[Đã xong] Lisp copy text số, tăng theo hàm bậc nhất !
28 replies to this topic
#21 nokia
nokia
  • 9 Bài viết
Đã gửi 22 October 2011 - 08:58 AM
Cần phải thêm dòng
(or *z1* (setq *z1* 10.0))
Vào trên dòng
(setq z1...
Tương tự với z2
;; free lisp from cadviet.com
;;; this lisp was downloaded from http://www.cadviet.com/forum/index.php?showtopic=27632&pid=175482&st=0&#entry175482
;;; this lisp was downloaded from http://www.cadviet.com/forum/index.php?showtopic=27632&pid=115904&st=0&#entry115904
(defun c:noisuy(/ p1 Z1 p2 Z2 p ptg Ztg dis ang Hz m cao oldos a)
;;;;copyright by Tue_NV. Contact : tue_nvcc@yahoo.com
(setq temperr *error*)
(setq *error* bloi)
(setq p1 (getpoint "\n Nhap diem P1 :") L '())
;(setq Z1 (getreal "\n Nhap cao do Z1 :"))
(setq z1 (getreal (strcat "\nCao do Z1 <" (rtos *z1* 2) ">: ")))
(if (not z1) (setq z1 *z1*) (setq *z1* z1))
(setq p2 (getpoint p1 "\n Nhap diem P2 :"))
; (setq Z2 (getreal "\n Nhap cao do Z2 :"))
(or *z2* (setq *z2* 10.0))
(setq z2 (getreal (strcat "\nCao do Z2 <" (rtos *z2* 2) ">: ")))
(if (not z2) (setq z2 *z2*) (setq *z2* z2))
(setq dis (distance p1 p2)
ang (angle p1 p2))
(setq Hz (- Z1 Z2) tana (abs (/ Hz dis)))
(setq m (getint "\n So phan tu nam giua A va B :") i 0) ; => em khong biet bo sung luu gia tri, v&#236; l&#224; getint ?
(or cao (setq cao 2)) ; 10 = Khoang cach mac dinh
(setq cao (cond ((getdist (strcat "\n chieu cao chu: <" (vl-princ-to-string cao) " > :")))(cao)))
; (setq cao (getdist "\n Nhap chieu cao chu :")) ;
(Setq oldos (getvar "OSMODE"))
(SETVAR "OSMODE" 0)
(Repeat (+ m 2)
(setq p (polar p1 ang (* i (/ dis (1+ m)))))
(setq a (distance p p1))
(if (< Z1 Z2)
(if (equal (+ (distance p1 p) dis) (distance p p2) 0.000001)
(progn (setq Z (+ Z1 (* tana (- a) )))
(setq L (append L (list (in (rtos Z 2 3) p cao (angle p1 p2)) )))
(progn (setq Z (+ Z1 (* tana (+ a) )))
(if (> Z1 Z2)
(if (equal (+ (distance p2 p) dis) (distance p p1) 0.000001)
(progn (setq Z (+ Z2 (* tana (- a) )))
(progn (setq Z (+ Z2 (* tana (+ a) )))
(command "point" p)
);while
(COMMAND "LINE" P1 P2 "")
(if (> (cadr p1) (cadr p2))
(progn (mapcar '(lambda(x y)
(vla-put-textstring
(vla-get-textstring (vlax-ename->vla-object x)) y)
) L (reverse L) )))
(SETVAR "OSMODE" oldos)
(setq *error* temperr)
(defun *error* (msg)
(princ "error: ")
(princ msg)
(defun bloi(errmsg)
(command "snap" "R" '(0 0 0) 0)
(defun in(txt p cao ang)
(while (> ang (/ pi 2))
(setq ang (- ang pi))
(entmakex (list(cons 0 "TEXT") (cons 1 txt) (cons 10 p) (cons 11 p) (cons 40 cao) (cons 50 ang)
(cons 72 1) (cons 73 1)
hihi. Được 80% rùi ạ. Còn cái lưu giá trị số phần tử nằm giữa AB thì e thua rùi. vì nó là getint ? help me !
#22 Doan Van Ha
  • 5485 Bài viết
Đã gửi 22 October 2011 - 09:07 AM
Để bạn tự làm cho mau lên tay. Ví dụ là:
(rtos a 2) ==> (itoa a)
#23 ketxu
  • 5699 Bài viết
Đã gửi 22 October 2011 - 09:21 AM
@Hanam : rất buồn là ngay trong lisp bạn post đã thừa đủ thử để bạn làm việc đó, bạn copy mà không chú ý đó thôi :
Getint thì có khác gì ?
P/S : tại sao bạn vẫn tiếp tục việc tạo nick mới để hỏi ? Bạn ngại người khác biết bạn lười à ?
http://www.cadviet.c...ndpost&p=174086
#24 nokia
nokia
  • 9 Bài viết
Đã gửi 22 October 2011 - 09:32 AM
(setq m (getint (strcat "\n so phan tu " < " (itoa m) " >:"")) ) ???
#25 hhhhgggg
hhhhgggg
    biết dimedit
  • 393 Bài viết
Điểm đánh giá: 30 (tàm tạm)
Đã gửi 24 October 2011 - 03:43 AM
Còn một dòng mà e loay hoay đổi các kiểu nửa tiếng mà không được, Bác nào check lỗi giúp em với ạ !
(setq *error* bloi)
(or *z2* (setq *z2* 20.0))
ang (angle p1 p2))
(or *m* (setq *m* 20.0))
(setq m (getint (strcat "\nSo phan tu <" (rtos m 2 0) ">: "))) ;=> dong nay e chua sua duoc !
(if (not m) (setq m *m*) (setq *m* m))
;(setq m (getint (strcat "\n so phan tu " < " (itoa m) " >:"")) )
;(setq m (getint "\n So phan tu nam giua A va B "(itoa m)" : ") i 0 ) ;
(SETVAR "OSMODE" 0)
(Repeat (+ m 2)
(if (< Z1 Z2)
(if (> Z1 Z2)
(command "point" p)
);while
(vla-put-textstring
) L (reverse L) )))
(princ "error: ")
(princ msg)
(defun bloi(errmsg)
Hoàng Giang
#26 Doan Van Ha
  • 5485 Bài viết
Đã gửi 24 October 2011 - 06:41 AM
Còn một dòng mà e loay hoay đổi các kiểu nửa tiếng mà không được, Bác nào check lỗi giúp em với ạ ![CODE]
Chọn 1 tron 2 cách: hoặc Int hoặc Real:
Nếu Int:
(or *m* (setq *m* 20))
(setq m (getint (strcat "\nSo phan tu <" (itoa *m*) ">: ")))
Nếu Real:
(setq m (getreal (strcat "\nSo phan tu <" (rtos *m* 2 0) ">: ")))
Nhưng, số phần tử thì nên Int thôi.
Thân thương!
#27 hanam1210
hanam1210
  • 61 Bài viết
Đã gửi 24 October 2011 - 07:27 AM
hic. lúc trước em cũng được gợi ý ITOA đó rùi, nhưng không hiểu sao lỗi. E đổi giống bác hướng dẫn nhưng mà bị lỗi ko chạy được ? chẳng hiểu vì sao. Bác xem cho em nhé
;;; this lisp was downloaded from http://www.cadviet.com/forum/index.php?showtopic=27632&pid=175903&st=20&#entry175903
(setq *error* bloi)
ang (angle p1 p2))
(setq m (getint (strcat "\nSo phan tu <" (itoa m) ">: ")))
(SETVAR "OSMODE" 0)
(Repeat (+ m 2)
(if (< Z1 Z2)
(if (> Z1 Z2)
(command "point" p)
);while
(vla-put-textstring
) L (reverse L) )))
(princ "error: ")
(princ msg)
(defun bloi(errmsg)
hic. Mà e không hiểu sao cái GETINT mình thay bằng GETREAL không được nhỉ ? e hiểu nôm na thì getreal là tập hợp mẹ của getint mà ? hức !
#28 ketxu
  • 5699 Bài viết
Đã gửi 24 October 2011 - 08:40 AM
Thay nhưng không hiểu, thành ra bị lỗi. Thay nhưng không đọc hướng dẫn nên cũng sinh lỗi. m chưa được gán giá trị bao giờ thì bạn I toa sao được ? (Chắc bác ĐVH nhầm chỗ này)
Lỗi nhưng không thèm copy thông báo lỗi lên nên mất bao nhiêu bài vẫn chưa giải quyết xong!
Bạn đọc kỹ những đoạn tương tự trong lisp và lắp ghép máy móc cho đúng (chưa cần hiểu vội) là lisp chạy thôi
@hanam, nokia, hhhhhhgggg : Hóa ra bắt đầu từ Hhhhhhhhhhgggggggggggg :D Thâm niên Request Lisp cả mấy năm rồi đấy..Haiza
Bạn chọn 1 nick để lại đi, mình xóa những nick còn lại. Diễn đàn không có quy định về vấn đề này, tuy nhiên thep mình thấy như vậy khá là vô duyên. Thân !
#29 Doan Van Ha
  • 5485 Bài viết
Đã gửi 24 October 2011 - 08:44 AM
Bạn 4h4g+hanam1210 thân mến!
Các bạn sửa chưa đúng, chưa đủ, lại còn bỏ bớt thì làm sao lisp chạy được. Tôi sửa lại cho 2 bạn đây (chú ý mấy dòng có dấu ;!!!!!!)
(setq *error* bloi)
ang (angle p1 p2))
(setq m (getint (strcat "\nSo phan tu <" (itoa *m*) ">: "))) ;!!!!!!!!
(if (not m) (setq m *m*) (setq *m* m)) ;!!!!!!!!
(SETVAR "OSMODE" 0)
(setq i 0) ;!!!!!!!
(Repeat (+ m 2)
(if (< Z1 Z2)
(alert "OK")
(if (> Z1 Z2)
(command "point" p)
);while
(vla-put-textstring
) L (reverse L) )))
(princ "error: ")
(princ msg)
(defun bloi(errmsg)
P/S (9h12'): hoá ra "các" bạn là 1 bạn, thế là không tốt đâu nhé!
