Hỏi cách Tô Hatch bỏ qua đối tượng là block bằng VBA?
#1 nvson
nvson
  • 52 Bài viết
Đã gửi 18 July 2011 - 01:54 PM
Các bác cho hỏi cách "Tô Hatch bỏ qua đối tượng là block bằng VBA"
Tôi dùng đoạn code sau nhưng cứ báo lỗi, mong các bác ra tay giúp đỡ.
Public Sub To_H()
'Error Resume Next
Dim hatchObj As AcadHatch
Dim patternName As String
Dim PatternType As Long
Dim bAssociativity As Boolean
Dim outerLoop(0) As AcadEntity
Dim innerLoop(0) As AcadEntity
Dim plineObj As AcadPolyline
Dim points(0 To 11) As Double
points(0) = 0: points(1) = 0: points(2) = 0
points(3) = 15: points(4) = 0: points(5) = 0
points(6) = 15: points(7) = 6: points(8) = 0
points(9) = 0: points(10) = 6: points(11) = 0
Set plineObj = AcadApplication.ActiveDocument.ModelSpace.AddPolyline(points)
plineObj.Closed = True
' Define the hatch
patternName = "set"
PatternType = 0
bAssociativity = True
Dim objBlock As AcadBlockReference
Dim ptB(0 To 2) As Double
ptB(0) = 5
ptB(1) = 3
Set objBlock = AutoCAD.ActiveDocument.ModelSpace.InsertBlock(ptB, "TL", "0.5", "0.5", "0.5", 0)
Dim x, varAtts
varAtts = objBlock.GetAttributes
For x = LBound(varAtts) To UBound(varAtts)
Select Case varAtts(x).TagString
Case "TEN-LOP"
varAtts(x).TextString = "1"
End Select
Next x
' Create the associative Hatch object
Set hatchObj = AcadApplication.ActiveDocument.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
Set outerLoop(0) = plineObj
hatchObj.PatternScale = 0.5
Set innerLoop(0) = objBlock
hatchObj.AppendOuterLoop (outerLoop)
hatchObj.AppendInnerLoop (innerLoop)
hatchObj.Evaluate
AcadApplication.ActiveDocument.Regen True
End Sub
đây là file dwg
Thanks!
#2 phamngoctukts
phamngoctukts
  • 1107 Bài viết
Điểm đánh giá: 708 (tốt)
Đã gửi 18 July 2011 - 04:49 PM
Public Sub To_H()
'Error Resume Next
' Define the hatch
patternName = "set"
PatternType = 0
ptB(0) = 5
ptB(1) = 3
Dim x, varAtts
Case "TEN-LOP"
End Select
Next x
hatchObj.Evaluate
End Sub
đây là file dwg
Thanks!
Vì method AppendOuterLoop và AppendinnerLoop có đối số là các đối tượng là line, pline, spline, circle, ellipse, region nên khi bạn áp dụng đối số là block thi trương chình bị lỗi. Khắc phục: Bạn có thể add thêm circle rồi hatch.
#3 phantuhuong
phantuhuong
    biết dimstyle
  • 389 Bài viết
Điểm đánh giá: 203 (khá)
Đã gửi 18 July 2011 - 05:02 PM
Đúng là nên tạo đường bao quanh Block, sau khi tô xong xoá bỏ. Đành khắc phục kiểu này vậy.
Cậu xem thêm ở đây nếu có nhiều block cần loại bỏ:
http://www.cadviet.c...showtopic=21050
