various
[ Hỏi ] Lỗi Lisp Vẽ Wipeout Không Có Tác Dụng Trong Acad2016
Em sử dụng lisp có code như thế này. Ở Acad2010 vẫn bình thường, sang 2016 thì không có tác dụng nữa. Mong mọi người giúp đỡ
;;; OB2WO (gile) -Gilles Chanteau- 10/03/07
;;; UPDATE BY KETXU (04/04/2012)
;;; Creates a "Wipeout" from an object (circle, ellipse, or polyline with arcs)
;;; Works whatever the current ucs and object OCS
;http://xaydungit.vn/diendan/showthread.php?7784-Wipe-PLine-và-bật-tắt-nhanh-Wipeout&p=14880779#post14880779
;----- Chuyen ss thanh cac Wipeout.
(defun c:OB2WO (/ ent lst nor ss)
  (if  (setq ss (ssget (list (cons 0 "CIRCLE,ELLIPSE,LWPOLYLINE"))))
      (vla-StartundoMark
    (vla-get-ActiveDocument (vlax-get-acad-object))
        (initget "Yes No")
        (setq ans (getkword "\nDelete source object? [Yes/No] <No>: "))
      (foreach ent (ST:Ss->ListEnt ss)
        (setq lst (ent2ptlst ent))
        (setq nor (cdr (assoc 210 (entget ent))))
        (makeWipeout lst nor)
        (if (or (not ans) (wcmatch (strcase ans) "YES"))(entdel ent))
      (vla-EndundoMark
;----- Bat/Tat qua lai giua Wipeout va Pline
;; WOF (gile)
;; Toggles wipeout frames
(defun c:wof (/ elst)
    ((and
        (setq elst (dictsearch (namedobjdict) "ACAD_WIPEOUT_VARS"))
        (ssget "x" '((0 . "WIPEOUT,INSERT")))
    (entmod    (subst    (cons 70 (boole 6 (cdr (assoc 70 elst)) 1))    (assoc 70 elst)    elst))
    (vlax-for obj (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))
        (vla-update obj)
    (T (princ "\nHave no wipeout object !"))
;----- Chuyen cac Wipeout thanh Pline
;; WO2PL (gile)
;; Re-creates a wipeout boundary (lwpolyline)
(defun c:wo2pl (/ ss n wo elst pts norm ans)
  (if (setq ss (ssget '((0 . "WIPEOUT"))))
    (initget "Yes No")
    (foreach wo    (ST:Ss->ListEnt ss)
        elst (entget wo)
        norm (vunit (v^v (cdr (assoc 11 elst)) (cdr (assoc 12 elst))))
        pts  (wipeout2plst wo)
      (entmake
    (append
      (list    '(0 . "LWPOLYLINE")
        '(100 . "AcDbEntity")
        '(100 . "AcDbPolyline")
        (cons 90 (length pts))
        (cons 38 (caddr (trans (car pts) 0 norm)))
        '(70 . 1)
        (cons 210 norm)
      (mapcar '(lambda (pt)
          (setq pt (trans pt 0 norm))
          (list 10 (car pt) (cadr pt))
          pts
      (if (or (not ans) (wcmatch (strcase ans) "YES"))(entdel wo))
;;==================SUB ROUTINES==================;;
;; returns the wipeout point list (WCS)
(defun wipeout2plst (wo / elst u v mat)
  (setq    elst (entget wo)
    u    (cdr (assoc 11 elst))
    v    (cdr (assoc 12 elst))
    mat  (list u (mapcar '- v) '(0. 0. 1.))
  (mapcar
    '(lambda (p)
    (mapcar '+
        (mxv (trp mat) p)
        (mapcar '(lambda (x y) (/ (+ x y) 2.)) u v)
        (cdr (assoc 10 elst))
    (cdr
      (mapcar 'cdr
          (vl-remove-if-not '(lambda (x) (= (car x) 14)) elst)
;; Transpose a matrix Doug Wilson
(defun trp (m)
  (apply 'mapcar (cons 'list m))
;; Apply a transformation matrix to a vector by Vladimir Nesterovsky
(defun mxv (m v)
  (mapcar '(lambda (r) (apply '+ (mapcar '* r v))) m)
;; V^V
;; Returns the cross product of 2 vectors
(defun v^v (v1 v2)
  (list    (- (* (cadr v1) (caddr v2)) (* (caddr v1) (cadr v2)))
    (- (* (caddr v1) (car v2)) (* (car v1) (caddr v2)))
    (- (* (car v1) (cadr v2)) (* (cadr v1) (car v2)))
;; VUNIT
;; Returns the single unit vector
(defun vunit (v)
  ((lambda (l)
  (if (/= 0 l)
    (mapcar (function (lambda (x) (/ x l))) v)
    (distance '(0 0 0) v)
;;; ENT2PTLST
;;; Returns the vertices list of the polygon figuring the curve object
;;; Coordinates defined in OCS
(defun ent2ptlst (ent / obj dist n lst p_lst prec)
  (if (= (type ent) 'ENAME)
    (setq obj (vlax-ename->vla-object ent))
    ((member (cdr (assoc 0 (entget ent))) '("CIRCLE" "ELLIPSE"))
  (setq dist    (/ (vlax-curve-getDistAtParam
          obj
          (vlax-curve-getEndParam obj)
        50
    n    0
  (repeat 50
  lst
      (cons
        (trans
          (vlax-curve-getPointAtDist obj (* dist (setq n (1+ n))))
          (vlax-get obj 'Normal)
        lst
    (T
  (setq p_lst (vl-remove-if-not
        '(lambda (x)
              (or (= (car x) 10)
              (= (car x) 42)
        (entget ent)
  (while p_lst
  lst
      (cons
        (append (cdr (assoc 10 p_lst))
            (list (cdr (assoc 38 (entget ent))))
        lst
    (if (/= 0 (cdadr p_lst))
    (setq prec (1+ (fix (* 25 (sqrt (abs (cdadr p_lst))))))
      dist (/ (- (if    (cdaddr p_lst)
                  (vlax-curve-getDistAtPoint
                obj
                (trans (cdaddr p_lst) ent 0)
                obj
                  obj
                  (trans (cdar p_lst) ent 0)
          prec
      n    0
    (repeat (1- prec)
        lst (cons
          (trans
          obj
          (+ (vlax-curve-getDistAtPoint
                  obj
            ent
          lst
    (setq p_lst (cddr p_lst))
  lst
;;; MakeWipeout creates a "wipeout" from a points list and the normal vector of the object
(defun MakeWipeout (pt_lst nor / dxf10 max_dist cen dxf_14)
  (if (not (member "acwipeout.arx" (arx)))
    (arxload "acwipeout.arx")
  (setq    dxf10 (list (apply 'min (mapcar 'car pt_lst))
            (apply 'min (mapcar 'cadr pt_lst))
            (caddar pt_lst)
    max_dist
  (float
    (apply 'max
          (mapcar '- (apply 'mapcar (cons 'max pt_lst)) dxf10)
  (setq cen (mapcar '+ dxf10 (list (/ max_dist 2) (/ max_dist 2) 0.0)))
    dxf14 (mapcar
        '(lambda (p)
        (mapcar '/
            (mapcar '- p cen)
            (list max_dist (- max_dist) 1.0)
        pt_lst
  (setq dxf14 (reverse (cons (car dxf14) (reverse dxf14))))
  (entmake (append (list '(0 . "WIPEOUT")
          '(100 . "AcDbWipeout")
          '(90 . 0)
          (cons 10 (trans dxf10 nor 0))
          (cons 11 (trans (list max_dist 0.0 0.0) nor 0))
          (cons 12 (trans (list 0.0 max_dist 0.0) nor 0))
          '(13 1.0 1.0 0.0)
          '(70 . 7)
          '(280 . 1)
          '(71 . 2)
          (cons 91 (length dxf14))
        (mapcar '(lambda (p) (cons 14 p)) dxf14)
(defun ST:Ss->ListEnt (ss / n e l)
  (setq n (sslength ss))
    (setq l (cons e l))
Do thiếu file acwipeout.arx, ban thử kiếm file đó ở 2010 rồi chép qua 2016 xem sao.
Em tìm trên mạng mà không có. :( Bác có thể upload lên hộ em được không ạ?
// Em search trên mạng thì hình như LSP này chưa working với cad2016
in autocad 2016 appears this message “error: ARXLOAD failed”, have someone tested or modify the lisp?
Bạn nói dùng vơi cad2010 vẫn bình thường, chứng tỏ là trong thư mục của 2010 đã có file đó rồi, cần gì kiếm trên mạng làm chi.
Từ Cad2013, arx này đã tích hợp vào "nhân" nên ko cần load nữa.
Chỉ cần tìm và xóa dòng dưới đây là chạy được.
Vẫn bị " nil " bác gia_bach ơi :(
Sửa lại và test trên AC2015 ok.
   (progn (vla-StartundoMark (vla-get-ActiveDocument (vlax-get-acad-object)))
     (initget "Yes No")
    (vla-EndundoMark (vla-get-ActiveDocument (vlax-get-acad-object)))
  (cond ((and (setq elst (dictsearch (namedobjdict) "ACAD_WIPEOUT_VARS"))
(ssget "x" '((0 . "WIPEOUT,INSERT"))) )
 (vlax-for obj (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))) (vla-update obj) ) )
 (progn (initget "Yes No")
   (entmake (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline")
(cons 90 (length pts)) (cons 38 (caddr (trans (car pts) 0 norm))) '(70 . 1) (cons 210 norm) )
(mapcar '(lambda (pt) (setq pt (trans pt 0 norm)) (list 10 (car pt) (cadr pt)) ) pts ) )
  (mapcar '(lambda (p) (mapcar '+ (mxv (trp mat) p) (mapcar '(lambda (x y) (/ (+ x y) 2.)) u v) (cdr (assoc 10 elst)) ) )
   (cdr (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 14)) elst) )))
 (defun trp (m) (apply 'mapcar (cons 'list m)))
 (defun mxv (m v)  (mapcar '(lambda (r) (apply '+ (mapcar '* r v))) m))
 (defun v^v (v1 v2)
 (defun vunit (v)
  ((lambda (l) (if (/= 0 l) (mapcar (function (lambda (x) (/ x l))) v) ) )
  (if (= (type ent) 'ENAME)  (setq obj (vlax-ename->vla-object ent)))
  (cond ((member (cdr (assoc 0 (entget ent))) '("CIRCLE" "ELLIPSE"))
(setq dist (/ (vlax-curve-getDistAtParam obj (vlax-curve-getEndParam obj) ) 50 ) n 0 )
(repeat 50 (setq lst (cons (trans (vlax-curve-getPointAtDist obj (* dist (setq n (1+ n)))) 0 (vlax-get obj 'Normal)) lst ))))
   (T (setq p_lst (vl-remove-if-not '(lambda (x) (or (= (car x) 10) (= (car x) 42) ) ) (entget ent) ) )
(while p_lst (setq lst (cons (append (cdr (assoc 10 p_lst)) (list (cdr (assoc 38 (entget ent)))) ) lst ) )
dist (/ (- (if (cdaddr p_lst) (vlax-curve-getDistAtPoint obj (trans (cdaddr p_lst) ent 0) )
(vlax-curve-getDistAtParam obj (vlax-curve-getEndParam obj) ) )
(vlax-curve-getDistAtPoint obj (trans (cdar p_lst) ent 0) ) ) prec ) n 0 )
   (repeat (1- prec)
    (setq lst (cons (trans (vlax-curve-getPointAtDist obj (+ (vlax-curve-getDistAtPoint obj (trans (cdar p_lst) ent 0) )
(* dist (setq n (1+ n))) ) ) 0 ent ) lst ) ))
  lst
 (setq dxf10 (list (apply 'min (mapcar 'car pt_lst)) (apply 'min (mapcar 'cadr pt_lst)) (caddar pt_lst)))
 (setq max_dist (float (apply 'max (mapcar '- (apply 'mapcar (cons 'max pt_lst)) dxf10))))
 (setq dxf14 (mapcar '(lambda (p) (mapcar '/ (mapcar '- p cen) (list max_dist (- max_dist) 1.0))) pt_lst))
    (entmake (append (list '(0 . "WIPEOUT") '(100 . "AcDbEntity") '(100 . "AcDbWipeout")
(cons 10 (trans dxf10 nor 0)) (cons 11 (trans (list max_dist 0.0 0.0) nor 0))
(cons 12 (trans (list 0.0 max_dist 0.0) nor 0)) '(13 1.0 1.0 0.0)
'(70 . 7) '(280 . 1) '(281 . 50) '(282 . 50) '(283 . 0)
'(71 . 2) (cons 91 (length dxf14)) )
(mapcar '(lambda (p) (cons 14 p)) dxf14) )
  (setq l (cons e l))
