Tapsutracdia
Em xin giúp đỡ về Lisp ạ
Anh chị cho em hỏi trước dùng cad 2007 thì load được mà giờ em dùng cad 2022 là thì load mãi n kh được là bị lsao vậy ạ?
;; free lisp from cadviet.comHSKT.lsp
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;HSKT.lsp
;;;Chuong trinh danh so va lap bang toa do ho so thua dat dia chinh
;;;Bang toa do tao thanh block, duoc dat ten theo so thu tu 1, 2, 3...
;;;Chap nhan cac doi tuong la Region, Polyline, Line va Arc khep kin
;;;Written by ssg and elleHCSC - January 2009 - www.cadviet.com
;;;PUBLIC FUNCTIONS
(Defun DTR (x) (/ (* x pi) 180))
;;;change degree to radian, return REAL
(defun lineP (p0 a r / p1)
;;;Line polar: point, degree angle, radius
  (setq p1 (polar p0 (dtr a) r))
  (command "line" p0 p1 "")
(defun linePX (p0 x) (lineP p0 0 x))
;;;Horizontal line: length x, from p0
(defun linePY (p0 y) (lineP p0 90 y))
;;;Vertical line: length y, from p0
(defun getVert (e / i L)
;;;Return list of all vertex from pline e
  (setq    i 0
    L nil
  (repeat (fix (+ (vlax-curve-getEndParam e) 1))
    (setq L (append L (list (vlax-curve-getPointAtParam e i))))
    (setq i (1+ i))
  L
;;; First point of List rearrangement
(defun relist(pt0 Lst / i rt)
  (setq i 0)
  (foreach pt Lst
    (if (equal pt0 pt 0.001)
      (setq rt i))
    (setq i (1+ i)))
  (append (append (member (nth rt Lst) Lst)
         (cdr (reverse (cdr (member (nth rt Lst) (reverse Lst))))))
      (list (nth rt Lst)))
;;;New Layer
(defun newlayer(a b c d)
    (if (not (tblsearch "layer" a))
       (command "-layer" "n" a "c" b a "l" c a "lw" d a ""))
(defun wtxtMC (txt p h k)
;;;Write text Middle Center, specify text, point, height
  (entmake (list (cons 0 "TEXT")
         (cons 7 (getvar "textstyle"))
         (cons 1 txt)
         (cons 10 p)
         (cons 11 p)
         (cons 40 h)
         (cons 72 1)
         (cons 73 2)
         (if k (cons 51 (DTR 18)) (cons 51 0))
(defun Collect (e / e2 SS)
;;;Selection set from e to entlast
  (setq SS (ssadd))
  (ssadd e SS)
  (while (setq e2 (entnext e)) (ssadd e2 SS) (setq e e2))
  SS
(defun Collect1    (e / ss)
;;;Selection set after e to entlast. If e nil, select all from fist entity of drawing.
  (if (= e nil)
    (setq ss (collect (entnext)))
    (progn (setq ss (collect e)) (ssdel e ss))
;;;PRIVATE FUNCTIONS
(defun txt1 (txtL / p1 p2 p3 p4 pL i)
;;;Write texts in 1 row
    p1 (list (+ (car p0) (* 2 h)) (- (cadr p0) (* 1.5 h)))
    p2 (polar p1 0 (* 7 h))
    p3 (polar p2 0 (* 10 h))
    p4 (polar p3 0 (* 9 h))
    pL (list p1 p2 p3 p4)
    i  0
  (repeat 4
    (wtxtMC (nth i txtL) (nth i pL) h t)
    (setq i (1+ i))
(defun txt2 (txtL / p1 p2 p3 p4 pL i)
    p4 (polar p4 (* 0.5 pi) h)
    i  0
  (repeat 4
    (setq i (1+ i))
;;;MAIN PROGRAM
(defun C:HSKT (/ h p et p0 p00 p01 p02 pt pvL n j pv num txtL ss bn ntp)
  (setvar "cmdecho" 0)
;;;New layer check
  (newlayer "kichthuoc" 7 "continuous" "default")
  (newlayer "stt" 1 "continuous" "default")
  (newlayer "bangtd" 7 "continuous" "default")
;;;GET TEXT HEIGHT
  (if (not h0)  (setq h0 1))
  (setq h (getreal (strcat "\nChon chieu cao text <" (rtos h0) ">:")))
  (if (not h)  (setq h h0)  (setq h0 h))
;;;GET DECIMAL PRECISION
  (if (not ntp0)  (setq ntp0 2))
  (setq ntp (getint (strcat "\nSo chu so thap phan <" (itoa ntp0) ">:")))
  (if (not ntp)  (setq ntp ntp0)  (setq ntp0 ntp))
;;;GET CIRCLE RADIUS
  (if (not cr0)  (setq cr0 0.3))
  (setq cr (getreal (strcat "\nNhap ban kinh vong tron <" (rtos cr0) ">:")))
  (if cr (setq cr0 cr))
;;;PICK & BASE POINT
  (initget "Y")
  (setq save (getkword "\nBan co muon luu file? < Y / Enter for No >:"))
  (setq oldos (getvar "osmode")
    pdau (getpoint "\nPick diem dau tien (so thu tu = 1) :"))
  (while pdau
    (setq p (getpoint "\nPick 1 diem giua mien kin:")
      pvL nil pvL1 nil)
    (command "boundary" p "")
    (setq et (entlast)
          pvL1 (reverse (getvert et)))
    (redraw et 3)
    (setq p00 (getpoint "\nDiem dat Bang TDGR:"))
    (command "erase" et "")
    (setq  p0 p00
           p01  (polar p00 (* 1.5 pi) (* h 3))
           pvL  (relist pdau pvL1)
           n    (length pvL)
           p02    (polar p01 (* 1.5 pi) (+ (* h 3) (* (1- n) h 2)))
;;;HEADER
  (setvar "CLAYER" "bangtd")
  (linepx p0 (* 32 h))
  (command "copy" "L" "" "m" p00 p01 p02 "")
  (linepy p0 (- (distance p0 p02)))
       (list (+ (car p0) (* 4 h)) (cadr p0))
       (list (+ (car p0) (* 14 h)) (cadr p0))
       (list (+ (car p0) (* 24 h)) (cadr p0))
       (list (+ (car p0) (* 32 h)) (cadr p0))
  (setq Lkqua nil)
  (wtxtMC "BAÛNG TOÏA ÑOÄ GOÙC RANH"
      (polar (polar p0 0 (* 16 h)) (* 0.5 pi) (* 2 h))
         (* 1.2 h) nil)
  (txt1 (setq Lkq (list "TT" "X (m)" "Y (m)" "S (m)")))
  (setq Lkqua (append Lkqua (list Lkq)))
  (setq p0 (polar p0 (* 1.5 pi) (* 3 h)))
;;;MAKE RECORDS
  (setq    j  0
    pt nil)
  (repeat n
      pv  (nth j pvL)
      num (itoa (1+ j))
    (if    pt
      (setq S (rtos (distance pt pv) 2 ntp))
      (setq S "")
      txtL (list num (rtos (car pv) 2 ntp) (rtos (cadr pv) 2 ntp) S)
      Lkqua (append Lkqua (list txtL))
    (txt2 txtL)
    (setq p0 (polar p0 (* 1.5 pi) (* 2 h)))
    (setq pt pv)
    (setq j (1+ j))
    (if    (= j (- n 1))  (setq j 0))
;;;MAKE BLOCK
  (setq ss (collect1 et))
  (setq bn "1")
  (while (tblsearch "block" bn)
    (setq bn (itoa (1+ (atoi bn))))
  (command "block" bn p00 ss "")
  (command "insert" bn p00 "" "" "")
;;;WRITE POINT NAME
  (setvar "CLAYER" "stt")
  (setq j 0)
  (repeat (1- n)
      pv  (nth j pvL)
      num (itoa (1+ j))
    (wtxtMC num (polar pv 0 h) h t)
    (command "circle" pv cr0)
    (command "hatch" "S" (setq vtron (entlast)) "")
    (command "erase" vtron "")
    (setq j (1+ j))
;;;GHI CANH THUA
    (setvar "CLAYER" "kichthuoc")
    (ghicanh)
;;;FINISH
    (savef)
    (setvar "osmode" oldos)
    (setq pdau (getpoint "\nPick diem dau tien (so thu tu = 1) :"))
  (setvar "cmdecho" 1)
(defun savef()
  (if save
      (setq file (open (setq tenfile (strcat (getvar "dwgprefix")
     (vl-filename-base (vl-string-right-trim "\\" (getvar "dwgname"))) ".txt")) "a"))
      (foreach line Lkqua
    (setq line1 "")
    (foreach it line
      (setq line1 (strcat line1 " " it)))
    (write-line line1 file)
      (close file)
      (princ (strcat "\nDa luu thanh file " tenfile))
;;;PHAN BO SUNG CUA elleHCSC
(defun Text_canh_TCA (S p a)
;;;Entmake text S at p with angle A - Top Center
  (if (/= p nil)
    (entmake (list
           (cons 0 "TEXT")
           (cons 62 5)
           (cons 10 p)
           (cons 40 h)
           (cons 1 S)
           (cons 50 a)
           (cons 41 0.7)
           (cons 72 1)
           (cons 11 p)
           (cons 73 3)
(defun Text_canh_BCA (S p a)
;;;Entmake text S at p with angle A - Bottom Center
  (if (/= p nil)
    (entmake (list
           (cons 0 "TEXT")
           (cons 62 5)
           (cons 10 p)
           (cons 40 h)
           (cons 1 S)
           (cons 50 a)
           (cons 41 0.7)
           (cons 72 1)
           (cons 11 p)
           (cons 73 1)
(defun Ghicanh (/ i k p1 p2 dist rad x_mp y_mp mp)
    i    0
    k    (1- (length pvL))
  (repeat k
      p1   (nth i pvL)
      p2   (nth (+ i 1) pvL)
      dist (distance p1 p2)
      rad  (angle p1 p2)
      x_mp (* (+ (car p1) (car p2)) 0.5)
      y_mp (* (+ (cadr p1) (cadr p2)) 0.5)
      mp   (list x_mp y_mp)
    (if    (and (> rad (* 0.5 pi)) (<= rad (* 1.5 pi)))
      (setq mp (polar mp (+ rad (* 0.5 pi)) (* 0.3 h)))
    (setq rad (+ rad pi))
    (Text_canh_TCA (rtos dist 2 2) mp rad)
      (Text_canh_BCA (rtos dist 2 2) mp rad)
    (setq i (1+ i))
  ;; repeat k;
Chắc có lisp nào khác load sau ghi đè hàm con làm cho nó triển khai không đúng gây ra lỗi runtime.
Tôi copy code đó vào chạy lệnh HSKT đó bình thường.
Bạn nên nhét toàn bộ các hàm con phía trên, dưới vào trong lệnh (defun C:HSKT () .......)  . Lúc đó nó sẽ chạy đúng bởi lúc thi hành lệnh sẽ khai báo lại hàm theo đúng chức năng mà lệnh mong muốn.
Nếu bạn không tự làm được hãy nhờ 1 con chat nào đó sửa với prompt như sau (có dán thêm code phía sau): Tổ chức và tối ưu lại code cho lệnh để không bị các hàm con nằm ngoài gây ảnh hưởng đến các lisp khác, chỗ nào dùng command sẽ đổi sang entmake.
