Đổi tên Block được chọn !
22 replies to this topic
#21 duvanngoc
duvanngoc
Đã gửi 12 April 2014 - 04:08 PM
Xin lỗi các bạn hôm trước mình đã sửa rồi quên up lại nên bị sai tí chút
code fix
(defun c:dt ()
  (command "undo" "be")
  (setq ten (cdr(assoc 2 (entget(car(entsel "\nChon block dien hinh: "))))))
  (princ "\nChon block can doi ten: ")
  (setq	ssc (ssget (list(cons 0 "INSERT")(cons 2 ten)))
	tm (getstring "\nNhap ten moi: ")
  (command "rename" "b" ten tm)
  (command "copyclip" ssc "")
  (command "block" "block_temp" "0,0" ssc "")
  (command "insert" "block_temp" "0,0" 1 1 0)
  (setq el (entlast))
  (setq pt (car(acet-ent-geomextents el)))
  (command "undo" "e"
	   "undo" 1)
  (command "erase" ssc "")
  (command "pasteclip" pt)
  (setvar "osmode" oldos)
Bạn cho hiển thị tên block cũ vào trước đoạn chèn tên block mới thì tốt, dễ kiểm soát (xem hình đính kèm)
1609588_638393552882417_6017030616240096
Mình trích
(or *kpblc-activedoc*
    (setq *kpblc-activedoc* (vla-get-activedocument (vlax-get-acad-object)))
    ) ;_ end of or
(defun c:vla-rename (/ ent name)
  (vla-startundomark *kpblc-activedoc*)
  (if
    (and (not (vl-catch-all-error-p
		(vl-catch-all-apply
		  '(lambda ()
		     (setq ent (car (entsel "\nSelect a block to be renamed")))
		     ) ;_ end of lambda
		  ) ;_ end of vl-catch-all-apply
		) ;_ end of vl-catch-all-error-p
	      ) ;_ end of not
	 ent
	 (= (cdr (assoc 0 (entget ent))) "INSERT")
	 (/= (substr (cdr (assoc 2 (entget ent))) 1 2) "*U")
		(vl-catch-all-apply
		  '(lambda ()
		     (setq name	(getstring t
					   (strcat "\nEnter new name <"
						   ) ;_ end of strcat
					   ) ;_ end of getstring
			   ) ;_ end of setq
		     ) ;_ end of lambda
	      ) ;_ end of not
	 (/= (vl-string-trim " " name))
	 ) ;_ end of and
     (if (vl-catch-all-error-p
	   (vl-catch-all-apply
	     '(lambda ()
		(vla-put-name
		  (vla-item (vla-get-blocks *kpblc-activedoc*)
			    ) ;_ end of vla-item
		  name
		  ) ;_ end of vla-put-name
		) ;_ end of lambda
       (princ (strcat "\nCan't rename a block "
		      " with new name "
		      name
		      ) ;_ end of strcat
	      ) ;_ end of princ
       ) ;_ end of if
     (princ (strcat "\nA error has been catched:"
		    "\nSelection error | Selected entity isn't a block "
		    "| It's a unnamed or dynamic block"
		    ) ;_ end of strcat
	    ) ;_ end of princ
     ) ;_ end of if
  (vla-endundomark *kpblc-activedoc*)
  ) ;_ end of defun
đoạn code có tính năng đó lên cho bạn tham khảo:
#22 lehoangtsbd
lehoangtsbd
Đã gửi 18 August 2014 - 03:13 PM
mấy cái list đó mình đổi tên 1 block là nó đổi hết những cái block khác cùng tên với nó bạn ah
#23 phieuluu35
phieuluu35
  • 16 Bài viết
Đã gửi 21 February 2016 - 08:22 PM
Cái lisp này không đổi được tên của dynamic block rồi, bạn cập nhật thêm phần này giúp  mình nhe
Thanks
