AutoCAD.NET: Chọn các text trùng điểm chèn.
Do trên Autodesk forum có 1 bạn hỏi về tìm các text trùng nhau, tôi post lên đây để mọi người tham khảo.
Code chọn các text trùng điểm chèn.
using System;
using System.Collections.Generic;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
namespace Gia_Bach
    public class TextDuplicatePosition
        [CommandMethod("GetTextOverlap")]
        public void GetTextOverlap()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.AllowDuplicates = false;
            pso.MessageForAdding = "Select Text";
            pso.RejectObjectsOnLockedLayers = true;
            TypedValue[] tv = { new TypedValue((int)DxfCode.Start, "Text") };
            SelectionFilter sf = new SelectionFilter(tv);
            PromptSelectionResult psr = ed.GetSelection(pso, sf);
            if (psr.Status != PromptStatus.OK)
                return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                Dictionary<Point3d, List<DBText>> dic = new Dictionary<Point3d, List<DBText>>();
                int sosole = 1;
                Point3d insPt;
                foreach (ObjectId oid in psr.Value.GetObjectIds())
                    DBText txt = tr.GetObject(oid, OpenMode.ForRead) as DBText;
                    if (txt.Justify == AttachmentPoint.BaseLeft)
                        insPt = txt.Position;
                    else
                        insPt = txt.AlignmentPoint;
                    insPt = RoundAndFlaten(insPt, sosole);
                    if (dic.ContainsKey(insPt))
                        List<DBText> lst = dic[insPt];
                        lst.Add(txt);
                        dic[insPt] = lst;
                    else
                        dic.Add(insPt, new List<DBText>() { txt });
                // đổi màu các text trùng nhau
                int color = 151;
                foreach (KeyValuePair<Point3d, List<DBText>> kvp in dic)
                    List<DBText> txtLst = kvp.Value;
                    if (txtLst.Count > 1)
                        // đổi màu
                        foreach (DBText txt in txtLst)
                            txt.UpgradeOpen();
                            txt.ColorIndex = color;
                tr.Commit();
        Point3d RoundAndFlaten(Point3d pt, int digits)
            return new Point3d(Math.Round(pt.X, digits), Math.Round(pt.Y, digits), 0);
File dll cho CAD 2013~2021 cho các bạn sử dụng,
NETTLOAD để load dll vào CADvà gõ lệnh GetTextOverlap thực thi.
GetTextOverlap.zip
  • Vote tăng 1
Vào lúc 20/7/2021 tại 13:33, gia_bach đã nói:
  • cadvietlisp.lsp
    lisp help
using ;
using ;
using ;
using ;
using ;
using ;
using ;
namespace Gia_Bach
            Document doc = ;
            Database db = ;
            Editor ed = ;
            pso.AllowDuplicates = ;
            pso.RejectObjectsOnLockedLayers = ;
            TypedValue[] tv = { new TypedValue((int)DxfCode.Start, "Text") ;
                int sosole = ;
                Point3d ;
                    DBText txt = tr.GetObject(oid, OpenMode.ForRead) as ;
                        insPt = ;
                    else
                        insPt = ;
                        List<DBText> lst = ;
                        lst.Add(txt);
                        dic[insPt] = ;
                    else
                int color = ;
                    List<DBText> txtLst = ;
                        // đổi màu
                            txt.UpgradeOpen();
                            txt.ColorIndex = ;
                tr.Commit();
GetTextOverlap.zip
Có cách nào dùng có cho cad từ 2007-2010 không anh
24 phút trước, huyenle đã nói:
Bạn dùng thử file này cho cad 2007-2010, tôi ko chắc lắm vì ko có cad 2007 để test.
GetTextOverlap_CAD2007.zip
