Minh Nghĩa
LISP RẢI BLOCKATT KẾT HỢP ĐÁNH SỐ THỨ TỰ
Nhờ các Pro giúp em, em muốn lisp vừa rải đối tượng vừa đánh số thứ tự cho BlockAtt, hoặc text
Mong các bác kết hợp giúp em 2 lệnh này thành 1 lệnh
1. lệnh rải đối tượng
(Defun c:RDT (/ ss)
(command "undo" "be")
(chonnhomdoituong)
(choncuver)
(raisoluong)
(command "undo" "end")
(Defun chonnhomdoituong ()
  (princ "\nChon doi tuong rai:")
  (setq ss (ssget))
      ((= ss nil) (princ "\nChua chon duoc doi tuong nao:") (chonnhomdoituong))
      ((/= ss nil)
 (setq dsl (sslength ss))
            ((= dsl 1)
(setq doituong (ssname SS 0))
(setq doituong (entget doituong))
(setq KIEUDOITUONG (cdr (assoc 0 doituong)))
                   ((= KIEUDOITUONG "INSERT") (setq dc (cdr (assoc 10 doituong))))
                   ((/= KIEUDOITUONG "INSERT") (setq dc (getpoint "\nChon diem goc: ")))
                   );ketthuccondxemblock
                 );kethucdsl1
            ((/= dsl 1) (setq dc (getpoint "\nChon diem goc: ")))
            );ketthuccondnho
);ketthucsetqdsl
 );ketthuccondtong
(Defun choncuver ()
(setq ddd (entsel "\nChon duong dan:"))
(while
(or
(null ddd)
(or (= "TEXT" (cdr (assoc 0 (entget (car ddd))))) (= "MTEXT" (cdr (assoc 0 (entget (car ddd))))) (= "HATCH" (cdr (assoc 0 (entget (car ddd))))) (= "INSERT" (cdr (assoc 0 (entget (car ddd))))) (= "REGION" (cdr (assoc 0 (entget (car ddd))))) (= "DIMENSION" (cdr (assoc 0 (entget (car ddd)))))
(setq ddd (entsel "\nDoi tuong khong the lam duong dan! Chon lai"))
(setq chondd (car ddd))
(setq luubatdiem (getvar "osmode"))
(setq chieudaicuver (vlax-curve-getDistAtParam chondd (vlax-curve-getEndParam chondd)))
(setq diemdau (vlax-curve-getPointAtDist chondd 0))
(setq diemcuoi (vlax-curve-getPointAtDist chondd chieudaicuver))
(setvar "osmode"luubatdiem)
(Defun raisoluong ()
(setq slc (getreal "\nChia duong dan thanh may lan:"))
(setq chieudaidoan (/ chieudaicuver slc))
(setq sl (fix (+ 1 slc)))
(thuchienrai)
(Defun thuchienrai (/ quaykhong)
  (setq quaykhong (strcase (getstring "\nCo quay doi tuong vuong goc voi duong dan khong: Khong/<Co>")))
(Cond
((= quaykhong "K") (setq copygiua copykoquay))
((/= quaykhong "K")(setq copygiua copyquay))
(setq index -1)
  (repeat sl
(setq index (1+ index))
(setq d2 (* chieudaidoan index))
(setq p2 (vlax-curve-getPointAtDist chondd d2))
(copygiua)
(defun copycuoiquay()
(setq d5 (- chieudaicuver 0.001))
(setq p5 (vlax-curve-getPointAtDist chondd d5))
 (setq L 0)
 (setq M (sslength ss))
 (while (< L M)
   (setq DT (ssname ss L))
   (command ".copy" DT "" dc p5)
   (command ".rotate" "last" "" diemcuoi p5)
   (command ".rotate" "last" "" diemcuoi 180)
   (setq L (1+ L))
(defun COPYQUAY(/ p3)
(setq d3 (+ (* chieudaidoan index) 0.001))
(setq p3 (vlax-curve-getPointAtDist chondd d3))
(Cond
((= p3 nil) (copycuoiquay))
((/= p3 nil)
 (setq L 0)
 (while (< L M)
   (command ".copy" DT "" dc p2)
   (command ".rotate" "last" "" p2 p3)
   (setq L (1+ L))
(defun COPYKOQUAY()
(command ".copy" ss "" dc p2 "")
2. lệnh đánh số thứ tự
(defun C:STT( / e e0 dn p1 cn c n p2 dat)
    e0 (car (entsel "\nSelect attribute block:"))
    e (entnext e0)
(if (/= (etype e) "ATTRIB") (progn (alert "Object is not a Attribute Block!") (exit)))
    dn (getint "\nIncrement <1>: ")
    p1 (getpoint "\nBase point:")
    cn (cdr (assoc 1 (entget e)))
(if (not dn) (setq dn 1))
(if (= cn "") (setq cn "1"))
    c (vl-string-right-trim "0 1 2 3 4 5 6 7 8 9" cn)
    n (vl-string-subst "" c cn)
(while (setq p2 (getpoint p1 "\nNew point <exit>: "))
    (command "copy" e0 "" p1 p2)
    (if (= n "")
        (setq cn (incC cn))
        (setq cn (strcat c (incN (vl-string-subst "" c cn) dn)))
        dat (entget (entnext (entlast)))
        dat (subst (cons 1 cn) (assoc 1 dat) dat)
    (entmod dat)
    (command "regen")
Thank you
