Chỉ giúp e lệnh SSX với
#1 trungkien_hatangdothi
    biết lệnh properties
  • 251 Bài viết
Điểm đánh giá: 121 (tàm tạm)
Đã gửi 19 June 2008 - 12:37 AM
Các bác vui lòng hướng dãn chi tiết cho e về lệh SSX này với,e chưa dung bao giờ nên ko rõ lắm.
cảcm ơn các bác trước nhe!
BUILD CAREER !
(Make life go to the dog..)
#2 duongsatdn
duongsatdn
  • 1657 Bài viết
Điểm đánh giá: 761 (tốt)
Đã gửi 19 June 2008 - 08:00 AM
Đây là một lênh của phần express. Tôi mở Help của nó thì được kết quả sau:
SSX
Creates a selection set
Either type SSX at the Command prompt to create a "previous" selection set or type (SSX) in response to any Select Objects prompt.
SSX returns a selection set that is either exactly like a selected object or, if you adjust the filter list, very similar to that object.
Command: SSX
Select object/<None>: Use an object selection method to select a template object, or press ENTER for none
>>Block name/Color/Entity/Flag/LAyer/LType/Pick/Style/Thickness/Vector:
Filter Options
Block name Specifies the block name to add or remove.
Color Specifies the color number to add or remove.
Entity Specifies the object type to add or remove.
Flag Toggles the ENTITIES FOLLOW flag.
Layer Specifies the layer name to add or remove.
Ltype Specifies the linetype name to add or remove.
Pick Selects object(s) using any selection set method.
Style Selects the text style name to add or remove.
Thickness Specifies the thickness to add or remove.
Vector Specifies the extrusion vector to add or remove.
Note:
Once you have a filter list, any of the filters can be removed by selecting the option keyword and then pressing ENTER. If an item exists in the filter list and you elect to add a new item, the old value is overwritten by the new value. You can have only one of each type of item in a single (ssget 'x') call.
Usage Example:
Select a line to use as a template object, but remove the layer filter.
Command: SSX
Select object/<None>: Select a line
Current Filter: ((0 . "LINE") (8 . "0") (39 . 2.0) (62 . 1) (210 0.0 0.0 1.0))
Enter filter option [Block name/Color/Entity/Flag/LAyer/LType/Pick/Style/Thickness/Vector]: layer
>>Layer name to add/<RETURN to remove>: Press ENTER to remove layer filter
Current Filter: ((0 . "LINE") (39 . 2.0) (62 . 1) (210 0.0 0.0 1.0))
Enter filter option [Block name/Color/Entity/Flag/LAyer/LType/Pick/Style/Thickness/Vector]: Press ENTER
To select objects that match the filter, enter "previous" at the next Select Objects prompt.
Command line: SSX
Files: ssx.lsp
#3 tranchan
tranchan
    biết lệnh break
  • 221 Bài viết
Điểm đánh giá: 93 (tàm tạm)
Đã gửi 19 June 2008 - 08:40 AM
Mục đích của lệnh SSX là lệnh lọc ra một tập hợp đối tượng theo nhóm block, text... giống như filter nhưng khác filter ở chổ filter lọc ra các đối tượng mà kô lưu lại dưới dạng tập hợp có tên, thì ssx lọc ra và lưu lại thành 1 tập hợp có tên , việc này có giá trị sd khi gõ một lệnh như copy, move và chỉ gõ tên tập hợp đó...(cái này cũng nghiền ngẫm từ help ra,chứ bản thân tui chưa bao giờ làm đc ...)
