sgcq 726 Báo cáo bài đăng Đã đăng Tháng 4 19, 2016 :D :D :D 1331 mẫu hatch patern thường dùng trong cad. Thư mục chép hatch đề xuất : C:\Users\SGCQ\AppData\Roaming\Autodesk\AutoCAD 2017\R21.0\enu\Support Hoặc bạn có thể để đâu tùy ý, xong vào option trỏ về. Link ở đây: Danh mục ở đây: 'STROIDS.PAT, 116.56505.pat, 12inrun1.pat, 12INRUN2.PAT, 12INRUN3.PAT, 13.pat, 153.43494.pat, 172.87498.pat, 1x1grid.pat, 1x2grid.pat, 1x4grid.pat, 24x48.pat, 26.56505.pat, 2h-stone.pat, 2x1grid.pat, 2x2.pat, 2X2BRICK.PAT, 2X2BRIKC.PAT, 2X2BRIKS.PAT, 2x4.pat, 3BRICK.PAT, 3TAB.PAT, 3xbrick.pat, 3xbrick2.pat, 4.pat, 4h-stone.pat, 4x1grid.pat, 9.pat, ACAD.PAT, adobe.pat, Aecconc.pat, Aecinsul.pat, Aecline.pat, Aecnet.PAT, agglom.pat, AGGREGAT.PAT, alarg1.pat, Alberelli.pat, Alberi01.pat, Alberi02.pat, Alberi03.pat, Alberi04.pat, Alberi05.pat, Alberi06.pat, Alberi07.pat, Alberi08.pat, alpes.pat, alumin.pat, ampli102.pat, ampli104.pat, ampli3.pat, ANCHORLK.PAT, andes.pat, angle.pat, anh.pat, ankh1.pat, ankh2.pat, ankh3.pat, ansi31.pat, ansi32.pat, ansi33.pat, ansi34.pat, ansi35.pat, ansi36.pat, ansi37.pat, ansi38.pat, APPIAN2.PAT, APPIANRN.PAT, AR-B816.pat, AR-B816C.pat, AR-B88.pat, AR-BRELM.pat, AR-BRSTD.pat, AR-CONC.pat, AR-HBONE.pat, AR-PARQ1.pat, AR-RROOF.pat, AR-RSHKE.pat, AR-SAND.pat, AR-Tile01.pat, AR-Tile02.pat, AR-Tile03.pat, AR-Tile04.pat, AR-Tile05.pat, AR-Tile06.pat, AR-Tile07.pat, AR-Tile08.pat, AR-Tile09.pat, AR-Tile10.pat, AR-Tile11.pat, AR-Tile12.pat, AR-Tile13.pat, AR-Tile14.pat, AR-Tile15.pat, AR-Tile16.pat, AR-Tile17.pat, AR-Tile18.pat, AR-Tile19.pat, AR-Tile20.pat, AR-Tile21.pat, AR-Tile22.pat, AR-Tile23.pat, AR-Tile24.pat, AR-Tile25.pat, AR-Tile26.pat, AR-Tile27.pat, AR-Tile28.pat, AR-Tile29.pat, AR-Tile30.pat, AR-Tile31.pat, AR-Tile32.pat, AR-Tile33.pat, AR-Tile34.pat, AR-Tile35.pat, AR-Tile36.pat, AR-Tile37.pat, AR-Tile38.pat, AR-Tile39.pat, AR-Tile40.pat, AR-Tile41.pat, AR-Tile42.pat, AR-Tile43.pat, AR-Tile44.pat, AR-Tile45.pat, AR-Tile46.pat, AR-Tile47.pat, AR-Tile48.pat, AR-Tile49.pat, AR-Tile50.pat, AR-Tile51.pat, AR-Tile52.pat, AR-Tile53.pat, AR-Tile54.pat, ar1.pat, ar10.pat, ar11.pat, ar12.pat, ar13.pat, ar14.pat, ar15.pat, ar16.pat, ar17.pat, ar18.pat, ar19.pat, ar2.pat, ar20.pat, ar21.pat, ar22.pat, ar23.pat, ar24.pat, ar25.pat, ar26.pat, ar27.pat, Ar28.pat, ar29.pat, ar3.pat, ar30.pat, ar4.pat, ar5.pat, ar6.pat, ar7.pat, ar8.pat, ar9.pat, ARAB3.PAT, arabesq.pat, arabtile.pat, arbeit1.pat, arbeit3.pat, argpes.pat, ASBESTOS.PAT, ASHLER.PAT, ASPHALT.PAT, Asphalt2.pat, asphalts.pat, ASTERISK.PAT, AUTOSQR.PAT, AUTOTRI.PAT, AYE.PAT, BACKGND.PAT, Bandiere.pat, bang1.pat, bang2.pat, basalt.pat, base.pat, BASKET.PAT, BASKETWV.PAT, BATT.PAT, BEVBRIC1.PAT, BEVBRIC2.PAT, BLOCK.PAT, BLOCWALL.PAT, bloon1.pat, bloon2.pat, bloon3.pat, bloons.pat, BOARD.PAT, boards.pat, BOARDW.PAT, BOARDWN.PAT, Bolle01.pat, Bolle02.pat, BOURGOGN.PAT, BOX.PAT, BOXES.PAT, BRASS.PAT, brblco.pat, brcobd.pat, brecca.pat, brenbd.pat, brflbd.pat, brflcb.pat, brick.pat, BRICK1.PAT, BRICK2.PAT, BRICKS.PAT, Brick_02.pat, brkcf.pat, brrnbd.pat, brstbd.pat, BRSTONE.PAT, BT-01.PAT, BT-Da1x2.PAT, BTCT.pat, BTCT2.pat, BTILE12.PAT, buscs4.pat, BUTTEDHB.PAT, BW.PAT, c-madera.pat, CARBON.PAT, cblfld.pat, cbulb1.pat, cbulb2.pat, cbulb3.pat, ccbss.pat, ccelev.pat, cdtop.pat, CEDAR.PAT, Cerchi00.pat, Cerchi01.pat, cforest1.pat, cforest2.pat, CH.PAT, chainlnk.pat, chalk.pat, check1.pat, check2.pat, Check3.pat, Check4.pat, Checker.PAT, chert.pat, chip.pat, chip2.pat, CHKDL.PAT, chkds.pat, CIRC.PAT, CIRCLE32.PAT, CIRCLES.PAT, CKD.PAT, cl.pat, CLAY.PAT, clayst.pat, clercut1.pat, clercut2.pat, clouds.pat, clover1.pat, clover2.pat, clslt.pat, clstn.pat, CLUSTHB.PAT, cl_ss.pat, cmpshl.pat, cmubp.pat, cmuelb.pat, coal.pat, COBBLES.PAT, common.pat, commonf.pat, conblk.pat, CONC.PAT, CONC2.PAT, CONCBLOK.PAT, conccn.pat, conclw.pat, concpr.pat, CONCRE.PAT, concret1.pat, CONCRET2.PAT, Concret3.pat, Concret4.pat, Concret5.pat, Concret6.pat, CONCRETE.PAT, CONCRT.PAT, concst.pat, Conc_01.pat, conglm.pat, conpbs.pat, Coppi01.pat, Coppi02.pat, Coppi03.pat, Coppi04.pat, coppi05.pat, CORK.PAT, CORRUG.PAT, COURSE.PAT, coustom1.pat, CROSS.PAT, cross1.pat, cross2.pat, cross3.pat, cross4.pat, cross5.pat, cross6.pat, crosseng.pat, CROSSF.PAT, crosslok.pat, crssbd_l.pat, crssbd_s.pat, crubb.pat, cs01.pat, cs02.pat, cs03.pat, cs04.pat, cs05.pat, cs06.pat, cs07.pat, cs08.pat, cs09.pat, cs1.pat, CS10.pat, CS11.pat, CS12.pat, CS13.pat, CS14.pat, CS15.pat, CS16.pat, CS17.pat, CS18.pat, CS19.pat, CS2.pat, CS20.pat, CS21.pat, CS22.pat, CS23.pat, CS24.pat, CS25.pat, CS26.pat, CS27.pat, CS28.pat, CS29.pat, CS3.pat, CS30.pat, CS31.pat, CS32.pat, CS33.pat, CS34.pat, CS35.pat, CS36.pat, CS37.pat, CS38.pat, CS39.pat, CS4.pat, CS40.pat, CS41.pat, CS42.pat, CS43.pat, CS44.pat, CS45.pat, CS46.pat, CS47.pat, CS48.pat, CS49.pat, CS5.pat, CS50.pat, CS51.pat, CS52.pat, CS53.pat, CS54.pat, CS55.pat, CS56.pat, CS57.pat, CS58.pat, CS59.pat, CS6.pat, CS60.pat, CS61.pat, CS62.pat, CS63.pat, cs64.pat, CS7.pat, CS8.pat, CS9.pat, cshale.pat, CSILK.PAT, csjnt.pat, cstile.pat, cstile2.pat, cstirn.pat, cstlstn.pat, cststn.pat, cswood.pat, cswood2.pat, cswood3.pat, cswood4.pat, ctilss.pat, ctree1.pat, ctree2.pat, CTYSQ6RN.PAT, CTYSQMK1.PAT, CTYSQMK2.PAT, CTYSQRN.PAT, CTYSQST.PAT, cutstn.pat, CUTSTONE.PAT, CYL.PAT, CYRAMIC.PAT, dash.pat, dashdot.pat, Dblhlnst.pat, DECBRK1.PAT, DECBRK2.PAT, deck.pat, deck2.pat, DECOTILE.PAT, DELTA.PAT, design1.pat, design10.pat, design11.pat, design12.pat, design2.pat, design3.pat, design4.pat, design5.pat, design6.pat, design7.pat, design8.pat, design9.pat, dfstn.pat, DIAMONDS.PAT, DIAPLATE.PAT, DIATREAD.PAT, DIJON.PAT, diorit.pat, dolcc_nipi.pat, dolcl.pat, dolcl_nipi.pat, DOLMIT.PAT, dolom.pat, dolss_nipi.pat, dol_.pat, dol_nipi.pat, dots.pat, double.pat, drftstn.pat, dslstn.pat, DSTAR.PAT, EARTH.PAT, EARTH2.PAT, ecstn.pat, eearth.pat, EGGCRATE.PAT, EIGHT.PAT, ell.pat, ELLPAVER.PAT, ENDCEDAR.PAT, ENDGRAIN.PAT, ENDSHAKE.PAT, ENGINE.PAT, ENGLISH.PAT, Erba.pat, Erbetta.pat, erock.pat, ESCHER.PAT, EXM.PAT, EXPAND.PAT, fan.pat, fancob.pat, FANCYBRC.PAT, FBBRICKC.PAT, FBBRICKS.PAT, fibfsf.pat, FILL.PAT, fillsc.pat, filtbd.pat, FINETTA.PAT, Fiori01.pat, FISHSCAL.PAT, FIVE.PAT, flagst2.pat, FLAGSTON.PAT, fldstn.pat, FLDSTONE.PAT, FLEMBOND.PAT, FLEMISH.PAT, FLEMISHX.PAT, FLEX.PAT, FLGSTONE.PAT, FLORTILE.PAT, FORMAL.PAT, Forro.pat, FOUR.PAT, fq-tile.pat, gabbro.pat, GARDEN.PAT, GBlock.PAT, GC.PAT, geoch.pat, geocl.pat, geogc.pat, geogm.pat, geogp.pat, geogw.pat, GEOL1.PAT, GEOL2.PAT, GEOL3.PAT, GEOL4.PAT, GEOL5.PAT, GEOL6.PAT, GEOL7.PAT, GEOL8.PAT, geomh.pat, geoml.pat, geooh.pat, geool.pat, geopi.pat, geosc.pat, geosm.pat, geosp.pat, geosw.pat, ghiaia1.pat, ghiaia2.pat, ghiaia3.pat, ghiaia4.pat, GLASBLOC.PAT, GLASS.PAT, GLASS1.PAT, GLASS2.PAT, glass3.pat, glass4.pat, GLB.PAT, gl_kizv.pat, gl_kpes.pat, GM.PAT, gndcover.pat, gneiss.pat, GP.PAT, grain.pat, grain7.pat, grain8.pat, granit.pat, GRASS.PAT, GRASS2.PAT, GRATE.PAT, GRAVEL.PAT, gravel2.pat, GRAVL1.PAT, graywc.pat, GRECODEK.PAT, GREEK.PAT, GRIDDOT.PAT, GROUT.PAT, grtstone.pat, grvcre.pat, grvpfe.pat, grvscl.pat, GW.PAT, gypppe.pat, h49.pat, h50.pat, HARDWOOD.PAT, HATCH1.PAT, HB.PAT, HBENGLES.pat, HBENGLET.pat, HBFLEMES.pat, HBFLEMET.pat, HBLOCKES.pat, HBLOCKET.pat, HBONE.PAT, HBSTRCES.pat, HBSTRCET.pat, HCHEQ1BS.pat, HCHEQ2BS.pat, HCHEQ3BS.pat, HCHEQ4BS.pat, HCHEQ5BS.pat, heart1.pat, heart2.pat, heart3.pat, heart4.pat, HERRING.PAT, herringb.pat, HEX.PAT, HEX2.PAT, HEXPERF.PAT, HEXTILE.PAT, HEXTILE9.PAT, hfract.pat, HLNBSK.PAT, HLNHER.PAT, HLNIST.PAT, HLNPARQ.PAT, HLNRN.PAT, Hlnst.pat, holly1.pat, HONEY.PAT, HOUND.PAT, HPCRS2N0.pat, HPCRS2N1.pat, HPCRS2N2.pat, HPCRS2N3.pat, HPCRS2N4.pat, HPCRS2N5.pat, HPCRS2N6.pat, HPCRS2N7.pat, HPCRS2N8.pat, HPCRS3N0.pat, HPCRS3N1.pat, HPCRS3N2.pat, HPCRS3N3.pat, HPCRS3N4.pat, HPCRS3N5.pat, HPCRS3N6.pat, HPCRS3N7.pat, HRCD35OS.pat, HRDD35OS.pat, HRPA55O1.pat, HRPA55O2.pat, HRPN35OT.pat, HRPN40OS.pat, HRPN40OT, HRPN40OT.pat, HRPN45OS.pat, HRPN50OS.pat, HRPN50OT.pat, HRPN55OS.pat, HRPN55OT.pat, HRPN60OS.pat, HRPN60OT.pat, HRPN70OS.pat, HRPN70OT.pat, HRPN80OS.pat, HRPN80OT.pat, HRPN90OT.pat, HSBDR1E1.pat, HSBDR2E0.pat, HSBDR3E0.pat, HSBDR4E0.pat, HSHP11E0.pat, HSHP21E0.pat, HSHP31E0.pat, HSHP41E0.pat, HSTON1E0.pat, HSTON2E0.pat, HSTON3E0.pat, HSTON4E0.pat, HSTON5E0.pat, HSTON6E0.pat, HSTON7E0.pat, HSTON8E0.pat, HSTON9E0.pat, HT1001ET.pat, HTREEC1S.pat, HTREECPS.pat, HTREECRS.pat, HTREED1S.pat, HTREEP1S.pat, HVEGE100.pat, HVSPR1E0.pat, HVSPR1E1.pat, HVSPR1E2.pat, HVSPR1E3.pat, HVSPR1E4.pat, HVSPR1E5.pat, HVSPR1E6.pat, HVSPR1E7.pat, HVYSHAKE.PAT, HWDLN1E1.pat, HWDLN2E1.pat, HWDLN3E1.pat, HWEND1N0.pat, HWEND2N0.pat, HWEND3N0.pat, HWEND4N0.pat, HWEND5N0.pat, HWEND6N0.pat, HWEND7N0.pat, HWEND8N0.pat, HWOD10E1.pat, HWOD20E1.pat, HWOD30E1.pat, HWOD40E1.pat, HWOOD1E1.pat, HWOOD2E1.pat, HWOOD3E1.pat, HWOOD4E1.pat, HWOOD5E1.pat, HWOOD6E1.pat, HWOOD7E1.pat, HWOOD8E1.pat, HWOOD9E1.pat, HWPLY3E1.pat, I-STONE.PAT, IBRICKL.PAT, IBRICKR.PAT, Ice.pat, II.pat, insrig.pat, insscm.pat, INSUL.PAT, inter1.pat, inter10.pat, inter11.pat, inter12.pat, inter13.pat, inter14.pat, inter2.pat, inter3.pat, inter4.pat, inter5.pat, inter6.pat, inter7.pat, inter8.pat, inter9.pat, ISO02W.pat, ISO03W.pat, ISO04W.pat, ISO05W.pat, ISO06W.pat, ISO07W.pat, ISO08W.pat, ISO09W.pat, ISO10W.pat, ISO11W.pat, ISO12W.pat, ISO13W.pat, ISO14W.pat, ISO15W.pat, izmedol.pat, LAM.PAT, lamiera.pat, LAT.PAT, LATH.PAT, LatNen01.PAT, LatNen02.PAT, LatNen03.PAT, LATTICE.PAT, LATTICE1.PAT, LATTICE2.PAT, Lattice3.pat, LAVA.PAT, leca.pat, lecash.pat, legno1.pat, legno2.pat, legno3.pat, legno4.pat, legno5.pat, limest.pat, limestn.pat, line.pat, link1.pat, link2.pat, link3.pat, link4.pat, list.txt, lm.pat, lmcl.pat, lmdol.pat, lmpure.pat, lmss.pat, lmstn.pat, lm_cl.pat, LOG-LOG.PAT, LOG.PAT, LOGEND.PAT, lrslate.pat, lstone.pat, lstones.pat, lswamp.pat, LUMBER.PAT, LuoiB40.PAT, Madeira.pat, map1.pat, map7.pat, marbl1.pat, marble.pat, MARKER.PAT, Marmore.pat, MarmoTXT.pat, MasselliAutobloccanti.pat, MAY-TRE.PAT, mazebloc.pat, MBLOCKC.PAT, MBLOCKS.PAT, medbrick.pat, MELBURY.PAT, MERCEDES.PAT, Meteo_06.pat, metro.pat, MH.PAT, ML.PAT, MOBY.PAT, MONCELLO.PAT, moon1.pat, moon2.pat, MOSAIC.PAT, mosaic1.pat, mosaic2.pat, MRBLOCKC.PAT, MRBLOCKS.PAT, mrl.pat, mrldol.pat, mrl_nipi.pat, MSBLOCKC.PAT, MSBLOCKS.PAT, msjnt.pat, MSTAR.PAT, MUDST.PAT, MUDSTONE.PAT, muro11.pat, muro12.pat, muro13.pat, muro15.pat, NET.PAT, NET3.PAT, NINE.PAT, Octa-dot.pat, OCTAGON.PAT, OCTAGONS.PAT, OCTASQR.PAT, OH.PAT, OL.PAT, oldbrik1.pat, Onde01.pat, Onde02.pat, Onde03.pat, Onde04.pat, ONE.PAT, OSBwood.pat, PANEL.PAT, panel1.pat, panel2.pat, PARQUET.PAT, PARQUET1.PAT, parquet10.pat, parquet11.pat, parquet12.pat, parquet13.pat, parquet14.pat, parquet15.pat, parquet16.pat, PARQUET2.PAT, PARQUET3.PAT, PARQUET4.PAT, PARQUET5.PAT, PARQUET6.PAT, PARQUET7.PAT, parquet8.pat, parquet9.pat, Parq_02.pat, pathway.pat, PATIO1.PAT, PATIO2.PAT, PATIO3.PAT, PATIO4.PAT, Pat_05.pat, Pat_11.pat, Pat_13.pat, Pavimento01.pat, Pavimento02.pat, Pavimento03.pat, Pavimento04.pat, PavimentoParquet01.pat, PavimentoParquet02.pat, PavimentoParquet03.pat, PAVING2.PAT, PAVINGBR.PAT, PAX.PAT, Pdcirc.pat, peb1.pat, pebble.pat, pebble2.pat, Pers1.pat, pesalarg.pat, pesarg.pat, pesargal2.pat, pflstn.pat, pgrain.pat, PHANTSQR.PAT, PI.PAT, Piastrella30x30Fuga.pat, pietra.pat, pietra1.pat, pietra3.pat, pietra4.pat, pietra5.pat, pietra6.pat, pine.pat, pine2.pat, pinwheel.pat, PIPE.PAT, pipe1.pat, pipe2.pat, PLANT.PAT, PLAST.PAT, plasti.pat, Plastic.pat, PLYWOOD.PAT, porous.pat, Punti01.pat, Punti02.pat, Quadrati01.pat, Quadrati02.pat, Quadrati03.pat, quartz.pat, Rain.pat, RAINDROP.PAT, RANDTILE.PAT, rangkaatap.pat, RATTAN.PAT, RBBRICKC.PAT, RBBRICKS.PAT, rdfill.pat, README.TXT, REDBRICK.PAT, regstone.pat, REV-ZEE.PAT, rgstonet.pat, rhyolt.pat, RIGID.PAT, RIGIDINS.PAT, ripple1.pat, ripple2.pat, ripple3.pat, RIPRAP.PAT, riprap1.pat, Riprap2.pat, ROCK.PAT, rocket1.pat, rocket2.pat, ROCKS.PAT, ROLOK.PAT, roof-1.pat, ROOFTILE.PAT, rrub.pat, RSLATE.PAT, rslate1.pat, rslate2.pat, RUBBLE.PAT, RUBBLE1.PAT, rubble2.pat, rubish1.pat, RUNBOND.PAT, running.pat, RUNSTACK.PAT, RUNTILE.PAT, RVB_PAT.DOC, rvrrck.pat, S-tile.pat, SACNCR.PAT, SAND.PAT, sandst.pat, Sassi01.pat, Sassi02.pat, SBBRICKC.PAT, Sbbricks.pat, SC.PAT, SCALLOP1.PAT, SCALLOP2.PAT, schist.pat, SCRATCH.PAT, SCREEN.PAT, Screen1.pat, Screen2.pat, SCRNBLOC.PAT, sdcl.pat, sdss.pat, SECGRILL.PAT, SelciatoGrano.pat, SelciatoOnde.pat, SelciatoPavone01.pat, SEMI-LOG.PAT, SEVEN.PAT, sgrain.pat, SHADEBLK.PAT, SHAKE.PAT, SHAKES.PAT, SHAKES1.PAT, SHAKES2.PAT, shell.pat, SHINGLE.PAT, SHINGLE1.PAT, Shingle2.pat, SHINGLES.PAT, SHRUBS.PAT, SIDING.PAT, SIDING1.PAT, Siding2.pat, SILK1.PAT, SILK2.PAT, SILK3.PAT, SILK4.PAT, SIX.PAT, SKIRTING.PAT, sl-df.pat, sl.pat, SLATE.PAT, slate1.pat, slotperf.pat, slstn.pat, SM.PAT, snd_cl.pat, Snow.pat, soapst.pat, SOIL.PAT, SOLDIER.PAT, SOLID.pat, SP.PAT, spalid.pat, SPANISH.PAT, SPANISH1.PAT, spanish2.pat, spanish3.pat, SPANTIL.PAT, SPANTIL1.PAT, SPANTIL2.PAT, SPANTILE.PAT, SPINA3.PAT, spltfc.pat, spltqrrd.pat, SQ-UNIT.PAT, SQDOTS.PAT, sqrperf.pat, SQRTMPLT.PAT, SQSHNGLE.PAT, sqstone.pat, Squama.pat, SQUARE.PAT, SQUAREF.PAT, SS.PAT, sstnwsb.pat, stack.pat, STAGGER.PAT, STAR1.PAT, star10-a.pat, star10-b.pat, star11-a.pat, star11-b.pat, star12-a.pat, star12-b.pat, star3-a.pat, star3-b.pat, star4-a.pat, star4-b.pat, star5-a.pat, star5-b.pat, star6-a.pat, star6-b.pat, star7-a.pat, star7-b.pat, star8-a.pat, star8-b.pat, star9-a.pat, star9-b.pat, STARS.PAT, STEEL.PAT, STIP1.PAT, STIP2.PAT, STIPLES.PAT, STIPPLE.PAT, stnd18.pat, stnsqr.pat, STONE.PAT, STONES.PAT, stones3.pat, stones5.pat, Stone_08.pat, Stone_10.pat, stonsand.pat, stroids.pat, stsstn.pat, SUPERDCR.PAT, SW.PAT, SWAMP.PAT, SWAMP1.PAT, T-storm.pat, tcbcss.pat, tcelev.pat, TCIDE.PAT, tcuss.pat, tegole01.pat, tegole02.pat, tegole03.pat, tegole04.pat, Telhado.pat, Terra.pat, terrzo.pat, TES10.PAT, TES36.PAT, Tessuto01.pat, Tessuto02.pat, TestoParcheggio.pat, TestoStrada.pat, TestoUfficio01.pat, TestoUfficio02.pat, TestoVerde.pat, TEXTURE.PAT, TEXTURED.PAT, thermal.pat, thirdrun.pat, THREAD.PAT, THREE.PAT, tilcer.pat, tile02.pat, tile03.pat, tile04.pat, tile06.pat, tile07.pat, TILE1.PAT, tile10.pat, tile11.pat, tile13.pat, tile14.pat, tile18.pat, tile19.pat, tile21.pat, tile22.pat, tile23.pat, tile25.pat, tile26.pat, tile29.pat, tile3.pat, tile30.pat, tile31.pat, tile32.pat, tile33.pat, tile34.pat, tile35.pat, tile36.pat, tile37.pat, tile38.pat, tile39.pat, tile40.pat, tile41.pat, tile42.pat, tile43.pat, tile44.pat, tile45.pat, tile47.pat, tile48.pat, tile49.pat, tile50.pat, tile51.pat, tile52.pat, tile53.pat, tilesf.pat, Tile_02.pat, TRANS.PAT, TREAD.PAT, TREADPLT.PAT, tree1.pat, tree2.pat, TRI45.PAT, TRI45A.PAT, TRIANG.PAT, triangcs.pat, TRIANGLE.PAT, TRIDOTS.PAT, TRIHEX.PAT, TRITMPLT.PAT, trivera.pat, tronco.pat, TROOF1.PAT, TROOF2.PAT, TROOF3.PAT, TROOF4.PAT, Troof5.pat, tuff.pat, TURF.PAT, TURFSTNE.PAT, TWO.PAT, UNICOLOC.PAT, UNIDECO.PAT, UNIDECOR.PAT, UNIHER.PAT, UNIPARQ.PAT, UNIRN.PAT, UNISTONE.PAT, UNIWEAVE.PAT, urb_1.pat, urb_2.pat, urb_3.pat, urb_4.pat, urb_5.pat, urb_6.pat, urb_8.pat, usa1.pat, uscs1.pat, uscs10.pat, uscs11.pat, uscs12.pat, uscs13.pat, uscs14.pat, uscs15.pat, uscs2.pat, uscs3.pat, uscs4.pat, uscs5.pat, uscs6.pat, uscs7.pat, uscs8.pat, uscs9.pat, usdbrk.pat, V.pat, vastrap.pat, VBRICKS.PAT, vespaio1.pat, vespaio2.pat, WAFFLE.PAT, WATER.PAT, water1.pat, Water2.pat, wdgrain.pat, wdgrain2.pat, weave-2.pat, WEAVE.PAT, WEAVE1.PAT, WEAVE2.PAT, WEAVE3.PAT, WEAVE4.PAT, Weave5.pat, welstn.pat, WELSTNx.pat, WHEAT1.PAT, WHEAT2.PAT, WICKER.PAT, wicker1.pat, Wicker2.pat, WIDECROS.PAT, windmill.pat, wiremesh.pat, WOOD.PAT, WOOD1.PAT, WOOD2.PAT, wood21.pat, WOOD3.PAT, WOOD4.PAT, Wood5.pat, Wood6.pat, Wood7.pat, WOOD8.PAT, wood9.pat, WOODFACE.PAT, Wood_01.pat, Wood_02.pat, Wood_06.pat, Wood_08.pat, Wood_09.pat, Wood_12.pat, wsjnt.pat, wtrwsh.pat, X.pat, x___01___.pat, x___02___.pat, x___03___.pat, x___04___.pat, x___05___.pat, x___06___.pat, x___07___.pat, x___08___.pat, x___09___.pat, x___10___.pat, x___11___.pat, x___12___.pat, x___13___.pat, x___14___.pat, x___15___.pat, x___16___.pat, x___17___.pat, x___18___.pat, x___19___.pat, x___20___.pat, x___21___.pat, x___22___.pat, x___23___.pat, x___24___.pat, x___25___.pat, x___26___.pat, x___27___.pat, x___28___.pat, x___29___.pat, x___30___.pat, x___31___.pat, x___32___.pat, x___33___.pat, x___34___.pat, x___35___.pat, x___36___.pat, x___37___.pat, x___38___.pat, x___39___.pat, x___40___.pat, x___41___.pat, x___42___.pat, x___43___.pat, x___44___.pat, x___45___.pat, x___46___.pat, x___47___.pat, x___48___.pat, x___49___.pat, x___50___.pat, x___51___.pat, x___52___.pat, x___53___.pat, x___54___.pat, x___55___.pat, x___56___.pat, x___57___.pat, x___58___.pat, x___59___.pat, x___60___.pat, x___61___.pat, x___62___.pat, ZERO.PAT, ZIGZAG.PAT, ZIGZAGF.PAT, ZIGZG2L.PAT, zonecl.pat, _Library.pat, , :D :D :D 1 Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
sgcq 726 Báo cáo bài đăng Đã đăng Tháng 4 19, 2016 :D :D :D Đã update file gộp hatch, 1331 Mẫu hatch chỉ trong 1 file. 2 lúa cũng share luôn mánh để có bộ sưu tập như trên. link cũng như trên luôn. :D :D :D Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
conghoa 125 Báo cáo bài đăng Đã đăng Tháng 4 20, 2016 Cách của Hai lúa có vẻ hơi thủ công hơn cách của ketxu :) 1 Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
thephong 0 Báo cáo bài đăng Đã đăng Tháng 4 20, 2016 thêm hatch ah Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
sgcq 726 Báo cáo bài đăng Đã đăng Tháng 4 20, 2016 Cách của Hai lúa có vẻ hơi thủ công hơn cách của ketxu :) :D :D :D Sư phụ @ketxu làm cách nào ta? Chỉ 2 lúa với! :D :D :D thêm hatch ah thêm hatch ah :D :D :D Cách tìm hatch + tạo hatch thì diễn đàn mình nhiều rồi. Mẫu hatch thì cũng vô tận. Mục tiêu của 2 lúa là tạo bộ hay dùng, 2 lúa cũng tạo luôn 2 bộ cho 2 cách xài khác nhau. 1. Bộ rời: Bạn down về giải nén vô 1 nơi nào đó trên máy, rồi vào cad trỏ vô để xài. 2. Bộ gộp: Bạn down về, đổi tên thành acadiso.pat, replace file mặc định của cad rồi xài. 3. Các thư viện này nằm trong kế hoạch mây hóa thư viện của 2 lúa. Vì cần thì 2 lúa cũng lên đó lấy về. Cả 2 cách đều tránh được các hatch trùng tên, cũng không có mẫu hatch nào bản quyền của 2 lúa, nên không phải là thêm hatch. Chỉ là bộ sưu tập thôi. :D :D :D Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
hocon_hp 84 Báo cáo bài đăng Đã đăng Tháng 11 25, 2016 download không được bác 2 lúa ơi Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
kienxd04 7 Báo cáo bài đăng Đã đăng Tháng 11 25, 2016 Link đã die, nhờ thớt chỉnh sửa giúp Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
25251325 0 Báo cáo bài đăng Đã đăng Tháng 11 28, 2016 link die rồi các bác ơi. Chia sẻ bài đăng này Liên kết tới bài đăng Chia sẻ trên các trang web khác
