sửa lỗi lisp
#1 nguyennamxm
nguyennamxm
  • 7 Bài viết
Đã gửi 14 July 2010 - 09:54 AM
mình có cái lisp như sau,bạn nào giúp mình nhé.
(defun tolr_err(MSG)
(setq *error* OLDERR)
(if(not TOLRERR)
printc(strcat"\nDDIMTOLR error:"MSG))
printc( TOLRERR)
(if OLDTOL (setvar"DIMTOL" OLDTOL))
(if OLDLIM (setvar"DIMLIM" OLDLIM))
(if OLDTIX (setvar"DIMTIX" OLDTIX))
(if OLDHIGH (setvar"HIGHTLIGHT" OLDHIGH))
(if OLDCMDE (setvar"CMDECHO" OLDCMDE))
(defun tolruser()
(setq I 1)
(white(=I 1)
(setq ENTPICK(car(entsel"\n選択すんぽう:")))
(while(=ENTPICK nil)
(prompt"何も、選んだもう一度やり直してください!)
(setq ENTPICK(car(entsel"\n選択すんぽう: )
(setq ETTYPE(cdr(assoc 0(entget entpick))))
(if(=ETTYPE"すんぽう")
(setq I 2)
(prompt"選択は、ディメンションではなかった!)
(defun tolrset()
(if(=OLDTP nil)
(setq OLDTP 0)
(if(=OLDTM nil)
(setq OLDTM 0)
(setq NEWTM OLDTM)
(setq NEWTP OLDTP)
(if (and(/=OLDTOL 1)(/=OLDLIM 1)
(setq OLDNONE 1)
(setq TTOLR 1)
(setq OLDNONE nil)
(if(=OLDTOL 1)
(setq TTOLR 2)
(if(=OLDLIM 1)
(setq TTOLR 3)
(if(=OLDTIX 1)
(setq OLDTIXYES 1)
(setq OLDTIXNO 1)
(setq TTIX 1)
(setq OLDTIXYES nil)
(setq OLDTIXNO 1)
(setq TTIX 2)
(defun tolr_dialog()
(setq DCLYES nil)
(setq DCL_ID(Load_dialog"DDIMTOLR.DCL"))
(if(not(new_dialog"dim_tolr"DCL_ID))(exit))
(if(=OLDNONE 1)
(set_tile"tolr_none" "1")
(mode_tile"tolr_tp" "1")
(mode_tile"tolr_tm" "1")
(if(=OLTOL 1)
(set_tile"tolr_tol" "1")
(set_tile"tolr_tp" (strcat(rtos OLDTP)))
(set_tile"tolr_tm" (strcat(rtos OLDTM)))
(if(=OLDTIXYES 1)
(set_tile"tix_yes" "1")
(if(=OLDTIXNO 1)
(set_tile"tix_no" "1")
(action_tile"tolr_none"
(strcat"(progn(mode_tile\"tolr_tp\"1)"
"(mode_tile\"tolr_tm\"1)"
(setq TTOLR 1))"
(action_tile"tolr_tol"
(strcat"(progn(mode_tile\"tolr_tp\"0)"
"(mode_tile\"tolr_tm\"0)"
(setq TTOLR 2))"
(action_tile"tolr_lim"
(setq TTOLR 3))"
(action_tile"tix_yes" "(setq TTIX 1)")
(action_tile"tix_no" "(setq TTIX 2)")
(action_tile"accept"
(strcat"(progn(setq NEWTP(atof(get_tile\"tolr_tp\")))"
"(setq NEWTM(atof(get_tile\"tolr_tm\")))"
"(done_dialog 1))"
(if(equal (start_dialog) 1)
(setq DCLYES 1)
(defun tolwork()
(if(=TTOLR 1)
(setvar "DIMTOL" 0)
(setvar "DIMLIM" 0)
(if(=TTOLR 2)
(setvar "DIMTOL" 1)
(setvar "DIMLIM" 0)
(if(=TTOLR 3)
(setvar "DIMTOL" 0)
(setvar "DIMLIM" 1)
(setvar "DIMTP" NEWTP)
(setvar "DIMTM" NEWTM)
(if(=TTIX 1)
(setvar "DIMTIX" 1)
(setvar "DIMTIX" 0)
(prompt"loading.......")
(defun c:DDIMTOLR()
(setq OLDERR *error*
*error* TOLR_ERR
OLDTOL nil
OLDLIM nil
OLDTIX nil
OLDHIGH nil
OLDCMDE nil
TOLRERR nil
(toluser)
(setq OLDHIGH (getvar"HIGHTLIGHT"))
OLDCMDE (getvar"CMDECHO")
OLDTP (getvar"dimtp")
OLDTM (getvar"dimtm")
OLDLIM (getvar"dimlim")
OLDTOL (getvar"dimtol")
OLDTIX (getvar"dimtix")
(tolset)
(tolr_dialog)
(if(=DCLYES 1)
(setvar "HIGHTLIGHT" 0)
(setvar "CMDECHO" 0)
(tolrwork)
(setvar "HIGHTLIGHT" OLDHIGH)
(setvar "CMDECHO" OLDCMDE)
(setvar "DIMTOL" OLDTOL)
(setvar "DIMLIM" OLDLIM)
(setvar "DIMTIX" OLDTIX)
(setq *error* OLDERR )
(prompt"done!")
(prompt"\nタイプ DDIMTOLR 実行する.")
(princ);
#2 VUVUZELA
VUVUZELA
    biết lệnh chamfer
  • 210 Bài viết
Điểm đánh giá: 97 (tàm tạm)
Đã gửi 14 July 2010 - 10:05 AM
Cái này có j hay đâu
Chỉ là chương trình set các biến của dimension thôi
Vả lại bạn phải cần có file *.DCL để mới load_dialog được chứ
Bác post kiểu này thì potay.com
#3 nguyennamxm
nguyennamxm
  • 7 Bài viết
Đã gửi 15 July 2010 - 11:36 AM
File hộp thoại nè bạn
dim_tolr:dialog{label="許容フォーマット";
:boxed_column{
:column{
:boxed_radio_column{label="許容スタイル";
:radio_button{
label="なし";
mnemonic="e";
key="tolr_none";
:radio_button{
label="制限";
mnemonic="l";
key="tolr_lim";
:radio_button{
label="恒数";
mnemonic="v";
key="tolr_tor";
:boxed_column{
:edit_box{
label="上限値";
mnemonic="p";
key="tolr_tp";
edit_width=6;
:edit_box{
label="低い値";
mnemonic="w";
key="tolr_tm";
edit_width=6;
:boxed_row{
:text{
label="拡張子内のテキスト";
:radio_row{
label="はい";
mnemonic="y";
key="tix_yes";
:radio_row{
label="いえ";
mnemonic="n";
key="tix_no";
:text{
label=" ";
ok_cancel;
