hanam1210
lisp đổi font của text style siêu nhanh !
Bản full option gửi anh em nhé.
Có sử dụng thêm List Box with Filter của cụ lee.
http://www.lee-mac.com/filtlistbox.html
anh em dùng cái này nhé
(defun c:cfst (/ doc sty font lst system)
    doc (vla-get-activedocument (vlax-get-acad-object))
    sty (vla-get-textstyles doc)
    system (strcat (getenv "systemroot") "\\Fonts")
    font (vl-directory-files (vl-string-translate "/" "\\" system) nil 1)
    font (vl-remove-if-not '(lambda (x) (vl-string-search "TTF" (strcase x))) font)
  (vlax-for s sty (setq lst (cons (vla-get-name s) lst)))
  (if (and
        (setq lst (LM:filtlistbox "Select Style" lst t))
        (setq font (car (LM:filtlistbox "Select Font" font nil)))
        (setq font (strcat system "\\" font))
    (foreach item lst
      (vla-put-fontfile (vla-item sty item ) font)
  (vla-regen doc acActiveViewport)
(defun LM:filtlistbox ( msg lst mtp / _addlist dch dcl des rtn sel tmp )
  (defun _addlist ( key lst )
    (start_list key)
    (foreach x lst (add_list x))
    (end_list)
    lst
  (if (and
        (setq dcl (vl-filename-mktemp nil nil ".dcl"))
        (setq des (open dcl "w"))
        (write-line (strcat
          "filtlistbox : dialog { label = \"" msg "\"; spacer;"
          ": list_box { key = \"lst\"; width = 50; fixed_width = true; height = 15; fixed_height = true; allow_accept = true; "
          "multiple_select = " (if mtp "true" "false") "; }"
          ": edit_box { key = \"flt\"; width = 50; fixed_width = true; label = \"Filter:\"; }"
          "spacer; ok_cancel; }") des)
        (not (close des))
        (< 0 (setq dch (load_dialog dcl)))
        (new_dialog "filtlistbox" dch)
      (_addlist "lst" (setq tmp lst))
      (set_tile "lst" (setq rtn "0"))
      (set_tile "flt" "*")
      (action_tile "lst" "(setq rtn $value)")
      (action_tile "flt" (vl-prin1-to-string '(progn
          flt (strcat "*" (strcase $value) "*")
          sel (mapcar '(lambda ( n ) (nth n tmp)) (read (strcat "(" rtn ")")))
        (_addlist "lst" (setq tmp (vl-remove-if-not '(lambda ( x ) (wcmatch (strcase x) flt)) lst)))
        (set_tile "lst" (setq rtn (vl-string-trim "()"
          (vl-princ-to-string (cond ((vl-sort (vl-remove nil (mapcar '(lambda ( x ) (vl-position x tmp)) sel)) '<))('(0)))))))
      (setq rtn (if (= 1 (start_dialog)) (mapcar '(lambda ( x ) (nth x tmp)) (read (strcat "(" rtn ")")))))
  (if (< 0 dch) (setq dch (unload_dialog dch)))
  (if (and (= 'str (type dcl)) (findfile dcl)) (vl-file-delete dcl))
  rtn
Vào lúc 9/3/2023 tại 08:58, tannguyen291 đã nói:
Bác cứ đùa em. Bác viết lisp lão làng rồi mà.
cái này do đường dẫn không có font em_khong_co.ttf.
Hoặc OS của bác không cài tại ổ C. Phải chỉnh lại 1 chút :))
Ý mình là lúc code các coder cứ chịu khó catch error đi thì sau này tay lên nhanh hơn. Nhiều lúc thấy nó có thể lỗi mà lười lên ... chẹp.
Vào lúc 9/3/2023 tại 09:14, tannguyen291 đã nói:
  (if (and
    (foreach item lst
    (start_list key)
    (end_list)
    lst
  (if (and
        (write-line (strcat
        (not (close des))
  rtn
Nhờ Các Bác có thể điều chỉnh thêm cả font .shx không ạ. Cám ơn các Bác.
