hatieu
Nhờ giải thích về vla-....???
Các bác giúp em với. Mấy cái này học ở trong mấy tài liệu về lisp không có. Mong các bác giúp đỡ.
Như đoạn lisp của bác Giabach:
;; free lisp from cadviet.com
(defun c:BlkQty (/ blk_id blk_len blk_name blks ent h header_lsp height i j
	 len0 lst_blk msp pt row ss str tblobj width width1 width2 x y)
;;  By : Gia Bach, gia_bach @  www.CadViet.com			;;
(defun TxtWidth (val h msp / txt minp maxp)
 (setq	txt (vla-AddText msp val (vlax-3d-point '(0 0 0)) h))
 (vla-getBoundingBox txt 'minp 'maxp )
 (vla-Erase txt)
 (-(car(vlax-safearray->list maxp))(car(vlax-safearray->list minp)))  )
(defun GetOrCreateTableStyle (tbl_name / name namelst objtblsty objtblstydic tablst txtsty)
 (setq objTblStyDic (vla-item (vla-get-dictionaries *adoc) "ACAD_TABLESTYLE") )
 (foreach itm (vlax-for itm objTblStyDic
	 (setq tabLst (append tabLst (list itm))))
(if (not
  (vl-catch-all-error-p
	(setq name (vl-catch-all-apply 'vla-get-Name (list itm)))))
  (setq nameLst (append nameLst (list name)))  )  )
 (if (not (vl-position tbl_name nameLst))
(vla-addobject objTblStyDic tbl_name "AcDbTableStyle"))
 (setq objTblSty (vla-item objTblStyDic tbl_name)
TxtSty (variant-value (vla-getvariable *adoc "TextStyle")))
 (mapcar '(lambda (x)(vla-settextstyle objTblSty x TxtSty))
	  (list acTitleRow acHeaderRow acDataRow) )
 (vla-setvariable *adoc "CTableStyle" tbl_name) )
(defun GetObjectID (obj)
 (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
(vlax-invoke-method *util 'GetObjectIdString obj :vlax-false )
(vla-get-Objectid obj)))
;main
 (if (setq ss (ssget (list (cons 0 "INSERT"))))
  (setq i -1 len0 8)
  (while (setq ent (ssname ss (setq i (1+ i))))
(setq blk_name (cdr (assoc 2 (entget ent))))
(if (> (setq blk_len (strlen blk_name)) len0)
  (setq str blk_name len0 blk_len) )
(if (not (assoc blk_name lst_blk))
  (setq lst_blk (cons (cons blk_name 1) lst_blk))
  (setq lst_blk (subst (cons blk_name (1+ (cdr (assoc blk_name lst_blk))))
			   (assoc blk_name lst_blk) lst_blk)))		)
  (setq lst_blk (vl-sort lst_blk '(lambda (x y) (< (car x) (car y)) ) ))
  (or *h* (setq *h* (* (getvar "dimtxt")(getvar "dimscale"))))
  (initget 6)
  (setq h (getreal (strcat "\nChieu cao chu <" (rtos *h*) "> :")))
  (if h (setq *h* h) (setq h *h*) )
  (or *adoc (setq *adoc (vla-get-ActiveDocument (vlax-get-acad-object))))
  (setq msp (vla-get-modelspace *adoc)
	*util (vla-get-Utility *adoc)
	blks (vla-get-blocks *adoc))
  (setq width1 (* 2 (TxtWidth "STT" h msp))
	width (* 2 (TxtWidth "So luong" h msp))
	height (* 2 h))
  (if str
(setq width2 (* 1.5 (TxtWidth (strcase str) h msp)))
(setq width2 width))
  (if (> h 3)
(setq width (* (fix (/ width 10))10)
	  width1 (* (fix (/ width1 10))10)
	  width2 (* (fix (/ width2 10))10)
	  height (* (fix (/ height 5))5)))
  (GetOrCreateTableStyle "CadViet")
  (setq pt (getpoint "\nDiem dat Bang :")
	TblObj (vla-addtable msp (vlax-3d-point pt) (+ (length lst_blk) 2) 5 height width))
  (vla-put-regeneratetablesuppressed TblObj :vlax-true)
  (vla-SetColumnWidth TblObj 0 width1)
  (vla-SetColumnWidth TblObj 1 width2)
  (vla-put-vertcellmargin TblObj (* 0.75 h))
  (vla-put-horzcellmargin TblObj (* 0.75 h))
  (mapcar '(lambda (x)(vla-setTextHeight TblObj x h))
  (mapcar '(lambda (x)(vla-setAlignment TblObj x 8))
	  (list acTitleRow acHeaderRow acDataRow))
  (vla-MergeCells TblObj 0 0 0 4)
  (vla-setText TblObj 0 0 "Bang thong ke")
  (setq j -1 header_lsp (list "STT" "Ten" "Don vi" "So luong" "Ky hieu"))
  (repeat (length header_lsp)
(vla-setText TblObj 1 (setq j (1+ j)) (nth j header_lsp)))
  (setq row 2 i 1)
  (foreach pt lst_blk
(setq blk_name (car pt) j -1)
(mapcar '(lambda (x)(vla-setText TblObj row (setq j (1+ j)) x))
	(list i blk_name "cai" (cdr pt)))
(vla-SetBlockTableRecordId TblObj row 4 (GetObjectID (vla-item blks blk_name)) :vlax-true)
(vla-SetCellAlignment TblObj row 1 7)
(vla-SetCellAlignment TblObj row 3 9)
(setq row (1+ row) i (1+ i))	)
  (vla-put-regeneratetablesuppressed TblObj :vlax-false)
  (vlax-release-object TblObj) )  )
