Giúp Fix Lỗi Vba
#1 hungnguyen1011
hungnguyen1011
Đã gửi 21 May 2016 - 07:35 PM
Chào mọi người,
như tiêu đề em làm tới khúc bấm H để chọn High card và L để chọn Low Card thì nó bị stop tại đó em không biết bị lỗi gì nữa mong mấy anh giúp dùm em. Code của em phía dưới.
Option Explicit
Sub HighOrLow()
  Dim name As String
  Dim balance As Long
  Dim Cards
  Dim Bet
  Dim HiLo As String
  name = InputBox("Please enter your name:")
  MsgBox ("Hi " & name & " Welcome to High and Low game")
  balance = 100
  If name = vbNullString Then Exit Sub
  Cards = Array("Ace", 2, 3, 4, 5, 6, 7, 8, 9, 10, "Jack", "Queen", "King")
  Call GetBet((name), (balance))
  Call GetHighOrLow((name), (balance), (Bet), (Cards))
End Sub
Function GetBet(name As String, balance As Long)
    Dim Bet As Integer
    Bet = InputBox(name & ", your current balance is $" & balance & "." & vbNewLine & "How much do you want to bet?")
        MsgBox ("So you want to bet: " & Bet & "$")
    If Bet = False Then Exit Function
    If Bet <> Int(Bet) Or Bet < 1 Or Bet > balance Then
        MsgBox (name & ", you must enter a whole number between 1 and " & balance & ".")
        Call GetBet(name, balance)
End If
End Function
Function GetHighOrLow(name As String, balance As Long, Bet As Integer, Cards)
    Dim HiLo As String
    Dim ComCard As String
    Dim RanCard(1 To 2) As Integer
    Dim H, L As String
    Randomize
    RanCard(1) = Int(13 * Rnd + 1)
    RanCard(2) = Int(13 * Rnd + 1)
    HiLo = InputBox(name & ", your card is: " & RanCard(1) & vbNewLine & "Do you think the computer's card is higher [H] or lower [L]?")
    If Not UCase(HiLo) Like "[HL]" Then
        MsgBox (name & ", you must enter [H] for higher or [L] for lower.")
    Call GetHighOrLow(name, balance, Bet, Cards)
    End If
    If HiLo = vbNullString Then Exit Function
   ComCard = (vbNewLine & "The computer's card is: " & Application.Index(Cards, RanCard(2)))
Do While HiLo = H
    If RanCard(2) > RanCard(1) Then
          MsgBox ("That's correct, " & name & "." & ComCard & vbNewLine & "your balance: " & balance = balance + Bet)
     ElseIf RanCard(2) < RanCard(1) Then
          MsgBox ("That's incorrect, " & name & "." & ComCard & vbNewLine & "Your balance: " & balance = balance - Bet)
     Else
          MsgBox ("It's a tie, " & name & "." & vbNewLine & ComCard & vbNewLine & "Your balance: " & balance)
    End If
Do While HiLo = L
          MsgBox ("That's correct, " & name & "." & ComCard & "Your balance" & balance = balance + Bet)
   ElseIf RanCard(2) > RanCard(1) Then
          MsgBox ("That's incorrect, " & name & "." & ComCard & "Your balance" & balance = balance - Bet)
    Else
         MsgBox ("It's a tie, " & name & "." & ComCard & "Your balance" & balance)
    End If
Loop
Loop
End Function
#2 hungnguyen1011
hungnguyen1011
Đã gửi 21 May 2016 - 07:39 PM
Code của em em chạy tới khúc bấm H và L thì nó bị lỗi
http://www.cadviet.c...1_highorlow.txt
