naturooo
Lisp Quick Filter: Lọc nhanh theo một số thuộc tính thông dụng
Thay vì lệnh Filter (FI) mặc định chọn rồi xoá xoá. Lisp Quick Filter (QF) này sẽ chọn một số thuộc tính thông dụng để lọc, giảm bớt vài thao tác thừa không cần thiết:
;; List Box  -  Lee Mac
;; Displays a DCL list box allowing the user to make a selection from the supplied data.
;; msg - [str] Dialog label
;; lst - [lst] List of strings to display
;; bit - [int] 1=allow multiple; 2=return indexes
;; Returns: [lst] List of selected items/indexes, else nil
(defun LM:listbox ( msg lst bit / dch des tmp rtn )
        (   (not
                (and
                    (setq tmp (vl-filename-mktemp nil nil ".dcl"))
                    (setq des (open tmp "w"))
                    (write-line
                        (strcat "listbox:dialog{label=\"" msg "\";spacer;:list_box{key=\"list\";multiple_select="
                            (if (= 1 (logand 1 bit)) "true" "false") ";width=50;height=15;}spacer;ok_cancel;}"
                        des
                    (not (close des))
                    (< 0 (setq dch (load_dialog tmp)))
                    (new_dialog "listbox" dch)
            (prompt "\nError Loading List Box Dialog.")
        (   t
            (start_list "list")
            (foreach itm lst (add_list itm))
            (end_list)
            (setq rtn (set_tile "list" "0"))
            (action_tile "list" "(setq rtn $value)")
            (setq rtn
                (if (= 1 (start_dialog))
                    (if (= 2 (logand 2 bit))
                        (mapcar '(lambda ( x ) (nth x lst)) (read (strcat "(" rtn ")")))
                      ;  (mapcar '(lambda ( x ) (nth x lst)) (read (strcat "(" rtn ")")))
    (if (< 0 dch)
        (unload_dialog dch)
    (if (and tmp (setq tmp (findfile tmp)))
        (vl-file-delete tmp)
    rtn
;====================================Main Lisp: Quick Filter (QF)======================================
(defun C:QF (/ ss ss1 ob lyrname colr blkname txth txtn lstQF lstDCL lstidx lstfi a)
  (setq ss1 (entsel "\nSelect Object: "))
  (while (or
	   (null ss1)
	   (= "" (cdr (assoc 0 (entget (car ss1)))))
  (setq ss1 (entsel "\nSelect Object Again: "))
  (setq ss (entget (car ss1)))
  (setq ob (cdr (assoc 0 ss)))
  (setq lstQF (list (cons 0 ob)))
  (if (= "INSERT" ob)
  	(setq lstDCL (list (strcat "Object           : " "Block")))
	(setq lstDCL (list (strcat "Object           : " ob)))
  );endif
  (setq lyrname (cdr (assoc 8 ss)))
  (setq lstQF (append lstQF (list (cons 8 lyrname))))
  (setq lstDCL (append lstDCL (list (strcat "Layer            : " lyrname))))
  (if (= 62 (car (assoc 62 ss)))
    	(setq colr (cdr (assoc 62 ss)))
        (setq lstQF (append lstQF (list(cons 62 colr))))
	(setq lstDCL (append lstDCL (list (strcat "Color            : " (rtos colr 2 0)))))
     );progn
	(setq lstQF (append lstQF '((62 . 256))))
	(setq lstDCL (append lstDCL (list (strcat "Color            : " "256"))))
  )					;end if
  (if (= 2 (car (assoc 2 ss)))
    	(setq blkname (cdr (assoc 2 ss)))
	(setq lstQF (append lstQF (list (cons 2 blkname))))
	(setq lstDCL (append lstDCL (list (strcat "Block Name       : " blkname))))
    );end progn
  )					;end if
  (if (= 40 (car (assoc 40 ss)))
    	(setq txth (cdr (assoc 40 ss)))
	(setq lstQF (append lstQF (list (cons 40 txth))))
	(setq lstDCL (append lstDCL (list (strcat "Text Height      : " (rtos txth)))))
    );end progn
  )					;end if
  (if (= 7 (car (assoc 7 ss)))
    	(setq txtn (cdr (assoc 7 ss)))
	(setq lstQF (append lstQF (list (cons 7 txtn))))
	(setq lstDCL (append lstDCL (list (strcat "Text Style Name  : " txtn))))
    );end progn
  )					;end if
 (setq lstidx (LM:listbox "Selection to Filter:" lstDCL 1))
 (foreach a lstidx
	(setq lstfi (append lstfi (list (nth a lstQF))))
(sssetfirst nil (ssget lstfi))
(Print "Write by: NghiaKieu")
  • Like 2
10 giờ trước, naturooo đã nói:
        (   (not
                (and
                    (write-line
                        des
                    (not (close des))
        (   t
            (start_list "list")
            (end_list)
            (setq rtn
    (if (< 0 dch)
        (unload_dialog dch)
    rtn
  (while (or
	   (null ss1)
  (if (= "INSERT" ob)
  );endif
     );progn
  );end if
    );end progn
  );end if
    );end progn
  );end if
    );end progn
  );end if
 (foreach a lstidx
lisp hay nhưng chọn màu còn bị lỗi rồi bác ơi,em test thử thấy cùng một màu 256 mà màu trắng với màu đỏ nó đều chọn hết,cùng một mã màu xanh mà cái thì nó chọn cái nó lại không chọn,những cái khác chưa test hết ạ
13 phút trước, vanlam6408 đã nói:
Mã 256 là By layer mà. Màu khác nhau nhưng để By layer thì nó chọn cả (Filter mặc định cũng vậy). Ý thứ 2 của bạn cũng như vậy.
5 phút trước, naturooo đã nói:
à vâng,ra thế,em tưởng nó có thể phân biệt được các màu khác nhau cả trong trường hợp by layer thì tốt quá
26 phút trước, vanlam6408 đã nói:
Lọc theo màu mà có màu đặt theo By layer thì khoai quá. Mình thì các nét toàn để By layer hết nên ít khi lọc theo màu lắm. Không biết các cao thủ trên có giải quyết được món này không? (Mình cũng Beginner :D)
53 phút trước, naturooo đã nói:
vâng.hi
11 giờ trước, vanlam6408 đã nói:
vâng.hi
(defun c:SelectByColour ( / c d e l )
   (if (setq e (car (entsel)))
           (setq c
                   (   (cdr (assoc 62 (entget e)))   )
                   (   (abs (cdr (assoc 62 (tblsearch "LAYER" (cdr (assoc 8 (entget e)))))))   )
           (while (setq d (tblnext "LAYER" (null d)))
               (if (= c (abs (cdr (assoc 62 d))))
                   (setq l (cons "," (cons (cdr (assoc 2 d)) l)))
           (sssetfirst nil
               (ssget "_X"
                   (if l
                       (list
                           (cons -4 "<OR")
                               (cons 62 c)
                               (cons -4 "<AND")
                                   (cons 62 256)
                                   (cons 8 (apply 'strcat (cdr l)))
                               (cons -4 "AND>")
                           (cons -4 "OR>")
                       (list (cons 62 c))
Mình tìm thấy cái chọn màu kể cả By layer của Lee Mac đây. Để lúc nào m thêm tuỳ chọn chọn cả theo màu của layer xem sao :)
18 giờ trước, naturooo đã nói:
Cũng chỉ là vào Table Layer của đối tượng đó rồi lấy màu thôi mà :)
26 phút trước, ketxu đã nói:
Vâng bác. Tại em chưa ngâm cứu đến bước đó nên thấy mới lạ lắm :(
12 giờ trước, naturooo đã nói:
  • selectbycolour.lsp
    lisp help
           (setq c
           (sssetfirst nil
               (ssget "_X"
                   (if l
                       (list
                           (cons -4 "<OR")
                               (cons 62 c)
                               (cons -4 "<AND")
                                   (cons 62 256)
                               (cons -4 "AND>")
                           (cons -4 "OR>")
                       (list (cons 62 c))
vâng,mong là qf sẽ sớm được hoàn thiện nhất.hi
22 giờ trước, vanlam6408 đã nói:
Đã chế lại màu lọc theo True Color (màu hiển thị). Bạn thử xem có lỗi gì k nhé!
(defun LM:listbox (msg lst bit / dch des tmp rtn)
    ((not
       (and
	 (write-line
		   msg
		     "true"
		     "false"
	   des
	 (not (close des))
    (t
     (start_list "list")
     (end_list)
     (setq rtn
		(mapcar	'(lambda (x) (nth x lst))
  (if (< 0 dch)
    (unload_dialog dch)
  rtn
;====================================Main Lisp: Quick Filter (QF) Update 19/08/2020 Loc theo "True Color"======================================
	     txth   txtn   lstQF  lstDCL lstidx	lstfi  a      c
	     d	    l
  (while (or
	   (null ss1)
  (if (= "INSERT" ob)
  );endif
  (setq	c
	   ((cdr (assoc 62 ss)))
	   ((abs (cdr (assoc 62 (tblsearch "LAYER" (cdr (assoc 8 ss)))))
(setq lstQF (append lstQF (list "True Color")))
  (setq	lstDCL (append lstDCL (list (strcat "True Color       : " (rtos c 2 0)))  )  )
    )					;end progn
  )					;end if
      (setq lstDCL
	     (append lstDCL
    )					;end progn
  )					;end if
    );end progn
  );end if
  (if lstidx
      (foreach a lstidx
	(if (= "True Color" (nth a lstQF))
		(if l
    			  (list
      				(cons -4 "<OR")
      				(cons 62 c)
      				(cons -4 "<AND")
      				(cons 62 256)
      				(cons -4 "AND>")
      				(cons -4 "OR>")
    			  (list (cons 62 c))
    ((not
       (and
	 (write-line
		   msg
		     "true"
		     "false"
	   des
	 (not (close des))
    (t
     (start_list "list")
     (end_list)
     (setq rtn
  (if (< 0 dch)
    (unload_dialog dch)
  rtn
	     d	    l
  (while (or
	   (null ss1)
  (if (= "INSERT" ob)
  );endif
  (setq	c
    );end progn
  );end if
      (setq lstDCL
	     (append lstDCL
    );end progn
  );end if
    );end progn
  );end if
  (if lstidx
      (foreach a lstidx
		(if l
    			  (list
      				(cons -4 "<OR")
      				(cons 62 c)
      				(cons -4 "<AND")
      				(cons 62 256)
      				(cons -4 "AND>")
      				(cons -4 "OR>")
    			  (list (cons 62 c))
hôm nay mới vào diễn đàn test thử hàng mới của bác ạ!Lisp chuẩn rồi bác ạ!cảm ơn bác đã cho em và diễn đàn một lisp mới thật là hay ạ!
Em có tải thử và sử dụng lisp, thấy khá tiện, mà không biết cách viết thêm để show 1 tính chất là dimstyle ấy ạ, Bác Naturooo có thể add thêm giúp em với hoặc chỉ em cách thêm được không ạ. Đa tạ bác nhiều.
2 giờ trước, tranhoang1218 đã nói:
Đây nhé bạn:
    ((not
       (and
	 (write-line
		   msg
		     "true"
		     "false"
	   des
	 (not (close des))
    (t
     (start_list "list")
     (end_list)
     (setq rtn
  (if (< 0 dch)
    (unload_dialog dch)
  rtn
	     txth   txtn   txtvl  lstQF	 lstDCL	lstidx dimsty lstfi
	     a	    c	   d	  l
  (while (or
	   (null ss1)
  (if (= "INSERT" ob)
  )					;endif
  (setq	c
    )					;end progn
  )					;end if
      (setq lstDCL
	     (append lstDCL
    )					;end progn
  )					;end if
    )					;end progn
  )					;end if
  (if (= 1 (car (assoc 1 ss)))
      (setq txtvl (cdr (assoc 1 ss)))
      (setq lstQF (append lstQF (list (cons 1 txtvl))))
			   (list (strcat "Text Value       : " txtvl))
    )					;end progn
  )					;end if
  (if (= 3 (car (assoc 3 ss)))
      (setq dimsty (cdr (assoc 3 ss)))
      (setq lstQF (append lstQF (list (cons 3 dimsty))))
		       (list (strcat "Dimension Style     : " dimsty))
    )					;end progn
  )					;end if
  (if lstidx
      (foreach a lstidx
	  (if l
				(list
				  (cons -4 "<OR")
				  (cons 62 c)
				  (cons -4 "<AND")
				  (cons 62 256)
				  (cons -4 "AND>")
				  (cons -4 "OR>")
				(list (cons 62 c))
      (sssetfirst nil)			; clear original-selection highlighting/gripping, then:
  • Like 4
1 giờ} trướ}c, tranhoang1218 đã nói:
Mà hình như lisp đang bị lỗi, bấm chọn vô cái nào nó cũng hiện bảng rồi tự động tắt luôn ạ.
Select Object: ; error: no function definition: ANDÏ»¿
Bản tải lại thử xem nhé
Vào lúc 15/6/2021 tại 11:54, naturooo đã nói:
Bác thêm giúp lọc thêm Value của Attribute giùm với , cảm ơn bác rẩt nhiều !!
Vào lúc 25/6/2025 tại 11:54, chocopie 33 đã nói:
Mong bác thêm tính năng chọn theo kiểu linetype nữa ạ. cảm ơn bác nhiều
    ((not
       (and
         (write-line
                   msg
                     "true"
                     "false"
                   ";width=40;height=20;}spacer;ok_cancel;}"
           des
         (not (close des))
    (t
     (start_list "list")
     (end_list)
     (setq rtn
  (if (< 0 dch)
    (unload_dialog dch)
  rtn
;; Tối ưu: Hàm lấy danh sách layer có cùng color
(defun get-layers-by-color (color-code / d layer-list)
  (setq layer-list '())
    (if (= color-code (abs (cdr (assoc 62 d))))
      (setq layer-list (cons (cdr (assoc 2 d)) layer-list))
  layer-list
;; Tối ưu: Hàm tạo filter cho True Color
(defun create-color-filter (color-code layer-list / filter-list)
  (if layer-list
      (setq filter-list (list (cons -4 "<OR") (cons 62 color-code) (cons -4 "<AND") (cons 62 256)))
      (foreach layer-name layer-list
        (setq filter-list (append filter-list (list (cons 8 layer-name))))
      (setq filter-list (append filter-list (list (cons -4 "AND>") (cons -4 "OR>"))))
    (list (cons 62 color-code))
;; Tối ưu: Hàm lấy thông tin entity
(defun get-entity-info (ent-data / info-list display-list obj-type layer-name color-code linetype-name block-name text-height text-style)
  (setq info-list '()
        display-list '())
  ;; Object Type
  (setq obj-type (cdr (assoc 0 ent-data)))
  (setq info-list (cons (cons 0 obj-type) info-list))
  (if (= "INSERT" obj-type)
    (setq display-list (cons "Object           : Block" display-list))
    (setq display-list (cons (strcat "Object           : " obj-type) display-list))
  ;; Layer
  (setq layer-name (cdr (assoc 8 ent-data)))
  (setq info-list (cons (cons 8 layer-name) info-list))
  (setq display-list (cons (strcat "Layer            : " layer-name) display-list))
  ;; Color
  (setq color-code
      ((cdr (assoc 62 ent-data)))
      ((abs (cdr (assoc 62 (tblsearch "LAYER" layer-name)))))
  (setq info-list (cons "True Color" info-list))
  (setq display-list (cons (strcat "True Color       : " (rtos color-code 2 0)) display-list))
  ;; Linetype - THÊM MỚI
  (setq linetype-name
      ((cdr (assoc 6 ent-data)))  ; Linetype của entity
      ((cdr (assoc 6 (tblsearch "LAYER" layer-name))))  ; Linetype của layer
      ("BYLAYER")  ; Mặc định
  (if linetype-name
      (setq info-list (cons (cons 6 linetype-name) info-list))
      (setq display-list (cons (strcat "Linetype         : " linetype-name) display-list))
  ;; Block Name
  (if (and (= "INSERT" obj-type) (setq block-name (cdr (assoc 2 ent-data))))
      (setq info-list (cons (cons 2 block-name) info-list))
      (setq display-list (cons (strcat "Block Name       : " block-name) display-list))
  ;; Text Height
  (if (setq text-height (cdr (assoc 40 ent-data)))
      (setq info-list (cons (cons 40 text-height) info-list))
      (setq display-list (cons (strcat "Text Height      : " (rtos text-height)) display-list))
  ;; Text Style
  (if (setq text-style (cdr (assoc 7 ent-data)))
      (setq info-list (cons (cons 7 text-style) info-list))
      (setq display-list (cons (strcat "Text Style Name  : " text-style) display-list))
  (list (reverse info-list) (reverse display-list))
;====================================Main Lisp: Quick Filter (QF) Enhanced======================================
(defun C:QF (/ ss ss1 ent-data info-result lstQF lstDCL lstidx lstfi color-code layer-list selected-item)
  ;; Chọn object
  (while (or (null ss1) (= "" (cdr (assoc 0 (entget (car ss1))))))
  ;; Lấy thông tin entity
  (setq ent-data (entget (car ss1)))
  (setq info-result (get-entity-info ent-data))
  (setq lstQF (car info-result))
  (setq lstDCL (cadr info-result))
  ;; Tối ưu: Pre-calculate layer list cho True Color
  (setq color-code
      ((abs (cdr (assoc 62 (tblsearch "LAYER" (cdr (assoc 8 ent-data)))))))
  (setq layer-list (get-layers-by-color color-code))
  ;; Hiển thị dialog chọn filter
  (if lstidx
      (setq lstfi '())
      (foreach idx lstidx
        (setq selected-item (nth idx lstQF))
          ;; Xử lý True Color với tối ưu
          ((= "True Color" selected-item)
           (setq lstfi (append lstfi (create-color-filter color-code layer-list)))
          ;; Xử lý các thuộc tính khác
          (t
           (setq lstfi (append lstfi (list selected-item)))
      ;; Clear selection và apply filter
      (sssetfirst nil)
  (princ "\nQuick Filter Enhanced - Write by: NghiaKieu")
;; Thêm command alias
(defun C:QFE () (C:QF))  ; Quick Filter Enhanced
(princ "\nQuick Filter Enhanced loaded. Commands: QF or QFE")
(princ "\nNew features: Linetype filtering + Optimized algorithm")
Đây nhé bạn.
Vào lúc 27/6/2025 tại 10:35, naturooo đã nói:
    ((not
       (and
         (write-line
                   msg
                     "true"
                     "false"
           des
         (not (close des))
    (t
     (start_list "list")
     (end_list)
     (setq rtn
  (if (< 0 dch)
    (unload_dialog dch)
  rtn
  layer-list
  (if layer-list
  (setq info-list '()
        display-list '())
  ;; Object Type
  ;; Layer
  ;; Color
  (setq color-code
  (setq linetype-name
  (if linetype-name
  ;; Block Name
  ;; Text Height
  ;; Text Style
  ;; Chọn object
  (setq color-code
  (if lstidx
      (setq lstfi '())
      (foreach idx lstidx
          (t
      (sssetfirst nil)
Đây nhé bạn.
Ngon rồi bác, em cảm ơn nhiều ạ
Vào lúc 2/7/2025 tại 17:13, cuongtk2 đã nói:
Lệnh Qselect có trong AutoCad đã đủ các chức năng filter rồi.
Vâng bác. Qselect lọc theo 1 thuộc tính, lisp thì lọc được theo mấy thuộc tính thông dụng hay dùng. Kể cả lọc theo 1 thuộc tính thì với em thì thao tác Qselect cũng không tiện bằng lisp :D
