  • Thông báo
    • Nguyen Hoanh
be_chanh
Hiren's BootCD 9.4 (download now)
be_chanh    890
Hiren's BootCD 9.4
All in one Dos Bootable CD which has all these utilities
Partition Tools
Partition Magic Pro 8.05
Best software to partition hard drive
Acronis Disk Director Suite 9.0.554
Popular disk management functions in a single suite
Paragon Partition Manager 7.0.1274
Universal tool for partitions
Partition Commander 9.01
The safe way to partition your hard drive,with undo feature
Ranish Partition Manager 2.44
a boot manager and hard disk partitioner.
The Partition Resizer 1.3.4
move and resize your partitions in one step and more.
Smart Fdisk 2.05
a simple harddisk partition manager
SPecial Fdisk 2000.03t
SPFDISK a partition tool.
eXtended Fdisk 0.9.3
XFDISK allows easy partition creation and edition
GDisk 1.1.1
Complete replacement for the DOS FDISK utility and more.
Super Fdisk 1.0
Create, delete, format partitions drives without destroying data
Disk Clone Tools
ImageCenter 5.6 (Drive Image 2002)
Best software to clone hard drive
Norton Ghost 11.0.1
Similar to Drive Image (with usb/scsi support)
Acronis True Image 8.1.945
Create an exact disk image for complete system backup and disk cloning.
Partition Saving 3.50
A tool to backup/restore partitions. (SavePart.exe)
COPYR.DMA Build013
A Tool for making copies of hard disks with bad sectors
Antivirus Tools
F-Prot Antivirus 3.16f (1410)
Very good virus scanner (with ntfs support and easy to use menu)
McAfee Antivirus 4.4.50 (1410)
a virus scanner (with ntfs support and easy to use menu)
Recovery Tools
Active Partition Recovery 3.0
To Recover a Deleted partition.
Active Uneraser 3.0
To recover deleted files and folders on FAT and NTFS systems.
Ontrack Easy Recovery Pro 6.10
To Recover data that has been deleted/virus attack
Winternals Disk Commander 1.1
more than just a standard deleted-file recovery utility
TestDisk 6.9
Tool to check and undelete partition.
Lost & Found 1.06
a good old data recovery software.
DiyDataRecovery Diskpatch 2.1.100
An excellent data recovery software.
Prosoft Media Tools 5.0 1.1.2.64
Another excellent data recovery software with many other options.
PhotoRec 6.9
File and pictures recovery Tool.
Testing Tools
System Speed Test 4.78
it tests CPU, harddrive, ect.
PC-Check 6.5
Easy to use hardware tests
Ontrack Data Advisor 5.0
Powerful diagnostic tool for assessing the condition of your computer
The Troubleshooter 7.02
all kind of hardware testing tool
PC Doctor 2004
a benchmarking and information tool
Test Cpu/Video/Disk 5.6
a tool to test cpu, video, and disk
Test Hard Disk Drive 1.0
a tool to test Hard Disk Drive
RAM (Memory) Testing Tools
DocMemory 3.1b
RAM Test utility
GoldMemory 5.07
RAM Test utility
Memtest86+ 2.00
PC Memory Test
Hard Disk Tools
Hard Disk Diagnostic Utilities
Seagate Seatools Desktop Edition 3.02
Western Digital Data Lifeguard Tools
Western Digital Diagnostics (DLGDIAG) 5.04f
Maxtor PowerMax 4.23
Maxtor amset utility 4.0
Maxtor(or any Hdd) Low Level Formatter 1.1
Fujitsu HDD Diagnostic Tool 7.00
Fujitsu IDE Low Level Format 1.0
Samsung HDD Utility(HUTIL) 2.04
Samsung Disk Diagnose (SHDIAG) 1.28
IBM/Hitachi Drive Fitness Test 4.11
IBM/Hitachi Feature Tool 2.08
Gateway GwScan 5.12
ExcelStor's ESTest 4.20
MHDD 4.6
WDClear 1.30
Toshiba Hard Disk Diagnostic 2.00b
SeaTools for Dos 1.09
HDD Regenerator 1.51
to recover a bad hard drive
Ontrack Disk Manager 9.57
Disk Test/Format/Maintenance tool.
Norton Disk Doctor 2002
a tool to repair a damaged disk, or to diagnose your hard drive.
Norton Disk Editor 2002
a powerful disk editing, manual data recovery tool.
Hard Disk Sentinel 0.01
Hard Disk health, performance and temperature monitoring tool.
Active Kill Disk 4.1
Securely overwrites and destroys all data on physical drive.
HDAT2 4.6b
main function is testing and repair (regenerates) bad sectors for detected devices
SmartUDM 2.00
Hard Disk Drive S.M.A.R.T. Viewer.
Victoria 3.33e and 3.52rus
a freeware program for low-level HDD diagnostics
HDD Eraser 1.0
Secure erase using a special feature built into most newer hard drives
System Information Tools
Aida16 2.14
a system information tool, extracts details of all components of the PC
PCI and AGP info Tool (1410)
The PCI System information & Exploration tool.
System Analyser 5.3t
View extensive information about your hardware
Navratil Software System Information 0.59.16
High-end professional system information tool
Astra 5.34
Advanced System info Tool and Reporting Assistant
HwInfo 5.1.0
a powerful system information utility
PC-Config 9.33
Complete hardware detection of your computer
SysChk 2.46
Find out exactly what is under the hood of your PC
CPU Identification utility 1.12
Detailed information on CPU (CHKCPU.EXE)
CTIA CPU Information
another CPU information tool
MBR (Master Boot Record) Tools
MBRWork 1.07b
a utility to perform some common and uncommon MBR functions
MBR Tool 2.2.100
backup, verify, restore, edit, refresh, remove, display, re-write...
DiskMan4
all in one tool for cmos, bios, bootrecord and more
BootFix Utility
Run this utility if you get 'Invalid system disk'
MBR SAVE / RESTORE 2.1
BootSave and BootRest tools to save / restore MBR
Boot Partition 2.60
add Partition in the Windows NT/2000/XP Multi-boot loader
Partition Table Doctor 3.5
a tool to repair/modify mbr, bootsector, partition table
Smart Boot Manager 3.7.1
a multi boot manager
Bootmagic 8.0
This tool is for multi boot operating systems
MBRWizard 2.0b
Directly update and modify the MBR (Master Boot Record)
BIOS / CMOS Tools
CMOS 0.93
CMOS Save / Restore Tool
BIOS Cracker 4.8
BIOS password remover (cmospwd)
BIOS Cracker 1.4
BIOS password remover (cmospwc)
BIOS Utility 1.35.0
BIOS Informations, password, beep codes and more.
!BIOS 3.20
a powerfull utility for bios and cmos
DISKMAN4
a powerful all in one utility
UniFlash 1.40
bios flash utility
Kill CMOS
a tiny utility to wipe cmos
Award DMI Configuration Utility 2.43
DMI Configuration utility for modifying/viewing the MIDF contents.
MultiMedia Tools
Picture Viewer 1.94
Picture viewer for dos, supports more then 40 filetypes.
QuickView Pro 2.58
movie viewer for dos, supports many format including divx.
MpxPlay 1.56
a small Music Player for dos
Password Tools
Active Password Changer 3.0.420
To Reset User Password on windows NT/2000/XP/2003/Vista (FAT/NTFS)
Offline NT/2K/XP Password Changer
utility to reset windows nt/2000/xp administrator/user password.
Registry Viewer 4.2
Registry Viewer/Editor for Win9x/Me/NT/2K/XP
Registry Reanimator 1.02
check and restore structure of the damaged registry files of NT/2K/XP
NTPWD
ATAPWD 1.2
Hard Disk Password Utility
NTFS Ext2FS, Ext3FS (FileSystems) Tools
NTFS Dos Pro 5.0
To access ntfs partitions from Dos
NTFS 4 Dos 1.9
Paragon Mount Everything 3.0
To access NTFS, Ext2FS, Ext3FS partitions from dos
NTFS Dos 3.02
EditBINI 1.01
to Edit boot.ini on NTFS Partition
Dos File Managers
Volkov Commander 4.99
Dos File Manager with LongFileName/ntfs support
(Similar to Norton Commander)
Dos Command Center 5.1
Classic dos-based file manager.
File Wizard 1.35
a file manager - colored files, drag and drop copy, move, delete etc.
File Maven 3.5
an advanced Dos file manager with high speed PC-to-PC file
transfers via serial or parallel cable
FastLynx 2.0
Dos file manager with Pc to Pc file transfer capability
LapLink 5.0
the smart way to transfer files and directories between PCs.
Dos Navigator 6.4.0
Dos File Manager, Norton Commander clone but has much more features
Mini Windows 98
Can run from Ram Drive, with ntfs support,
Added 7-Zip which supports .7z .zip .cab .rar .arj .gzip,
.bzip2 .z .tar .cpio .rpm and .deb
Disk Defragmenter, Notepad / RichText Editor,
Image Viewer, .avi .mpg .divx .xvid Movie Player, etc...
Other Tools
Ghost Walker 2003.793
utility that changes the security ID (SID) for Windows NT, 2000 and XP
DosCDroast beta 2
Dos CD Burning Tools
Universal TCP/IP Network 6.2
MSDOS Network Client to connect via TCP/IP to a Microsoft based
network. The network can either be a peer-to-peer or a server based
network, it contains 91 different network card drivers
Dos Tools
USB CD-Rom Driver 1
Standard usb_cd.sys driver for cd drive
Universal USB Driver 2
Panasonic v2.20 ASPI Manager for USB mass storage
SCSI Support
SCSI Drivers for Dos
SATA Support
SATA Driver (gcdrom.sys) and JMicron JMB361 (xcdrom.sys) for Dos
1394 Firewire Support
1394 Firewire Drivers for Dos
Interlnk support at COM1
To access another computer from COM port
Interlnk support at LPT1
To access another computer from LPT port
and too many great dos tools
very good collection of dos utilities
extract.exe pkzip.exe pkunzip.exe unrar.exe rar.exe
ace.exe lha.exe gzip.exe uharcd.exe mouse.com
attrib.com deltree.exe xcopy.exe diskcopy.com imgExtrc.exe
undelete.com edit.com fdisk.exe fdisk2.exe fdisk3.exe
lf.exe delpart.exe wipe.com zap.com format.com
move.exe more.com find.exe hex.exe debug.exe
split.exe mem.exe mi.com sys.com smartdrv.exe
xmsdsk.exe killer.exe share.exe scandisk.exe scanreg.exe
guest.exe doskey.exe duse.exe biosdtct.exe setver.exe
intersvr.exe interlnk.exe loadlin.exe lfndos.exe doslfn.com
Windows Tools
SpaceMonger 1.4
keeping track of the free space on your computer
WinDirStat 1.1.2.80
a disk usage statistics viewer and cleanup tool for Windows.
Drive Temperature 1.0
Hard Disk Drive temperature meter
Disk Speed 1.0
Hard Disk Drive Speed Testing Tool
MemTest 1.0
a Memory Testing Tool
S&M Stress Test 1.9.1
cpu/hdd/memory benchmarking and information tool, including temperatures/fan speeds/voltages
PageDfrg 2.32
System file Defragmenter For NT/2k/XP
WhitSoft File Splitter 4.5a
a Small File Split-Join Tool
Ghost Image Explorer 11.0.1
to add/remove/extract files from Ghost image file
DriveImage Explorer 5.0
to add/remove/extract files from Drive image file
Drive SnapShot 1.38
creates an exact Disk Image of your system into a file while windows is running.
Active Undelete 5.5
a tool to recover deleted files
Restoration 2.5.14
GetDataBack for FAT 2.31
Data recovery software for FAT file systems
GetDataBack for NTFS 2.31
Data recovery software for NTFS file systems
Recuva 1.10.223
Restore deleted files from Hard Drive, Digital Camera Memory Card, usb mp3 player...
Partition Find and Mount 2.3
Partition Find and Mount software is designed to find lost or deleted partitions
Unstoppable Copier 3.12
Allows you to copy files from disks with problems such as bad sectors,
scratches or that just give errors when reading data.
HDD Scan 2.8
This is a Low-level HDD diagnostic tool, it scans surface find bad sectors etc.
Express Burn 4.06
CD/DVD Burner Program to create and record CDs/DVDs, also create/burn .iso and .nrg images
Data Shredder 1.0
A tool to Erase disk and files (also wipe free space) securely
Startup Control Panel 2.8
a tool to edit startup programs
NT Registry Optimizer 1.1j
Registry Optimization for Windows NT/2000/2003/XP/Vista
DefragNT 1.9
This tool presents the user with many options for disk defragmenting
JkDefrag 3.34
Free disk defragment and optimize utility for Windows 2000/2003/XP/Vista
Startup Monitor 1.02
it notifies you when any program registers itself to run at system startup
IB Process Manager 1.04
a little process manager for 9x/2k, shows dll info etc.
Process Explorer 11.04
shows you information about which handles and DLLs processes have opened or loaded
Pocket KillBox 2.0.0.978
can be used to get rid of files that stubbornly refuse to allow you to delete them
Unlocker 1.8.5
This tool can delete file/folder when you get this message - Cannot delete file:
Access is denied, The file is in use by another program etc.
HijackThis 2.0.2
a general homepage hijackers detector and remover and more
RootkitRevealer 1.7
Rootkit Revealer is an advanced patent-pending root kit detection utility.
Silent Runners Revision 55
A free script that helps detect spyware, malware and adware in the startup process
Autoruns 9.12
Displays All the entries from startup folder, Run, RunOnce, and other Registry keys,
Explorer shell extensions,toolbars, browser helper objects, Winlogon notifications,
auto-start services, Scheduled Tasks, Winsock, LSA Providers, Remove Drivers
and much more which helps to remove nasty spyware/adware and viruses.
Dial a Fix 0.60.0.24
Fix errors and problems with COM/ActiveX object errors and missing registry entries,
Automatic Updates, SSL, HTTPS, and Cryptography service (signing/verification)
issues, Reinstall internet explorer etc. comes with the policy scanner
CurrPort 1.20
displays the list of all currently opened TCP and UDP ports on your computer
Unknown Devices 1.2 (1410)
helps you find what those unknown devices in Device Manager really are
PCI 32 Sniffer 1.1 (1410)
device information tool (similar to unknown devices)
NewSID 4.10
Double Driver 1.0
Driver Backup and Restore tool
DriverBackup! 1.0.3
Another handy tool to backup drivers
CPU-Z 1.44
It gathers information on some of the main devices of your system
CWShredder 2.19
Popular CoolWebSearch Trojan Remover tool
SmitFraudFix 2.289
This removes Some of the popular Desktop Hijack malware
Winsock 2 Fix for 9x
to fix corrupted Winsock2 information by poorly written Internet programs
XP TCP/IP Repair 1.0
Repair your Windows XP Winsock and TCP/IP registry errors
CCleaner 2.04.543
Crap Cleaner is a freeware system optimization and privacy tool
EzPcFix 1.0.0.16
Helpful tool when trying to remove viruses, spyware, and malware
Content Advisor Password Remover 1.0
It Removes Content Advisor Password from Internet Explorer
WinKeyFinder 1.73
Allows you to View and Change Windows XP/2003 Product Keys, backup and restore
activation related files, backup Microsoft Office 97, 2000 SP2, XP/2003 keys etc.
ProduKey 1.20
Recovers lost the product key of your Windows/Office
Wireless Key View 1.15
Recovers all wireless network keys (WEP/WPA) stored in your computer by WZC
Monitor Tester 1.0
Allows you to test CRT/LCD/TFT screens for dead pixels and diffective screens
Shell Extensions Manager (ShellExView) 1.19
An excellent tool to View and Manage all installed Context-menu/Shell extensions
TweakUI 2.10
This PowerToy gives you access to system settings that are not exposed in the Windows Xp
Xp-AntiSpy 3.96.7
it tweaks some Windows XP functions, and disables some unneeded Windows services quickly
PC Wizard 2008 1.83
Powerful system information/benchmark utility designed especially for detection of hardware.
Spybot - Search & Destroy 1.5.2 (1410)
Application to scan for spyware, adware, hijackers and other malicious software.
SpywareBlaster 3.5.1 (1410)
Prevent the installation of spyware and other potentially unwanted software.
Ad-Aware SE Personal 1.06 (1410)
find and remove spyware, adware, dialers etc. (a must have tool)
Hiren's BootCD 9.4
For information about this bootcd please visit http://www.hiren.info
Please email feedback to: thankihiren(a)hotmail.com
link download: http://rapidshare.com/files/99137974/Hiren_s_BootCD.9.4.rar
pass: www.cadviet.com
ngayve324    270
bác Ji đã nói về Hiren's BootCD 9.4
mình xin bổ sung link download: http://www.mediafire.com/?1ztvs00u9cq (cái này mình thấy bên benhvientinhoc.com)
Các công cụ phân vùng:
* Partition Magic Pro 8.05 - phần mềm định dạng ổ cứng tốt nhất
* Acronis Disk Director Suite 9.0.554 - những tính năng quản lí đĩa phổ biến trong một công cụ riêng lẻ
* Paragon Partition Manager 7.0.1274 - công cụ phân vùng đa năng
* Partition Commander 9.01 - phân vùng ổ cứng an toàn, với tính năng undo
* Ranish Partition Manager 2.44 - trình quản lí khởi động và phân vùng
* The Partition Resizer v1.3.4 - di chuyển và định cỡ phân vùng
* Smart Fdisk 2.05 - trình quản lí phân vùng ổ cứng đơn giản
* SPecial Fdisk 2000.03t - công cụ phân vùng SPFDISK
* eXtended Fdisk 0.9.3 - XFDISK cho phép dễ dàng tạo và chỉnh sửa phân vùng
* GDisk 1.1.1 - thay thế hoàn hảo cho tiện ích DOS FDISK và hơn thế
* Super Fdisk 1.0 - Tạo, xóa, định dạng phân vùng mà không hủy dữ liệu
Các công cụ sao lưu đĩa:
* ImageCenter 5.6 (Drive Image 2002) - phần mềm tốt nhất để sao lưu ổ cứng
* Norton Ghost 11.0.1 (New) - Similar to Drive Image (with usb/scsi support)
* Acronis True Image 8.1.945 - tạo ảnh đĩa chính xác giúp sao lưu hệ thống và sao chép ổ đĩa
* Partition Saver 3.30 - công cụ sao lưu/phục hồi phân vùng
* COPYR.DMA Build013 - công cụ giúp tạo bản sao của ổ cứng bị hỏng sector
Các công cụ diệt virus :
* F-Prot Antivirus 3.16f (1602) - quét virus rất tốt (hỗ trợ ntfs và trình đơn dễ sử dụng)
* McAfee Antivirus 4.4.50 (1602) - chương trình quét virus (hỗ trợ ntfs và trình đơn dễ dùng)
Các công cụ phục hồi :
* Active Partition Recovery 3.0 - phục hồi phân vùng bị xóa
* Active Uneraser 3.0 - Khôi phục các file và thư mục trên hệ thống FAT và NTFS
* Ontrack Easy Recovery Pro 6.10 - Phục hồi dữ liệu bị xóa/ virus tấn công
* Winternals Disk Commander 1.1 - còn hơn cả một tiện ích phục hồi file bình thường
* TestDisk 6.7b - Công cụ kiểm tra và phục hồi phân vùng
* Lost & Found 1.06 - phần mềm khôi phục dữ liệu cũ
* DiyDataRecovery Diskpatch 2.1.100 - phần mềm khôi phục dữ liệu xuất sắc
* Prosoft Media Tools 5.0 v1.1.2.64 - một phần mềm xuất sắc khác với nhiều tùy chọn
* PhotoRec 6.9b - công cụ phục hồi file và ảnh
Các công cụ kiểm tra:
* System Speed Test 4.78 - kiểm tra CPU, ổ cứng v…v
* PC-Check 6.5 - công cụ kiểm tra phần cứng dễ dùng
* Ontrack Data Advisor 5.0 - công cụ chẩn đoán mạnh mẽ giúp đánh giá điều kiện hoạt động của máy tính
* The Troubleshooter 7.02 - mọi thể loại công cụ kiểm tra phần cứng
* PC Doctor 2004 - công cụ đo hiệu năng và xem thông tin
* Test Cpu/Video/Disk 5.6 - công cụ kiểm tra CPU, video, ổ đĩa v…v
* Test Hard Disk Drive 1.0 - công cụ kiểm tra ổ cứng
Các công cụ kiểm tra bộ nhớ
* DocMemory 3.1b - tiện ích kiểm tra RAM
* GoldMemory 5.07 - tiện ích kiểm tra RAM
* Memtest86+ 2.00 - kiểm tra bộ nhớ máy tính
Các công cụ ổ cứng:
* Hard Disk Diagnostic Utilities
* Seagate Seatools Desktop Edition 3.02
* Western Digital Data Lifeguard Tools
* Western Digital Diagnostics (DLGDIAG) 5.04f
* Maxtor PowerMax 4.23
* Maxtor amset utility 4.0
* Maxtor(or any Hdd) Low Level Formatter 1.1
* Fujitsu HDD Diagnostic Tool 7.00
* Fujitsu IDE Low Level Format 1.0
* Samsung HDD Utility(HUTIL) 2.04
* Samsung Disk Diagnose (SHDIAG) 1.28
* IBM/Hitachi Drive Fitness Test 4.11
* IBM/Hitachi Feature Tool 2.03
* Gateway GwScan 5.12
* ExcelStor’s ESTest 4.20
* MHDD 4.6
* WDClear 1.30
* Toshiba Hard Disk Diagnostic 2.00b
* SeaTools for Dos 1.09
* HDD Regenerator 1.51 - khôi phục ổ cứng hỏng
* Ontrack Disk Manager 9.57 - công cụ kiểm tra/ định dạng/ duy trì ổ đĩa
* Norton Disk Doctor 2002 - công cụ sửa ổ đĩa hỏng, hoặc chẩn đoán ổ đĩa
* Norton Disk Editor 2002 - công cụ chỉnh sửa ổ đĩa, phục hồi dữ liệu thủ công mạnh mẽ
* Active Kill Disk 4.1 - Xóa đè và hủy mọi dữ liệu trên ổ vật lí một cách an toàn
* HDAT2 4.6.b - tính năng chính là kiểm tra và sửa các sector bị hỏng cho thiết bị
* SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer.
* Victoria 3.33e and 3.52rus - phần mềm miễn phí giúp chẩn đoán sơ qua ổ cứng
* HDD Eraser 1.0 -Secure erase using a special feature built into most newer hard drives
Các công cụ thông tin hệ thống:
* Aida16 2.14 - công cụ thông tin hệ thống, trích ra các chi tiết về mọi thành phần của máy tính
* Công cụ hiển thị thông tin PCI và AGP (1602) - công cụ thông tin PCI
* System Analyser version 5.3t - xem nhiều thông tin phần cứng
* Navratil Software System Information 0.59.16 - công cụ thông tin hệ thống chuyên nghiệp
* Astra 5.34 - công cụ thông tin hệ thống và báo cáo nâng cao
* HwInfo 5.1.0 - tiện ích thông tin hệ thống mạnh mẽ
* PC-Config 9.33 - phát hiện phần cứng máy tính
* SysChk 2.46- chính xác tìm ra những gì ẩn dưới lớp vỏ máy tính
* CPU Identification utility v1.12 - Các thông tin CPU chi tiết
* CTIA CPU Information - một công cụ thông tin CPU khác
Các công cụ MBR (Master Boot Record) :
* MBR Work 1.07b - tiện ích với một số tính năng MBR thường thấy và hiếm gặp
* MBR Tool 2.2.100 - sao lưu, kiểm tra, phục hồi, chỉnh sửa, xóa bỏ, hiển thị, ghi lại …
* DiskMan4 - công cụ tất cả trong một cho cmos, bios, bootrecord và hơn thế
* BootFix Utility - chạy tiện ích này nếu bạn bị lỗi ‘Invalid system disk’
* MBR SAVE / RESTORE 2.1 - công cụ BootSave và BootRest giúp lưu/ phục hồi MBR
Boot Partition 2.60 - thêm phân vùng vào Windows NT/2000/XP Multi-boot loader
* Partition Table Doctor 3.5 - công cụ sửa/ tinh chỉnh mbr, bootsector, bảng phân vùng
* Smart Boot Manager 3.7.1 - trình quản lí multi boot
* Bootmagic 8.0 - công cụ dành cho các hệ điều hành multi boot
* MBRWizard 2.0b - trực tiếp cập nhật và chỉnh sửa MBR (Master Boot Record)
Các công cụ BIOS / CMOS :
* CMOS 0.93 - công cụ lưu/ phục hồi CMOS
* BIOS bẻ khóaer 4.8 - xóa mật khẩu BIOS (cmospwd)
* BIOS bẻ khóaer 1.4 - xóa mật khẩu BIOS (cmospwc)
* BIOS Utility 1.35.0 - thông tin , mật khẩu , mã beep của BIOS và hơn thế
* !BIOS 3.20 - tiện ích mạnh mẽ cho bios và cmos
* DISKMAN4 - tiện ích mạnh mẽ tất cả trong một
* UniFlash 1.40 - tiện ích bios flash
* Kill CMOS - tiện ích nhỏ giúp quét cmos
* Award DMI Configuration Utility 2.43 - tiện ích cấu hình DMI giúp chỉnh sửa/ xem nội dung MIDF
Các công cụ đa phương tiện:
* Picture Viewer 1.94 - công cụ xem ảnh dành cho dos, hỗ trợ hơn 40 loại file
* QuickView Pro 2.58 - công cụ xem phim cho dos, hỗ trợ nhiều loại file kể cả divx
* MpxPlay 1.56 - công cụ chơi nhạc nhỏ cho dos
Các công cụ mật khẩu:
* Active Password Changer 3.0.420 - reset mật khẩu người dùng windows NT/2000/XP/2003 (FAT/NTFS)
* Offline NT/2K/XP Password Changer - tiện ích xác lập lại mật khẩu người dùng/ quản trị windows nt/2000/xp
* Registry Viewer 4.2 - xem/ chỉnh sửa Registry cho Win9x/Me/NT/2K/XP
* Registry Reanimator v1.02 - kiểm tra và phục hồi cấu trúc của các file Registry hỏng của NT/2K/XP
* NTPWD - tiện ích xác lập lại mật khẩu người dùng/ quản trị windows nt/2000/xp
* ATAPWD 1.2 - tiện ích mật khẩu ổ cứng
Các công cụ NTFS Ext2FS, Ext3FS (FileSystems):
* NTFS Dos Pro 5.0 - truy cập phân vùng ntfs từ Dos
* NTFS 4 Dos 1.9 - truy cập phân vùng ntfs từ Dos
* Paragon Mount Everything 3.0 - truy cập phân vùng NTFS, Ext2FS, Ext3FS từ dos
* NTFS Dos 3.02 - truy cập phân vùng ntfs từ Dos
* EditBINI 1.01 - Chỉnh sửa boot.ini trong phân vùng NTFS
Các trình quản lí file Dos:
* Volkov Commander 4.99 - quản lí file dos hỗ trợ tên file dài và ntfs (giống Norton Commander)
* Dos Command Center 5.1 - trình quản lí file nền dos
* File Wizard 1.35 - trình quản lí file - các file có màu, sao chép, xóa, di chuyển v…v nhờ kéo và thả
* File Maven 3.5 - trình quản lí file trong dos với tính năng chuyển file tốc độ cao giữa các máy tính thông qua cáp mã hoặc parallel
* FastLynx 2.0 - quản lí và chuyển file giữa các máy tính
* LapLink 5.0 - chuyển file và thư mục giữa các máy tính
* Dos Navigator 6.4.0 - quản lí file trong dos, bản sao của Norton Commander nhưng có nhiều tính năng hơn
* Mini Windows 98 - có thể chạy từ Ram Drive, hỗ trợ ntfs, thêm công cụ 7-Zip hỗ trợ .7z .zip .cab .rar .arj .gzip, .bzip2 .z .tar .cpio .rpm and .deb, Disk Defragmenter, Notepad / RichText Editor, Image Viewer, .avi .mpg .divx .xvid Movie Player, etc…
Các công cụ khác:
* Ghost Walker 2003.793 - tiện ích thay đổi ID bảo mật(SID) cho Windows NT, 2000 and XP
* DosCDroast beta 2 - ghi đĩa từ Dos
* Universal TCP/IP Network 6.2 - MSDOS Network Client kết nối qua TCP/IP tới hệ thống mạng nền Windows. Hệ thống mạng có thể là ngang hàng hoặc nền máy chủ, nó bao gồm 85 trình điều khiển card mạng khác nhau
CÁc công cụ Dos:
* USB CD-Rom Driver 1 - trình điều khiển thông thường cho ổ cd
* Universal USB Driver 2 - Panasonic v2.20 ASPI Manager cho thiết bị lưu trữ usb
* SCSI Support - trình điều khiển SCSI cho Dos
* SATA Support - trình điều khiển SATA (gcdrom.sys) và JMicron JMB361 (xcdrom.sys) cho Dos
* 1394 Firewire Support - trình điều khiển 1394 Firewire cho Dos
* Interlnk support at COM1 truy cập máy tính khác từ cổng COM
* Interlnk support at LPT1 - truy cập máy tính khác từ cổng LPT
* Các Công Cụ kèm thêm :
Các công cụ Windows:
* SpaceMonger 1.4 - theo dõi dung lượng ổ cứng trống
* Drive Temperature 1.1.2.80 - đo nhiệt độ ổ cứng
* Disk Speed 1.0 - công cụ đo tốc độ ổ cứng
* MemTest 1.0 - công cụ kiểm tra bộ nhớ
* PageDfrg 2.32 - giải phân mảnh file hệ thống cho NT/2k/XP
* WhitSoft File Splitter 4.5a - công cụ cắt/ nối file
* Ghost Image Explorer 11.0.1 - thêm/ xóa/ trích xuất file từ file Ghost
* DriveImage Explorer 5.0 -thêm/ xóa/ trích xuất file từ file ảnh trong ổ
* Drive SnapShot 1.38 - tạo ảnh đĩa chuẩn xác của hệ thống vào một file khi windows đang chạy
* Active Undelete 5.5. - công cụ khôi phục file bị xóa
* Restoration 2.5.14 - khôi phục file bị xóa
* GetDataBack for FAT 2.31 - phần mềm khôi phục dữ liệu cho hệ thống file FAT
* GetDataBack for NTFS 2.31 - khôi phục dữ liệu cho hệ thống file NTFS
* Unstoppable Copier 3.12 - cho phép bạn sao chép file từ ổ bị các vấn đề như bad sectors, xước hay bị lỗi khi đọc dữ liệu
* Startup Control Panel 2.8 - công cụ chỉnh sửa các chương trình khởi động cùng máy
* Startup Monitor 1.02 - thông báo chương trình tự đăng kí khởi động cùng hệ thống
* IB Process Manager 1.04 - trình quản lí tiến trình nhỏ cho 9x/2k, hiển thi thông tin dll v…v
* Pocket KillBox 2.0.0.978 - được sử dụng để xóa các file không cho bạn xóa
* Unlocker 1.8.5 - có thể xóa các file/ thư mục khi bạn gặp phải thông báo - Cannot delete file: Access is denied, The file is in use by another program v…v.
* HijackThis 2.0.2 - phát hiện và xóa bỏ các hijacker trang chủ và hơn thế nữa
* RootkitRevealer 1.7 - Rootkit Revealer là tiện ích phát hiện root kit đang đợi bằng sáng chế
* Silent Runners Revision 55 - đoạn mã giúp phát hiện spyware, malware và adware trong quá trình khởi động
* Autoruns 9.12 - Hiển thị mọi thông tin nhập từ thư mục startup, Run, RunOnce, và các khóa Registry , Explorer shell extensions,thanh công cụ, các đối tượng hỗ trợ trình duyệt, thông báo Winlogon , các dịch vụ tự khởi động, các tác vụ định sẵn, Winsock, LSA Providers, loại bỏ trình điều khiển giúp bạn loại bỏ spyware/adware và virus
* Dial a Fix 0.60.0.24 - sửa lỗi và các vấn đề với lỗi COM/ActiveX , thiếu thông tin nhập registry , Automatic Updates, SSL, HTTPS, và dịch vụ Cryptography (signing/verification)v…v.
* CurrPort 1.07 - hiển thị mọi cổng TCP và UDP hiện đang mở trên máy tính
* Unknown Devices 1.2 (1602) - giúp bạn tìm ra các thiết bị không phát hiện được trong Device Manager thực ra là gì
* PCI 32 Sniffer 1.4 (1602) - công cụ thông tin thiết bị
* NewSID 4.10 - tiện ích thay đổi ID bảo mật (SID) cho Windows NT, 2000 và XP
* Double Driver 1.0 - công cụ sao lưu và phục hồi trình điều khiển
* DriverBackup! 1.0.3 - công cụ linh hoạt giúp sao lưu trình điều khiển
* CPU-Z 1.44 -tập hợp thông tin về một số thiết bị chính trên hệ thống
* CWShredder 2.19 - công cụ xóa Trojan CoolWebSearch
* Winsock 2 Fix for 9x - sửa thông tin Winsock2 nị hỏng do các chương trình Internet xấu
* XP TCP/IP Repair 1.0 - Repair your Windows XP Winsock and TCP/IP registry errors
* CCleaner 2.04.543 - phần mềm miễn phí giúp tối ưu và bảo mật hệ thống
* EzPcFix 1.0.0.16 - công cụ hữu dụng diệt viruses, spyware, và malware
* Content Advisor Password Remover 1.0 - xóa bỏ mật khẩu từ IE
* WinKeyFinder 1.0 - cho phép bạn xem và thay đổi mã sản phẩm của Xp, Windows 2003 and .NET
* Spybot - Search & Destroy 1.73 (1602) - Quét spyware, adware, hijackers và các phần mềm có hại khác
* SpywareBlaster 3.5.1 (1602) - bảo vệ cài đặt khỏi spyware và các phần mềm không mong đợi khác
* Ad-Aware SE Personal 1.06 (1602) - tìm và diệt spyware, adware, dialers v..v (một công cụ phải có)
*NT Registry Optimizer 1.1j : Chỉnh Sửa Registry Cho 98 > Vista
ngayve324    270
Các bác hiểu biết nhiều vấn đề quá, thật đáng kính phục!
hê hê MANHHUNGXDA quá lời rùi. cái này mình chỉ đọc được bên benvientinhoc.com thôi thấy bác Ji đã giưới thiệu chi tiết rồi nhưng là tiếng anh nên mình post lên đây để chia sẽ cùng anh em. Hy vọng cai này cũng bổ ích
còn đây là cách ghi thành đĩa hiren's Boot CD9.4 http://www.benhvientinhoc.com/index.php?showtopic=28977
  • Vote tăng 1
be_chanh    890
đợi tẹo, chuẩn bị up xong rồi...hí hí.
và không phải quá lời đâu, thành viên của cadviet bạn không để ý à? ai cũng thế hết đấy, có cơ hội là khen thật lực thôi, hí hí
  • Vote tăng 3
ngayve324    270
ở trên có link down rồi mà bác jikibo khỏi up cho đở tốn công sức
ngayve324    270
Đã có bản Hiren's BootCD 9.5, mời các bạn có quan tâm vào trang http://www.9down.com/Hiren-s-BootCD-9-5-23765/ để down miễn phí.
xem ra tui với duongsatdn co duyên rùi. bản 9.5 này có gì mới không?
a` hỏi thăm chút nhé. hình như bác ở DN hả, vừa rùi có vào DN xem bắn pháo hoa thích thật
duongsatdn    762
Tôi cũng chưa xài thử H9.5.
Mời bác lại vào ĐN xem pháo hoa dịp này sang năm!
Khi nào có dịp công tác ở ĐN, bác liên hệ trước với em qua CADViet cũng được. ANh em gặp nhau mời bác vài chén Hồng đào quê em!
ngayve324    270
rất cám ơn về lời mời của bác. chúc bác công tác tốt thành công và có nhiều cống hiến cho CADVIET
P/S Chén hồng đào này tui xin ghi nhận, nếu vào DN tui sẽ liên lạc trước qua cadviet
