Revit Extensions for Revit Structure 2009 2010
#1 magicstone
magicstone
Đã gửi 02 June 2010 - 11:38 PM
Đây là địa chỉ download
Code:
http://rapidshare.co...2/Ext.part1.rar
http://rapidshare.co...8/Ext.part2.rar
http://rapidshare.co...6/Ext.part3.rar
http://rapidshare.co...7/Ext.part4.rar
http://rapidshare.co...7/Ext.part5.rar
http://rapidshare.co...1/Ext.part6.rar
Các bạn vào trang này http://www.extensions4revit.com/n/e4r để coi chi tiết nhé!
Link rapid khó down với một số bạn không có premium. Nếu ai không có tài khoản thì vào trang leech sau nhờ người leech hộ
http://now4ever.vn/
hoặc
http://10giay.com/rapid/
The Revit Extensions for Revit Structure 2010 delivers a full range of benefits to enhance and leverage Autodesk® Revit® Structure 2010. Users of these extensions will benefit from their ease of use, enabling them to be more productive and agile while working on projects and responding to customer requests.
Enhancements in Revit Extensions for Revit Structure 2010 include:
Robot Structural Analysis
Composite Design, Load Takedown, Integration with Robot Structural Analysis, Reinforcement Design
Simulation Beams, Conceptual Form Simulation, Frames, Trusses, Slabs
AutoCAD Structural Detailing
Integration with Steel Module, Reinforcement Drawings, Integration with Formwork Drawings Module
Steel Connections (Knots)
Beam to column - end-plate, Column base
Import / Export (Import / Export)
CIS / 2 Export, CIS / 2 Import
Reinforcement (Reinforcement)
Automatic Reinforcement Generation, Parapets, Piles, Retaining Walls, Slab Corners, Wall Corners, Walls, Beams, Columns, Spread Footings, Continuous Footings, Slab Openings, Pile Caps
Modeling (Modeling)
Bridge, Excel Based Model Generation, Grids Generator
Miscellaneous (Misc)
Content Generator, Text Generator, Elements Positioning, Freeze Drawings, Compare Models
Centered on the structural analysis, modeling, reinforcement of concrete, interoperability, and documentation design, Extensions for Revit Structure 2010 Revit, an extensive range of tools, users can start to take advantage of today!
Nhà: http://revitviet.vn <----- revit và lập trình trong revit
Lang thang: http://magic.revitviet.vn <----- Hầm bà lằng nhằng
#2 nnkeng47
nnkeng47
Đã gửi 15 June 2010 - 09:13 AM
Bản Extensions này có vẻ chưa phải đầy đủ với revit 2010 các bác ạ, Một số cấu kiện như dầm liên tục (multi span beams) extensions này chưa được hỗ trợ để tự động bỗ trí cốt thép.
Bác nào có bàn full hoặc có chỉ dần để đặt thép cho những cấu kiện này thì chỉ em với ạ.
#3 minhvan21287
minhvan21287
  • 64 Bài viết
Đã gửi 12 July 2010 - 04:28 PM
bác nào có bản đầy đủ của 4 tính năng bên ngoài của revit structure 2009 thì poss lên cho anh em đi
