duy782006
Tổng hợp các lisp của Duy782006
Vào lúc 23/6/2025 tại 19:14, Nd_vnt đã nói:
sếp ơi, sếp nhận viết lisp cho nganh gỗ k ạ, dạng cad 3d, với lại thống kê cho cad 2d luôn ấy ạ
Sếp thì sao viết được. Sếp sẽ đuổi cổ ngay vì thống kê mà không đếm được.
Khồng!
Vào lúc 25/6/2025 tại 12:43, amateurday đã nói:
Lm cnc mà bác, ngày quá tr file ngồi đếm lòi họng luôn :v
On 4/17/2024 at 8:58 PM, duy782006 said:
1. This lisp is written based on personal work needs. Of course, when writing, I also aim to use it for many users, so the level of customization for users to choose is also relatively flexible (I think).
2. I'm still using cad2007 so in this lisp there are some cad tasks that are already available in higher versions, that's okay.
3. At first, I classified this bunch of lisps relatively coherently, but the more I wrote and edited, the more it became a tangled mess, so I couldn't separate each lisp anymore.
4. I tested it from cad2007 to 2022 and it worked fine, however, for some mysterious reason some machines couldn't load it and I haven't found the reason yet, so if you can't use it, it's not surprising.
5. To use, you download this file, unzip it to the lisp folder and copy it anywhere as long as the path does not contain Vietnamese with accents, then load all these lisps and use it.
6. Actually, I have no way to remember all the lisp commands and their uses, so I made a menu and a dialog box for this.
-For dialog box, you use THL command, it will open dialog box, with command name and effect (Vietnamese with accents), click on any command to execute that command.
-Menu: when lisp is loaded, type the command TMMN and it will create a menu named tuy782006 (Vietnamese without accents).
7. Throughout this lisp, I have 2 important commands: EDT and EDB:
-EDB command is used to edit blocks. In many commands, I use some blocks (generated by lisp). If some blocks are special, EDB command will edit them in the way I want, and other blocks will only edit the parameters like normal block editing command.
-EDT command is used to edit objects such as text, att. If you select blocks that need to calculate values, they will be updated in the way you want, and for other text, att, you only edit the parameters like the normal text edit command.
8. Now, I will slowly introduce each command and specific applications in work.  If anyone is also looking for academic support, especially in subjects like economics, I recommend checking out MyAssignmentHelp economics essay writer — they provide reliable and quality assistance for students.
lisp.rar
Thanks for sharing your lisp and all these detailed explanations! It's really impressive how much effort you've put into making it flexible and useful across different versions of CAD, especially considering you started with CAD 2007. The menu and dialog box features sound like great user-friendly touches, which definitely help with command recall and ease of use.
It's interesting that some machines have trouble loading it—sometimes those issues can be due to system configurations or security settings. Hopefully, you can pinpoint the cause soon, but it's great that it works smoothly on most systems.
Looking forward to seeing your introduction of each command and its applications. Your approach to editing blocks and objects with EDT and EDB commands sounds very practical and efficient for daily CAD tasks.
Thanks again for sharing your work—this will surely help a lot of users! If you need any help troubleshooting or want to discuss specific commands, feel free to ask.
Vào lúc 16/8/2025 tại 11:29, quangcda đã nói:
Bác duy giúp gửi hàm CAL với ạ! Thiếu nên vẽ dầm dọc (VDD) và VCOTL không được ạ!
Bạn mở cad lên gỏ lệnh CAL (có sẳn trong cad) một lần là sau đó lisp chạy được thôi. mình đã lồng vào rồi nhưng có lúc bị vậy, chịu khó chút.
