Lisp Vẽ Đường Thẳng Có Ghi Kích Thước Không Bắt Điểm Được...
#1 lenhatminh078
lenhatminh078
Đã gửi 30 July 2016 - 11:51 AM
MÌNH CÓ SƯU TẦM ĐƯỢC LISP VẼ POLYLINE KÈM KÍCH THƯỚC NHƯNG LẠI KO BẮT ĐIỂM ĐƯỢC VUÔNG GÓC
MONG MỌI NGƯỜI GIÚP MÌNH VIẾT THÊM CHẾ ĐỘ BẮT ĐIỂM, VÌ MÌNH LÀM BÊN CẤP THOÁT NƯỚC NÊN CÁI NÀY MÌNH THẤY THẬT SỰ RẤT HAY
CẢM ƠN MỌI NGƯỜI
http://www.cadviet.c..._kich_thuoc.lsp
(defun c:PLKT ( )
(command "undo" "be")
  (if (null dolora)(setq dolora "4"))
(Setq temp T)
(While temp
(setq a (strcat "\nKhoang cach dim hien hanh la (" dolora ") /<Diem dau tien>: "))
(Initget "k K")
(setq str (getpoint a))
(Cond
  ((= str "k") (setq dolora (getstring ("\nKhoang cach dim voi line <" dolora "> :"))))
  ((= str "K") (setq dolora (getstring ("\nKhoang cach dim voi line <" dolora "> :"))))
   (Progn
  (Setq a str)
   (setq temp nil)
(setq b (getpoint "\nChon diem tiep theo: "))
(setq doclora (atof dolora))
(setq gocxeo(angle a B))
(setq daiab (distance a B))
(setq c (polar a gocxeo (/ daiab 2)))
(setq d (polar c (+ gocxeo (/ pi 2)) doclora))
(command ".pline" a b "")
(setq plhoinay (entlast))
(command "DIMALIGNED" a b d)
((> gocxeo (/ pi 2)) (command ".rotate" "last" "" c 180))
(setq a B)
(setvar "osmode" luubatdiem)
(While (setq b (getpoint "\nChon diem tiep theo: <Enter de ket thuc> "))
(command "pedit" "m" "L" plhoinay "" "j" "0" "")
(setq a B)
(command "undo" "end")
(Princ)
Bài viết đã được chỉnh sửa nội dung bởi lenhatminh078: 30 July 2016 - 04:09 PM
#2 vanngeonhuxua
vanngeonhuxua
  • 66 Bài viết
Đã gửi 01 August 2016 - 04:41 PM
Thử xem đúng ý bạn không.
http://www.cadviet.c...ich_thuoc_2.lsp
