ketxu 3020 Báo cáo bài đăng Đã đăng Tháng 6 14, 2011 Base.dcl là Dialog cơ sở của CAD, không hiểu tại sao lại không thấy trong Express (máy em) ^^. Bác Bình cũng thấy thế thì xơi tạm code của nó và cho vào support nè : (tên file Base.dcl ) // Next available MSG number is 15 // MODULE_ID BASE_DCL_ /* Next available MSG number is 24 */ // BASE.DCL Version 1.1 // // Copyright 1991-1994,1996-1997 by Autodesk, Inc. // // Permission to use, copy, modify, and distribute this software // for any purpose and without fee is hereby granted, provided // that the above copyright notice appears in all copies and // that both that copyright notice and the limited warranty and // restricted rights notice below appear in all supporting // documentation. // // AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. // AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF // MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. // DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE // UNINTERRUPTED OR ERROR FREE. // // Use, duplication, or disclosure by the U.S. Government is subject to // restrictions set forth in FAR 52.227-19 (Commercial Computer // Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii) // (Rights in Technical Data and Computer Software), as applicable. // //. // // Define common prototypes and subassemblies for use by // ACAD.DCL and user-defined dialogs (AutoCAD), and by // ACLT.DCL (AutoCAD LT). // (The primitive widgets are set up automatically by init_dialog. The // equivalent DCL is shown here (commented out) for reference.) // dialog { // layout = vertical; // is_enabled = false; // } // // cluster { // layout = horizontal; // } // // radio_cluster { // layout = horizontal; // is_enabled = true; // } // // tile { // layout = horizontal; // is_enabled = true; // } // // text : tile { // fixed_height = true; // inhibit vertical expansion // } // // image : tile { // } // // button : tile { // fixed_height = true; // is_tab_stop = true; // } // // image_button : button { // is_tab_stop = true; // } // // toggle : tile { // fixed_height = true; // is_tab_stop = true; // } // // radio_button : tile { // fixed_height = true; // is_tab_stop = true; // } // // list_box : tile { // is_tab_stop = true; // height = 10; // width = 10; // } // // edit_box : tile { // fixed_height = true; // is_tab_stop = true; // } // // popup_list : tile { // is_tab_stop = true; // fixed_height = true; // } // // slider : tile { // is_tab_stop = true; // } // // spacer : tile { // } //----- Styles of clusters. row : cluster { horizontal_margin = none; vertical_margin = none; children_alignment = centered; } column : cluster { layout = vertical; horizontal_margin = none; vertical_margin = none; } boxed_row : cluster { label = " "; boxed = true; children_alignment = centered; } boxed_column : cluster { layout = vertical; label = " "; boxed = true; } //----- Styles of radio clusters. radio_row : radio_cluster { horizontal_margin = none; vertical_margin = none; children_alignment = centered; } radio_column : radio_cluster { layout = vertical; horizontal_margin = none; vertical_margin = none; } boxed_radio_row : radio_cluster { label = " "; boxed = true; children_alignment = centered; } boxed_radio_column : radio_cluster { layout = vertical; label = " "; boxed = true; } //----- Horizontal and vertical blocks of running text. concatenation : cluster { fixed_width = true; fixed_height = true; children_alignment = centered; } paragraph : cluster { layout = vertical; fixed_height = true; } text_part : text { horizontal_margin = none; vertical_margin = none; } text_25 : text { width = 25; } //----- Common spacers. spacer_0 : spacer { height = 0; width = 0; horizontal_margin = none; vertical_margin = none; } spacer_1 : spacer { height = 1; width = 1; horizontal_margin = none; vertical_margin = none; } //----- The normal default widget. default_button : button { is_default = true; } //----- Standard prototype for making consistent "dialog retirement buttons". // Used below for the predefined retirement buttons, and for user-defined // dialogs that need retirement buttons with specialized verbs. retirement_button : button { fixed_width = true; width = 8; alignment = centered; } //----- Standard dialog retirement buttons. Unless one is building a dialog // retirement subassembly containing specialized verbs, these will // normally not be used directly by DCL code outside of base.dcl; use // the pre-built subassemblies in the next section. ok_button : retirement_button { label = " OK "; key = "accept"; is_default = true; } cancel_button : retirement_button { label = "Cancel"; key = "cancel"; is_cancel = true; } help_button : retirement_button { label = "&Help"; key = "help"; is_help = true; } info_button : retirement_button { label = "&Info..."; key = "info"; } //----- Pre-built arrays of dialog bottom-line buttons. ok_only : column { fixed_width = true; alignment = centered; : ok_button { is_cancel = true; } } ok_cancel : column { : row { fixed_width = true; alignment = centered; ok_button; : spacer { width = 2; } cancel_button; } } ok_cancel_help : column { : row { fixed_width = true; alignment = centered; ok_button; : spacer { width = 2; } cancel_button; : spacer { width = 2; } help_button; } } ok_cancel_help_info : column { : row { fixed_width = true; alignment = centered; ok_button; : spacer { width = 2; } cancel_button; : spacer { width = 2; } help_button; : spacer { width = 2; } info_button; } } //----- Error reporting tiles. errtile : text { label = ""; key = "error"; width = 35; // must be long enough to hold error msgs is_error_tile = true; } // A custer consisting of OK, Cancel, and Help on one line with the error tile // below. ok_cancel_help_errtile : column { ok_cancel_help; errtile; } // The same thing without the Help button for subdialogues that have no help // available. ok_cancel_err : column { ok_cancel; errtile; } //----- Currently, the only dcl setting is the audit_level which controls the // level of semantic error checking applied during a load_dialog operation. // (0 = none, 1 = errors, 2 = warnings, 3 = hints) // See AutoCAD's README for details. default_dcl_settings : tile { audit_level = 1; } //----- Miscellaneous parts used by ACAD.DCL (AutoCAD) & ACLT.DCL (AutoCAD LT). image_block : image { key = "show_image"; height = 1; width = 1; } icon_image : image_button { color = 0; width = 12; aspect_ratio = 0.66; allow_accept = true; fixed_height = true; fixed_width = true; } edit12_box : edit_box { edit_width = 12; edit_limit = 148; // 18 * 8 (CIF/MIF size) } edit32_box : edit_box { edit_width = 32; edit_limit = 2048; // MAX_VALUE (256 * 8 (CIF/MIF size)) } // The following are for the color-selection dialogs swatch : image_button { vertical_margin = none; horizontal_margin = none; fixed_height = true; fixed_width = true; height = 1.5; width = 3; allow_accept = true; } color_palette_1_7 : row { // Standard colors 1-7 : swatch { color = 001; key = "001"; } : swatch { color = 002; key = "002"; } : swatch { color = 003; key = "003"; } : swatch { color = 004; key = "004"; } : swatch { color = 005; key = "005"; } : swatch { color = 006; key = "006"; } : swatch { color = 007; key = "007"; } } color_palette_1_9 : row { // Standard colors, plus 8 and 9 color_palette_1_7; : swatch { color = 008; key = "008"; } : swatch { color = 009; key = "009"; } } color_palette_0_9 : row { // Standard colors, plus 0, 8, and 9 : swatch { color = 000; key = "000"; } color_palette_1_9; } color_palette_250_255 : row { // Grey shades 250-255 : swatch { color = 250; key = "250"; } : swatch { color = 251; key = "251"; } : swatch { color = 252; key = "252"; } : swatch { color = 253; key = "253"; } : swatch { color = 254; key = "254"; } : swatch { color = 255; key = "255"; } } std_rq_color :column{ :column { :boxed_row { fixed_width = true; label = "Standard Colors"; color_palette_1_9; } :row { :boxed_row { fixed_width = true; label = "Gray Shades"; color_palette_250_255; } :boxed_row { fixed_width = true; label = "Logical Colors"; :button { label = "BY&LAYER"; key = "256"; } :button { label = "BY&BLOCK"; key = "000"; } } } } :boxed_column { label = "Full Color Palette"; :image_button{ key = "hiside"; alignment = centered; width = 40; height = 4; allow_accept = true; is_enabled = false; } :image_button{ alignment = centered; key = "loside"; width = 40; height = 4; allow_accept = true; is_enabled = false; } } :row { fixed_width = true; alignment = centered; children_alignment = bottom; :edit12_box { label = "Color:"; key = "color_edit"; allow_accept = true; } :swatch { key = "color_image"; } } ok_cancel_help_errtile; } // The preceding are for color-selection dialogs // Top and bottom sub-assemblies for the files dialogue files_topdf : column { : edit_box { key = "pedit"; label = "&Pattern:"; edit_width = 35; } : row { : text { label = "Directory:"; } : text { key = "dirtext"; width = 35; } } } files_bottomdf : column { : edit_box { key = "fedit"; label = "&File:"; allow_accept = true; } ok_cancel; errtile; } fcf_ibut : image_button { horizontal_margin = none; width = 3.5; height = 1.2; color = 0; alignment = bottom; } fcf_ebox : edit_box { horizontal_margin = none; edit_width = 7; fixed_width = true; alignment = bottom; } fcf_ebox1 : edit_box { horizontal_margin = none; edit_width = 3; edit_limit = 3; fixed_width = true; alignment = bottom; } fcf_ibut1 : image_button { width = 5.0; aspect_ratio = 0.66; color = 0; allow_accept = true; } Base.dcl là Dialog cơ sở của CAD, không hiểu tại sao lại không thấy trong Express (máy em) ^^. Bác Bình cũng thấy thế thì xơi tạm code của nó và cho vào support nè : (tên file Base.dcl ) Thằng này nhiều khi nó nằm sâu thăm thẳm bác Ketxu ạ! Chẳng hạn: c:\Documents and Settings\vanha.DTVKSTKMT\Application Data\Autodesk\AutoCAD 2007\R17.0\enu\Support\base.dcl c:\Program Files\AutoCAD 2007\UserDataCache\Support\base.dcl Thằng này nhiều khi nó nằm sâu thăm thẳm bác Ketxu ạ! Chẳng hạn: c:\Documents and Settings\vanha.DTVKSTKMT\Application Data\Autodesk\AutoCAD 2007\R17.0\enu\Support\base.dcl c:\Program Files\AutoCAD 2007\UserDataCache\Support\base.dcl CHính xác là mình phải lấy code này cho bác Bình từ khu vực dành cho Thùng rác của ổ .... D D:\$RECYCLE.BIN\S-1-5-21-4002689898-964897584-2226308410-1002\$RXX19GM\CAD2008\en-us\Acad\Program Files\Root\UserDataCache\Support Thật là phi thường :) CHính xác là mình phải lấy code này cho bác Bình từ khu vực dành cho Thùng rác của ổ .... D Thật là phi thường :) DVH : Ủa, không có nó sao Cad chạy được? Thế mềnh mới dùng từ Phi thường ^^ Xin phép hợp nhất bài lại cho đỡ loãng topic Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
3d.decor 1 Báo cáo bài đăng Đã đăng Tháng 6 15, 2011 pro nào rảnh viết hộ lisp dọn mặt bằng để chuyển sang 3d EXTRUDE hộ mình được không bao gồm dùng lệnh OVERKILL nối và tẩy tất cả line trùng nhau nối tất các line hở kể cả line song song ( nối hai đầu hở ) nếu tẩy các nét thừa và giao nhau ( phía trong ) như lisp WALL không biết pro nào viết thì tốt ( nhưng đây là mặt bàng bên kiến trúc chuyển có tường rồi ) sau đó hàn kín lại như lệnh BOUNDARY thành một đối tượng chuyển sang 3d max EXTRUDE là OK pro nào viết được thì em rất nhàn em vẽ 3d ngày tẩy mấy cái mặt bằng rất mất công rất cảm ơn a Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
vietthang228 0 Báo cáo bài đăng Đã đăng Tháng 6 15, 2011 Tình hình là e đang rất khó khăn, nhờ các bác cho e xin 1 lisp như sau: E có 1 chuỗi các text. VD như: một hai ba bốn năm sáu (các text này nằm trong 1 văn bản word) bây giờ e muốn đưa nó vào cad mà khi chọn vị trí thứ nhất nó hiện một, chọn vị trí thứ hai nó chọn hai... E đã thử viết mà chưa được! Mong các bro giúp đỡ e! Địa chỉ email của e: vietthang228@gmail.com hoặc bác nào có thời gian xin chỉ giáo qua yahô: vthangpecc1 E xin chân thành cảm ơn các bác! Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
ketxu 3020 Báo cáo bài đăng Đã đăng Tháng 6 15, 2011 pro nào rảnh viết hộ lisp dọn mặt bằng để chuyển sang 3d EXTRUDE hộ mình được không bao gồm dùng lệnh OVERKILL nối và tẩy tất cả line trùng nhau nối tất các line hở kể cả line song song ( nối hai đầu hở ) nếu tẩy các nét thừa và giao nhau ( phía trong ) như lisp WALL không biết pro nào viết thì tốt ( nhưng đây là mặt bàng bên kiến trúc chuyển có tường rồi ) sau đó hàn kín lại như lệnh BOUNDARY thành một đối tượng chuyển sang 3d max EXTRUDE là OK pro nào viết được thì em rất nhàn em vẽ 3d ngày tẩy mấy cái mặt bằng rất mất công rất cảm ơn a Có những thứ máy móc không làm thay con người được bạn ạ :) Tình hình là e đang rất khó khăn, nhờ các bác cho e xin 1 lisp như sau: E có 1 chuỗi các text. VD như: một hai ba bốn năm sáu (các text này nằm trong 1 văn bản word) bây giờ e muốn đưa nó vào cad mà khi chọn vị trí thứ nhất nó hiện một, chọn vị trí thứ hai nó chọn hai... E đã thử viết mà chưa được! Mong các bro giúp đỡ e! Địa chỉ email của e: vietthang228@gmail.com hoặc bác nào có thời gian xin chỉ giáo qua yahô: vthangpecc1 E xin chân thành cảm ơn các bác! Với những thông tin bạn đưa ra thì .. gần như vô vọng :) Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
traitimsat034 15 Báo cáo bài đăng Đã đăng Tháng 6 15, 2011 Bạn sửa lại 1 tí như vầy :) Brgs (defun c:rtt(/ ss sst) (setq ss (ssadd)) (while (or (= (setq sst (acet-list-to-ss (vl-remove-if '(lambda(x) (null (wcmatch (acet-dxf 0 (entget x)) "*TEXT"))) (acet-ss-to-list ss)))) nil) (>(sslength sst) 1)) (Prompt "\nXin h\U+00E3y ch\U+1ECDn \U+0111\U+1ED1i t\U+01B0\U+1EE3ng :") (setq ss (ssget)) ) (command ".rotate" ss "" (acet-dxf 10 (entget(ssname sst 0))) (* 180.0 (/ (getangle "\nG\U+00F3c quay :") pi))) ) Bác KETXU ơi làm ơn sửa lisp này giúp mình với. sau một thời gian sử dụng thì mình thấy hơi bất tiện nên đành phải nhờ bạn lần nữa. vấn đề là khi text của mình hợp với phương ngang 1 góc khác 0 thì khi sử dụng lệnh nó lại quay theo một góc không đúng theo ý mình. bạn có thể sửa sao cho phương của text là trùng với phương của 2 điểm pick. cám ơn bạn, ngại quá. Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
3d.decor 1 Báo cáo bài đăng Đã đăng Tháng 6 15, 2011 pro nào rỗi tẩy xoá hộ mình đoạn lisp ofset đường trục giữa của tường chỉ giữ lại doạn sau là trim các điểm giao nhau của tường được không lisp WALL rất cám ơn ạ (defun c:wall () (command "trim" "" "e" "e" "p" "n" "") (command "undo" "be") (setvar "cmdecho" 0) (setq old_layer (getvar "clayer")) (setq snap (getvar "osmode")) (setq hl (getvar "highlight")) (setq tbl (tblsearch "layer" "center")) (if (= tbl nil) (command "-layer" "n" "center" "c" "8" "center" "")) (setq tbl (tblsearch "layer" "cut")) (if (= tbl nil) (command "-layer" "n" "cut" "c" "1" "cut" "l" "center" "cut" "")) (setq tbl (tblsearch "layer" "wall")) (if (= tbl nil) (command "-layer" "n" "wall" "")) (setvar "clayer" "wall") (setvar "osmode" 0) (setq ss (ssget '((0 . "line")))) (setq day (cond (day) (220))) (setq oldday day) (setq day (getint (strcat "\nnhap chieu day tuong <"(rtos oldday 2 1)"> : "))) (if (null day) (setq day oldday) ) (setq day1 (/ (* day 7) 15)) (command "change" ss "" "p" "la" "center" "") (setq i 0) (setq lp nil) (setq ssml nil) (setq ssml (ssadd)) (while (< i (sslength ss)) (setq name (ssname ss i) ent (entget name) p1 (cdr (assoc 10 ent)) p2 (cdr (assoc 11 ent)) lp (append (list (append (list p1) (list p2))) lp) ) (command "mline" "j" "z" "s" day p1 p2 "") (command "explode" "l") (setq ssline (ssget "p")) (setq line1 (ssname ssline 0)) (setq line2 (ssname ssline 1)) (setq ssml (ssadd line1 (ssadd line2 ssml))) (setq i (1+ i)) ) (command "-layer" "off" "center" "") (setq j 0) (setvar "highlight" 0) (while (< j (length lp)) (setq nhom (nth j lp) pt1 (car nhom) pt2 (last nhom) angf (+ (angle pt1 pt2) (/ pi 2)) t1 (polar pt1 angf day1) t2 (polar pt1 (+ angf pi) day1) t3 (polar pt2 (+ angf pi) day1) t4 (polar pt2 angf day1) ) (command "trim" ssml "" "f" t1 t2 t3 t4 t1 "" "") (setq j (1+ j)) ) (setq q 0) (setq ssml (ssget "x" '((0 . "line") (8 . "center")))) (while (< q (sslength ssml)) (setq l1 (ssname ssml q) pf1 (cdr (assoc 10 (entget l1))) pf2 (cdr (assoc 11 (entget l1))) ) (setq k 0) (while (< k (sslength ssml)) (setq l2 (ssname ssml k) pf3 (cdr (assoc 10 (entget l2))) pf4 (cdr (assoc 11 (entget l2))) d1 (distance pf1 pf3) d2 (distance pf1 pf4) d3 (distance pf2 pf3) d4 (distance pf2 pf4) ) (if (or (and (< (fix d1) (* day1 2)) (> d1 0)) (and (< (fix d2) (* day1 2)) (> d2 0)) (and (< (fix d3) (* day1 2)) (> d3 0)) (and (< (fix d4) (* day1 2)) (> d4 0))) (command "fillet" l1 l2) ) (setq k (1+ k)) ) (setq q (1+ q)) ) (command "change" ssml "" "p" "la" "center" "") (dimtuong) (setvar "clayer" old_layer) (command "-layer" "on" "wall" "") (setvar "osmode" snap) (setvar "highlight" hl) (setvar "cmdecho" 1) (command "undo" "e") (command "trim" "" "e" "n" "") ) Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
ketxu 3020 Báo cáo bài đăng Đã đăng Tháng 6 15, 2011 pro ơi có tính được từng loại hatch ko Mình không hiểu ý bạn ? Mình trả lời rất kỹ trên mỗi bài viết rồi! Chú ý bạn 3d.decor : Nếu bạn yêu cầu liên tục như thế này, sẽ khó có người giúp bạn kịp. Hãy nghĩ kỹ trước khi post 1 yêu cầu , và phải nghiêm túc với nó.Cố gắng tránh post vài bài liền nhau 1, cũng như vài yêu cầu trong 1 bài Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
ketxu 3020 Báo cáo bài đăng Đã đăng Tháng 6 16, 2011 Trên diễn đàn có 1 lisp chuyển tất cả font trong text style về font mình muốn nhưng lại không chỉnh trong mục width factor về 1,kính nhờ các bác chỉnh sửa thêm chức năng đưa width factor bằng 1 giùm e.Thanks. Bạn 790312 có thâm niên post bài rồi, mình nhắc bạn cho code vào trong thẻ code, không lại có những khi bị xóa thì thật phí :) Yêu cầu của bạn đã được giải quyết ở Đây 1 Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
3d.decor 1 Báo cáo bài đăng Đã đăng Tháng 6 16, 2011 bác nào viết hộ lisp này với link: http://www.cadviet.com/forum/index.php?showtopic=507 nọi dung Command: pe PEDIT Select polyline or [Multiple]: m Select objects: Specify opposite corner: 11 found Select objects: Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: j Join Type = Extend Enter fuzz distance or [Jointype] <8.0270>: 5.0 10 segments added to polyline Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: viết cho dễ sử dụng gõ lệnh seleck go kich thuoc noi line ok rất cảm ơn không có bác nào chịu khó tấy lisp wall bỏ lisp offset chỉ giữ lại trim hộ mình sao Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
ketxu 3020 Báo cáo bài đăng Đã đăng Tháng 6 16, 2011 bác nào viết hộ lisp này với link: http://www.cadviet.com/forum/index.php?showtopic=507 nọi dung Command: pe PEDIT Select polyline or [Multiple]: m Select objects: Specify opposite corner: 11 found Select objects: Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: j Join Type = Extend Enter fuzz distance or [Jointype] <8.0270>: 5.0 10 segments added to polyline Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: viết cho dễ sử dụng gõ lệnh seleck go kich thuoc noi line ok rất cảm ơn không có bác nào chịu khó tấy lisp wall bỏ lisp offset chỉ giữ lại trim hộ mình sao Những dòng không phải code mà là trích lại từ command bạn cho vào Quote cho đẹp bài viết. không có bác nào chịu khó tấy lisp wall bỏ lisp offset chỉ giữ lại trim hộ mình sao là những câu nói tối nghĩa, mong bạn tôn trọng người đọc một chút :)Còn yêu cầu trên của bạn, bạn ngó qua Bài này , bạn đọc những dòng sau chữ command và liên hệ với các thao tác thủ công của bạn, bạn sẽ tìm thấy điểm tương đồng, từ đó có thể chủ động chỉnh sửa theo ý mình. Mình không nghĩ nó quá khó, hơn nữa, tốt nhất là nên biết mình dùng cái gì bạn à. Phong cách post bài của bạn khiến liên tưởng đến mem leejang, dạo này ít thấy xuất hiện :rolleyes: Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
hugo007 1 Báo cáo bài đăng Đã đăng Tháng 6 16, 2011 Đây là đoạn lisp chuyển text về text style doifont,nhờ các bác thêm chức năng cho chuyển thêm mtext giùm e.Thanks. (defun c:ET () (command "undo" "be") (command "-style" "doifont" ".VnHelvetInsH Medium" "0" "1" "0" "n" "n") (prompt "\nChon chu muon chinh.") (setq ss (ssget)) (setq c 0) (if ss (setq e (ssname ss c))) (while e (setq e (entget e)) (if (= (cdr (assoc 0 e)) "TEXT") (progn (setq txt "doifont") (setq e (subst (cons 7 txt) (assoc 7 e) e)) (entmod e) ) ) (setq c (1+ c)) (setq e (ssname ss c)) ) (command "undo" "end") (Princ) ) Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
hugo007 1 Báo cáo bài đăng Đã đăng Tháng 6 17, 2011 Đây là đoạn lisp chuyển text về text style doifont,nhờ các bác thêm chức năng cho chuyển thêm mtext giùm e.Thanks. (defun c:ET () (command "undo" "be") (command "-style" "doifont" ".VnHelvetInsH Medium" "0" "1" "0" "n" "n") (prompt "\nChon chu muon chinh.") (setq ss (ssget)) (setq c 0) (if ss (setq e (ssname ss c))) (while e (setq e (entget e)) (if (= (cdr (assoc 0 e)) "TEXT") (progn (setq txt "doifont") (setq e (subst (cons 7 txt) (assoc 7 e) e)) (entmod e) ) ) (setq c (1+ c)) (setq e (ssname ss c)) ) (command "undo" "end") (Princ) ) Không bác nào giúp được e sao?Mong các bác giúp giùm e với.Thanks. Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
lenhatanh 2 Báo cáo bài đăng Đã đăng Tháng 6 17, 2011 Em nhờ các Bác sửa cho em đoạn lisp sau: - Nhập liên tục các điểm thuộc mặt cắt ngang trên bình đồ. - Nhập liên tục các điểm cao độ... - Nhập liên tục khoảng cách giữa các điểm cao độ... - Làm hiện thứ tự số điểm cao độ trên Listbox "TT", hiện trị số cao độ, khoảng cách trên Listbox "CD" "KC" của Hộp thoại... (Hiện thông số vừa nhập lên Listbox). Em xin cảm ơn trước ! (defun Get_tt (/ g:tt) (set_tile "error" "") (setq g:tt (get_tile "tt")) (setq tt g:tt) ) ;------------------------------------------ (defun Get_cd (/ g:cd) (set_tile "error" "") (setq g:cd (get_tile "cd")) (setq cd g:cd) ) ;------------------------------------------ (defun Get_kc (/ g:kc) (set_tile "error" "") (setq g:kc (get_tile "kc")) (setq kc g:kc) ) ;------------------------------------------ (defun Get_li() (start_list "tt" 3) (foreach ch1 ltt (add_list ch1)) (end_list) (start_list "cd") (foreach ch2 lcd (add_list (rtos ch2 2 2))) (end_list) (start_list "kc") (foreach ch3 lkc (add_list (rtos ch3 2 2))) (end_list) (mode_tile "start" 0) (start_dialog) ) ;---------------------------------------------------------------------------------------------------------- (defun nhapdiem (/ di ki tlb tim tti) (setq ldi '() lcd '() lkc '() ltt '() tti 1) (setq tlb (getreal "\n Tile Cua Binh Do: ")) (setq tim (getreal "\n Khoang Cach Tu Mep Den Tim Kenh: ")) (while (setq di (getpoint "\n Pick point...(<Retern>to end) :")) (command "color" 40 "donut" "0" "0.15" di "") (setq ldi (cons di ldi) ltt (cons (itoa tti) ltt)) (setq tii (+ tii 1)) ) (while (setq di (getreal "\n Nhap Cao Do...(<Retern> to end) :")) (setq lcd (cons di lcd)) ) (while (setq ki (getreal "\n Nhap Khoang Cach...(<Retern> to end) :")) (setq lkc (cons ki lkc)) ) (Get_li) ) ;****************************************************************************************** ;----------------------------- Chuong trinh chinh ----------------------------------------- (defun C:Ve-MCN (/ gii mss cdo tt done) (if (= (getvar "cmdecho") 1) (setvar "cmdecho" 0)) (setq datafile nil filename nil ltt nil lkc nil lcd nil) (setq gii (load_dialog "Ve_Mcn.dcl")) (setq done 3) (while (> done 1) (if (not (new_dialog "vemcn" gii)) (exit)) (action_tile "tt" "(Get_tt)") (action_tile "cd" "(Get_cd)") (action_tile "kc" "(Get_kc)") (action_tile "nd" "(done_dialog 2)") (action_tile "start" "(done_dialog 1)") (action_tile "cancel" "(done_dialog 0)") (setq done (start_dialog)) (cond ((= done 2) (nhapdiem)) ) );---dong while (unload_dialog gii) (command "color" "bylayer" "ortho" "on" "osmode" 33 "REDRAW") ) ;------------------------------------------------------------- ;;;----------------Code file Ve_Mcn.DCL vemcn : dialog { label = "LËp Files Sè LiÖu vµ VÏ MCN §Þa H×nh"; fixed_width = center; : boxed_row { fixed_width = true; fixed_height = true; label = "Thong So Cac Diem:"; : list_box { label = " TT"; fixed_width = true; list = "1"; width = 5; height = 26; key="tt"; } : list_box { label = " Cao Do"; fixed_width = true; list = "0.0"; width = 10; height = 26; key="cd"; } : list_box { label = " Kh.Cach"; fixed_width = center; list = "0.0"; width = 10; height = 26; key="kc"; } } : row { fixed_width = true; children_alignment = centered; :spacer { width=3.5; } : button { label = "Nhap Diem"; is_default = true ; key = "nd"; width = 15; } : button { label = "Ve MCN" ; is_default = true ; key = "start" ; width = 8; } :spacer { height=0; } : button { label = "Cancel" ; width = 8; is_cancel= true ; } :spacer { height=3; } } } Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
phamthanhbinh 3151 Báo cáo bài đăng Đã đăng Tháng 6 17, 2011 Em đã test thử lại lisp trên CAD2007-2008 vẫn chạy tốt mà, trình tự và ý muốn em ghi lại trong file word nhờ các Bác đọc và chỉ giúp nhé. Em cảm ơn ! http://www.mediafire.com/?qm99m8s817s77kl Hề hề hề, Quả thực minh chưa chạy được cái lisp của bạn. Song theo suy luận khi đọc cái lisp của bạn thì bạn hãy thử làm như sau xem sao. Có khi ăn tiền đấy. Hề hề hề.... 1/ Bổ sung đoạn code (UNLOAD_DIALOG DCL_AREA) vào cái hàm con (defun SO_DWG (/ NUMS) như sau: (defun SO_DWG (/ NUMS) (setq NUMS (ATOF (GET_TILE "sodt"))) (setq NUMSO NUMS) (setq TRUNGNHAU 0) (alert (rtos NUMSO)) (UNLOAD_DIALOG DCL_AREA) (setq DCL_AREA (LOAD_DIALOG (strcat "muare" (rtos NUMSO 2 0) ".dcl"))) (if (not (new_dialog (strcat "muare" (rtos NUMSO 2 0)) DCL_AREA)) (progn ;;;;;;;;;;;(Restore) (exit)) ) (ACTION_TILE "cancel" "(unload_dialog dcl_area)") (START_DIALOG) (UNLOAD_DIALOG DCL_AREA) ) Hề hề hề, nếu vậy mà chưa được như ý thì đừng oán mình nghen, chỉ là đoán mò vậy mà. Hề hề hề,... Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
lenhatanh 2 Báo cáo bài đăng Đã đăng Tháng 6 17, 2011 Hề hề hề, Quả thực minh chưa chạy được cái lisp của bạn. Song theo suy luận khi đọc cái lisp của bạn thì bạn hãy thử làm như sau xem sao. Có khi ăn tiền đấy. Hề hề hề.... 1/ Bổ sung đoạn code (UNLOAD_DIALOG DCL_AREA) Vẫn chưa được, dù sao cũng cám ơn mọi người, cám ơn bác Phamthanhbinh. lúc khác em port file ảnh cho dễ hiểu hơn vậy... Tiện đây, bác nào có Lisp (ví dụ cụ thể) trong đó có chuyển, bật tắt nhiều (2 trở lên) hộp thoại thì port lên cho em tham khảo với nhé. Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
victor85 11 Báo cáo bài đăng Đã đăng Tháng 6 18, 2011 các bác pro viết dùm em cái lisp nè với: Chọn riêng tất cả các đối tượng fakedim gom chung vào 1 layer tên là fakedim để tiện cho việc quản lý với! Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
Tue_NV 3918 Báo cáo bài đăng Đã đăng Tháng 6 18, 2011 các bác pro viết dùm em cái lisp nè với: Chọn riêng tất cả các đối tượng fakedim gom chung vào 1 layer tên là fakedim để tiện cho việc quản lý với! Cái này không cần Lisp đâu. Bạn dùng lệnh FIND -> gõ ~<> vào Find text string Sử dụng chức năng select All của lệnh Find để chọn ra những anh dim này. Khi chọn ra được những Fakedim (những dim có không có chứa <> , tức là chứa chuỗi ~<>) thì công việc gom chung vào 1 layer tên là fakedim đó đơn giản rồi, phải không bạn? Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
ketxu 3020 Báo cáo bài đăng Đã đăng Tháng 6 18, 2011 các bác pro viết dùm em cái lisp nè với: Chọn riêng tất cả các đối tượng fakedim gom chung vào 1 layer tên là fakedim để tiện cho việc quản lý với! Nếu lười qs thì victor làm thế này : (defun c:2fd () (command ".change" (ssget "X" '((0 . "DIMENSION")(1 . "?*"))) "" "P" "LA" "fakedim" "")) Layer fakedim phải tạo từ trước, nếu cần thì có thể copy dòng command tạo layer vào nhé. P/S : chiều nay PS k victor ơi, mưa này làm j ^^ 1 Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
victor85 11 Báo cáo bài đăng Đã đăng Tháng 6 18, 2011 Cái này không cần Lisp đâu. Bạn dùng lệnh FIND -> gõ ~<> vào Find text string Sử dụng chức năng select All của lệnh Find để chọn ra những anh dim này. Khi chọn ra được những Fakedim (những dim có không có chứa <> , tức là chứa chuỗi ~<>) thì công việc gom chung vào 1 layer tên là fakedim đó đơn giản rồi, phải không bạn? Đã thử và không đc bác ạ. nó không chọn đc đối tượng nào cả. em dùng cad10 http://cc5.upanh.com/23.833.30899694.5sq0/1.png Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
Tue_NV 3918 Báo cáo bài đăng Đã đăng Tháng 6 18, 2011 Đã thử và không đc bác ạ. nó không chọn đc đối tượng nào cả. em dùng cad10 http://cc5.upanh.com/23.833.30899694.5sq0/1.png Bạn tick vào Use wildcards ở mục Search options -> Bấm nút Find -> Sau đó là nút select all Chúc bạn thành công 1 Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
790312 5 Báo cáo bài đăng Đã đăng Tháng 6 18, 2011 E có nhờ bác Tue sửa giùm e 1 tí trong đoạn lisp bác viết giùm e,chưa thấy bác trả lời.Bài 3818 bác ah.Mong bác xem giúp.Thanks. Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
phamthanhbinh 3151 Báo cáo bài đăng Đã đăng Tháng 6 18, 2011 E làm thử theo bác thì không được bác ah. FontName (getstring "\nT\U+00EAn Font<vhelvcn.ttf> :") Hề hề hề, Quả nhiên là không được thật. Do mình lầm lẫn, hàm getstring không phù hợp để dùng keyword. Xin lỗi bạn nhiều nhiều... Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
Tue_NV 3918 Báo cáo bài đăng Đã đăng Tháng 6 18, 2011 Nhờ bác bỏ giùm bảng hiện 'Ban chon DIMENSION STYLE ' giùm e,khi sổ danh sách ta chọn thì sẽ chuyển về dimension style ta chọn,không cần hiện bảng 'Ban chon DIMENSION STYLE 'e đã thử sửa trong lisp thì nó báo lỗi.Cảm ơn bác nhiều. E có nhờ bác Tue sửa giùm e 1 tí trong đoạn lisp bác viết giùm e,chưa thấy bác trả lời.Bài 3818 bác ah.Mong bác xem giúp.Thanks. @790312 : Bài viết 3818 là bài viết của Tue_NV viết để thay đổi bề rộng chiều cao , Style của chữ trong Block ATT, chẳng ăn nhập gì với DIMENSION STYLE cả, chẳng hiểu yêu cầu của bạn là như thế nào nữa bác nào giúp em cái này với, công việc cắt tạo góc xoay bình đồ thường phải lặp lại rất nhiều lần. thường em hay làm như này. kẽ một đường thẳng cắt ngang qua(hai đường) rồi cắt hai phân rời ra rồi lại chọn cái phần cần xoay và nhập góc để xoay. xin nhờ các bác giúp em một cái lips - khi gạch một đường thẳng cắt ngang qua thì tự động hai phần sẽ được cắt rời nhau - chương trình sẽ hỏi bạn cần xoay bên trái hay phải(nhập vào) - và sau do là nhập góc cần xoay giúp em với nhé. chân thành cảm ơn @zizpo_hetxang : Khi xoay thì dữ liệu nhập vào ngoài góc xoay còn có tâm xoay? Nếu xoay bên trái thì xoay tại đâu? Xoay bên phải thì xoay tại đâu? bạn nên gửi file .dwg, kết quả và viết rõ hơn vấn đề của bạn Nhờ các cao thủ giúp đỡ! Mình có file cad như sau: http://www.cadviet.com/upfiles/3/vi_du_01.dwg Trong đó mình có tập hợp các điểm cao trình được mô tả bằng các nhóm text. Các nhóm text có cấu tạo bởi 3 đối tượng, text A, dấu chấm point, text B. (Chú ý rằng điểm cao trình có tọa độ trùng với tọa độ của dấu chấm point) Chân text, dấu chấm point và đầu text B nằm trên cùng 1 đường thẳng (cùng giá trị Y); và cách nhau lần lượt các khoảng bằng 0.4; cao độ text = 2. Mong các cao thủ viết giúp mình lisp có thể thực hiện các yêu cầu sau: 1. Chọn tất cả các nhóm text ở trên, sử dụng lisp biến 2 đối tượng rời rạc A1,B1; A2, B2; ...An, Bn thành các số thập phân A1.B1; A2.B2;...An.Bn với dấu chấm trong text trùng với dấu chấm point ban đầu. 2. Từ các text được nối lại ở trên, cộng hoặc trừ giá trị các text này cho cùng 1 hằng số. (bước này có thể ko cần thiết, vì ta có thể đi đường vòng hơn bằng cách xuất text ra cell xử lý rồi xuất ngược vào cad, nhưng nếu lisp làm được thì quá tuyệt) 3. Từ tập hợp các text đã được xử lý ở bước 2 hoặc tập hợp text mới, tách thành các tập hợp text giống như ban đầu (Nghĩa là mỗi text A'.B' tách thành 3 đối tượng A',và B' có vị trí không dổi giống nhóm A,B ban đầu . xem thêm trong bản vẽ. Xin chân thành cảm ơn! @gasmanc : Bước thứ 2 cũng cần thiết đấy bạn. Không có bước 2 sao có bước 3 được. Hằng số mà bạn nói ấy luôn luôn bằng nhau khi duyệt qua từng cặp Text và point à? Không biết hằng số đấy có bằng nhau không? Hay là có quy luật? Có lẽ bạn nên upload 1 file .dwg chứa một số đối tượng để người viết Lisp cho bạn có thể test để kiểm tra, Hơn nữa bạn nên nói rõ hơn về kết quả bạn muốn nhé. Còn kết quả thì Minh họa 1 vài kết quả đạt được thôi Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
Doan Van Ha 3212 Báo cáo bài đăng Đã đăng Tháng 6 18, 2011 Hề hề hề, Quả nhiên là không được thật. Do mình lầm lẫn, hàm getstring không phù hợp để dùng keyword. Xin lỗi bạn nhiều nhiều... Hàm getkword thì được bác phamthanhbinh ạ. Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
790312 5 Báo cáo bài đăng Đã đăng Tháng 6 18, 2011 @790312 : Bài viết 3818 là bài viết của Tue_NV viết để thay đổi bề rộng chiều cao , Style của chữ trong Block ATT, chẳng ăn nhập gì với DIMENSION STYLE cả, chẳng hiểu yêu cầu của bạn là như thế nào nữa Bác Tue sao vậy,bác xem kỹ lại đi,e nhờ bác sửa từ lisp của bac gia_bach viết giùm e lisp sổ danh sách DIMENSION STYLE mà,bác xem kỹ lại bài 3818 đi,đó là ý e nhờ bác đó. Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
