vcdichoi
Tính diện tích quy đổi ra m2
Em chào Các Bác trên điễn đàn
Em tham khảo được đoạn code tính diện tích, đoạn code ghi kết quả ra mm2, giờ em muốn quy đổi đơn vị diện tích ra m2
Rất mong dược các bác sửa giúp em với ạ! em xin cảm ơn!
Quote
;;------------------------=={ Areas to Field }==------------------------;;
;;  This program allows a user to create an MText object containing a   ;;
;;  Field Expression referencing the area, or sum of areas, of one or   ;;
;;  more selected objects.                                              ;;
;;  Upon issuing the command syntax 'A2F' at the AutoCAD command-line,  ;;
;;  the user is prompted to make a selection of objects for which to    ;;
;;  retrieve the area; if more than one object is selected, the         ;;
;;  cumulative area for all objects will be displayed by the resultant  ;;
;;  MText Field.                                                        ;;
;;  Following object selection, the user is prompted to pick a point    ;;
;;  at which to create the MText Field. If the specified point resides  ;;
;;  within an AutoCAD table cell, the program will populate the table   ;;
;;  cell with the appropriate Field Expression.                         ;;
;;  The Field will display the sum of the areas of the selected         ;;
;;  objects, formatted using the Field formatting code specified at     ;;
;;  the top of the program - this formatting code may be altered to     ;;
;;  suit the user's requirements.                                       ;;
;;  Author:  Lee Mac, Copyright   2014  -  www.lee-mac.com              ;;
;;  Version 1.3    -    2014-07-17                                      ;;
(defun c:a2f ( / *error* fmt inc ins lst sel str )
    (setq fmt "%lu6%qf1") ;; Field Formatting
    (defun *error* ( msg )
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
    (if (and (setq sel (ssget '((0 . "ARC,CIRCLE,ELLIPSE,HATCH,*POLYLINE,REGION,SPLINE"))))
             (setq ins (getpoint "\nPick point or cell for field: "))
            (if (setq tmp
                    (ssget "_X"
                        (list '(0 . "ACAD_TABLE")
                            (if (= 1 (getvar 'cvport))
                                (cons 410 (getvar 'ctab))
                               '(410 . "Model")
                (repeat (setq idx (sslength tmp))
                    (setq tab (cons (vlax-ename->vla-object (ssname tmp (setq idx (1- idx)))) tab))
            (if (= 1 (sslength sel))
                (setq str
                    (strcat
                        "%<\\AcObjProp Object(%<\\_ObjId "
                        (LM:ObjectID (vlax-ename->vla-object (ssname sel 0)))
                        ">%).Area \\f \"" fmt "\">%"
                    (repeat (setq idx (sslength sel))
                        (setq lst
                            (vl-list*
                                (LM:ObjectID (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))))
                                ">%).Area>%" " + "
                                lst
                    (setq str
                        (strcat
                            "%<\\AcExpr "
                            (apply 'strcat (reverse (cdr (reverse lst))))
                            " \\f \"" fmt "\">%"
            (LM:startundo (LM:acdoc))
            (if (setq tmp (LM:getcell tab (trans ins 1 0)))
                (apply 'vla-settext (append tmp (list str)))
                (vla-addmtext
                    (vlax-get-property (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
                    (vlax-3D-point (trans ins 1 0))
                    0.0
                    str
;; ObjectID  -  Lee Mac
;; Returns a string containing the ObjectID of a supplied VLA-Object
;; Compatible with 32-bit & 64-bit systems
(defun LM:ObjectID ( obj )
    (eval
        (list 'defun 'LM:ObjectID '( obj )
            (if
                (and
                    (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
                    (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)
                (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
               '(itoa (vla-get-objectid obj))
    (LM:ObjectID obj)
;; Get Cell  -  Lee Mac
;; If the supplied point lies within a cell boundary,
;; returns a list of: (<VLA Table Object> <Row> <Col>)
(defun LM:getcell ( lst pnt / dir )
    (setq dir (vlax-3D-point (trans (getvar 'viewdir) 1 0))
          pnt (vlax-3D-point pnt)
    (vl-some
       '(lambda ( tab / row col )
            (if (= :vlax-true (vla-hittest tab pnt dir 'row 'col))
                (list tab row col)
        lst
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
(vl-load-com) (princ)
;;                             End of File                              ;;
Areas2FieldV1-3.lsp
1 giờ trước, vcdichoi đã nói:
Areas2FieldV1-3.lsp
tìm chỗ này:
sửa thành một trong các dòng sau:
(setq fmt "%lu6%qf1%ct8[1e-6] ") ;; Field Formatting - theo dinh dang cua ban ve
(setq fmt "%lu2%pr1%ct8[1e-6]")  ;; Field Formatting - pr0,1,2,3...so le la 0,1,2,3 chu so
hoặc dùng lisp này
https://www.lee-mac.com/lengthfield.html
6 phút trước, vietduc147258 đã nói:
tìm chỗ này:
hoặc dùng lisp này
cảm ơn bác ạ!
