crack cad 2011
#1 bang
bang
Đã gửi 02 March 2011 - 11:17 AM
chào diễn đàn. mình đang gặp khó khăn trong việc crack cad 2011 mình Crack nhung không được nó báo lỗi ai biết giúp mình vơí.
#2 hdg2318
hdg2318
    biết lệnh mirror
  • 158 Bài viết
Điểm đánh giá: 31 (tàm tạm)
Đã gửi 14 March 2011 - 10:27 PM
đây là file hướng dẫn nguyên bản, bạn đọc kỹ trước khi dùng nhé.
1.Install Autodesk...
2.Use as Serial 666-69696969, 667-98989898, 400-45454545 .. or anything matching this template
3.Use as Product Key 001C1
4.Finish the installation & restart Autodesk Product
5.Before clicking on Activate
You have 2 options :
- a) Disable Your network Card, pull the network cable out or block with firewall
(this is just to disable online serial check)
OR
- B) Click on Activate and it will tell you that your serial is wrong, simply click
on close , open the keygen and Click on Mem Patch (you should see successfully patched) then click on autodesk activate again.
6. Select I have an activation code from Autodesk
9.Copy the request code into the keygen and press generate
10.Now copy the activation code back to the activation screen and click Next
You have a fully registered autodesk product
NB:
1.Make sure you are running the Keygen as administrator and with UAC off on Vista or Windows7
but you have to anyway to install Adesk products.
Có 2 cách để nhìn đời:
1 là : coi như chẳng có gì là huyền diệu
2 là : coi như mọi điều đều huyền diệu
Click here
