Không cài đươc cad 2007 xin giúp đỡ....
#1 sinhviengtvt
sinhviengtvt
Đã gửi 28 December 2012 - 03:32 PM
File autocad setup txt của e báo là như sau
2012/12/28:15:07:03 Admin MRPHONG === Installation started on MRPHONG by Admin ===
2012/12/28:15:07:18 Admin MRPHONG Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 4.5.6001.22159
2012/12/28:15:07:18 Admin MRPHONG Install .NET Framework Runtime 2.0 Skipped .NET Framework Runtime upgrade is not required. System Version = 2.0.50727.0
2012/12/28:15:07:18 Admin MRPHONG Install .NET Framework Runtime 2.0 Language Pack Skipped Installation not required
2012/12/28:15:07:20 Admin MRPHONG Install DirectX 9.0 Runtime Succeeded Command = "D:\Vu Truong Xuan\SOFTPhanMem on Kythuat\AutoCAD 2007\viet4room.com_cad 2007\cad 2007\Bin\AcadFEUI\support\DirectX\DXSETUP.exe" /silent
2012/12/28:15:07:20 Admin MRPHONG Install MDAC 2.7 Skipped MDAC upgrade is not required. System Version = 2.81.1132.0
2012/12/28:15:07:24 Admin MRPHONG Install Autodesk DWF Viewer Failed Failure is ignored, Result=5
2012/12/28:15:07:25 Admin MRPHONG Install Flash Failed Failure is ignored, Result=1
2012/12/28:15:09:31 Admin MRPHONG Install AutoCAD 2007 Failed Installation aborted, Result=1603
2012/12/28:15:09:31 Admin MRPHONG === Installation ended ===
Còn hình ảnh
#2 sinhviengtvt
sinhviengtvt
Đã gửi 28 December 2012 - 03:41 PM
uppppppppppppppppppp
#3 hantinh
hantinh
    biết lệnh attdef
  • 417 Bài viết
Điểm đánh giá: 45 (tàm tạm)
Đã gửi 28 December 2012 - 05:58 PM
phía trên nó thông báo cho bạn rất rõ rồi mà.
ở cái dòng cuối ấy: 2012/12/28:15:07:24 Admin MRPHONG Install Autodesk DWF Viewer Failed Failure is ignored, Result=5
2012/12/28:15:09:31 Admin MRPHONG Install AutoCAD 2007 Failed Installation aborted, Result=1603.
bạn cài lại mấy thằng mình bôi đỏ là được
