naturooo
Lisp Quick Filter: Lọc nhanh theo một số thuộc tính thông dụng
Thay vì lệnh Filter (FI) mặc định chọn rồi xoá xoá. Lisp Quick Filter (QF) này sẽ chọn một số thuộc tính thông dụng để lọc, giảm bớt vài thao tác thừa không cần thiết:
;; List Box  -  Lee Mac
;; Displays a DCL list box allowing the user to make a selection from the supplied data.
;; msg - [str] Dialog label
;; lst - [lst] List of strings to display
;; bit - [int] 1=allow multiple; 2=return indexes
;; Returns: [lst] List of selected items/indexes, else nil
(defun LM:listbox ( msg lst bit / dch des tmp rtn )
        (   (not
                (and
                    (setq tmp (vl-filename-mktemp nil nil ".dcl"))
                    (setq des (open tmp "w"))
                    (write-line
                        (strcat "listbox:dialog{label=\"" msg "\";spacer;:list_box{key=\"list\";multiple_select="
                            (if (= 1 (logand 1 bit)) "true" "false") ";width=50;height=15;}spacer;ok_cancel;}"
                        des
                    (not (close des))
                    (< 0 (setq dch (load_dialog tmp)))
                    (new_dialog "listbox" dch)
            (prompt "\nError Loading List Box Dialog.")
        (   t
            (start_list "list")
            (foreach itm lst (add_list itm))
            (end_list)
            (setq rtn (set_tile "list" "0"))
            (action_tile "list" "(setq rtn $value)")
            (setq rtn
                (if (= 1 (start_dialog))
                    (if (= 2 (logand 2 bit))
                        (mapcar '(lambda ( x ) (nth x lst)) (read (strcat "(" rtn ")")))
                      ;  (mapcar '(lambda ( x ) (nth x lst)) (read (strcat "(" rtn ")")))
    (if (< 0 dch)
        (unload_dialog dch)
    (if (and tmp (setq tmp (findfile tmp)))
        (vl-file-delete tmp)
    rtn
;====================================Main Lisp: Quick Filter (QF)======================================
(defun C:QF (/ ss ss1 ob lyrname colr blkname txth txtn lstQF lstDCL lstidx lstfi a)
  (setq ss1 (entsel "\nSelect Object: "))
  (while (or
	   (null ss1)
	   (= "" (cdr (assoc 0 (entget (car ss1)))))
  (setq ss1 (entsel "\nSelect Object Again: "))
  (setq ss (entget (car ss1)))
  (setq ob (cdr (assoc 0 ss)))
  (setq lstQF (list (cons 0 ob)))
  (if (= "INSERT" ob)
  	(setq lstDCL (list (strcat "Object           : " "Block")))
	(setq lstDCL (list (strcat "Object           : " ob)))
  );endif
  (setq lyrname (cdr (assoc 8 ss)))
  (setq lstQF (append lstQF (list (cons 8 lyrname))))
  (setq lstDCL (append lstDCL (list (strcat "Layer            : " lyrname))))
  (if (= 62 (car (assoc 62 ss)))
    	(setq colr (cdr (assoc 62 ss)))
        (setq lstQF (append lstQF (list(cons 62 colr))))
	(setq lstDCL (append lstDCL (list (strcat "Color            : " (rtos colr 2 0)))))
     );progn
	(setq lstQF (append lstQF '((62 . 256))))
	(setq lstDCL (append lstDCL (list (strcat "Color            : " "256"))))
  )					;end if
  (if (= 2 (car (assoc 2 ss)))
    	(setq blkname (cdr (assoc 2 ss)))
	(setq lstQF (append lstQF (list (cons 2 blkname))))
	(setq lstDCL (append lstDCL (list (strcat "Block Name       : " blkname))))
    );end progn
  )					;end if
  (if (= 40 (car (assoc 40 ss)))
    	(setq txth (cdr (assoc 40 ss)))
	(setq lstQF (append lstQF (list (cons 40 txth))))
	(setq lstDCL (append lstDCL (list (strcat "Text Height      : " (rtos txth)))))
    );end progn
  )					;end if
  (if (= 7 (car (assoc 7 ss)))
    	(setq txtn (cdr (assoc 7 ss)))
	(setq lstQF (append lstQF (list (cons 7 txtn))))
	(setq lstDCL (append lstDCL (list (strcat "Text Style Name  : " txtn))))
    );end progn
  )					;end if
 (setq lstidx (LM:listbox "Selection to Filter:" lstDCL 1))
 (foreach a lstidx
	(setq lstfi (append lstfi (list (nth a lstQF))))
(sssetfirst nil (ssget lstfi))
(Print "Write by: NghiaKieu")
  • Like 2
10 giờ trước, naturooo đã nói:
        (   (not
                (and
                    (write-line
                        des
                    (not (close des))
        (   t
            (start_list "list")
            (end_list)
            (setq rtn
    (if (< 0 dch)
        (unload_dialog dch)
    rtn
  (while (or
	   (null ss1)
  (if (= "INSERT" ob)
  );endif
     );progn
  );end if
    );end progn
  );end if
    );end progn
  );end if
    );end progn
  );end if
 (foreach a lstidx
lisp hay nhưng chọn màu còn bị lỗi rồi bác ơi,em test thử thấy cùng một màu 256 mà màu trắng với màu đỏ nó đều chọn hết,cùng một mã màu xanh mà cái thì nó chọn cái nó lại không chọn,những cái khác chưa test hết ạ
13 phút trước, vanlam6408 đã nói:
Mã 256 là By layer mà. Màu khác nhau nhưng để By layer thì nó chọn cả (Filter mặc định cũng vậy). Ý thứ 2 của bạn cũng như vậy.
5 phút trước, naturooo đã nói:
à vâng,ra thế,em tưởng nó có thể phân biệt được các màu khác nhau cả trong trường hợp by layer thì tốt quá
26 phút trước, vanlam6408 đã nói:
Lọc theo màu mà có màu đặt theo By layer thì khoai quá. Mình thì các nét toàn để By layer hết nên ít khi lọc theo màu lắm. Không biết các cao thủ trên có giải quyết được món này không? (Mình cũng Beginner :D)
53 phút trước, naturooo đã nói:
vâng.hi
11 giờ trước, vanlam6408 đã nói:
vâng.hi
(defun c:SelectByColour ( / c d e l )
   (if (setq e (car (entsel)))
           (setq c
                   (   (cdr (assoc 62 (entget e)))   )
                   (   (abs (cdr (assoc 62 (tblsearch "LAYER" (cdr (assoc 8 (entget e)))))))   )
           (while (setq d (tblnext "LAYER" (null d)))
               (if (= c (abs (cdr (assoc 62 d))))
                   (setq l (cons "," (cons (cdr (assoc 2 d)) l)))
           (sssetfirst nil
               (ssget "_X"
                   (if l
                       (list
                           (cons -4 "<OR")
                               (cons 62 c)
                               (cons -4 "<AND")
                                   (cons 62 256)
                                   (cons 8 (apply 'strcat (cdr l)))
                               (cons -4 "AND>")
                           (cons -4 "OR>")
                       (list (cons 62 c))
Mình tìm thấy cái chọn màu kể cả By layer của Lee Mac đây. Để lúc nào m thêm tuỳ chọn chọn cả theo màu của layer xem sao :)
18 giờ trước, naturooo đã nói:
Cũng chỉ là vào Table Layer của đối tượng đó rồi lấy màu thôi mà :)
26 phút trước, ketxu đã nói:
Vâng bác. Tại em chưa ngâm cứu đến bước đó nên thấy mới lạ lắm :(
12 giờ trước, naturooo đã nói:
  • selectbycolour.lsp
    lisp help
           (setq c
           (sssetfirst nil
               (ssget "_X"
                   (if l
                       (list
                           (cons -4 "<OR")
                               (cons 62 c)
                               (cons -4 "<AND")
                                   (cons 62 256)
                               (cons -4 "AND>")
                           (cons -4 "OR>")
                       (list (cons 62 c))
vâng,mong là qf sẽ sớm được hoàn thiện nhất.hi
22 giờ trước, vanlam6408 đã nói:
Đã chế lại màu lọc theo True Color (màu hiển thị). Bạn thử xem có lỗi gì k nhé!
(defun LM:listbox (msg lst bit / dch des tmp rtn)
    ((not
       (and
	 (write-line
		   msg
		     "true"
		     "false"
	   des
	 (not (close des))
    (t
     (start_list "list")
     (end_list)
     (setq rtn
		(mapcar	'(lambda (x) (nth x lst))
  (if (< 0 dch)
    (unload_dialog dch)
  rtn
;====================================Main Lisp: Quick Filter (QF) Update 19/08/2020 Loc theo "True Color"======================================
	     txth   txtn   lstQF  lstDCL lstidx	lstfi  a      c
	     d	    l
  (while (or
	   (null ss1)
  (if (= "INSERT" ob)
  );endif
  (setq	c
	   ((cdr (assoc 62 ss)))
	   ((abs (cdr (assoc 62 (tblsearch "LAYER" (cdr (assoc 8 ss)))))
(setq lstQF (append lstQF (list "True Color")))
  (setq	lstDCL (append lstDCL (list (strcat "True Color       : " (rtos c 2 0)))  )  )
    )					;end progn
  )					;end if
      (setq lstDCL
	     (append lstDCL
    )					;end progn
  )					;end if
    );end progn
  );end if
  (if lstidx
      (foreach a lstidx
	(if (= "True Color" (nth a lstQF))
		(if l
    			  (list
      				(cons -4 "<OR")
      				(cons 62 c)
      				(cons -4 "<AND")
      				(cons 62 256)
      				(cons -4 "AND>")
      				(cons -4 "OR>")
    			  (list (cons 62 c))
    ((not
       (and
	 (write-line
		   msg
		     "true"
		     "false"
	   des
	 (not (close des))
    (t
     (start_list "list")
     (end_list)
     (setq rtn
  (if (< 0 dch)
    (unload_dialog dch)
  rtn
	     d	    l
  (while (or
	   (null ss1)
  (if (= "INSERT" ob)
  );endif
  (setq	c
    );end progn
  );end if
      (setq lstDCL
	     (append lstDCL
    );end progn
  );end if
    );end progn
  );end if
  (if lstidx
      (foreach a lstidx
		(if l
    			  (list
      				(cons -4 "<OR")
      				(cons 62 c)
      				(cons -4 "<AND")
      				(cons 62 256)
      				(cons -4 "AND>")
      				(cons -4 "OR>")
    			  (list (cons 62 c))
hôm nay mới vào diễn đàn test thử hàng mới của bác ạ!Lisp chuẩn rồi bác ạ!cảm ơn bác đã cho em và diễn đàn một lisp mới thật là hay ạ!
Em có tải thử và sử dụng lisp, thấy khá tiện, mà không biết cách viết thêm để show 1 tính chất là dimstyle ấy ạ, Bác Naturooo có thể add thêm giúp em với hoặc chỉ em cách thêm được không ạ. Đa tạ bác nhiều.
2 giờ trước, tranhoang1218 đã nói:
Đây nhé bạn:
    ((not
       (and
	 (write-line
		   msg
		     "true"
		     "false"
	   des
	 (not (close des))
    (t
     (start_list "list")
     (end_list)
     (setq rtn
  (if (< 0 dch)
    (unload_dialog dch)
  rtn
	     txth   txtn   txtvl  lstQF	 lstDCL	lstidx dimsty lstfi
	     a	    c	   d	  l
  (while (or
	   (null ss1)
  (if (= "INSERT" ob)
  )					;endif
  (setq	c
    )					;end progn
  )					;end if
      (setq lstDCL
	     (append lstDCL
    )					;end progn
  )					;end if
    )					;end progn
  )					;end if
  (if (= 1 (car (assoc 1 ss)))
      (setq txtvl (cdr (assoc 1 ss)))
      (setq lstQF (append lstQF (list (cons 1 txtvl))))
			   (list (strcat "Text Value       : " txtvl))
    )					;end progn
  )					;end if
  (if (= 3 (car (assoc 3 ss)))
      (setq dimsty (cdr (assoc 3 ss)))
      (setq lstQF (append lstQF (list (cons 3 dimsty))))
		       (list (strcat "Dimension Style     : " dimsty))
    )					;end progn
  )					;end if
  (if lstidx
      (foreach a lstidx
	  (if l
				(list
				  (cons -4 "<OR")
				  (cons 62 c)
				  (cons -4 "<AND")
				  (cons 62 256)
				  (cons -4 "AND>")
				  (cons -4 "OR>")
				(list (cons 62 c))
      (sssetfirst nil)			; clear original-selection highlighting/gripping, then:
  • Like 4
1 giờ} trướ}c, tranhoang1218 đã nói:
Mà hình như lisp đang bị lỗi, bấm chọn vô cái nào nó cũng hiện bảng rồi tự động tắt luôn ạ.
Select Object: ; error: no function definition: ANDÏ»¿
Bản tải lại thử xem nhé
Vào lúc 15/6/2021 tại 11:54, naturooo đã nói:
Bác thêm giúp lọc thêm Value của Attribute giùm với , cảm ơn bác rẩt nhiều !!
