dtdz1986 0 Báo cáo bài đăng Đã đăng Tháng 1 2, 2020 Cho mình xin key với Serial Number: KR150721056000001506 DISKV7MBVGT Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
Nulled2020 0 Báo cáo bài đăng Đã đăng Tháng 2 13, 2020 (DEFUN ACTIVEKEY( / NAMESERI FLAGG DCL123 NSERI STRS STRKEY KEYONLINE SRI SERIREGADIT SERIREGADITI STLENKEYONLINE KEYCUNGONLINE SERVER2 CHIEUDAI ) (setq LSTSTRKEY (LIST )) (FOREACH SERIAL (GETHDDSERI ) (setq SERIAL (VL-STRING-LEFT-TRIM " " SERIAL )) (setq SERIAL (VL-STRING-RIGHT-TRIM " " SERIAL )) (if (< (STRLEN SERIAL ) 3 ) (PROGN (setq SERIAL (STRCAT "DtU4zH6yk" (SUBSTR SERIAL 2 ) )) )) (setq STRSERIAL (CLICKTOTOP SERIAL )) (setq LSTSTRKEY (APPEND (LIST STRSERIAL ) LSTSTRKEY )) ) (if (AND (/= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\QDV\\Active\\SerialNumber" ) nil ) (/= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\Alo" ) nil ) (/= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\DUdu" ) nil ) (/= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\Prsoftware" ) nil ) (/= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Printers\\Settings\\Prin\\Paper\\Prime" ) nil ) (/= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Printers\\Settings\\Prin\\Paper\\Diamond" ) nil ) (/= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Printers\\Settings\\Prin\\Paper\\Pravor" ) nil ) (/= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\AppEvents\\Schemes\\Apps\\Pree\\Update" ) nil ) (/= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\AppEvents\\Schemes\\Apps\\Pree\\Restore" ) nil ) (/= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\QDV\\Layername\\Layernamelist" ) nil ) (/= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\QDV\\Customscale\\Dem\\Tuso" ) nil ) (/= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\QDV\\Layout\\Listlayout\\LayoutChinh" ) nil ) (VL-POSITION (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Printers\\Settings\\Prin\\Paper\\Pravor" ) LSTSTRKEY ) (VL-POSITION (VL-REGISTRY-READ "HKEY_CURRENT_USER\\QDV\\Active\\SerialNumber" ) LSTSTRKEY ) (VL-POSITION (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\DUdu" ) LSTSTRKEY ) (VL-POSITION (VL-REGISTRY-READ "HKEY_CURRENT_USER\\QDV\\Customscale\\Dem\\Tuso" ) LSTSTRKEY ) (VL-POSITION (VL-REGISTRY-READ "HKEY_CURRENT_USER\\AppEvents\\Schemes\\Apps\\Pree\\Restore" ) LSTSTRKEY ) (= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\Alo" ) "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\DUdu" ) (= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\Prsoftware" ) "HKEY_CURRENT_USER\\Printers\\Settings\\Prin\\Paper\\Diamond" ) (= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Printers\\Settings\\Prin\\Paper\\Prime" ) "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\Prsoftware" ) (= (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Printers\\Settings\\Prin\\Paper\\Diamond" ) "HKEY_CURRENT_USER\\QDV\\Layername\\Layernamelist" ) ) (PROGN (ALERT "\nB\\U+1EA1n \\U+0111\\U+00E3 Acitve Lisp In Model - Layout QDV!!! \nCh\\U+00FAc b\\U+1EA1n th\\U+00E0nh c\\U+00F4ng trong c\\U+00F4ng vi\\U+1EC7c, cu\\U+1ED9c s\\U+1ED1ng!!!" ) ) ... (PROGN (setq KEYONLINE (STRCAT "http://lispinmodellayout.xtgem.com/" (STRCASE NAMESERI T ) )) (setq STLENKEYONLINE (STRLEN STRKEY )) (if (= (GETKEYONLINEVDNVD KEYONLINE STLENKEYONLINE ) STRKEY ) (PROGN (ALERT "\nCh\\U+00FAc m\\U+1EEBng b\\U+1EA1n \\U+0111\\U+00E3 ACTIVE Th\\U+00E0nh C\\U+00F4ng Lisp In Model - Layout!!!" ) (setq FLAGG 1) (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\QDV\\Active\\SerialNumber" "" STRKEY ) (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\Alo" "" "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\DUdu" ) (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\DUdu" "" STRKEY ) (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\Prsoftware" "" "HKEY_CURRENT_USER\\Printers\\Settings\\Prin\\Paper\\Diamond" ) (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Printers\\Settings\\Prin\\Paper\\Prime" "" "HKEY_CURRENT_USER\\Software\\Software\\Freedom\\None\\Prsoftware" ) (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Printers\\Settings\\Prin\\Paper\\Diamond" "" "HKEY_CURRENT_USER\\QDV\\Layername\\Layernamelist" ) (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Printers\\Settings\\Prin\\Paper\\Pravor" "" STRKEY ) (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\AppEvents\\Schemes\\Apps\\Pree\\Update" "" "HKEY_CURRENT_USER\\Printers\\Settings\\Prin\\Paper\\Pravor" ) )(PROGN (ALERT "\nCh\\U+01B0a th\\U+1EC3 ACTIVE!!! \nKey c\\U+1EE7a b\\U+1EA1n ch\\U+01B0a \\U+0111\\U+01B0\\U+1EE3c ph\\U+00E1t h\\U+00E0nh!!! \nVui l\\U+00F2ng \\U+0111\\U+0103ng k\\U+00FD \\U+0111\\U+1EC3 s\\U+1EED d\\U+1EE5ng!!!" ) (setq FLAGG 3) )) ) (PROGN (setq FLAGG 3) (ALERT "\nKey kh\\U+00F4ng \\U+0111\\U+00FAng - Vui l\\U+00F2ng th\\U+1EED l\\U+1EA1i!!!" ) )) ) (PROGN (ALERT "\nB\\U+1EA1n ch\\U+01B0a nh\\U+1EADp Key!!!" ) (setq FLAGG 3) )) )) (if (= FLAGG 2 ) (PROGN (DANGKYLISP ) )) ) (if (= FLAGG 0 ) (PROGN (PROMPT "\nB\\U+1EA1n ch\\U+01B0a ACTIVE!" ) )) )) ) Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
DDev_TT 0 Báo cáo bài đăng Đã đăng Tháng 7 13, 2020 serinumber của em: MJ8AN61081060AM17 Gmail: thientuan0997@gmail.com _________________________________________ Em cảm ơn ạ! Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
Nad SK 8 Báo cáo bài đăng Đã đăng Tháng 7 27, 2020 Ôi thật là VL, sau bao nhiêu ngày không mò vô thì sau khi down về để thử xem có gì hay ho không. Lọ mọ down về, bật AutoCAD lên, gõ AP, load lisp lên. Hồi hộp gõ QDV thì bụp hiện lên cái bảng thông báo: Bạn đã gian lận nên không thể tiếp tục sử dụng! Liên hệ nvdoangt@gmail.com để ACTIVE!. Giờ em phải nàm thao đây. Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
sea368 0 Báo cáo bài đăng Đã đăng Tháng 7 29, 2020 cho mình xin 1 key nhé. mail sea368@gmail.com. thank! Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
dinhnhat 2 Báo cáo bài đăng Đã đăng Tháng 11 4, 2020 Cho em xin key với ạ. Cám ơn anh nhiều. Mail: dinhnhat143@gmail.com Model Name SerialNumber Size HGST HTS545050A7E680 \\.\PHYSICALDRIVE1 RB250A58G3T63K 500105249280 WDC WDS120G2G0A-00JH30 \\.\PHYSICALDRIVE0 183102802917 120039736320 Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
herobatman 0 Báo cáo bài đăng Đã đăng Tháng 12 22, 2020 Bác @Đoàn Nguyên Văn cho mình xin 01 KEY với ạ Serial number của máy gmail: tranthienphuocag@gmail.com Xin cảm ơn! Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
thanhhit 0 Báo cáo bài đăng Đã đăng Tháng 1 19, 2021 Cho em xin key với ạ. Cám ơn anh nhiều. Mail: thanhhit1703@gmail.com Máy tính e k lấy dc serial a ơi máy tính nó báo SerialNumber Default string Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
Thuy Vu 0 Báo cáo bài đăng Đã đăng Tháng 4 3, 2021 Cho em xin với ạ Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
Doan Nguyen Van 495 Báo cáo bài đăng Đã đăng Tháng 4 4, 2021 20 giờ trước, Thuy Vu đã nói: Cho em xin với ạ Ib zalo 0976379894 nhé bạn Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
Doan Nguyen Van 495 Báo cáo bài đăng Đã đăng Tháng 7 22, 2021 Cập nhật in được với các bản vẽ lỗi khung tên XREF... Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
tanbqtb03 11 Báo cáo bài đăng Đã đăng Tháng 8 20, 2021 Đã mua bản cũ có được update lên bản mới này ko vậy e ơi? :) Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
Doan Nguyen Van 495 Báo cáo bài đăng Đã đăng Tháng 8 20, 2021 1 giờ trước, tanbqtb03 đã nói: Đã mua bản cũ có được update lên bản mới này ko vậy e ơi? :) Tất nhiên là được nhé Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
colehuco 0 Báo cáo bài đăng Đã đăng Tháng 9 8, 2021 Cho mình xin key với! 51930708045D00075359 DISKV7MBVGT ngochuan.tv@gmail.com Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
leinh14 0 Báo cáo bài đăng Đã đăng Tháng 6 29, 2023 anh cho em xin key vs ạ: 335A_4730_4D70_1970_0025_3858_0000_0001. DISKV7MBVGT Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
Bkga93 1 Báo cáo bài đăng Đã đăng Tháng 1 12, 2024 Bác có thể update để chọn được cả block và rectangle làm khung in không ạ ? Cảm ơn bác rất nhiều vì đã chia sẻ lisp hữu dụng cho mọi người ! Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
