mr.thanh2610
[NHỜ CHỈNH SỬA] Về vấn đề lisp hatch nhanh
(defun c:SF(/ p dt ans ten sc ang dt)
(setvar "cmdecho" 0)
(initget "B B1 B2 BK G GD GD1 GL GL1 GL2 D D1 C K N N1 TO GO GO1")
(setq ans (getkword "\n Chon kieu hatch < B/B1/B2/BK/G/GD/GD1/GL/GL1/GL2/D/D1/C/K/N/N1/TO/GO/GO1 > : "))
(initget "P S")
(setq ansp (getkword "\n Chon kieu pick diem hay chon doi tuong < P/S > :"))
(setq p nil dt t)
;(WHILE (or (not p) (not dt))
(if (= ans "B")
(setq ten "AR-CONC" sc 20.0 ang 0.0
ten2 "ANSI32" sc2 200.0 ang 0.0)
 (if (= ansp "P")
     (while (setq p (getpoint "\n Chon 1 diem trong vung can hatch :"))
     		(lh1 p ten sc ang)
     		(lh1 p ten2 sc2 ang)
     (princ "\n Chon doi tuong can hatch :")
     (while (setq dt (ssget) )
     (lh dt ten sc ang)
     (lh dt ten2 sc2 ang)
(if (= ans "B1")
(setq ten "AR-CONC" sc 20.0 ang 0.0)
  (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "B2")
(setq ten "GRAVEL" sc 100.0 ang 0.0)
  (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "BK")
(setq ten "SOLID" sc 200.0 ang 0.0)
  (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "G")
(setq ten "ANSI31" sc 400.0 ang 0.0)
  (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "GD")
(setq ten "AR-B816" sc 10.0 ang 0.0)
  (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "GD1")
(setq ten "FLGSTONE" sc 500.0 ang 0.0)
  (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "GL")
(setq ten "NET" sc 1500.0 ang 0.0)
  (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "GL1")
(setq ten "ANGLE" sc 700.0 ang 0.0)
  (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "GL2")
(setq ten "AR-HBONE" sc 20.0 ang 0.0)
  (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "D")
(setq ten "HOUND" sc 500.0 ang 45.0)
  (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "D1")
(setq ten "EARTH" sc 500.0 ang 45.0)
  (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "C")
(setq ten "AR-SAND" sc 20.0 ang 0.0)
  (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "K")
(setq ten "AR-RROOF" sc 500.0 ang 45.0)
   (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "N")
(setq ten "AR-RSHKE" sc 30.0 ang 0.0)
   (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "N1")
(setq ten "SPANTILE" sc 400.0 ang 0.0)
   (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "TO")
(setq ten "ANSI32" sc 200.0 ang 45.0)
   (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "GO")
(setq ten "WOOD8" sc 700.0 ang 0.0)
   (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
(if (= ans "GO1")
(setq ten "WOOD2" sc 500.0 ang 0.0)
   (if (= ansp "P")
		(lh1 p ten sc ang)
    		(lh dt ten sc ang)
;);WHILE
(defun lh1(p name tle goc)
(setvar "hpgaptol" 50.0)
(vl-cmdf "bhatch" "P" name tle goc p "")
(defun lh(dt name tle goc)
(vl-cmdf "bhatch" "P" name tle goc "S" dt "" "")
Tình hình là mình có sưu tầm 1 Lisp hatch nhanh vật liệu nhưng mình gặp 1 vấn đề là hatch 2 vị trí khác nhau trở lên là mảng hatch không liền khối, mình ko rành lắm về Code chỉ chỉnh sửa lại sơ sơ thôi, nhờ anh em nào rành chỉnh thêm giúp mình với, xin cảm ơn
HATCH NHANH VAT LIEU (SF).lsp
Bạn gõ lệnh HPSEPARATE (lệnh cad)
- Nhập 0: tất cả các hatch tạo ra trong 1 lệnh sẽ đc gộp thành 1 hatch
- Nhập 1: tất cả các hatch tạo ra trong 1 lệnh sẽ đc chia thành nhiều hatch
Lệnh này đúng với cả lệnh HATCH của cad cũng như lisp trên của bạn (chỉ dám nói lisp trên của bạn, các lisp khác trên mạng chưa chắc).
Cách này cũng tương tự cách trên:
Trong bảng lệnh HATCH, ô màu đỏ: tích là 1, bỏ tích là 0. Nhưng sẽ chỉ đc lưu lại khi bạn tạo xong hatch, tích xong mà ấn ESC cũng coi như ko.
Cái đó mình cũng đã thử rồi, nhưng không được bạn à, vì chắc phải chỉnh trong lisp nhưng mình không biết viết code nên không chỉnh sửa được, không có cao nhân nào biết về lisp chỉ giáo với ạ
5 phút trước, mr.thanh2610 đã nói:
Mình thử vẫn được mà, có lẽ nào do ăn ở ???
(if (= ans "B")
(if (= ans "B1")
(if (= ans "B2")
(if (= ans "BK")
(if (= ans "G")
(if (= ans "GD")
(if (= ans "GD1")
(if (= ans "GL")
(if (= ans "GL1")
(if (= ans "GL2")
(if (= ans "D")
(if (= ans "D1")
(if (= ans "C")
(if (= ans "K")
(if (= ans "N")
(if (= ans "N1")
(if (= ans "TO")
(if (= ans "GO")
(if (= ans "GO1")
 (setvar "hpname" ten)
 (setvar "hpscale" sc)
 (setvar "hpang" ang)
(initdia)
(command "hatch")
(while (< 0 (getvar "CMDACTIVE"))
(command pause)
Sửa 1 xí . Lệnh và lựa chọn kiểu hatch như cũ. chọn xong trả lại cho lệnh hatch của cad muốn chọn gì thì chọn.
10 giờ trước, duy782006 đã nói:
(if (= ans "B")
(if (= ans "B1")
(if (= ans "B2")
(if (= ans "BK")
(if (= ans "G")
(if (= ans "GD")
(if (= ans "GD1")
(if (= ans "GL")
(if (= ans "GL1")
(if (= ans "GL2")
(if (= ans "D")
(if (= ans "D1")
(if (= ans "C")
(if (= ans "K")
(if (= ans "N")
(if (= ans "N1")
(if (= ans "TO")
(if (= ans "GO")
(if (= ans "GO1")
(initdia)
(command "hatch")
(command pause)
Cảm ơn ông anh đồng hương nhé, hj, có dịp về quê gặp cà phê hậu tạ ^_^, em ở Nghĩa Hành
8 giờ trước, mr.thanh2610 đã nói:
Mà cho em hỏi thêm xíu, sao chỉnh angle trong lisp là 45 mà sang đây nó đổi thành 58 hết cho hatch nào có góc 45 vậy anh
Chắc phải đổi độ về radian
2 giờ trước, mr.thanh2610 đã nói:
Cảm ơn bạn, mình đã thử và thành công, mà có cách nào để chỉnh độ thành độ không nhỉ
Hình như trong lisp đơn vị đo góc là radian thì phải
Mình không hiểu code lắm nên hỏi anh em để chỉnh đơn vị bên lisp là độ trùng với đơn vị bên bản vẽ ấy mà, chứ mỗi lần chỉnh góc là phải quy đổi
28 phút trước, mr.thanh2610 đã nói:
Sửa lại cho bạn nhập góc theo độ nhé:
(defun c:SF(/ p dt ans ten sc dt angrad)
(or (and ang (or (= (type ang) 'int) (= (type ang) 'real))) (setq ang 0.00))
(setq ang (cond ((getreal (strcat "\nNhap goc theo do <" (rtos ang 2 2) ">: "))) (ang)))
(setq angrad (*(/ ang 180) pi))
(if (= ans "B")
ten2 "ANSI32" sc2 200.0)
(if (= ans "B1")
(setq ten "AR-CONC" sc 20.0)
(if (= ans "B2")
(setq ten "GRAVEL" sc 100.0)
(if (= ans "BK")
(setq ten "SOLID" sc 200.0)
(if (= ans "G")
(setq ten "ANSI31" sc 400.0)
(if (= ans "GD")
(setq ten "AR-B816" sc 10.0)
(if (= ans "GD1")
(setq ten "FLGSTONE" sc 500.0)
(if (= ans "GL")
(setq ten "NET" sc 1500.0)
(if (= ans "GL1")
(setq ten "ANGLE" sc 700.0)
(if (= ans "GL2")
(setq ten "AR-HBONE" sc 20.0)
(if (= ans "D")
(setq ten "HOUND" sc 500.0)
(if (= ans "D1")
(setq ten "EARTH" sc 500.0)
(if (= ans "C")
(setq ten "AR-SAND" sc 20.0)
(if (= ans "K")
(setq ten "AR-RROOF" sc 500.0)
(if (= ans "N")
(setq ten "AR-RSHKE" sc 30.0)
(if (= ans "N1")
(setq ten "SPANTILE" sc 400.0)
(if (= ans "TO")
(setq ten "ANSI32" sc 200.0)
(if (= ans "GO")
(setq ten "WOOD8" sc 700.0)
(if (= ans "GO1")
(setq ten "WOOD2" sc 500.0)
 (setvar "hpang" angrad)
(initdia)
(command "hatch")
(command pause)
21 giờ trước, huunhantvxdts đã nói:
(if (= ans "B")
(if (= ans "B1")
(if (= ans "B2")
(if (= ans "BK")
(if (= ans "G")
(if (= ans "GD")
(if (= ans "GD1")
(if (= ans "GL")
(if (= ans "GL1")
(if (= ans "GL2")
(if (= ans "D")
(if (= ans "D1")
(if (= ans "C")
(if (= ans "K")
(if (= ans "N")
(if (= ans "N1")
(if (= ans "TO")
(if (= ans "GO")
(if (= ans "GO1")
(initdia)
(command "hatch")
(command pause)
Cảm ơn bạn nhiều nhé....
(if (= ans "B")
(if (= ans "B1")
(if (= ans "B2")
(if (= ans "BK")
(if (= ans "G")
(if (= ans "GD")
(if (= ans "GD1")
(if (= ans "GL")
(if (= ans "GL1")
(if (= ans "GL2")
(if (= ans "D")
(if (= ans "D1")
(if (= ans "C")
(if (= ans "K")
(if (= ans "N")
(if (= ans "N1")
(if (= ans "TO")
(if (= ans "GO")
(if (= ans "GO1")
(initdia)
(command "hatch")
(command pause)
Sao bạn không sửa getread thành getangle là được rồi mà.
8 phút trước, ngokiet đã nói:
Giờ biết thêm hàm này lâu nay đâu biết mà sử dụng
Cám ơn bạn nhiều!!!!
23 giờ trước, mr.thanh2610 đã nói:
Mình sửa lại cho bạn theo phiên bản gốc nè. Bạn có thể bổ sung hay thêm bớt các kiểu tùy ý và dễ sửa hơn.
(có thể chồng nhiều loại hatch như kiểu bêton)
Nếu bạn sửa (command "hatch") Thành  (command "-hatch")
Thì nó mặc định là pick điểm. Còn nhấn S sẽ là select.
sf-hatchnhanh.lsp
10 giờ trước, ngokiet đã nói:
(defun c:SF(/ en1 list1 i)
  (setq en1  (entlast)
	list1 '(("B"   ("ANSI32"   200  0.0) ("AR-CONC" 20 0.0))
		("B1"  ("AR-CONC"   20  0.0))
		("B2"  ("GRAVEL"   100  0.0))
		("BK"  ("SOLID"    200  0.0))
		("G"   ("ANSI31"   400  0.0))
		("GD"  ("AR-B816"   10  0.0))
		("GD1" ("FLGSTONE" 500  0.0))
		("GL"  ("NET"     1500  0.0))
		("GL1" ("ANGLE"    400  0.0))
		("GL2" ("AR-HBONE"  20  0.0))
		("D"   ("HOUND"    500 45.0))
		("D1"  ("EARTH"    500 45.0))
		("C"   ("AR-SAND"   20  0.0))
		("K"   ("AR-RROOF" 500 45.0))
		("N"   ("AR-RSHKE"  30  0.0))
		("N1"  ("SPANTILE" 400  0.0))
		("TO"  ("ANSI32"   200 45.0))
		("GO"  ("WOOD8"    700  0.0))
		("GO1" ("WOOD2" 500 0.0))
  (initget (apply 'strcat (mapcar '(lambda(x) (strcat (car x) " ")) list1)))
  (if (setq i (vl-position
		(getkword (strcat "\n Chon kieu hatch < "
				  (vl-string-right-trim "/" (apply 'strcat (mapcar '(lambda(x) (strcat (car x) "/")) list1)))
		(mapcar 'car list1)))
      (mapcar 'setvar '(hpname hpscale hpang)
	      (list (caar (setq i (cdr (nth i list1))))
		    (cadar i)
		    (*(/ (caddar i) 180) pi)))
      (initdia)
      (command "hatch")
	(command pause))
      (if (/= en1 (setq en1 (entlast)))
	(while (setq i (cdr i))
	  (entmakex
	    (mapcar '(lambda(x)
		       (cond ((eq (car x) 2) (cons 2 (caar i)))
			     ((eq (car x) 41) (cons 41 (cadar i)))
			     ((eq (car x) 52) (cons 52 (*(/(caddar i)180)pi)))
			     (T x)))
		    (entget en1)))
	  (setq i (cdr i))))))
Cảm ơn bạn nhiều nha, cái này rất đúng ý mình, bạn thật có tâm :)
Vào lúc 17/6/2019 tại 16:56, ngokiet đã nói:
sf-hatchnhanh.lsp
Bạn sửa giúp mình khi nhấn S thì có thể quét được nhiều đối tượng thay vì chọn tùng đối tượng không, thank !
