emhoccad
Xin lisp thông kê đối tượng Text
Vào lúc 17/2/2022 tại 18:32, emhoccad đã nói:
Chào các bác,
E cần lisp thống kê danh sách các Text trong bản vẽ thành 1 danh sách như bảng dưới.
Ví dụ: N1,N2,N3,vv...
Cảm ơn các bác^^
thong ke text.dwg
Gửi bạn!!!!
(defun C:TKTE(/ acdoc acspc lsttthe lsttk nd lstin point point2 p1 p2 pointt cur_lay oldos)
(setq cur_lay (getvar "clayer" ))
(setq oldos (getvar "OSMODE"))
(setvar "cmdecho" 0)
(command "UNDO" "Be")
(setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object))
		acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'paperspace 'modelspace)))
(prompt "\nChon TEXT thong ke")
(setq lsttthe (ST:SS->List-Vla (ssget '((0 . "TEXT")))))
(setq lsttk nil)
(foreach ent lsttthe
;(setq ent (vlax-ename->vla-object (car (entsel))))
(setq nd (vlax-get-property ent 'TextString))
(setq lsttk (append (list nd) lsttk))
(setq lstin (LM:CountItems lsttk))
(setq lstin  (vl-sort lstin '(lambda (x y) (< (car x) (car y)))))
(setq point (getpoint "/nPick diem dat"))
(setq point2 (polar point 0 1.38))
(command "Line" point point2 "")
(foreach ent lstin
(setq p1 (polar point (/ pi -2) 0.36))
(setq p2 (polar point2 (/ pi -2) 0.36))
(command "Line" p1 p2 "")
(command "Line" point p1 "")
(command "Line" point2 p2 "")
(command "Line" (polar point 0 (/ 1.38 2)) (polar p1 0 (/ 1.38 2)) "")
(setq pointt (polar (polar p1 0 0.1247) (/ pi 2) 0.0745))
(vla-addtext acspc (car ent) (vlax-3d-point pointt) 0.18)
(setq pointt (polar pointt 0 0.8305))
(vla-addtext acspc (cdr ent) (vlax-3d-point pointt) 0.18)
(setq point p1)
(setq point2 p2)
(command "UNDO" "End")
(setvar "clayer" cur_lay)
(setvar "osmode" oldos)
(setvar "CMDECHO" 1)
(defun LM:CountItems ( l / c l r x )
    (while l
        (setq x (car l)
              c (length l)
              l (vl-remove x (cdr l))
              r (cons (cons x (- c (length l))) r)
    (reverse r)
(defun ST:SS->List-Vla (ss / n e l)
(setq n (sslength ss))
(setq l (cons (vlax-ename->vla-object e) l))
2 giờ trước, thanhduan2407 đã nói:
Thiếu hàm: ST:SS->List-Vla mà bác vẫn chạy được nhỉ?
Chắc là máy có load hàm đó vào trong 1 lisp khác rồi Hehehe
Vào lúc 19/2/2022 tại 11:25, huunhantvxdts đã nói:
À cũng ko hẳn vậy, trong quá trình chờ đợi các bác trên này rep. E có search dc trên mạng lisp của anh Lee-Marc có tính năng đáp ứng đúng nhu cầu của em.
Một lần nữa cảm ơn các bác.
12 phút trước, emhoccad đã nói:
Cái đó mình đã sửa lại lúc phát hiện thiếu hàm rồi mà
