* - - - - 1 Bình chọn
Bộ cài AutoCAD 2011 full 32&64 bit
25 replies to this topic
#1 kienxdhp
kienxdhp
  • 61 Bài viết
Điểm đánh giá: 29 (tàm tạm)
Đã gửi 22 April 2010 - 03:31 PM
AUTODESK AUTOCAD 2011 MULTI-LANGUAGE WIN32 & WIN64
Win 32bit & Win 64bit | Image type: ISO | 2.91 GB for Win32 | 3.06 GB for Win64
Languages included: English, French, Spanish, Brazilian-Portuguese
Autodesk® AutoCAD is a CAD (Computer Aided Design or Computer Aided Drafting) software application for 2D and 3D design and drafting, developed and sold by Autodesk, Inc. Initially released in late 1982, Autodesk® AutoCAD was one of the first CAD programs to run on personal computers, and notably the IBM PC. Most CAD software at the time ran on graphics terminals connected to mainframe computers or mini-computers.
Design and shape the world around you with the powerful, flexible features found in AutoCAD® software, one of the world’s leading 2D and 3D design applications. With robust 3D tools that can create almost any shape imaginable, AutoCAD helps you intuitively explore design ideas. It offers innovations that can increase design and documentation efficiency, and enables you to more securely, accurately, a nd seamlessly share those designs with colleagues. Powerful programming tools and thousands of available add-ons provide the ultimate in flexibility, helping you customize AutoCAD software for your specific needs. With these capabilities and more, AutoCAD delivers the power and flexibility needed to take documentation and design further.
AUTODESK.AUTOCAD.V2011.MULTI.WIN32-ISO
@mediafire.com
Autodesk Autocad 2011 (x32 x64)
@HotFile.com:
Part 1 | Part 2 | Part 3 | Part 4 | Part 5 | Part 6 | Part 7
AUTODESK.AUTOCAD.V2011.MULTI.WIN64-ISO
@HotFile.com:
Password: http://avaxhome.ws/blogs/avaxklan
  • 10
#2 nhatha
nhatha
  • 85 Bài viết
Điểm đánh giá: 33 (tàm tạm)
Đã gửi 25 April 2010 - 04:38 PM
Bản này so với bản 2010 khác nhau chổ nào vậy bác nhỉ ...:undecided::blink:
790312
    biết lệnh fillet
  • 204 Bài viết
Đã gửi 25 April 2010 - 05:28 PM
Bản này dùng lệnh hatch rấtt chậm,và sẽ không hiện bảng hatch lên.
#4 kienxdhp
kienxdhp
  • 61 Bài viết
Đã gửi 25 April 2010 - 05:53 PM
Cad 2011 có phần preview hatch, load lệnh này chậm hơn, không hiển thị hộp thoại của lệnh này, các tùy chọn nó hiện thị luôn trên dải ribbon. Còn nếu muốn hiển thị hộp thoại khi dùng lệnh này bạn phải chuyển về giao diện kiểu cổ điển, không dùng ribbon nữa.
#5 vaonghe
vaonghe
  • 68 Bài viết
Điểm đánh giá: 74 (tàm tạm)
Đã gửi 25 April 2010 - 05:59 PM
@HotFile.com:
@HotFile.com:
Dùng gì mà lắm phiên bản thế bạn, cứ cài bản 2008 hoặc 2009 mà dùng cho lành. Cad là phần mềm phục vụ đa ngành nên mình có bao h dùng hết tính năng của nó đâu. Còn ai muốn cái mới mẻ thì cứ zô Down thôi.
(Nếu có muốn anh em dơn thì bạn nhớ up lên mediafỉe cho nhanh nhé, up lên mấy trang này ấm ức lắm.)
#6 tranlaogia
tranlaogia
    biết lệnh scale
  • 142 Bài viết
Điểm đánh giá: 16 (tàm tạm)
Đã gửi 29 April 2010 - 08:47 AM
@HotFile.com:
@HotFile.com:
cai nay cua bac load phai dang ki. bac co the up len www.mediafire.com/ duoc ko?
#7 kienxdhp
kienxdhp
  • 61 Bài viết
Đã gửi 29 April 2010 - 01:01 PM
Cái hotfile cho download miễn phí, 15 phút được 1 lần download, không cần phải đăng ký, cứ chờ 15 phút được bấm 1 lần, hơn 1h là down xong.
#8 tranlaogia
tranlaogia
    biết lệnh scale
  • 142 Bài viết
Đã gửi 05 May 2010 - 04:15 PM
chào các bác. sao mà cái bản này mình up về rồi mà giải nén toàn bị lỗi. bác có bản khác không, up lai cho anh em thử dùng với.cám ơn nhiều nhé
#9 kienxdhp
kienxdhp
  • 61 Bài viết
Đã gửi 05 May 2010 - 04:57 PM
Bạn có thể vào http://usa.autodesk....amp;id=13779351 khai báo 1 vài thông tin download bản demo, tốc độ cho down trang này rất nhanh, sau đó thuốc thang xong là ok.
#10 minhhung29
minhhung29
  • 29 Bài viết
Đã gửi 05 May 2010 - 11:20 PM
tớ khai báo tá lả . xong rùi cho down,nhưng down chẳng được gì cả. Cắm máy cả đêm mà như không , chán quá không thèm down nữa luôn.
pác có thể úp file của pác cho anh em được ko, trên mạng tùm lum, nhiều file không rõ ràng, dung lượng không thống nhất. Lên trang chủ lại ko down được, bùn ! Thanks pác đã chia sẻ !
#11 tranlaogia
tranlaogia
    biết lệnh scale
  • 142 Bài viết
Đã gửi 06 May 2010 - 07:46 AM
Đúng rồi đó. mình download trên mạng bản này đã là bản thứ 3 rồi mà về giải nén toàn bị nỗi, kiểu này chán quá chẳng muốn down nữa bà con à.
có bác nào có bản chuẩn up lên mạng để anh em coi thử đươc kô nhỉ.
#12 kienxdhp
kienxdhp
  • 61 Bài viết
Đã gửi 06 May 2010 - 08:41 AM
Tớ kiếm được links mediafire Up lên cho anh em (đã up bên trên). Cái này em chưa test em lụm trên internet thôi, em nói trước không lại oánh em :cheers: (bản của em dùng là bản hotfile, chạy rầm rầm). :cheers:
#13 tranlaogia
tranlaogia
    biết lệnh scale
  • 142 Bài viết
Đã gửi 06 May 2010 - 08:59 AM
bộ cài này mình đã tải về rồi nhưng giải nén bị lỗi. cái bản của bạn tải trên "hotfile, chạy rầm rầm" là bản 32 hay 64 đấy. mình down bản 64 về kô giải nén được
:cry:
#14 tranlaogia
tranlaogia
    biết lệnh scale
  • 142 Bài viết
Đã gửi 07 May 2010 - 03:51 PM
sao mà của mình khi giải nén xong file giải nén không phải là file set up bác có thể chỉ giùm mình kô?
#15 amino
amino
  • 19 Bài viết
Đã gửi 07 May 2010 - 09:00 PM
Dùng quen office 07 nên dùng các bản 09 hay 10 đều thấy nhanh hơn, giờ ko mún dùng mấy bản từ 08 trở về trước nữa :cry: . Máy e ram có 2G nên xài bản 10 thui, vừa đủ yêu cầu nên lần đầu khởi động cũng hơi chậm, còn sau khi khởi động đc rùi thì khởi động lại nhanh như gió :cheers:). Khi nào kím thêm Ram thì sẽ đầu tư lên phát này :cheers:)
Đây là bản BETA hay là bản hoàn chỉnh rùi bác?
#16 Van Hai
Van Hai
Đã gửi 26 July 2010 - 10:16 AM
*** có thể dùng để thay thế hoặc dùng song song với AutoCAD.
*** tương thích với AutoCAD. Dung lượng tải nhẹ.
:D Hãy trải nghiệm vẽ sáng tạo với ***:
http://www.staricad....NG_SP100611.exe
:cheers: Những tính năng đặc biệt của *** 2010 có thể xem trên cadviet:
http://www.cadviet.c...showtopic=13042
#17 cupypinky
cupypinky
Đã gửi 10 August 2010 - 03:00 PM
Cho mình hỏi! Mình down 15 bản pack của cad10 rồi, giải nén được rồi, vào chạy settup thì khi install lên chạy xong settup instilling =>product vào rồi accep như ai! nhưng khi nó chạy thì cứ đứng im ở net ...! Không chạy xuống dirext 9.0runtime hay autocad 2010 mà cứ đứng im tại chỗ! Các Pro chỉ giùm mình với!
#18 phongvanbt
phongvanbt
Đã gửi 20 September 2010 - 03:07 PM
Mình down về giải nén và cài đặt bình thường mà. Thanks chủ topic.
#19 nguyenthanhcao
nguyenthanhcao
  • 69 Bài viết
Điểm đánh giá: 10 (tàm tạm)
Đã gửi 24 September 2010 - 07:10 AM
@mediafire.com
@HotFile.com:
@HotFile.com:
bạn ơi xem lại giúp mình file 6(của bản 32 ấy) với.
hình file bị lỗi. mình tải về được nhưng không định dạng wỉnarr như các file khác.
bạn up lại file 6 nhé. thanks
#20 linhlinh
linhlinh
  • 19 Bài viết
Đã gửi 27 September 2010 - 08:05 AM
@mediafire.com
@HotFile.com:
@HotFile.com:
Mình đã down về nhưng không biết pass giải file nén. Bạn có thể chỉ cho mình được không
