Game on Cad
24 replies to this topic
#1 phamtuan
phamtuan
    biết lệnh scale
  • 145 Bài viết
Điểm đánh giá: 222 (khá)
Đã gửi 01 September 2008 - 02:56 PM
; Program Name: Troy.lsp [Troy R5] - Asteroids AutoLISP game
; Created By: phamtuan (Email: tuanngph@hpc.org.vn)
; Date Created: 1-20-06
; Notes: Troy is an Asteroids AutoLISP game driven by the grread function.
; It can be run inside of an existing drawing. When it's finished,
; it purges all entities, styles and layers it created. You have
; three ships to use to shoot down as many Troys as possible. If
; a Troy runs into your ship, it blows up your ship and you loose
; 10 points. Each Troy you blow up, you gain its value in points.
; Use the mouse to keep the game moving. Pick the mouse to fire
; at Troys. Each fire cost you 1 point. Press P to pause the game.
; Press Q to quit the game before it ends, in order to purge all
; entities, styles and layers it created. If you press the escape
; key to abort the game, simply rerun Troy again and select the
; Clear option. So do not press the escape key to abort the game.
; Disclaimer: This program is free to download and share and learn from. It
; contains many useful functions that may be applied else where.
; Every effort on my part has been to create a grread game that
; will run in most versions of AutoCAD, and when finished it will
; return to the environment before it started. Troy is now yours
; to tweak, debug, add to, rename, use parts of, or create another
; grread game from. It is now your responsibility when, and within
; what drawings you should run it. If you are unsure of how it may
; affect certain drawing environments, do a saveas before running
; it. Do not save a drawing without running the Troy Clear option.
; Revision History
; Rev By Date Description
; 1 TM 1-20-06 Initial version.
; 2 TM 6-20-06 Revised PurgeGroups function.
; 3 TM 6-24-06 Revised program to switch to the Model tab if there are
; viewports on the current Layout tab.
; 4 TM 6-26-06 Added Settings option to adjust number of Troys, speed of
; Troys and Color Scheme.
; 5 TM 1-1-07 The *_nth list functions were revised for maximum speed.
; c:Troy - Asteroids AutoLISP game
(defun c:Troy (/ Colors$ Loop Option$ Settings$)
(initget "Intro Clear Settings Play")
(if (not (setq Option$ (getkword "\nTroy options [Intro/Clear/Settings/<Play>]: ")))
(setq Option$ "Play")
);if
((= Option$ "Clear")(TroyClear)(princ "\nTroy objects Cleared."))
((= Option$ "Settings")
(initget "Troys Speed Colors Defaults")
(if (not (setq Settings$ (getkword "\nSettings [Troys/Speed/Colors/<Defaults>]: ")))
(setq Settings$ "Defaults")
);if
((= Settings$ "Troys")
(setq Loop t)
(while Loop
(if (not (setq *MinTroys#* (getint "\nMinimum number of Troys <5>: ")))
(setq *MinTroys#* 5)
);if
(if (not (setq *MaxTroys#* (getint "\nMaximum number of Troys <10>: ")))
(setq *MaxTroys#* 10)
);if
(if (or (< *MinTroys#* 1) (<= *MaxTroys#* *MinTroys#*))
(princ "\nThe maximum number must be greater than the minimum number,\nand the minimum number must be greater than 0.")
(setq Loop nil)
);if
);while
(if (> *MaxTroys#* 20)
(princ "\nIncreasing the maximum number of Troys may slow down the game.")
);if
);case
((= Settings$ "Speed")
(setq Loop t)
(while Loop
(if (not (setq *TroySpeed~* (getreal "\nAdjust speed of Troys\nEnter a number between 0.5 and 5.0 <1.0>: ")))
(setq *TroySpeed~* 1.0)
);if
(if (or (< *TroySpeed~* 0.5)(> *TroySpeed~* 5.0))
(princ "\nThe number must in the range of 0.5 to 5.0.\nThe larger the number the faster the Troys move.")
(setq Loop nil)
);if
);while
);case
((= Settings$ "Colors")
(initget "Bright Dim Ghost")
(if (not (setq Colors$ (getkword "\nColor Scheme [<Bright>/Dim/Ghost]: ")))
(setq Colors$ "Bright")
);if
(setq *ColorScheme#*
((= Colors$ "Bright") 1)
((= Colors$ "Dim") 2)
((= Colors$ "Ghost") 3)
);cond
);setq
);case
((= Settings$ "Defaults")
(setq *MinTroys#* 5 *MaxTroys#* 10 *TroySpeed~* 1.0 *ColorScheme#* 1)
);case
);cond
(c:Troy)
);case
(t (Troy Option$))
);if
);defun c:Troy
; Troy - Troy main function
(defun Troy (Option$ / AddArray: Ang~ AxisPt BuildShip: CenPt ChangeArray: CirAng~
CirEnt^ CirLimits~ CirPt1 CirPt2 Color1 Color1_5 Color2 Color3 Color4 Color5
Color6 Color7 Color8 Cnt# Code# Counter# CreateArray: Dia1~ Dia2~ Direction#
Dist~ Ent^ Ent1^ Ent2^ Flame$ Flame^ FlameArray@ HalfStep~ Inc# Inc1~ Inc2~
Increase~ Item Limit# Loop MainEnt^ MainList@ MainNum# NorthEast NorthWest
Nth# Nths@ Num# NumSteps# Offset~ OldDirection# Option$ Passed Pnts# Points#
Previous@ Pt Pt1 Pt2 Pt3 Pt4 Pt5 Pt6 Pt7 Pt8 Pt9 Pt10 Pt11 Pt12 Radius~ Read@
Refresh: Rotate~ ShipName$ SouthEast SouthWest SS& StepDist~ SubList@ TextEnt^
Total# TroyArray@ Unit~ Value ViewExtents@ ViewSize~ Xmin~ Xmax~ Ymin~ Ymax~)
; AddArray: - Add new Troy entity specs to the TroyArray@ list
; Arguments: 1
; StartPt = Specify starting point or nil
; Returns: A list of a new random Troy specs to be added to TroyArray@ list
(defun AddArray: (StartPt / Ang~ Num#)
(if StartPt
(setq CirPt1 StartPt)
(setq CirPt1 (polar CenPt (* (GetRnd 6283) 0.001) CirLimits~))
);if
(setq Num# (GetRnd 8))
(setq StepDist~;Determines Troys Speed
(cond; Points Dia Units
((= Num# 0)(* Unit~ 0.100 *TroySpeed~*));50 2.0
((= Num# 1)(* Unit~ 0.125 *TroySpeed~*));75 2.5
((= Num# 2)(* Unit~ 0.150 *TroySpeed~*));100 3.0
((= Num# 3)(* Unit~ 0.175 *TroySpeed~*));125 3.5
((= Num# 4)(* Unit~ 0.200 *TroySpeed~*));150 4.0
((= Num# 5)(* Unit~ 0.225 *TroySpeed~*));175 4.5
((= Num# 6)(* Unit~ 0.250 *TroySpeed~*));200 5.0
((= Num# 7)(* Unit~ 0.275 *TroySpeed~*));225 5.5
((= Num# 8)(* Unit~ 0.300 *TroySpeed~*));250 6.0
);cond
);setq
(setq HalfStep~ (/ StepDist~ 2.0))
(setq Points# (+ (* Num# 25) 50));50 to 250
(setq Radius~ (/ (* Unit~ (* 0.1 (+ (+ (* Num# 5) 10) 10))) 2.0))
(command "_CIRCLE" CirPt1 Radius~)
(setq Ent1^ (entlast))
(command "_CHPROP" Ent1^ "" "_C" Color8 "")
(command "_HATCH" "AR-CONC" (* (getvar "VIEWSIZE") 0.0045) "" Ent1^ "")
(setq Ent2^ (entlast))
(command "_CHPROP" Ent2^ "" "_C" Color8 "")
(command "_-GROUP" "_C" (UniqueName) "" Ent1^ Ent2^ "")
(setq CirEnt^ (entlast))
(setq CirAng~ (+ (- (angle CirPt1 CenPt) (dtr 30)) (* (GetRnd 1047) 0.001)))
(setq CirPt2 (polar CirPt1 CirAng~ StepDist~))
(setq Offset~ (+ (* Radius~ 2)(* Radius~ (GetRnd 10))))
(setq Ang~ (atan (/ HalfStep~ Offset~)))
(setq Pt (polar CirPt1 CirAng~ HalfStep~))
(if (< CirAng~ (angle CirPt1 CenPt))
(setq AxisPt (polar Pt (+ CirAng~ (dtr 90)) Offset~) Direction# 1)
(setq AxisPt (polar Pt (- CirAng~ (dtr 90)) Offset~) Direction# -1)
);if
(setq NumSteps# (+ (GetRnd 10) 2))
(list CirEnt^ CirPt1 CirPt2 AxisPt Radius~ Direction# NumSteps# Points#)
);defun AddArray:
; ChangeArray: - Change or Move entity in the TroyArray@ list
; Arguments: 1
; List@ = A sublist within the TroyArray@ list
; Returns: Changes or Moves Troy entities in the TroyArray@ list
(defun ChangeArray: (List@ / Ang~ Num#)
(setq CirEnt^ (nth 0 List@)
CirPt1 (nth 1 List@)
CirPt2 (nth 2 List@)
AxisPt (nth 3 List@)
Radius~ (nth 4 List@)
Direction# (nth 5 List@)
NumSteps# (nth 6 List@)
Points# (nth 7 List@)
StepDist~ (distance CirPt1 CirPt2)
Ang~ (- (* pi 0.5)(acos (/ HalfStep~ (distance AxisPt CirPt2))))
);setq
(command "_MOVE" CirEnt^ "" CirPt1 CirPt2)
(setq NumSteps# (1- NumSteps#))
(if (= NumSteps# 0)
(setq OldDirection# Direction#)
(setq Num# (GetRnd 10))
(if (> Num# 5)
(setq Direction# 1);ccw
(setq Direction# -1);cw
);if
(if (= OldDirection# 1);ccw
(if (= Direction# 1);ccw
(setq AxisPt (polar CirPt2 (angle CirPt2 AxisPt) Offset~))
(setq AxisPt (polar CirPt2 (angle AxisPt CirPt2) Offset~))
);if
(if (= Direction# -1);cw
);if
);if
(setq Ang~ (- (* pi 0.5)(acos (/ HalfStep~ Offset~))))
(setq Pt (polar AxisPt (+ (angle AxisPt CirPt2) (* Ang~ 2)) (distance AxisPt CirPt2)))
(setq Pt (polar AxisPt (- (angle AxisPt CirPt2) (* Ang~ 2)) (distance AxisPt CirPt2)))
);if
(setq CirPt1 CirPt2 CirPt2 Pt)
);progn
);progn
);progn
);if
);if
;(command "LINE" AxisPt CirPt1 ""); Uncomment to see Troys paths while debuging
;If you're tweaking or debugging this code, you've got to uncommend the above line
;at least once to see these patterns. Run Troy in the Intro or Play mode for about
;10 seconds then press the escape key to abruptly abort the game. Then turn off
;all layers except for the Troy layer, and do a zoom extents and print it.
);defun ChangeArray:
; CreateArray: - Creates the initial TroyArray@ list
; Arguments: 1
; TowardCenter = 1 for toward center, else away from center
; Returns: Creates the initial TroyArray@ list moving in direction specified.
(defun CreateArray: (TowardCenter)
(setq TroyArray@ nil)
(if (= TowardCenter 1)
(setq Rotate~ (* (GetRnd 6283) 0.001))
(repeat 10
(setq TroyArray@ (append TroyArray@ (list (AddArray: (polar CenPt Rotate~ CirLimits~)))))
(setq Rotate~ (+ Rotate~ (/ pi 5.0)))
);repeat
);progn
Dist~ (/ (distance NorthWest NorthEast) 7)
Increase~ (/ (* Dist~ 3) 20.0)
);setq
(repeat 10
(setq Pt (polar CenPt Rotate~ Dist~))
(setq List@ (AddArray: Pt))
(setq List@ (Switch_nth 1 2 List@))
(setq List@ (Change_nth 5 (* (nth 5 List@) -1) List@))
(setq TroyArray@ (append TroyArray@ (list List@)))
(setq Rotate~ (+ Rotate~ 0.897 (* (GetRnd 359) 0.001))
Dist~ (+ Dist~ Increase~)
);setq
);repeat
);progn
);if
);defun CreateArray:
; BuildShip: - Draws Ships
; Arguments: 2
; Num# = The number of ship created in the function BuildShip:
; InsPt = Insertion base point of the ship
; Returns: Draws and makes a block of ship at the insertion point specified.
; Also creates the variables MainEnt^ and MainList@ of the ships specs.
(defun BuildShip: (Num# InsPt / SS&)
(if (not (member Num# (list 0 1 2 3)))(setq Num# 1))
((= Num# 0);Red Ship in Intro
(setq Pt1 (polar InsPt (dtr 90) (* Unit~ 0.5))
Pt1 (polar Pt1 pi (* Unit~ 0.875))
Pt2 (polar Pt1 pi (* Unit~ 0.375))
Pt2 (polar Pt2 (dtr 270) (* Unit~ 0.125))
Pt3 (polar Pt2 pi (* Unit~ 0.25))
Pt3 (polar Pt3 (dtr 270) (* Unit~ 0.125))
Pt4 (polar Pt3 (dtr 270) (* Unit~ 0.75))
Pt4 (polar Pt4 0 (* Unit~ 0.5))
Pt5 (polar Pt4 0 (* Unit~ 1.25))
Pt5 (polar Pt5 (dtr 270) (* Unit~ 0.5))
Pt6 (polar InsPt 0 (* Unit~ 2.5))
Pt7 (polar Pt6 (dtr 90) (* Unit~ 0.5))
Pt7 (polar Pt7 pi Unit~)
Pt8 (polar Pt7 pi (* Unit~ 0.5))
Pt8 (polar Pt8 (dtr 90) (* Unit~ 0.125))
Pt9 (polar Pt3 0 (* Unit~ 0.5))
Pt10 (polar InsPt (dtr 270) (* Unit~ 0.25))
Pt11 (polar Pt9 0 (* Unit~ 2.25))
Pt12 (polar InsPt (dtr 90) Unit~)
);setq
(setq SS& (ssadd))
(command "_COLOR" Color1);Red
(command "_ARC" Pt1 Pt2 Pt3)(ssadd (entlast) SS&)
(command "_ARC" Pt3 Pt4 Pt5)(ssadd (entlast) SS&)
(command "_ARC" "" Pt6)(ssadd (entlast) SS&)
(command "_ARC" Pt6 Pt7 Pt8)(ssadd (entlast) SS&)
(command "_COLOR" Color4);Cyan
(command "_ARC" Pt9 Pt10 Pt11)(ssadd (entlast) SS&)
(command "_ARC" Pt11 Pt12 Pt9)(ssadd (entlast) SS&)
(command "_COLOR" "_BYLAYER")
(setq ShipName$ (UniqueName))
(command "_BLOCK" ShipName$ InsPt SS& "")
(command "_INSERT" ShipName$ InsPt 1 1 0)
(setq MainEnt^ (entlast))
(setq MainList@ (entget MainEnt^))
);case
((= Num# 1);Green Ship
(setq Pt (polar InsPt pi Unit~) Pt (polar Pt (dtr 90) (* Unit~ 0.5)))
(command "_PLINE" Pt (polar Pt (dtr 270) Unit~) (polar InsPt 0 (* Unit~ 2)) "_C")
(command "_CHPROP" "_L" "" "_C" Color3 "");Green
(command "_BLOCK" ShipName$ InsPt "_L" "")
);case
((= Num# 2);Cyan Ship
(setq Pt (polar InsPt pi Unit~) Pt1 (polar Pt (dtr 270) Unit~)
Pt4 (polar Pt1 (dtr 90) (* Unit~ 2)) Pt (polar InsPt 0 Unit~)
Pt2 (polar Pt (dtr 270) (* Unit~ 0.5)) Pt3 (polar Pt2 (dtr 90) Unit~)
);setq
(command "_PLINE" (polar InsPt pi (* Unit~ 0.5)) Pt1 (polar InsPt (dtr 270) (* Unit~ 0.5))
Pt2 (polar InsPt 0 (* Unit~ 2)) Pt3 (polar InsPt (dtr 90) (* Unit~ 0.5)) Pt4 "_C"
);command
(command "_CHPROP" "_L" "" "_C" Color4 "");Cyan
);case
((= Num# 3);Magenta Ship
(setq Pt (polar InsPt pi Unit~) Pt1 (polar Pt (dtr 270) (* Unit~ 0.5))
Pt4 (polar Pt1 (dtr 90) Unit~) Pt2 (polar Pt1 0 (* Unit~ 1.5))
Pt3 (polar Pt4 0 (* Unit~ 1.5))
);setq
(command "_PLINE" InsPt Pt1 (polar InsPt (dtr 270) Unit~) Pt2
(polar InsPt 0 (* Unit~ 2)) Pt3 (polar InsPt (dtr 90) Unit~) Pt4 "_C"
);command
(command "_CHPROP" "_L" "" "_C" Color6 "");Magenta
);case
);cond
);defun BuildShip:
; Refresh: - Erases Troy entities and creates a new TroyArray@ list
(defun Refresh: ()
(setq SS& (ssget "_x" (list '(8 . "Troy"))))
(command "_ERASE" SS& "")
(setq FlameArray@ nil TroyArray@ nil Counter# 0 MainNum# (1+ MainNum#))
(CreateArray: (GetRnd 1))
);defun Refresh:
; Start of Main Function
(if (not *MinTroys#*) (setq *MinTroys#* 5))
(if (not *MaxTroys#*) (setq *MaxTroys#* 10))
(if (not *TroySpeed~*) (setq *TroySpeed~* 1.0))
(if (not *ColorScheme#*) (setq *ColorScheme#* 1))
(if (not *Speed#) (Speed))
(if (not *Clayer$*) (setq *Clayer$* (getvar "CLAYER")))
(if (not *Osmode#*) (setq *Osmode#* (getvar "OSMODE")))
(if (not *TextStyle$*) (setq *TextStyle$* (getvar "TEXTSTYLE")))
(if (not *TextSize~*) (setq *TextSize~* (getvar "TEXTSIZE")))
(setvar "BLIPMODE" 0)(setvar "CMDECHO" 0)
(setvar "OSMODE" 0)(setvar "GRIDMODE" 0)(graphscr)
(if (>= (atoi (getvar "ACADVER")) 15)
(if (not *CTab$*) (setq *CTab$* (getvar "CTAB")))
(if (/= (getvar "CTAB") "Model")
(command "_PSPACE")
(if (setq SS& (ssget "_x" (list '(-4 . "<AND")'(0 . "VIEWPORT")(cons 410 (getvar "CTAB"))'(-4 . "AND>"))))
(if (> (sslength SS&) 1)
(command "_LAYOUT" "_S" "Model")
);if
);if
);progn
);if
(setq *TroyTab$* (getvar "CTAB"))
);progn
);if
(if (tblsearch "LAYER" "Troy")
(command "_LAYER" "_T" "Troy" "_U" "Troy" "_ON" "Troy" "_M" "Troy" "")
(command "_LAYER" "_M" "Troy" "")
);if
(if (setq SS& (ssget "_x" (list '(8 . "Troy"))))
);if
(setq ViewExtents@ (ViewExtents))
(command "_ZOOM" "_W" (car ViewExtents@)(cadr ViewExtents@))
(setq Xmin~ (car (nth 0 ViewExtents@))
Ymax~ (cadr (nth 0 ViewExtents@))
Xmax~ (car (nth 1 ViewExtents@))
Ymin~ (cadr (nth 1 ViewExtents@))
NorthWest (car ViewExtents@)
SouthEast (cadr ViewExtents@)
SouthWest (list Xmin~ Ymin~)
NorthEast (list Xmax~ Ymax~)
CenPt (getvar "VIEWCTR")
ViewSize~ (getvar "VIEWSIZE")
Unit~ (/ (getvar "VIEWSIZE") 50.0)
Limit# (1+ (fix (/ (distance CenPt (car ViewExtents@)) Unit~)))
CirLimits~ (* (+ Limit# 3) Unit~)
North (polar CenPt (dtr 90) (+ (* Unit~ 3) (/ (getvar "VIEWSIZE") 2.0)))
South (polar CenPt (dtr 270) (+ (* Unit~ 3) (/ (getvar "VIEWSIZE") 2.0)))
East (polar CenPt 0 (+ (* Unit~ 3) (/ (distance NorthWest NorthEast) 2.0)))
West (polar CenPt pi (+ (* Unit~ 3) (/ (distance NorthWest NorthEast) 2.0)))
);setq
; Customize Color Schemes as desired and add to top menu in c:Troy
((= *ColorScheme#* 1); Bright colors
(setq Color1 1 ;Red Red ship
Color1_5 30 ;Orange Exploding Troys
Color2 2 ;Yellow Bonus points
Color3 3 ;Green 1st ship
Color4 4 ;Cyan 2nd ship
Color5 5 ;Blue Letter O in TroyIntro
Color6 6 ;Magenta 3rd ship
Color7 7 ;White Not used
Color8 33 ;Grey Troys
);setq
);case
((= *ColorScheme#* 2); Dim colors
(setq Color1 12 ;Red Red ship
Color1_5 32 ;Orange Exploding Troys
Color2 52 ;Yellow Bonus points
Color3 86 ;Green 1st ship
Color4 152 ;Cyan 2nd ship
Color5 162 ;Blue Letter O in TroyIntro
Color6 192 ;Magenta 3rd ship
Color8 250 ;Grey Troys
);setq
);case
((= *ColorScheme#* 3); Ghost colors
(setq Color1 250 ;Red Red ship
Color1_5 250 ;Orange Exploding Troys
Color2 250 ;Yellow Bonus points
Color3 250 ;Green 1st ship
Color4 250 ;Cyan 2nd ship
Color5 250 ;Blue Letter O in TroyIntro
Color6 250 ;Magenta 3rd ship
Color7 250 ;White Not used
);setq
);case
);cond
; Create Flame$ block
(setq SS& (ssadd))(setq Pt SouthEast)
(command "_COLOR" Color2);Yellow
(command "_LINE" Pt (setq Pt (polar Pt 0 Unit~)) "")(ssadd (entlast) SS&)
(command "_COLOR" "_BYLAYER")(setq Flame$ (UniqueName))
(command "_BLOCK" Flame$ SouthEast SS& "")
(if (= Option$ "Intro")(TroyIntro))
;(command "RECTANG" (car ViewExtents@)(cadr ViewExtents@)); Uncomment while debuging
;(command "CIRCLE" CenPt CirLimits~); Uncomment while debuging
; Build Ship 1
(BuildShip: 1 CenPt)
; Create first Troys
(command "_STYLE" "Troy" "ROMANS" "0.0" "0.75" "" "" "" "")
; Start of grread Loop
(setq Loop t Counter# 0 Total# 100 MainNum# 1)
(setq Previous@ (list 5 (polar CenPt 0 Unit~)));Start the Loop moving
(princ (strcat "\nCommand:\nTotal: " (itoa Total#) "\n"))
(while Loop
; Read the mouse movements and picks
(if (not (setq Read@ (grread t 8)))
(setq Read@ Previous@)
);if
(setq Code# (nth 0 Read@))
(setq Value (nth 1 Read@))
((= Code# 3); Fire if picked
(setq Ang~ (angle CenPt Value)
Pt1 (polar CenPt Ang~ (* Unit~ 2))
Pt2 (polar Pt1 Ang~ Unit~)
);setq
(command "_INSERT" Flame$ Pt1 1 1 (rtd Ang~))
(setq FlameArray@ (append FlameArray@ (list (list (entlast) Pt1 Pt2 Ang~))))
(setq Total# (1- Total#))
);case
((= Code# 5); Rotate if moved
(setq Previous@ Read@)
(setq Ang~ (angle CenPt Value))
(setq MainList@ (entmod (subst (cons 50 Ang~) (assoc 50 MainList@) MainList@)))
);case
((= Code# 2); Key was pressed
((or (= Value 80)(= Value 112));P or p then pause
(getpoint "\nTroy paused. Pick mouse to continue. ")
);case
((or (= Value 81)(= Value 113));Q or q then quit
(setq Loop nil)
);case
(t (princ "\nMove mouse to rotate ship, pick mouse to fire, press P to Pause, or Q to quit.")
(princ (strcat "\nTotal: " (itoa Total#) "\n"))
);case
);case
);case
);cond
; Move flame objects
(if FlameArray@
(setq Cnt# 0 Nths@ nil)
(foreach List@ FlameArray@
(setq Flame^ (nth 0 List@)
Pt1 (nth 1 List@)
Pt2 (nth 2 List@)
Ang~ (nth 3 List@)
);setq
(if (or (and (> (car Pt2)(car East))(> (car Pt2)(car Pt1)))
(and (< (car Pt2)(car West))(< (car Pt2)(car Pt1)))
(and (> (cadr Pt2)(cadr North))(> (cadr Pt2)(cadr Pt1)))
(and (< (cadr Pt2)(cadr South))(< (cadr Pt2)(cadr Pt1)))
);or
(command "_ERASE" Flame^ "")
(setq Nths@ (append Nths@ (list Cnt#)))
);progn
(command "_MOVE" Flame^ "" Pt1 Pt2)
(setq Pt1 Pt2 Pt2 (polar Pt2 Ang~ Unit~))
(setq List@ (list Flame^ Pt1 Pt2 Ang~))
(setq FlameArray@ (Change_nth Cnt# List@ FlameArray@))
);progn
);if
(setq Cnt# (1+ Cnt#))
);foreach
(if Nths@
(setq FlameArray@ (Remove_nths Nths@ FlameArray@))
);if
);progn
);if
; Check if Troys are hit
(foreach List@ TroyArray@ ; Troy list
(if FlameArray@ ; Flame list
);setq
(setq Num# 0 Num@ nil)
(foreach SubList@ FlameArray@
(setq Flame^ (nth 0 SubList@)
Pt2 (nth 2 SubList@)
);setq
(if (and (> (car Pt2) (+ Xmin~ Radius~))(< (car Pt2) (- Xmax~ Radius~))
(> (cadr Pt2) (+ Ymin~ Radius~))(< (cadr Pt2) (- Ymax~ Radius~)))
(if (<= (distance Pt2 CirPt1) Radius~)
(command "_ERASE" CirEnt^ Flame^ "")
(setq Num@ (append Num@ (list Num#)))
(command "_TEXT" "_M" CirPt1 Unit~ 0 (itoa Points#))
(command "_CHPROP" "_L" "" "_C" Color2 "")
(setq TextEnt^ (entlast))
(setq Total# (+ Total# Points#))
(command "_COLOR" Color1_5)
(setq Dia1~ (* Radius~ 2) Dia2~ (* Radius~ 3) Ang~ (dtr 270) Pnts# 7)
(repeat 3
(StarBurst CirPt1 Dia1~ Dia2~ Pnts# Ang~)(delay 0.125)
(setq Dia2~ (* Radius~ 3.5) Ang~ (+ Ang~ (/ (* pi 2) (* Pnts# 3))))
(command "_ERASE" (entlast) "")
(setq Dia2~ (* Radius~ 3) Ang~ (dtr 90))
(setq Dia2~ (* Radius~ 3.5) Ang~ (- Ang~ (/ (* pi 2) (* Pnts# 3))))
(setq Dia2~ (* Radius~ 3) Ang~ (dtr 270))
);repeat
(command "_ERASE" TextEnt^"")
);progn
);if
);if
(setq Num# (1+ Num#))
);foreach
(if Num@
(setq FlameArray@ (Remove_nths Num@ FlameArray@))
);if
);progn
);if
(if TroyArray@
(setq TroyArray@ (Change_nth Cnt# (ChangeArray: List@) TroyArray@))
(CreateArray: 1)
);if
);foreach
(if Nths@
(setq TroyArray@ (Remove_nths Nths@ TroyArray@))
);if
(if (not TroyArray@)
(CreateArray: 1)
);if
; Erase Troys that are out of limits
(setq Cnt# 0)
);setq
(if (or (and (> (car CirPt1)(car East))(> (car CirPt2)(car CirPt1)))
(and (< (car CirPt1)(car West))(< (car CirPt2)(car CirPt1)))
(and (> (cadr CirPt1)(cadr North))(> (cadr CirPt2)(cadr CirPt1)))
(and (< (cadr CirPt1)(cadr South))(< (cadr CirPt2)(cadr CirPt1)))
);or
(command "_ERASE" CirEnt^ "")
(setq TroyArray@ (Change_nth Cnt# (AddArray: nil) TroyArray@))
(setq Counter# (1+ Counter#))
(if (= Counter# 3);Add Troys per Counter#
(setq Counter# 0)
(if (< (length TroyArray@) *MaxTroys#*)
(setq TroyArray@ (append TroyArray@ (list (AddArray: nil))))
);if
);progn
);if
);progn
);if
);foreach
; Check if Troys ran into Ship or total points is <= 0
(setq Cnt# 0 Passed t)
(while Passed
(setq List@ (nth Cnt# TroyArray@)
);setq
(if (or (< (distance CenPt CirPt1) (+ Radius~ (* Unit~ 2.5))) (<= Total# 0))
(command "_ERASE" MainEnt^ "")
((= MainNum# 1)(setq Color# Color3));Green
((= MainNum# 2)(setq Color# Color4));Cyan
((= MainNum# 3)(setq Color# Color6));Magenta
);cond
(command "_COLOR" Color#)
(setq Dia1~ 1 Dia2~ 4 Ang~ (dtr 270) Inc# 0 Inc1~ 0.125 Inc2~ 0.375)
(repeat 20
(if (= Inc# 11)(setq Inc1~ -0.125 Inc2~ -0.375))
(StarBurst CenPt (* Unit~ Dia1~) (* Unit~ Dia2~) 5 Ang~)(delay 0.5)
(setq Dia1~ (+ Dia1~ Inc1~) Dia2~ (+ Dia2~ Inc2~))
(setq Ang~ (+ Ang~ (/ (* pi 2) 3)))
(setq Inc# (1+ Inc#))
);repeat
(setq Total# (- Total# 10))
(if (<= Total# 0)
(setq MainNum# 3)
(princ "\nCommand:\nTotal: 0")
);progn
);if
((= MainNum# 1); Build Ship 2
(Refresh:)
(BuildShip: 2 CenPt)
);case
((= MainNum# 2); Build Ship 3
(Refresh:)
(BuildShip: 3 CenPt)
);case
((= MainNum# 3); Finished!
(setq Passed nil Loop nil)
);case
);cond
(setq Passed nil)
);progn
);if
(if (> Cnt# (1- (length TroyArray@)))
(setq Passed nil)
);if
);while
(if (< (length TroyArray@) *MinTroys#*)
);if
(if (or (/= (getvar "VIEWCTR") CenPt)(/= (getvar "VIEWSIZE") ViewSize~))
);if
);while
(TroyClear)
(princ (strcat "\nCommand:\nTotal: " (itoa Total#) " Finished!"))
);defun Troy
; TroyIntro - Introduction
(defun TroyIntro (/ Color# Divisions# Fire# Fourth# Inc~ Increase~ Ltr# Move#
O-Ang~ O-Cnt# O-Ent^ O-Ins O-List@ O-Pt O-Pts@ O-Size~ Path# Path@ Path1@
Path2@ Path3@ Path4@ R-Ang~ R-Cen R-Cnt# R-Ent^ R-Ins R-List@ R-Pt R-Pts@
R-Size~ Rotate~ Rnd# RndLtr@ Sevenths Step~ T-Ang~ T-Cen T-Cnt# T-Ent^ T-Ins
T-List@ T-Pt T-Pts@ T-Size~ Tl-Ang~ TxSize~ TxSizeInc~ TxSizeMax~ TxSizeMin~
Y-Ang~ Y-Cnt# Y-Ent^ Y-Ins Y-List@ Y-Pt Y-Pts@ Y-Size~)
(princ "\nTroy Intro.\n")
(command "_STYLE" "Troy" "ROMAND" "0.0" "1" "" "" "" "")
(setq T-Pt (polar CenPt pi (* Unit~ 4.5))
R-Pt (polar CenPt pi (* Unit~ 1.5))
O-Pt (polar CenPt 0 (* Unit~ 1.5))
Y-Pt (polar CenPt 0 (* Unit~ 4.5))
TxSizeMax~ (* Unit~ 3)
TxSizeMin~ (* Unit~ 0.5)
Inc~ (* Unit~ 2);Speed of letters
Pt0 (polar R-Pt (- (angle R-Pt SouthWest) 0.009) (distance R-Pt SouthWest))
Pt (polar R-Pt (angle R-Pt Pt0) (/ (distance R-Pt Pt0) 2.0))
Pt (polar Pt (+ (angle R-Pt Pt0) (* pi 0.5)) (/ (distance R-Pt Pt0) 7.0))
R-Cen (Center3Pt R-Pt Pt Pt0)
Radius~ (distance R-Pt R-Cen)
Ang~ (* (- (* pi 0.5) (acos (/ (/ Inc~ 2.0) Radius~))) 2)
Inc# (fix (/ (- (angle R-Cen R-Pt) (angle R-Cen SouthWest)) Ang~))
Pt0 (polar T-Pt (- (angle T-Pt NorthWest) 0.043) (distance R-Pt SouthWest))
Pt (polar T-Pt (angle T-Pt Pt0) (/ (distance R-Pt Pt0) 2.0))
Pt (polar Pt (+ (angle T-Pt Pt0) (* pi 0.5)) (/ (distance R-Pt Pt0) 7.0))
T-Cen (Center3Pt T-Pt Pt Pt0)
TxSizeInc~ (/ (- TxSizeMax~ TxSizeMin~) (float Inc#))
TxSize~ TxSizeMax~
T-Pts@ (list T-Pt)
R-Pts@ (list R-Pt)
O-Pts@ (list O-Pt)
Y-Pts@ (list Y-Pt)
T-Ang~ 0
);setq
(repeat Inc#
(setq T-Pt (polar T-Cen (- (angle T-Cen T-Pt) Ang~) Radius~)
T-Pts@ (append T-Pts@ (list T-Pt))
R-Pt (polar R-Cen (- (angle R-Cen R-Pt) Ang~) Radius~)
R-Pts@ (append R-Pts@ (list R-Pt))
O-Pt (polar CenPt (angle R-Pt CenPt) (distance R-Pt CenPt))
O-Pts@ (append O-Pts@ (list O-Pt))
Y-Pt (polar CenPt (angle T-Pt CenPt) (distance T-Pt CenPt))
Y-Pts@ (append Y-Pts@ (list Y-Pt))
T-Ang~ (- T-Ang~ (dtr 30))
TxSize~ (- TxSize~ TxSizeInc~)
);setq
);repeat
(setq T-Pts@ (reverse T-Pts@)
R-Pts@ (reverse R-Pts@)
O-Pts@ (reverse O-Pts@)
Y-Pts@ (reverse Y-Pts@)
R-Ang~ T-Ang~ O-Ang~ T-Ang~ Y-Ang~ T-Ang~
T-Size~ TxSize~ R-Size~ TxSize~ O-Size~ TxSize~ Y-Size~ TxSize~
T-Cnt# 0 R-Cnt# 0 O-Cnt# 0 Y-Cnt# 0 Fourth# (/ Inc# 4)
);setq
(setq T-Pt (last T-Pts@) R-Pt (last R-Pts@) O-Pt (last O-Pts@) Y-Pt (last Y-Pts@) RndLtr@ (list 0))
(while (/= (length RndLtr@) 5)
(setq Rnd# (1+ (GetRnd 3)))
((= Rnd# 1)(setq Pt T-Pt))
((= Rnd# 2)(setq Pt R-Pt))
((= Rnd# 3)(setq Pt O-Pt))
((= Rnd# 4)(setq Pt Y-Pt))
);cond
(if (not (member Pt RndLtr@))
(setq RndLtr@ (append RndLtr@ (list Pt)))
);if
);while
Dist~ (/ (distance NorthWest NorthEast) 10)
);setq
(repeat 20
);setq
);repeat
(setq Step~ (* Unit~ 1.5);Speed of red ship
Pt1 (polar SouthWest (dtr 90) (/ (distance SouthWest NorthWest) 6.0))
Pt2 (polar Pt1 0 (/ (distance SouthWest SouthEast) 3.0))
Pt (polar Pt1 0 (/ (distance Pt1 Pt2) 2.0))
Pt (polar Pt (dtr 90) (* Unit~ 2))
Pt (Center3Pt Pt1 Pt Pt2)
Radius~ (distance Pt Pt1)
Tl-Ang~ (- (angle Pt Pt1) (angle Pt Pt2))
Ang~ (* 2 (- (* pi 0.5) (acos (/ (* Step~ 0.5) Radius~))))
Divisions# (fix (1+ (/ Tl-Ang~ Ang~)))
Pt2 (polar Pt (- (angle Pt Pt1) (* Ang~ Divisions#)) Radius~)
);setq
(setq Path1@ (list Pt1))
(repeat Divisions#
(setq Pt1 (polar Pt (- (angle Pt Pt1) Ang~) Radius~))
(setq Path1@ (append Path1@ (list Pt1)))
);repeat
(setq Pt (polar Pt (angle Pt Pt2) (* Radius~ 2)))
(repeat (fix (1+ (/ Divisions# 2.0)))
(setq Pt1 (polar Pt (+ (angle Pt Pt1) Ang~) Radius~))
(if (< (angle Pt Pt1) (dtr 270))
);if
);repeat
(setq Pt1 (last Path1@)
Pt2 (inters Pt1 (polar Pt1 0 Unit~) NorthEast SouthEast nil)
Ang~ (atan (/ 1 2.0))
Radius~ (* (distance Pt1 Pt2) (tan Ang~))
Pt (polar Pt1 (dtr 90) Radius~)
Tl-Ang~ (atan (/ (distance Pt1 Pt2) Radius~))
);setq
(repeat Divisions#
);repeat
(setq Pt Pt2
Tl-Ang~ (- (angle Pt Pt1) (* pi 0.5))
);setq
(repeat Divisions#
(setq Pt2 Pt1)
(if (> (angle Pt Pt1) (* pi 0.5))
);if
);repeat
(setq Ang~ (angle Pt2 Pt1))
(repeat 5
(setq Pt1 (polar Pt1 Ang~ Step~))
);repeat
(setq Ang~ (angle (nth 1 Path1@) (nth 0 Path1@)))
(repeat 5
(setq Pt (polar (nth 0 Path1@) Ang~ Step~))
(setq Path1@ (Insert_nth 0 Pt Path1@))
);repeat
(foreach Item Path1@
(setq Pt2 (MirrorPt Item CenPt 0))
(setq Path2@ (append Path2@ (list Pt2)))
(setq Pt3 (MirrorPt Item CenPt (dtr 90)))
(setq Path3@ (append Path3@ (list Pt3)))
(setq Pt4 (MirrorPt Pt3 CenPt 0))
(setq Path4@ (append Path4@ (list Pt4)))
);foreach
(setq Path# (1+ (GetRnd 3)))
((= Path# 1)(setq Path@ Path1@))
((= Path# 2)(setq Path@ Path2@))
((= Path# 3)(setq Path@ Path3@))
((= Path# 4)(setq Path@ Path4@))
);cond
; First Loop
(setq Loop t)
(while Loop
(if (<= T-Cnt# Inc#)
(if (= T-Cnt# 0)
(command "_TEXT" "_M" (nth T-Cnt# T-Pts@) T-Size~ (rtd T-Ang~) "T")
(setq T-Ent^ (entlast))
(command "_CHPROP" T-Ent^ "" "_C" Color3 "");Green
(setq T-List@ (entget T-Ent^)
T-Size~ (+ T-Size~ TxSizeInc~)
T-Ang~ (+ T-Ang~ (dtr 30))
T-Cnt# (1+ T-Cnt#)
T-Ins (nth T-Cnt# T-Pts@)
);setq
);progn
(setq T-List@ (entmod (subst (cons 50 T-Ang~) (assoc 50 T-List@) T-List@)))
(setq T-List@ (entmod (subst (cons 11 T-Ins) (assoc 11 T-List@) T-List@)))
(setq T-List@ (entmod (subst (cons 40 T-Size~) (assoc 40 T-List@) T-List@)))
(setq T-Size~ (+ T-Size~ TxSizeInc~)
T-Cnt# (1+ T-Cnt#)
);setq
(if (<= T-Cnt# Inc#) (setq T-Ins (nth T-Cnt# T-Pts@)))
);progn
);if
);if
(if (>= T-Cnt# Fourth#)
(if (<= R-Cnt# Inc#)
(if (= R-Cnt# 0)
(command "_TEXT" "_M" (nth R-Cnt# R-Pts@) R-Size~ (rtd R-Ang~) "R")
(setq R-Ent^ (entlast))
(command "_CHPROP" R-Ent^ "" "_C" Color4 "");Cyan
(setq R-List@ (entget R-Ent^)
R-Size~ (+ R-Size~ TxSizeInc~)
R-Ang~ (+ R-Ang~ (dtr 30))
R-Cnt# (1+ R-Cnt#)
R-Ins (nth R-Cnt# R-Pts@)
);setq
);progn
(setq R-List@ (entmod (subst (cons 50 R-Ang~) (assoc 50 R-List@) R-List@)))
(setq R-List@ (entmod (subst (cons 11 R-Ins) (assoc 11 R-List@) R-List@)))
(setq R-List@ (entmod (subst (cons 40 R-Size~) (assoc 40 R-List@) R-List@)))
(setq R-Size~ (+ R-Size~ TxSizeInc~)
R-Cnt# (1+ R-Cnt#)
);setq
(if (<= R-Cnt# Inc#) (setq R-Ins (nth R-Cnt# R-Pts@)))
);progn
);if
);if
);if
(if (>= R-Cnt# Fourth#)
(if (<= O-Cnt# Inc#)
(if (= O-Cnt# 0)
(command "_TEXT" "_M" (nth O-Cnt# O-Pts@) O-Size~ (rtd O-Ang~) "O")
(setq O-Ent^ (entlast))
(command "_CHPROP" O-Ent^ "" "_C" Color5 "");Blue
(setq O-List@ (entget O-Ent^)
O-Size~ (+ O-Size~ TxSizeInc~)
O-Ang~ (+ O-Ang~ (dtr 30))
O-Cnt# (1+ O-Cnt#)
O-Ins (nth O-Cnt# O-Pts@)
);setq
);progn
(setq O-List@ (entmod (subst (cons 50 O-Ang~) (assoc 50 O-List@) O-List@)))
(setq O-List@ (entmod (subst (cons 11 O-Ins) (assoc 11 O-List@) O-List@)))
(setq O-List@ (entmod (subst (cons 40 O-Size~) (assoc 40 O-List@) O-List@)))
(setq O-Size~ (+ O-Size~ TxSizeInc~)
O-Cnt# (1+ O-Cnt#)
);setq
(if (<= O-Cnt# Inc#) (setq O-Ins (nth O-Cnt# O-Pts@)))
);progn
);if
);if
);if
(if (>= O-Cnt# Fourth#)
(if (<= Y-Cnt# Inc#)
(if (= Y-Cnt# 0)
(command "_TEXT" "_M" (nth Y-Cnt# Y-Pts@) Y-Size~ (rtd Y-Ang~) "Y")
(setq Y-Ent^ (entlast))
(command "_CHPROP" Y-Ent^ "" "_C" Color6 "");Magenta
(setq Y-List@ (entget Y-Ent^)
Y-Size~ (+ Y-Size~ TxSizeInc~)
Y-Ang~ (+ Y-Ang~ (dtr 30))
Y-Cnt# (1+ Y-Cnt#)
Y-Ins (nth Y-Cnt# Y-Pts@)
);setq
);progn
(setq Y-List@ (entmod (subst (cons 50 Y-Ang~) (assoc 50 Y-List@) Y-List@)))
(setq Y-List@ (entmod (subst (cons 11 Y-Ins) (assoc 11 Y-List@) Y-List@)))
(setq Y-List@ (entmod (subst (cons 40 Y-Size~) (assoc 40 Y-List@) Y-List@)))
(setq Y-Size~ (+ Y-Size~ TxSizeInc~)
Y-Cnt# (1+ Y-Cnt#)
);setq
(if (<= Y-Cnt# Inc#) (setq Y-Ins (nth Y-Cnt# Y-Pts@)))
);progn
);if
);if
);if
(setq Cnt# 0)
);setq
(if (> (distance CenPt CirPt1) CirLimits~)
);progn
);if
);foreach
(delay 0.15);Speed of Loop
(if (> Y-Cnt# Inc#)(setq Loop nil))
);if
);while
; Second Loop
(setq Loop t Move# 0 Ltr# 0 Sevenths# (/ (length Path@) 7) Fire# (1+ Sevenths#))
(BuildShip: 0 (nth 0 Path@))
(if (> Path# 2)
(setq MainList@ (entmod (subst (cons 42 -1.0) (assoc 42 MainList@) MainList@)))
);if
(while Loop
; Move Ship
(setq Pt1 (nth Move# Path@)
Pt2 (nth (1+ Move#) Path@)
Ang~ (angle Pt1 Pt2)
);setq
;(command "LINE" Pt1 Pt2 "");Uncomment while debuging
(setq MainList@ (entmod (subst (cons 10 Pt1) (assoc 10 MainList@) MainList@)))
; Fire at Troy Letters
(setq Fire# (1+ Fire#))
(if (= Fire# (fix (* Sevenths# 2.5)))(setq Fire# Sevenths#));First time
(if (= Fire# Sevenths#);Fire in these intervals
(setq Fire# 0 Ltr# (1+ Ltr#))
(if (member Ltr# (list 1 2 3 4))
(setq Pt (nth Ltr# RndLtr@)
Ang~ (angle Pt1 Pt)
Pt1 (polar Pt1 Ang~ (* Unit~ 2))
);setq
);progn
);if
);progn
);if
(if FlameArray@
(setq Cnt# 0 Nth# nil)
Pt1 (nth 1 List@)
Pt2 (nth 2 List@)
Ang~ (nth 3 List@)
);setq
);or
(setq Nth# Cnt#)
);progn
);progn
);if
);foreach
(if Nth#
(setq FlameArray@ (Delete_nth Nth# FlameArray@))
);if
);progn
);if
; Check to see if Troy Letters are hit
(if FlameArray@
(setq Num# 0)
(setq Ent^ (nth 0 List@)
Pt2 (nth 2 List@)
Pt nil
);setq
((<= (distance Pt2 T-Pt) Unit~)
(command "_ERASE" T-Ent^ Ent^ "")
(setq FlameArray@ (Delete_nth Num# FlameArray@))
(setq Pt T-Pt T-Pt SouthWest Color# Color3);Green
);case
((<= (distance Pt2 R-Pt) Unit~)
(command "_ERASE" R-Ent^ Ent^ "")
(setq Pt R-Pt R-Pt SouthWest Color# Color4);Cyan
);case
((<= (distance Pt2 O-Pt) Unit~)
(command "_ERASE" O-Ent^ Ent^ "")
(setq Pt O-Pt O-Pt SouthWest Color# Color5);Blue
);case
((<= (distance Pt2 Y-Pt) Unit~)
(command "_ERASE" Y-Ent^ Ent^ "")
(setq Pt Y-Pt Y-Pt SouthWest Color# Color6);Magenta
);case
);cond
; Explode Letter
(if Pt
(setq Dia1~ 0.5 Dia2~ 3 Ang~ (* (GetRnd 6283) 0.001) Inc# 0 Inc1~ 0.125 Inc2~ 0.375)
(repeat 10
(if (= Inc# 6)(setq Inc1~ -0.125 Inc2~ -0.375))
(StarBurst Pt (* Unit~ Dia1~) (* Unit~ Dia2~) (+ (GetRnd 5) 5) Ang~)(delay 0.125)
(setq Ang~ (* (GetRnd 6283) 0.001))
);repeat
);progn
);if
);foreach
);progn
);if
(setq Cnt# 0)
);setq
);progn
);if
);foreach
(setq Move# (1+ Move#))
(if (= Move# (1- (length Path@)))(setq Loop nil))
);if
);while
(setq SS& (ssget "x" (list '(8 . "Troy"))))
);defun TroyIntro
; TroyClear - Troy clear function
(defun TroyClear (/ Block$ Passed SS&)
(if *TroyTab$* (command "_LAYOUT" "_S" *TroyTab$*))
(if *Clayer$* (setvar "CLAYER" *Clayer$*))
(if *Osmode#* (setvar "OSMODE" *Osmode#*))
(if *TextStyle$* (setvar "TEXTSTYLE" *TextStyle$*))
(if *TextSize~* (setvar "TEXTSIZE" *TextSize~*))
);if
(setq Block$ (strcat (substr (UniqueName) 1 5) "*"))
(foreach Item (GetBlockList)
(if (wcmatch Item Block$) (setq Passed t))
);foreach
(if Passed (command "_PURGE" "_BL" Block$ "_N"))
(if (tblsearch "LAYER" "Troy") (command "_PURGE" "_LA" "Troy" "_N"))
(if (tblsearch "STYLE" "Troy") (command "_PURGE" "_ST" "Troy" "_N"))
(setq *Clayer$* nil *Osmode#* nil *TextStyle$* nil *TextSize~* nil)
(PurgeGroups)
(if *CTab$*
(progn (command "_LAYOUT" "_S" *CTab$*)(setq *CTab$* nil *TroyTab$* nil))
);if
(repeat 45 (princ (strcat "\n" (chr 160))))
);defun TroyClear
; Start of Troy Support Utility Functions
; acos
; Arguments: 1
; x = real number between 0 and 1. May be passed as the sum of dividing two
; sides of a right triangle.
; Returns: acos of x, the radian degrees between sides of a right triangle
(defun acos (x)
(atan (/ (sqrt (- 1 (* x x))) x))
);defun acos
; asin
; Arguments: 1
; sine = real number between -1 to 1
; Returns: arcsin of sine
(defun asin (sine / cosine)
(setq cosine (sqrt (- 1.0 (expt sine 2))))
(if (zerop cosine)
(setq cosine 0.000000000000000000000000000001)
);if
(atan (/ sine cosine))
);defun asin
; Center3Pt - Center point of 3 points on a circle
; Arguments: 3
; Pt1 = First point
; Pt2 = Second point
; Pt3 = Third point
; Returns: Center point of 3 points on a circle
(defun Center3Pt (Pt1 Pt2 Pt3 / Pt Pt4 Pt5 Pt6 Pt7)
(setq Pt4 (polar Pt1 (angle Pt1 Pt2) (/ (distance Pt1 Pt2) 2.0))
Pt5 (polar Pt4 (+ (angle Pt1 Pt2) (* pi 0.5)) 1)
Pt6 (polar Pt2 (angle Pt2 Pt3) (/ (distance Pt2 Pt3) 2.0))
Pt7 (polar Pt6 (+ (angle Pt2 Pt3) (* pi 0.5)) 1)
Pt (inters Pt4 Pt5 Pt6 Pt7 nil)
);setq
);defun Center3Pt
; Change_nth - Changes the nth item in a list with a new item value.
; Arguments: 3
; Num# = Nth number in list to change
; Value = New item value to change to
; OldList@ = List to change item value
; Returns: A list with the nth item value changed.
(defun Change_nth (Num# Value OldList@)
(if (<= 0 Num# (1- (length OldList@)))
(if (> Num# 0)
(cons (car OldList@) (Change_nth (1- Num#) Value (cdr OldList@)))
(cons Value (cdr OldList@))
);if
OldList@
);if
);defun Change_nth
; delay - time delay function
; Arguments: 1
; Percent~ - Percentage of *Speed# variable
; Returns: time delay
(defun delay (Percent~ / Number~)
(repeat (fix (* *Speed# Percent~)) (setq Number~ pi))
);defun delay
; Delete_nth - Deletes the nth item from a list.
; Arguments: 2
; Num# = Nth number in list to delete
; OldList@ = List to delete the nth item
; Returns: A list with the nth item deleted.
(defun Delete_nth (Num# OldList@)
(vl-remove-if '(lambda (x) (zerop (setq Num# (1- Num#)))) OldList@)
);defun Delete_nth
; dtr - Degrees to Radians.
; Arguments: 1
; Deg~ = Degrees
; Syntax: (dtr Deg~)
; Returns: Value in radians.
(defun dtr (Deg~)
(* pi (/ Deg~ 180.0))
);defun dtr
; GetBlockList
(defun GetBlockList (/ BlockList@ Block$ List@)
(if (setq List@ (tblnext "BLOCK" 't))
(while List@
(setq Block$ (cdr (assoc 2 List@)))
(if (/= (substr Block$ 1 1) "*")
(setq BlockList@ (append BlockList@ (list Block$)))
);if
(setq List@ (tblnext "BLOCK"))
);while
);if
(if BlockList@
(setq BlockList@ (Acad_StrlSort BlockList@))
);if
BlockList@
);defun GetBlockList
; GetRnd - Generates a random number
; Arguments: 1
; Num# = Maximum random integer number range greater than or less than 0.
; Returns: Random integer number between 0 and Num#.
(defun GetRnd (Num# / MaxNum# PiDate$ RndNum# Minus Loop)
(if (or (/= (type Num#) 'INT)(= Num# 0))
(princ "\nSyntax: (GetRnd Num#) Num# = Maximum random integer number range\ngreater than or less than 0.")
(exit)
);progn
);if
(if (< Num# 0)
(setq MaxNum# (abs (1- Num#)) Minus t)
(setq MaxNum# (1+ Num#))
);if
(if (not *RndNum*) (setq *RndNum* 10000))
(setq Loop t)
(while Loop
(if (or (null *int*)(> *int* 100))
(setq *int* 1)
(setq *int* (1+ *int*))
);if
(setq PiDate$ (rtos (* (getvar "cdate") (* pi *int*)) 2 8 ))
((>= MaxNum# 10000)
(setq RndNum# (fix (* (atof (substr PiDate$ 13 5)) (* MaxNum# 0.00001))))
((>= MaxNum# 1000)
(setq RndNum# (fix (* (atof (substr PiDate$ 14 4)) (* MaxNum# 0.0001))))
((>= MaxNum# 100)
(setq RndNum# (fix (* (atof (substr PiDate$ 15 3)) (* MaxNum# 0.001))))
((>= MaxNum# 10)
(setq RndNum# (fix (* (atof (substr PiDate$ 16 2)) (* MaxNum# 0.01))))
((>= MaxNum# 1)
(setq RndNum# (fix (* (atof (substr PiDate$ 17 1)) (* MaxNum# 0.1))))
(t (setq RndNum# 0))
);cond
(if (/= RndNum# *RndNum*)
(setq Loop nil)
);if
);while
(setq *RndNum* RndNum#)
(if Minus
(setq RndNum# (* RndNum# -1))
);if
RndNum#
);defun GetRnd
; Insert_nth - Inserts a new item value into the nth number in list.
; Arguments: 3
; Num# = Nth number in list to insert item value
; Value = Item value to insert
; OldList@ = List to insert item value
; Returns: A list with the new item value inserted.
(defun Insert_nth (Num# Value OldList@ / Temp@)
(if (< -1 Num# (1+ (length OldList@)))
(repeat Num#
(setq Temp@ (cons (car OldList@) Temp@)
OldList@ (cdr OldList@)
);setq
);repeat
(append (reverse Temp@) (list Value) OldList@)
);progn
OldList@
);if
);defun Insert_nth
; MirrorPt - Mirror point
; Arguments: 3
; Pt = Point to mirror
; BasePt = Base point
; Angle~ = Mirror angle in radians
; Returns: Returns location of mirrored point
(defun MirrorPt (Pt BasePt Angle~ / Pt1)
(if (> Angle~ pi)
(setq Angle~ (- Angle~ pi))
);if
(setq Pt1 (inters Pt (polar Pt (+ Angle~ (* pi 0.5)) 1)
BasePt (polar BasePt Angle~ 1) nil)
Pt1 (polar Pt1 (angle Pt Pt1) (distance Pt Pt1))
);setq
);defun MirrorPt
; Move_nth - Moves the nth Num1# item value to the nth Num2# location in a list.
; Arguments: 3
; Num1# = Nth number in list to move item value
; Num2# = Nth number in list to move item value of nth Num1# into
; OldList@ = List to move item values
; Returns: A list with nth item value moved.
(defun Move_nth (Num1# Num2# OldList@ / Move_nth:)
(defun Move_nth: (Num1# Num2# OldList@ Nth# Item)
((and (> Nth# Num1#) (> Nth# Num2#))
OldList@
);case
((= Nth# Num1#)
(Move_nth: Num1# (1+ Num2#) (cdr OldList@) (1+ Nth#) Item)
);case
((= Nth# Num2#)
(cons Item (Move_nth: (1+ Num1#) Num2# OldList@ (1+ Nth#) Item))
);case
((cons (car OldList@)
(Move_nth: Num1# Num2# (cdr OldList@) (1+ Nth#) Item))
);case
);cond
);defun Move_nth:
(if (and (/= Num1# Num2#) (<= 0 Num1# (1- (length OldList@))) (<= 0 Num2# (1- (length OldList@))))
(Move_nth: Num1# Num2# OldList@ 0 (nth Num1# OldList@))
OldList@
);if
);defun Move_nth
; PurgeGroups - Purge Unused Groups
(defun PurgeGroups (/ AllGroups@ Cnt# Dictionary^ EntFirst^ EntList@ FirstGroup$
Group^ GroupName$ Item Previous$ Pt SS& UsedGroups@)
(setq Pt (polar (getvar "VIEWCTR") (* pi 1.5)(/ (getvar "VIEWSIZE") 2.0)))
(command "_LINE" Pt (polar Pt (* pi 1.5) 0.00000001) "")
(setq EntFirst^ (entlast))
(setq FirstGroup$ (UniqueName))
(command "_-GROUP" "_C" FirstGroup$ "" EntFirst^ "")
(setq EntList@ (entget EntFirst^))
(setq Group^ (cdr (assoc 330 EntList@)))
(setq EntList@ (entget Group^))
(setq Dictionary^ (cdr (assoc 330 EntList@)))
(setq EntList@ (entget Dictionary^))
(foreach Item EntList@
(if (= (car Item) 3)
(if (not (member (cdr Item) AllGroups@))
(setq AllGroups@ (append AllGroups@ (list (cdr Item))))
);if
);if
);foreach
(setq SS& (ssget "_X"))
(setq Cnt# 0)
(repeat (sslength SS&)
(setq EntList@ (entget (ssname SS& Cnt#)))
(if (= (cdr (assoc 102 EntList@)) "{ACAD_REACTORS")
(if (setq Dictionary^ (cdr (assoc 330 EntList@)))
(setq Previous$ "")
(setq Item (cdr Item))
(if (equal Item Group^)
(setq GroupName$ Previous$)
);if
(setq Previous$ Item)
);foreach
(if (not (member GroupName$ UsedGroups@))
(setq UsedGroups@ (append UsedGroups@ (list GroupName$)))
);if
);progn
);if
);progn
);if
);repeat
(foreach GroupName$ AllGroups@
(command "_-GROUP" "_E" GroupName$)
);if
);foreach
(command "_-GROUP" "_E" FirstGroup$)
(command "_ERASE" EntFirst^ "")
);defun PurgeGroups
; Remove_nths - Removes the RemoveList@ of nths from a list.
; Arguments: 2
; RemoveList@ = List of nths to remove
; OldList@ = List to remove the list of nths from
; Returns: A list with the list of nths removed.
(defun Remove_nths (RemoveList@ OldList@)
(if (and RemoveList@ OldList@)
(if (zerop (car RemoveList@))
(Remove_nths (mapcar '1- (cdr RemoveList@)) (cdr OldList@))
(cons (car OldList@) (Remove_nths (mapcar '1- RemoveList@) (cdr OldList@)))
);if
OldList@
);if
);defun Remove_nths
; rtd - Radians to degrees
; Arguments: 1
; Rad~ = radians
; Syntax: (rtd R)
; Returns: value in degrees.
(defun rtd (Rad~)
(* 180.0 (/ Rad~ pi))
);defun rtd
; Speed - Determines the computer processing speed and sets the global variable
; *speed# which may be used in delay loops.
(defun Speed (/ Cdate~ Cnt# NewSecond# OldSecond#)
(setq Cdate~ (getvar "CDATE"))
(setq NewSecond# (fix (* (- (* (- Cdate~ (fix Cdate~)) 100000)(fix (* (- Cdate~ (fix Cdate~)) 100000))) 10)))
(repeat 2
(setq Cnt# 0)
(setq OldSecond# NewSecond#)
(while (= NewSecond# OldSecond#)
);while
);repeat
(setq *Speed# Cnt#)
);defun Speed
; StarBurst - Draws a starburst shape
; Arguments: 5
; CenPt = Center of starburst
; Dia1~ = Inside diameter
; Dia2~ = Outside diameter
; Sides# = Number of points
; StartAng~ = Radian angle of first point
; Returns: Draws a starburst shape
(defun StarBurst (CenPt Dia1~ Dia2~ Sides# StartAng~ / Ang~ Ang1~ List@ List1@
List2@ List3@ Cnt1# Cnt2# Pt)
(setq Ang~ (/ pi Sides#))
(setq Ang1~ (+ StartAng~ (/ Ang~ 2.0)))
(repeat (* Sides# 2)
(setq Pt (polar CenPt Ang1~ (/ Dia1~ 2.0)))
(setq List1@ (append List1@ (list Pt)))
(setq Ang1~ (+ Ang1~ Ang~))
);repeat
(setq Ang1~ (+ StartAng~ Ang~))
(repeat Sides#
(setq Pt (polar CenPt Ang1~ (/ (+ Dia1~ Dia2~) 4.0)))
(setq List2@ (append List2@ (list Pt)))
(setq Ang1~ (+ Ang1~ (* Ang~ 2)))
);repeat
(setq Ang1~ StartAng~)
(repeat Sides#
(setq Pt (polar CenPt Ang1~ (/ Dia2~ 2.0)))
(setq List3@ (append List3@ (list Pt)))
);repeat
(setq Cnt1# 0 Cnt2# 0)
(repeat Sides#
(setq List@ (append List@ (list (nth Cnt1# List3@))))
(setq List@ (append List@ (list (nth Cnt2# List1@))))
(setq Cnt2# (1+ Cnt2#))
(setq List@ (append List@ (list (nth Cnt1# List2@))))
(setq Cnt1# (1+ Cnt1#))
);repeat
(setq List@ (append List@ (list (nth 0 List3@))))
(command "_PLINE" (foreach Pt List@ (command Pt)))
);defun StarBurst
; Switch_nth - Switches the nth Num1# and Num2# item values in a list.
; Arguments: 3
; Num1# = nth number in list to switch with nth Num2#
; Num2# = nth number in list to switch with nth Num1#
; OldList@ = List to switch item values
; Returns: A list with two item values switched.
(defun Switch_nth (Num1# Num2# OldList@ / Index#)
(setq Index# -1)
(if (and (< -1 Num1# (length OldList@)) (< -1 Num2# (length OldList@)))
(mapcar '(lambda (x) (setq Index# (1+ Index#))
((= Index# Num2#) (nth Num1# OldList@))
((= Index# Num1#) (nth Num2# OldList@))
(x)
)) OldList@
);mapcar
OldList@
);if
);defun Switch_nth
; tan - Tangent of radian degrees
; Arguments: 1
; radians = Radian degrees
; Returns: Tangent of radian degrees
(defun tan (radians)
(/ (sin radians) (cos radians))
);defun tan
; UniqueName - Creates a unique name for temp blocks and groups
(defun UniqueName (/ Loop Name$)
(setq Loop t)
(while Loop
(setq Name$ (rtos (getvar "CDATE") 2 8))
(setq Name$ (strcat (substr Name$ 4 5)(substr Name$ 10 8)))
(if (/= Name$ *UniqueName$)
(setq *UniqueName$ Name$ Loop nil)
);if
);while
*UniqueName$
);defun UniqueName
; ViewExtents
; Returns: List of upper left and lower right points of current view
(defun ViewExtents (/ A B C D X)
(setq B (getvar "VIEWSIZE")
A (* B (/ (car (getvar "SCREENSIZE")) (cadr (getvar "SCREENSIZE"))))
X (trans (getvar "VIEWCTR") 1 2)
C (trans (list (- (car X) (/ A 2.0)) (+ (cadr X) (/ B 2.0))) 2 1)
D (trans (list (+ (car X) (/ A 2.0)) (- (cadr X) (/ B 2.0))) 2 1)
);setq
(list C D)
);defun ViewExtents
Anh em chơi thư nghe
#2 pikeman286
pikeman286
    biết dimdiameter
  • 337 Bài viết
Điểm đánh giá: 244 (khá)
Đã gửi 01 September 2008 - 03:12 PM
Cái này chơi thế nào ấy nhỉ?
#3 ghost8.3
ghost8.3
    biết dimdiameter
  • 335 Bài viết
Điểm đánh giá: 162 (tàm tạm)
Đã gửi 01 September 2008 - 03:18 PM
Có ai chơi thử chưa? Hướng dẫn sơ bộ thử xem. :lol:
#4 MANHHUNGXDA
MANHHUNGXDA
  • 926 Bài viết
Điểm đánh giá: 458 (tốt)
Đã gửi 01 September 2008 - 03:45 PM
LENH LÀ TROY
BẮN PHÁ LUNG TUNG BEN LÊN
Hãy ước cho trọn 1 ước mơ!
#5 Nguyen Hoanh
  • 4106 Bài viết
Đã gửi 01 September 2008 - 03:53 PM
Mình chưa chơi, nhưng mình biết email gốc là terrycadd@yahoo.com chứ không phải là tuanngph@hpc.org.vn.
Nhân tiện cũng giới thiệu với mọi người về tác giả terrycadd, mọi người vào trang web của ông ta để xem thêm, nhiều thứ khá thú vị: http://web2.airmail.net/terrycad
#6 ghost8.3
ghost8.3
    biết dimdiameter
  • 335 Bài viết
Đã gửi 01 September 2008 - 03:56 PM
Bắn phá lung tung mỗi lần di chuyển chuột, nhưng chả có hành tinh nào bị bể hết
:lol:
#7 ph168xd
ph168xd
  • 779 Bài viết
Điểm đánh giá: 309 (khá)
Đã gửi 01 September 2008 - 04:17 PM
:lol:
Em vào chơi thử rùi, giám đốc nhìn thấy khoái lém, cho cả công ty ngồi chơi luôn
#8 duongsatdn
duongsatdn
  • 1657 Bài viết
Điểm đánh giá: 761 (tốt)
Đã gửi 01 September 2008 - 04:18 PM
Vụ này có phải là "Bắt giò truyện ngắn" ở báo Mực tím không nhẩy(?!)
#9 MANHHUNGXDA
MANHHUNGXDA
  • 926 Bài viết
Đã gửi 01 September 2008 - 04:29 PM
cHƠI THÌ CHƠI, XONG RỒI NẾU MÀ CẢM THẤY CÁI LISP NÀY HAY THÌ ẤN NÚT THANK NHÉ
http://www.cadviet.c...files/LAYER.lsp
LỆNH LÀ ELA enter
gõ troy
#10 MANHHUNGXDA
MANHHUNGXDA
  • 926 Bài viết
Đã gửi 01 September 2008 - 04:30 PM
bác duongsat chỉ đưọc cái thâm thuý
#11 duy782006
  • 2156 Bài viết
Điểm đánh giá: 1360 (rất tốt)
Đã gửi 01 September 2008 - 04:34 PM
Trước đây có bạn nào đó đã dưa lên rồi. Nhiều lắm chứ không phải nhiêu đâu. Chơi cũng được nhưng hể mình sửa qua tiếng việt là nó hông chạy nửa. dài quá nên không dò ra là nó kiểm tra chổ nào nửa.
#12 ph168xd
ph168xd
  • 779 Bài viết
Đã gửi 01 September 2008 - 04:37 PM
LỆNH LÀ ELA enter
gõ troy
KO hiểu lish cảu Bác nên chưa thấy hay nên chưa cám ơn đc :lol:
Bác giải thích đi
#13 MANHHUNGXDA
MANHHUNGXDA
  • 926 Bài viết
Đã gửi 01 September 2008 - 04:40 PM
Bác giải thích đi
CHưa chơi à?
KHi đang vẽ 1 bản vẽ mà bạn chơi trò này thi khi chơi xong, các đối tượng vẫn còn hiện thì đè lện bản vẽ
LỆnh kia giúp xoá đối twợng có layer TROY
đến lưọt bạn rồi đó, ..............
#14 pikeman286
pikeman286
    biết dimdiameter
  • 337 Bài viết
Đã gửi 01 September 2008 - 04:54 PM
CHưa chơi à?
Thôi cả nhà cứ đợi bác Phamtuan. Vì bác ấy là "create By....mà" . Không có cái phím nào có thể cho nó bắn cả.Mà em cũng chẳng biết cái phím nào để thoát game. Toàn dùng Task Manage. Chuối thế.
#15 vndesperados
vndesperados
    biết lệnh xref
  • 547 Bài viết
Điểm đánh giá: 253 (khá)
Đã gửi 01 September 2008 - 05:04 PM
Game này có gì hay hơn so với các game đang có trên thị trường không?
#16 MANHHUNGXDA
MANHHUNGXDA
  • 926 Bài viết
Đã gửi 01 September 2008 - 05:07 PM
cốt là nó chơi trên cad, lỡ xếp có nhìn thấy cũng.......
(như kiểu là rửa tiền ấy bác..)
#17 ghost8.3
ghost8.3
    biết dimdiameter
  • 335 Bài viết
Click chuột ngay mũi tên là nó bắn ra 1 viên đạn mảnh tật mảnh, trúng hành tinh náo là nó nổ và ăn điểm. Nếu không chơi nữa thì ESC
:lol:
#18 phamtuan
phamtuan
    biết lệnh scale
  • 145 Bài viết
Đã gửi 02 September 2008 - 09:14 PM
Kaka, mở quan kinh doanh game đc rồi, tôi chỉ dày công sưu tập trên mạng rồi chia sẽ cho anh em thôi. Có cần bới móc như vậy không.
Còn khá nhiều game trên cad anh em xem nếu cần cứ PM tôi, keke, vui rồi
#19 vanduong
vanduong
  • Validating
  • 1383 Bài viết
Điểm đánh giá: 536 (tốt)
Đã gửi 03 September 2008 - 10:03 AM
he hé
Hùng ơi
ở cơ quan tớ
quýnh Game online thỏa mái-sếp còn quýnh hơn cả mình nữa
he hé
ờ mà cái Game này ai cải tiến bắn đạn nhiều nhiều tý - chứ thế này chả gọi là xả Sờ trét tý nào cả :lol:
#20 ghost8.3
ghost8.3
    biết dimdiameter
  • 335 Bài viết
Đã gửi 03 September 2008 - 11:22 AM
he hé
Hùng ơi
ở cơ quan tớ
he hé
vanduong chơi game online gì thế? volam, ongame, hay cái gì. Nêúa chơi volam thì dụng hàng rồi. keke :lol:
