Chutuyen
Sửa lisp
Nhờ các bác sửa giúp đoạn lisp em sưu tầm được:
đoạn lisp coppy theo thứ tự từ trái qua phải, em muốn sửa thành coppy từ trên xuống dưới mong, các bác giúp đỡ? xin chân thành cảm ơn.!
(defun C:TCC (/ lst str txt 2ClipB) ;***** TCC = copy *****
  (princ "\nChon cac Text/Mtext/Dimension can copy...")
  (setq lst (acet-ss-to-list (ssget '((0 . "*TEXT,DIMENSION")))))
  (setq str "")
  (foreach n lst
      ((= (cdr (assoc 0 (entget n))) "TEXT")
       (setq txt (cdr (assoc 1 (entget n))))
      ((= (cdr (assoc 0 (entget n))) "MTEXT")
      ((= (cdr (assoc 0 (entget n))) "DIMENSION")
       (if (= (cdr (assoc 1 (entget n))) "")
     (setq txt (rtos (cdr (assoc 42 (entget n)))2 0))
    (setq str (strcat str txt "\n"))
  (vlax-invoke
    (vlax-get
      (vlax-get    (setq 2ClipB (vlax-create-object "htmlfile"))
        'ParentWindow
      'ClipBoardData
    'SetData
    "Text"
    str
  (vlax-release-object 2ClipB)
(defun C:DD (/ ss->vla s1 s2 s3 s11 s12 n e1 e2 i j i1 ii) ;***** DD -> da'n *****
    (setq s11 (QGetClipText))
    (princ "\nSelect Texts to Paste value:  ")
    (setq s2 (ssget '((0 . "*TEXT"))))
    (command "_.undo" "_be")
    (setq ii 0)
    (While (> (vl-string-search "\n" s11) 0)
        (setq s11 (vl-string-subst "*" "\n" s11))
        (setq ii (+ 1 ii))
    (setq s1 (vl-sort (ss_vla s2)
                 '(lambda (a b)
                (< (car (vlax-get a 'InsertionPoint))
                   (car (vlax-get b 'InsertionPoint))
    (setq s2 (vl-sort (ss_vla s2)
                 '(lambda (a b)
    (If (> ii (vl-list-length s2))
        (Progn
            (Alert "So kich thuoc copy nhieu hon so kich thuoc can da'n !")
            (command "_.undo" "_end")
            (Ext)
    (setq i1 -1)
    (setq s12 "")
    (While (> (strlen s11) 0)
        (setq s12 (substr s11 1 (vl-string-search "*" s11)))
        (setq s11 (vl-string-subst "" (strcat s12 "*") s11))
        (vla-put-textstring (nth (setq i1 (1+ i1)) s1) s12)
    (setq s3 "")
    (setq i 0)
    (setq j 1)
    (While (< i (- ii 1))
        (While (< j ii)
            (if (> (atof (vla-get-textstring (nth i s1))) (atof (vla-get-textstring (nth j s1))))
                (Progn
                (setq s3 (vla-get-textstring (nth i s1)))
                (vla-put-textstring (nth i s1) (vla-get-textstring (nth j s1)))
                (vla-put-textstring (nth j s1) s3)
            (setq j (+ 1 j))
        (setq  j (+ 1 i))
        (setq i (+ 1 i))
    (setq n  (min (vl-list-length s1) (vl-list-length s2)))
    (setq i  -1)
    (repeat n
        (vla-put-textstring
            (nth (setq i (1+ i)) s2)
Thay hết
thành
 (> (cadr (vlax-get a 'InsertionPoint))
                   (cadr (vlax-get b 'InsertionPoint))
9 phút trước, Chutuyen đã nói:
em làm theo hướng dẫn mà không được bác à?
                 '(lambda (a b)
                 '(lambda (a b)
thay cả 2 dòng này chưa ?
28 phút trước, Chutuyen đã nói:
không theo thứ tự b à?
gửi lại file cad lên đây. Có ghi rõ trước và sau khi chạy lisp nhé b.
