tiamo129
lỗi khi cài AUTOCAD 2007
của e thì như thế này... e đã cài lại win...load net framework runtime 2.0 về và chạy rồi...nhưng khi cài vẫn bị lỗi trên
2012/8/19:12:33:01 Admin ITQUANGNAM === Installation started on ITQUANGNAM by Admin ===
2012/8/19:12:33:02 Admin ITQUANGNAM Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 3.1.4001.5512
2012/8/19:12:34:26 Admin ITQUANGNAM Install .NET Framework Runtime 2.0 Succeeded Command = "support\dotnetfx\dotnetfx.exe" /q /c:"install /l /qb"
2012/8/19:12:34:26 Admin ITQUANGNAM Install .NET Framework Runtime 2.0 Language Pack Skipped Installation not required
2012/8/19:12:34:29 Admin ITQUANGNAM Install DirectX 9.0 Runtime Succeeded Command = "support\DirectX\DXSETUP.exe" /silent
2012/8/19:12:34:30 Admin ITQUANGNAM Install MDAC 2.7 Skipped MDAC upgrade is not required. System Version = 2.81.1132.0
2012/8/19:12:34:30 Admin ITQUANGNAM Install Autodesk DWF Viewer Failed Failure is ignored, Result=3
2012/8/19:12:34:31 Admin ITQUANGNAM Install Flash Failed Failure is ignored, Result=1
2012/8/19:12:38:00 Admin ITQUANGNAM Install AutoCAD 2007 Failed Installation aborted, Result=1603
2012/8/19:12:38:00 Admin ITQUANGNAM === Installation ended ===
Mấy anh bờ pro vào giải quyết cái lỗi phía trên cái...nản quá...cài đi cài lại...thử key khác cũng k được
Có thể phiên bản của bác có lỗi gì đó, thử vào trang này lấy phiên bản khác xem sao:
http://www.vn-zoom.com/f103/download-autocad-2013-32-and-64bit-full-crack-1789761.html
2012/9/11:11:01:59 admin SON === Installation started on SON by admin ===
2012/9/11:11:02:00 admin SON Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 3.1.4000.2435
2012/9/11:11:02:00 admin SON Install .NET Framework Runtime 2.0 Skipped .NET Framework Runtime upgrade is not required. System Version = 2.0.50727.0
2012/9/11:11:02:00 admin SON Install .NET Framework Runtime 2.0 Language Pack Skipped Installation not required
2012/9/11:11:02:03 admin SON Install DirectX 9.0 Runtime Failed Failure is ignored, Result=-9
2012/9/11:11:02:03 admin SON Install MDAC 2.7 Skipped MDAC upgrade is not required. System Version = 2.81.1117.0
2012/9/11:11:02:13 admin SON Install Autodesk DWF Viewer Succeeded Command = "D:\autocad 2007\Bin\AcadFEUI\support\aev\DWFViewerSetup.exe" /u2 /q2 /b0
2012/9/11:11:02:15 admin SON Install Flash Failed Failure is ignored, Result=1
2012/9/11:11:04:10 admin SON Install AutoCAD 2007 Failed Installation aborted, Result=1603
2012/9/11:11:04:10 admin SON === Installation ended ===
e bị lỗi thế này,ai giúp e với
Các anh em giúp với, không thể nào cài đc Cad2007 cứ báo lỗi, mặt dù đã xem anh em nói ở trên nhưng vẫn không đươc.
2007/5/17:11:29:10 Admin THUNGAN === Installation started on THUNGAN by Admin ===
2007/5/17:11:29:11 Admin THUNGAN Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 3.1.4001.5512
2007/5/17:11:29:11 Admin THUNGAN Install .NET Framework Runtime 2.0 Skipped .NET Framework Runtime upgrade is not required. System Version = 4.0.0.0
2007/5/17:11:29:11 Admin THUNGAN Install .NET Framework Runtime 2.0 Language Pack Skipped Installation not required
2007/5/17:11:29:14 Admin THUNGAN Install DirectX 9.0 Runtime Succeeded  Command = "D:\NAM\PHAN MEM\cad\cad2007\cad2007\Bin\AcadFEUI\support\DirectX\DXSETUP.exe" /silent
2007/5/17:11:29:14 Admin THUNGAN Install MDAC 2.7 Skipped MDAC upgrade is not required. System Version = 2.81.1132.0
2007/5/17:11:29:54 Admin THUNGAN Install Autodesk DWF Viewer Succeeded  Command = "D:\NAM\PHAN MEM\cad\cad2007\cad2007\Bin\AcadFEUI\support\aev\DWFViewerSetup.exe" /u2 /q2 /b0
2007/5/17:11:29:56 Admin THUNGAN Install Flash Failed Failure is ignored, Result=1
2007/5/17:11:30:04 Admin THUNGAN Install AutoCAD 2007 Failed Installation aborted, Result=1603
2007/5/17:11:30:04 Admin THUNGAN === Installation ended ===
không hiễu bị gì nữa
các pro giúp với, tôi bị lỗi tương tự
