = "340"
ZoomAll
insertPoint(0) = 5.5: insertPoint(1) = 12.3: insertPoint(2) = 0
Width = 14
textString = "60"
ZoomAll
insertPoint(0) = 4.3: insertPoint(1) = 11.8: insertPoint(2) = 0
Width = 14
textString = "2640"
ZoomAll
insertPoint(0) = 4.3: insertPoint(1) = 10.8: insertPoint(2) = 0
Width = 14
textString = "540"
ZoomAll
insertPoint(0) = 3.3: insertPoint(1) = 10.5: insertPoint(2) = 0
Width = 14
textString = "340"
ZoomAll
insertPoint(0) = 5.5: insertPoint(1) = 10.3: insertPoint(2) = 0
Width = 14
textString = "60"
insertPoint(0) = 4.3: insertPoint(1) = 9.8: insertPoint(2) = 0
Width = 14
textString = "5000"
ZoomAll
insertPoint(0) = 3.3: insertPoint(1) = 8.5: insertPoint(2) = 0
Width = 14
textString = "210"
ZoomAll
insertPoint(0) = 4.3: insertPoint(1) = 8.8: insertPoint(2) = 0
Width = 14
textString = "210"
ZoomAll
insertPoint(0) = 5.5: insertPoint(1) = 8.3: insertPoint(2) = 0
Width = 14
textString = "60"
ZoomAll
insertPoint(0) = 4.3: insertPoint(1) = 5.3: insertPoint(2) = 0
Width = 14
textString = "220"
ZoomAll
insertPoint(0) = 5: insertPoint(1) = 5.7: insertPoint(2) = 0
Width = 14
textString = "120"
ZoomAll
insertPoint(0) = 4.3: insertPoint(1) = 4.7: insertPoint(2) = 0
Width = 14
textString = "6000"
ZoomAll
insertPoint(0) = 3.7: insertPoint(1) = 3.6: insertPoint(2) = 0
Width = 14
textString = "120"
ZoomAll
insertPoint(0) = 4.3: insertPoint(1) = 3.3: insertPoint(2) = 0
Width = 14
textString = "220"
ZoomAll
insertPoint(0) = 3.3: insertPoint(1) = 2.5: insertPoint(2) = 0
Width = 14
textString = "210"
ZoomAll
insertPoint(0) = 4.3: insertPoint(1) = 2.8: insertPoint(2) = 0
Width = 14
textString = "210"
ZoomAll
insertPoint(0) = 5.5: insertPoint(1) = 2.3: insertPoint(2) = 0
Width = 14
textString = "60"
ZoomAll
insertPoint(0) = 3.7: insertPoint(1) = 1.6: insertPoint(2) = 0
Width = 14
textString = "120"
ZoomAll
insertPoint(0) = 4.3: insertPoint(1) = 1.3: insertPoint(2) = 0
Width = 14
textString = "220"
ZoomAll
insertPoint(0) = 3.55: insertPoint(1) = 0.45: insertPoint(2) = 0
Width = 14
textString = "50"
ZoomAll
insertPoint(0) = 3.8: insertPoint(1) = 0.2: insertPoint(2) = 0
Width = 14
textString = "150"
ZoomAll
End Sub
Sub DAI()
textString = "DAI"
insertionPoint(1) = 12.5
height = 0.2
textObj.Update
Dim basePoint(0 To 2) As Double
Dim rotationAngle As Double
basePoint(0) = 1: basePoint(1) = 12.5: basePoint(2) = 0
rotationAngle = 1.5707963 ' 90 degrees
textObj.Rotate basePoint, rotationAngle
textObj.Update
End Sub
Sub COC1()
textString = "COC-C1"
insertionPoint(1) = 7
height = 0.2
textObj.Update
basePoint(0) = 1: basePoint(1) = 7: basePoint(2) = 0
textObj.Update
End Sub
Sub COC2()
textString = "COC-C2"
insertionPoint(1) = 2
height = 0.2
textObj.Update
basePoint(0) = 1: basePoint(1) = 2: basePoint(2) = 0
textObj.Update
End Sub
làm ơn sửa giúp em nah mail cua em là taanhvanv30@gmail.com :rolleyes: :rolleyes:
#2 anhcos
anhcos
    biết lệnh text
  • 274 Bài viết
Điểm đánh giá: 177 (tàm tạm)
Đã gửi 16 December 2009 - 08:42 AM
Hiện tại chỉ thấy chương trình in ra khung với hàng tiêu đề thôi.
Còn phần nội dung bên dưới thì chưa thấy gì, cái phần này bạn phải viết tiếp thôi.
Góp ý một chút ở chỗ nạp dữ liệu cho mảng, bạn làm như thế này cho gọn:
Đây là phần kẻ khung:
points(0) = 0: points(1) = 0 points(2) = 14: points(3) = 0 points(4) = 14: points(5) = 16
points(6) = 0: points(7) = 16 points(8) = 0: points(9) = 0 points(10) = 0: points(11) = 15
points(12) = 14: points(13) = 15 points(14) = 14: points(15) = 10 points(16) = 0: points(17) = 10
points(18) = 0: points(19) = 5 points(20) = 14: points(21) = 5 points(22) = 14: points(23) = 0
points(24) = 2: points(25) = 0 points(26) = 2: points(27) = 16 points(28) = 3: points(29) = 16
points(30) = 3: points(31) = 0 points(32) = 6: points(33) = 0 points(34) = 6: points(35) = 16
points(36) = 7: points(37) = 16 points(38) = 7: points(39) = 0 points(40) = 9: points(41) = 0
points(42) = 9: points(43) = 16 points(44) = 10: points(45) = 16 points(46) = 10: points(47) = 0
points(48) = 12: points(49) = 0 points(50) = 12: points(51) = 15.5 points(52) = 10: points(53) = 15.5
VD thay thế:
   'biến tạm
Dim pts As Variant
pts = Array(0, 0, 14, 0, 14, 16, 0, 16,0,0,0,15) '--> thêm vào cho đủ 56 phần tử
'mảng chính cần đặt giá trị
For i = 0 To UBound(pts) - 1
points(i) = pts(i)
Next i
Với lại ch trình đang dùng tọa độ tuyệt đối, sau này khi cần chèn tại một điểm khác thì hơi mệt vì vậy cần tham số truyền vào cho mỗi hàm:
VD Sub Thongke(x as double,y as double) 'x,y là tọa độ điểm chèn
thì phần tọa độ của các đối tượng sẽ cộng thêm vào x và y tương ứng
Vì thế phần xử lý bên trên viết lại
if i mod 2 = 0 then'vị trí là chẵn --> là tọa độ x
points(i) = pts(i) + x
else
points(i) = pts(i) + y
end if
Next i
Clear sky!
MF Rock collection.
#3 unlucky12
unlucky12
Đã gửi 18 December 2009 - 11:03 PM
VD thay thế:
   'biến tạm
Dim pts As Variant
points(i) = pts(i)
Next i
else
end if
Next i
thanks anh nha nhưng em vẫn chưa hiểu cách load số liệu vào trong bảng hy vọng anh chỉ giúp em với :(
còn đoạn coda tính toán thống kê em vẫn chưa nghĩ ra :rolleyes:
em nghĩ thống kê đường kính theo mau` mà ko hiểu làm cách nào
