alibaba2209
Anh chị giúp em lsp thể hiện độ xa gần nhìn từ trên xuống
Tự nghiên cứu (vì lisp của người ta, tôi chỉ lưu lại khi cần chứa chưa dùng): LISP ĐÁNH BÓNG
;; free lisp from cadviet.com
;;; this lisp was downloaded from http://www.cadviet.com/forum/index.php?showtopic=61922
;by PhamThanhBinh
(defun c:kbg (/ e1 e2 a  a1 e  k p pd pc dis B)
(command "undo" "be")
(command "ucs" "w")
(setq e1 (car(entsel "\n Chon duong bien thu nhat"))
        e2 (car(entsel "\n Chon duong bien thu hai"))
        e (car (entsel "\n Chon duong ke chuan"))
        ;;; a (getreal "\n Nhap khoang cach chuan: ")
        k (Getreal "\n Nhap he so khoang cach: ")
        p (getpoint "\n Chon huong rai duong ke bong")
        dis (distance p (vlax-curve-getClosestPointTo (vlax-ename->vla-object e) p T))
        b 0
(if (not a1) (setq a1 (getreal "\n Nhap khoang cach chuan: ")))
(if (/= a1 nil)
(setq a a1)
(setq a 10))
(setq la (getstring t "\n Nhap ten layer: "))
(if (= (tblsearch "layer" la) nil)
    (command "layer" "m" la "c" 8 "" "")
(setvar "clayer" la)
(command "change" e "" "p" "la" la "")
(while (and (< b dis) (> a 0.01))
    (command "offset" a e p "")
    (setq e (entlast)
             a (* k a)
             b (+ b a)
             pd (vlax-curve-getstartpoint e)
             pc (vlax-curve-getendpoint e)
             d1 (vlax-curve-getclosestpointto e1 pd T)
    (if (setq p1 (acet-geom-intersectwith e e1 0))
        (command "trim"  e1 ""  pd "")
        (command "extend" e1 "" pd "")
    (if (setq p2 (acet-geom-intersectwith e e2 0))
        (command "trim" e2 "" pc "")
        (command "extend" e2 "" pc "")
;;;(command "ucs" "p")
(command "undo" "e")
