Xin được diễn giải về Lisp chèn ký tự !!!
#1 songvotinh
songvotinh
Đã gửi 30 January 2008 - 10:01 PM
Tôi có một đoạn List như sau:
(defun C:ve (/ scalei  pto  mtxtin i orx pti)
(setq pto (getpoint "Nhap toa do "))
(setq scalei (getreal "Nhap khoang cach chu: "))
(setq mtxtin "")
(setq mtxtin (getstring "input text: "))
(setq tlen (strlen mtxtin))
(setq i 1)
(setq orx (car pto))
(while (<= i tlen )
(setq pti (polar pto 0.0 orx))
(if (= (substr mtxtin i 1) "a") (command "Insert" "a" pti "" "" ""))
(if (= (substr mtxtin i 1) "b") (command "Insert" "b" pti "" "" ""))
(if (= (substr mtxtin i 1) "c") (command "Insert" "c" pti "" "" ""))
(if (= (substr mtxtin i 1) "d") (command "Insert" "d" pti "" "" ""))
(if (= (substr mtxtin i 1) "e") (command "Insert" "e" pti "" "" ""))
(if (= (substr mtxtin i 1) "f") (command "Insert" "f" pti "" "" ""))
(if (= (substr mtxtin i 1) "g") (command "Insert" "g" pti "" "" ""))
(if (= (substr mtxtin i 1) "h") (command "Insert" "h" pti "" "" ""))
(if (= (substr mtxtin i 1) "i") (command "Insert" "i" pti "" "" "" ))
(if (= (substr mtxtin i 1) "j") (command "Insert" "j" pti "" "" ""))
(if (= (substr mtxtin i 1) "k") (command "Insert" "k" pti "" "" ""))
(if (= (substr mtxtin i 1) "l") (command "Insert" "l" pti "" "" ""))
(if (= (substr mtxtin i 1) "m") (command "Insert" "m" pti "" "" ""))
(if (= (substr mtxtin i 1) "n") (command "Insert" "n" pti "" "" ""))
(if (= (substr mtxtin i 1) "o") (command "Insert" "o" pti "" "" ""))
(if (= (substr mtxtin i 1) "p") (command "Insert" "p" pti "" "" "" ))
(if (= (substr mtxtin i 1) "q") (command "Insert" "q" pti "" "" ""))
(if (= (substr mtxtin i 1) "r") (command "Insert" "r" pti "" "" ""))
(if (= (substr mtxtin i 1) "s") (command "Insert" "s" pti "" "" ""))
(if (= (substr mtxtin i 1) "t") (command "Insert" "t" pti "" "" ""))
(if (= (substr mtxtin i 1) "u") (command "Insert" "u" pti "" "" ""))
(if (= (substr mtxtin i 1) "v") (command "Insert" "v" pti "" "" ""))
(if (= (substr mtxtin i 1) "x") (command "Insert" "x" pti "" "" "" ))
(if (= (substr mtxtin i 1) "y") (command "Insert" "y" pti "" "" ""))
(if (= (substr mtxtin i 1) "z") (command "Insert" "z" pti "" "" ""))
(if (= (substr mtxtin i 1) "w") (command "Insert" "w" pti "" "" ""))
(setq orx (+ scalei orx))
Và đi kèm với nó là File ABC
http://www.cadviet.com/upfiles/ABC.dwg
Bác Hoanh và các cao thủ có thể giúp tôi chỉnh sửa nó với... hiện nay tôi muốn sử dụng list mà ko cần đi kèm với File cad có được ko ? và tôi muốn chèn ký tự tại chính điểm chọn thì làm thế nào (hiện tại điểm chèn ký tự ko trùng với điểm chọn)
Xin các bác chỉ giáo dùm... xin cảm ơn... rất nhiều
Cadviet rất hay và ý nghĩa, chúc các bạn mạnh khoẻ...
#2 Nguyen Hoanh
  • 4145 Bài viết
Đã gửi 30 January 2008 - 10:34 PM
Xin được trả lời bạn như sau:
1. File DWG đó chứa các block để chương trình chèn vào, để chương trình này chạy được cần có file đó.
2. Bạn muốn chèn vào tại chính điểm chọn thì bạn sửa dòng mã (setq pti (polar pto 0.0 orx)) thành (setq pti pto).
#3 romeo1982
romeo1982
    biết lệnh mirror
  • 152 Bài viết
Điểm đánh giá: 19 (tàm tạm)
Đã gửi 13 February 2008 - 04:51 PM
<a href="http://www.cadviet.com/upfiles/ABC.dwg" target="_blank">http://www.cadviet.com/upfiles/ABC.dwg</a>
Cho mình hỏi là lệnh VE và bản vẽ mẫu để chèn kí tự này dùng vào việc gì và load vào cad như thế nào mới xài được
#4 duy782006
  • 2163 Bài viết
Điểm đánh giá: 1372 (rất tốt)
Đã gửi 14 February 2008 - 08:52 AM
Theo mình biết thì phải mở chính cái file này hoặc dùng lệnh insert chèn bản vẽ này vào rồi mới load cái lisp kia thì mới dùng được. Và nói chung thì nó còn rất thô sơ vì mẫu text như thế thì đã có sẳn rồi (cái này lãi cghưa có cả dấu nửa) thường thì chỉ dùng cho các text do mình tự sáng tác ra thôi vì lúc này 1 dòng text là cả lô block vậy mà.
