  • Thông báo
    • Nguyen Hoanh
snowman.hms
Generate Non-Overlapping Polygons From A Set Of [Lwpoly]Lines
Doan Van Ha    2.676
Hồi trước có đọc thuật toán về thứ này nhưng chưa đụng vào công việc nên chưa nghiên cứu.
Gởi bạn xem liệu có tốt hơn không nhé
http://www.cadviet.com/upfiles/7/67029_12epcgpolygondetection.pdf?
snowman.hms    30
i've Fixed the bugs.
new result be:
Command: tt
Select objects:
 Time to Get Edges : 16.00 ms.
 Time to calculate edges : 6599 ms
 Times to process edges : 7285.0000 ms
Number of vertex: 22772.
Number of Edges : 45006.
 Times to calculate polygons : 20390.0000 ms
 Times to Create polygons : 9578.0000 ms
 Total time is : 46754.0000 ms
Total: 22235 polygons found./
Chỉnh sửa theo snowman.hms
snowman.hms    30
(defun _getedges (lst / e enx l typ 3d->2d dxf t0)
(defun 3d->2d (3dpt) (list (car 3dpt) (cadr 3dpt)))
(defun dxf (i el) (cdr (assoc i el)))
(setq t0 (getvar "MilliSecs"))
(foreach e lst
(setq enx (entget e))
(cond ((= (setq typ (dxf 0 enx)) "LINE")
(setq l (cons (list (list (3d->2d (dxf 10 enx)) (3d->2d (dxf 11 enx)))) l))
((= typ "LWPOLYLINE") (setq l (cons (_Lw2Params enx) l)))
(princ (strcat "\n\tTime to Get Edges : " (rtos (- (getvar "MilliSecs") t0) 2 2) " ms."))
(apply (function append) l)
(defun _Lw2Params (el / caaddddr cdaddddr rtn cls)
(defun caaddddr (l) (caar (cddddr l)))
(defun cdaddddr (l) (cdar (cddddr l)))
(if (= 1 (cdr (assoc 70 el)))
(setq cls t)
(setq el (member (assoc 10 el) el))
(while (= 10 (caaddddr el))
(setq rtn (cons (list (cdar el) (cdaddddr el)) rtn)
el (cddddr el)
(if cls
(setq rtn (cons (list (cdar el) (car (last rtn))) rtn))
(reverse rtn)
(defun _sortxy (l)
(vl-sort l
(function (lambda (a b)
(if (equal (car a) (car b) 1e-3)
(<= (cadr a) (cadr b))
(< (car a) (car b))
(defun LM:Unique ( l / x r )
(while l
(setq x (car l)
l (vl-remove x (cdr l))
r (cons x r)
(reverse r)
(defun ff1 (l fuz / e e1 l1 l2 t0 p a)
a (/ 1 fuz)
(foreach e l (setq l1 (cons (_sortxy e) l1)))
(setq l (vl-sort l1 (function (lambda (a b) (<= (caar a) (caar b)))))
l1 nil
(while (setq e (car l))
(setq l (cdr l))
(while (and (setq e1 (car l)) (>= (car (last e)) (caar e1)))
(setq l (cdr l))
(if (setq p (inters (car e) (last e) (car e1) (last e1)))
(setq e (vl-list* (car e) p (cdr e))
e1 (vl-list* (car e1) p (cdr e1))
(setq l1 (cons e1 l1))
(if l1
(progn (foreach a l1 (setq l (cons a l)))
(setq l2 (cons (_UniqueFuzz (_sortxy e) fuz) l2)
l1 nil
(setq l2 (cons (_UniqueFuzz (_sortxy e) fuz) l2))
(setq l2 (apply (function append) (mapcar (function _grouppair) l2))
l2 (vl-sort l2 (function (lambda (a b) (<= (caar a) (caar b)))))
l1 nil
(setq l2 (mapcar (function
(lambda (x)
(mapcar (function (lambda (p) (list (/ (fix (* (car p) a)) a) (/ (fix (* (cadr p) a)) a)))) x)
l2
(setq l2 (_UniqueFuzz l2 fuz))
(princ "\n\tTime to calculate edges : ")
(princ (- (getvar "MilliSecs") t0))
(princ " ms\n")
l2
(defun _grouppair (l / r)
(if (cdr l)
(cons (list (car l) (cadr l)) (_grouppair (cdr l)))
(defun _UniqueFuzz (l f / x r)
;; l - list of "sorted" edges
(while (setq x (car l))
(setq l (cdr l))
(while (and l (equal x (car l) fuz)) (setq l (cdr l)))
(cond ((equal (car x) (cadr x) fuz))
((setq r (cons x r)))
(reverse r)
(defun sort_adj-ccw (p l lp / ang<2pi pi/2)
(defun ang<2pi (a) (rem (+ pi pi a) (+ pi pi)))
(setq p (nth p lp)
l (mapcar '(lambda (x) (cons x (nth x lp))) l)
pi/2 (/ pi 2.)
(mapcar 'car
(vl-sort l
(function
(lambda (x y) (< (ang<2pi (+ pi/2 (angle p (cdr x)))) (ang<2pi (+ pi/2 (angle p (cdr y))))))
(defun safearray-get (ar i) (read (vlax-safearray-get-element ar i)))
(defun safearray-put (ar i v) (vlax-safearray-put-element ar i (vl-prin1-to-string v)))
(defun get-neighbors (p GB) (safearray-get GB p))
(defun remove-neighbor (p n GB) (safearray-put GB p (vl-remove n (safearray-get GB p))))
(defun remove-chain (l GB / a b)
(if (setq a (car l))
(progn (foreach b (get-neighbors a GB)
(remove-neighbor a b GB)
(remove-neighbor b a GB)
(if (not (cadr (vl-remove a (get-neighbors b GB))))
(remove-chain (cons b (cdr l)) GB)
(remove-chain (cdr l) GB)
(defun nth- (a l)
(if (= a (car l))
(last l)
(nth (1- (vl-position a l)) l)
(defun f1 (a GB / a1 c c1 l1 l2 CC)
(if (and (setq l1 (get-neighbors a GB)) (cadr l1))
(progn (setq a1 a
l2 l1
(while (cadr l1)
(setq b (car l1)
a a1
c1 (list b a)
l1 (cdr l1)
(while (and (setq c (get-neighbors b GB)) (setq c (nth- a c)) (/= c (car l1)) (not (vl-position c c1)))
(setq c1 (cons c c1)
a b
b c
(if (and (>= (length c1) 2) (= (car l1) c))
(setq c1 (cons (car l1) c1)
cc (cons c1 cc)
(remove-neighbor x a1 GB) ;(remove-neighbor a1 x GB)
l2
cc
(defun f2 (le / lp lpi l1 l2 l3 l4 p t0)
(setq le (vl-sort le
(function (lambda (x y)
(if (equal (caar x) (caar y) 1e-3)
(<= (cadar x) (cadar y))
(< (caar x) (caar y))
lp (apply (function append) le)
lp (vl-sort lp
(if (= (car x) (car y))
(<= (cadr x) (cadr y))
(< (car x) (car y))
l1 nil
(while (setq p (car lp))
(if (equal p (car l1) 1e-3)
(setq lp (cdr lp))
(setq l1 (cons p l1)
lp (cdr lp)
(setq lp (reverse l1)
lpi (vl-sort-i lp
(if (= (car x) (car y) )
(< (car x) (car y))
l4 lp
l1 (mapcar (function car) le)
l2 (mapcar (function cadr) le)
l1 (f3 l1 lp)
l2 (f3 l2 lp)
le (mapcar (function list) l1 l2)
(princ (strcat "\n\tTime to process edges : "
(rtos (- (getvar "MilliSecs") t0))
" ms\n"
(list lp lpi le)
(defun f3 (l1 l2 / p i j l3 li)
(setq li (vl-sort-i l1
(< (car x) (car y))
l1 (vl-sort l1
(< (car x) (car y))
i 0
l3 nil
(while (setq j 0
p (car l1)
(while (and (equal (car p) (caar l1) 1e-3)
(equal (cadr p) (cadar l1) 1e-3)
(setq j (1+ j)
l1 (cdr l1)
(while (if (equal (car p) (caar l2) 1e-2)
(not (equal (cadr p) (cadar l2) 1e-2))
t
(setq i (1+ i)
l2 (cdr l2)
(repeat j (setq l3 (cons i l3)))
(mapcar (function cdr)
(vl-sort (mapcar (function cons) li (reverse l3))
(function (lambda (a b) (<= (car a) (car b))))
(defun _Lwpoly (lr lst cl)
(entmakex (apply 'append
(list (list '(0 . "LWPOLYLINE")
(cons 100 "AcDbEntity")
(cons 8 lr)
(cons 62 cl)
(cons 100 "AcDbPolyline")
(cons 90 (length lst))
(cons 38 (caddr (trans '(0 0 0) 1 (trans '(0. 0. 1.) 1 0))))
(cons 70 1)
(mapcar '(lambda (x) (list 10 (car x) (cadr x))) lst)
(list (cons 210 (trans '(0. 0. 1.) 1 0)))
(defun c:tt (/ l lp lpi le c cc t0 t1 t2 n GB GD GV i n tm)
(progn (repeat 3 (gc))
L (F2
(ff1 (_getedges (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex (ssget))))) 1e-3)
t1 (getvar "MilliSecs")
lp (car l)
lpi (cadr l)
le (caddr l)
cc nil
c nil
(princ (strcat "\nNumber of vertex: " (itoa (length lp)) "."))
(princ (strcat "\nNumber of Edges : " (itoa (length le)) "."))
(setq n (length lpi)
GB (vlax-make-safearray vlax-vbstring (cons 0 (1- n)))
(mapcar (function (lambda (x y)
(safearray-put GB x (cons y (safearray-get GB x)))
(safearray-put GB y (cons x (safearray-get GB y)))
(setq lb (mapcar (function read) (vlax-safearray->list GB))
i -1
tm nil
(repeat n (setq i (1+ i)) (setq tm (cons (sort_adj-ccw i (nth i lb) lp) tm)))
(setq lb (reverse tm)
tm nil
i -1
(mapcar (function (lambda (x) (safearray-put GB (setq i (1+ i)) x))) lb)
(if (setq i -1
tm (vl-remove nil
(if (= (length x) 1)
i
lb
(remove-chain tm GB)
(foreach p lpi (setq c (f1 p GB)) (setq cc (cons c cc)))
(princ (strcat "\n\tTime to calculate polygons : " (rtos (- (setq t2 (getvar "MilliSecs")) t1)) " ms\n"))
(if cc
(progn (setq cc (vl-remove nil (apply 'append cc)))
(mapcar (function (lambda (c) (_Lwpoly "tmpp" (mapcar '(lambda (x) (nth x lp)) c) 44))) cc)
(princ (strcat "\n\tTime to Create polygons : " (rtos (- (getvar "MilliSecs") t2)) " ms\n"))
(princ (strcat "\n\tTotal time is : " (rtos (- (getvar "MilliSecs") t0)) " ms\n"))
(princ (strcat "\nTotal: " (itoa (length cc)) " polygons found./"))
(princ "\nThere is no Cycle found!")
