Nhờ các pro sửa lỗi Lisp giúp
21 replies to this topic
#21 phamthanhbinh
Đã gửi 12 July 2014 - 01:14 AM
xin lỗi bác bình. cosd đậy a. trăm sự nhờ bác.
https://mail.google....=f_hxfy4of80
(Defun c:T6() (setvar "dimtxt" 2.5); cheu cao text
(setvar "dimdli" 2.8) ; k/c kich thuoc //
(setvar "dimasz" 1.2); do lon mui ten
(setvar "dimclre" 82) ; mau duong dong kich thuoc
(setvar "dimclrt" 82) ; mau text
(setvar "dimclrd" 82);  mau duong kich thuoc
(setvar "dimtad" 0)
(setvar "dimzin" 8)
(vl-cmdf "ucs" "W")
(vl-cmdf "LTSCALE" "3")
(vl-cmdf "undo" "be")
(setq a (getpoint "\n xin chao! day la chuong trinh ve truc trong co khi. Duoc viet boi <<nguyenbd159@Gmail.com>>. hay nhap diem dau tien cua doan truc: "))
(setq b (getpoint a"\n VUI LONG NHAP CHIEU DAI DOAN TRUC : "))
(vl-cmdf ".line" a b "")
(if (= droffld nil)
(setq droffld1 2.00)
(setq droffld1 droffld)
droffld (GETREAL (strcat "\nVUI LONG NHAP DUONG KINH TRUC. SAU DO CHON DOAN THANG VUA VE TREN DESTOP : <" (rtos droffld1 2 2) ">"))
(if (= droffld nil)
(setq droffld droffld1)
(if (= droffled nil)
(setq droffled1 2.00)
(setq droffled1 droffled)
(setq droffled droffled1)
(setq offlong (/ droffld 2))
(setq offle (+ offlong droffled))
(setq SS (ssget (list (cons 0 "arc,ellipse,lwpolyline,spline,line,circle"))))
(setq i 0)
(setq N (sslength ss))
(while (< i N)
(setq TEXTENT (ssname SS i))
(setq diemchuan (vlax-curve-getPointAtDist TEXTENT 0))
(setq diemdinhhuong (vlax-curve-getPointAtDist TEXTENT 0.01))
(setq goc (angle diemchuan diemdinhhuong))
(setq diembentrai (polar diemchuan (- goc (/ pi 2)) offle))
(setq diembenphai (polar diemchuan (+ goc (/ pi 2)) offle))
(vl-cmdf ".offset" offlong textent diembentrai "")
(vl-cmdf ".offset" offlong textent diembenphai "")
(vl-cmdf "CHANGE" "P" "" "Properties"  "Color"  "10" "" )
(vl-cmdf "CHANGE" "P" "" "Properties"  "lt"  "center" "" )
(setvar "osmode" luubatdiem)
(vl-cmdf "undo" "end")
(setvar "osmode" 15359)
(command "line" diembentrai diembenphai"")
(command "CIRCLE" "0,0" offlong "")
(command  "dimlinear" pause PAUSE "T" "%%C<>" pause "" "*Cancel*" " *Cancel*")
(vl-cmdf "ucs" "M"  PAUSE )
(vl-cmdf "qdim"  )
(setvar "dimtad" 0)
(setvar "dimzin" 8)
(vl-cmdf "ucs" "W")
(if (= droffld nil)
(if (= droffld nil)
(setq i 0)
(while (< i N)
(vl-cmdf "qdim"  )
(setvar "dimtad" 0)
(setvar "dimzin" 8)
(vl-cmdf "ucs" "W")
(if (= droffld nil)
(if (= droffld nil)
(setq i 0)
(while (< i N)
(vl-cmdf "qdim"  )
(setvar "dimtad" 0)
(setvar "dimzin" 8)
(vl-cmdf "ucs" "W")
(if (= droffld nil)
(if (= droffld nil)
(setq i 0)
(while (< i N)
(vl-cmdf "qdim"  )
(setvar "dimtad" 0)
(setvar "dimzin" 8)
(vl-cmdf "ucs" "W")
(if (= droffld nil)
(if (= droffld nil)
(setq i 0)
(while (< i N)
(vl-cmdf "qdim"  )
Code của bạn vẽ thừa là do thằng offle đó. Bạn có thể thay thằng này trong hai dòng code :
bằng thằng oflong thì sẽ hết bị thừa.
Tuy nhiên code của bạn viết khá lủng củng và còn nhiều điều cần xem lại do cách nghĩ của bạn còn khá đơn giản.
Nếu bạn rảnh và có thời gian thì trao đổi qua yahoo mình sẽ nói rõ hơn.
#22 nguyenbd1
nguyenbd1
    biết lệnh text
  • 276 Bài viết
Điểm đánh giá: 13 (tàm tạm)
Đã gửi 12 July 2014 - 06:11 PM
hay quá bác bình ơi. cảm ơn bác.. thật sự em còn gà con lắm bác à
