vankiemquytong
[Yêu cầu] lisp cộng trừ nhân chia text
;--------Nguyen The Anh-Road No2-RECO-TEDI-----------
;--------Standard command for edit section-----------
(setq #tyle 0.001)
(setq tle 1)
(setq #height 0.34)
(setq #widthfactor 1)
(setvar "dimzin" 0)
(defun c:setup()
        (if (not (and (/= #tyle 0) (/= #tyle nil))) (setq #tyle n1))
    (setq xau (strcat "New Scale (1/<" (rtos (/ 1 #tyle) 2 0) ">): "))
    (setq h1 (getreal xau))
    (if h1 (setq #tyle h1) (setq h1 #tyle))
(if (null #tyle) (setq #tyle (getreal "\Ty le (1/<1000>) :")))
 (if (null #tyle) (setq #tyle 0.001))
    (setq tle (/ 1 #tyle))
    (setq tle (/ tle 1000))
(setq #height (entsel "\nText lam mau:"))
    (if (null #height) (princ)
      (setq ds (entget (car #height)))
      (setq #height (cdr (assoc 40 ds)))
      (setq #widthfactor (/ (distance (cdr (assoc 10 ds)) (cdr (assoc 11 ds)) ) 2))
;=====Area for scale================================
(defun c:Ac ( / po ent dt dtc tle1)
   (Start)
   (setq osmd1 (getvar "osmode"))
    (setq po (getpoint "/Chon 1 diem trong:")
          dtc 0)
    (setvar "osmode" osmd1)
    (while po
       (command"bpoly" po "")
       (setq ent (entlast))
       (command"area" "e" ent)
       (setq dt (getvar "area")
	     dtc (+ dtc dt))
       (command "erase" ent "")
       (setq po (getpoint "/Diem trong tiep/<Enter> de ket thuc: "))
(setq dc (getpoint "/Diem dat Text:"))
(setq dt (rtos (* dtc tle tle) 2 2))
(setq dt1 dt)
(command ".text" dc #height "0" dt1)
    (kthuc)
;-------------Lenght for grow grass -----------
(defun c:tca ()
 (start)
 (setvar "osmode" 33)
 (setq tco 0)
 (setq poo (getpoint "\<Start Point>:"))
(while poo
  (setq p1 poo)
  (setq p2 (getpoint "\<Second Point>:"))
  (setq kca (distance p1 p2))
  (setq tco (+ kca tco))
  (setq poo (getpoint "\<Enter> Stop/<Next Point>:"))
;*** End while ***
 (setq tco (* tco tle))
 (setq text1 (rtos tco 2 2))
 (setq dc (getpoint "\<Insert>:"))
 (command ".text" dc #height "0" text1)
 (kthuc)
(defun laygiatri (  ds1  / gt1  gt)
(setq 	gt1 (cdr (assoc 1 (entget ds1)))
	gt	(rtos (read gt1) 2 2)
(defun laygiatritru (  ds1 ds2  / gt1 gt2 gt)
	gt2  (cdr (assoc 1 (entget ds2)))
	gt	(rtos (- (read gt1 ) (read gt2)) 2 2)
(defun laygiatritong (  ds1 ds2  / gt1 gt2 gt)
	gt	(rtos (+ (read gt1 ) (read gt2)) 2 2)
(defun layso ( thongbao / gtri a kq)
(setq a (entsel thongbao))
(and
	(/= a  nil)
	(= (type (setq gtri (assoc  1 (entget (car a))))) 'STR)
	(= (type (read gtri)) 'REAL)
 (setq kq gtri)
;-------Thay Text cho Text--------------------------
;(defun c:sa ( / ds1 ds3 gt ds dsach)
;(setq
;	ds1 (car (entsel "\n Chi Text gia tri: "))
;	ds3 (car (entsel "\n Chi Text muon thay: " ))
;	ds  (entget ds3)
;	gt  (cons 1 (laygiatri ds1 ))
;	(entdel ds3)
;		(foreach tam 	ds
;			(if (/= (car tam)	1)	(setq dsach 	(append dsach (list tam)))
;						(setq dsach 	(append dsach (list gt)))
;	(entmake dsach)
;(princ)
(defun c:sa ()
 (setvar "Cmdecho" 0)
 (prompt "\n<<   Select Data             >>")
 (setq sstcong (entsel))
        (setq sdk (entget (car sstcong)))
        (if (= (cdr (assoc 0 sdk)) "TEXT")
            (setq tckl (cdr (assoc 1 sdk)))
            (prompt "\n<< ERROR : Nothing Text Selected. >>")
 (prompt "\n<<   Select Text To Copy.  >>")
 (setq tcong (ssget))
 (setq sslen (sslength tcong))
      (while (> sslen 0)
        (setq stc (entget (ssname tcong (setq sslen (1- sslen)))))
        (if (= (cdr (assoc 0 stc)) "TEXT")
            (entmod (subst (cons 1 tckl) (assoc 1 Stc) Stc))
  (setvar "Cmdecho" 1)
;--------Tru 2 Text va thay Text-----------
(defun c:Ta ( / ds1 ds2 ds3 gt ds dsach)
	ds1 (car (entsel "\nGia tri bi tru: "))
	ds2 (car (entsel "\nLuong can tru: " ))
	ds3 (car (entsel "\n Thay Text: " ))
	ds  (entget ds3)
	gt  (cons 1 (laygiatritru ds1 ds2))
	(entdel ds3)
		(foreach tam 	ds
	(entmake dsach)
;--------------Sum value text---------------------------
(defun c:ca ( / ds1 ds2 ds3 gt ds dsach)
	ds1 (car (entsel "\n Gia tri 1: "))
	ds2 (car (entsel "\n Gia tri 2: " ))
	ds3 (car (entsel "\n Thay Text/Gia tri: " ))
	ds  (entget ds3)
	gt  (cons 1 (laygiatritong ds1 ds2))
	(entdel ds3)
		(foreach tam 	ds
	(entmake dsach)
;---------------Ham goc----------------------
(defun start ()
 (setq osmd (getvar "osmode"))
 (setq tex (getvar "texteval"))
 (setq cmd (getvar "cmdecho"))
 (setq angb (getvar "angbase"))
 (setq angd (getvar "angdir"))
 (setvar "texteval" 1)
(defun kthuc ()
 (setvar "osmode" osmd)
 (setvar "texteval" tex)
 (setvar "cmdecho" cmd)
 (setvar "angbase" angb)
 (setvar "angdir" angd)
;-----Evelation - Edit from "SuaTN.lsp"----
(defun c:cda ()
   (start)
   (setq p111 (getpoint "\nChon diem chuan :"))
   (setq c1 "caodo")
   (while (not (numberp c1))
   (setq c1 (car (entsel "\nChi cho text cao do cua diem chuan:")))
   (if (null c1) (princ)
     (if (/= (assoc 1 (entget c1)) nil)
      (setq c1 (read (cdr (assoc 1 (entget c1)))))
  (setq p211 (getpoint p111 "\nDiem can tinh : "))
   (while p211
    (setq px (* (- (cadr p211) (cadr p111)) tle))
    (setq tet (+ c1 px))
    (setq tet (rtos tet 2 2))
    (setq dc (getpoint p211 "\nDiem chen : "))
    ;(setq dc (mapcar '- dc (list 0.0 #widthfactor)))
    ;(setq dc1 (mapcar '+ dc (list 0.0 (* #widthfactor 2.0)) ))
    (command "text" dc #height 90 tet "" "")
    (setq p211 (getpoint p111 "\nDiem can tinh/<Enter> for End: "))
   );End While
 (kthuc)
;-----------Khoang cach le------------------
(defun c:kca ()
 (start)
 (setvar "osmode" 1)
 (setq p3 (getpoint "\nChon diem thu nhat : "))
 (while p3
  (setq p4 (getpoint p3 "\nChon diem thu hai : "))
  (setq kca (abs (- (car p3) (car p4))))
  (setq kca2 (abs (* kca tle)))
  (setq text (rtos kca2 2 2))
  (setq dc (getpoint "\nDiem chen : "))
 (if (>= kca2 1.0) (princ)
                   (if (>= kca 2.23)
                                  (setq height 2)
                                  (setq height (* kca 0.78))
                   (setq ddtext1 (list (+ (car dc) (/ height 2)) (- (cadr dc) 2.0)))
                   (setq ddtext2 (list (+ (car dc) (/ height 2)) (+ (cadr dc) 2.0)))
                   (command "text" dc #height 90 text "" "")
                   );end progn
  );end if
  (if (< kca2 1.0) (princ)
        (setq ddtext1 (list (- (car dc) (/ kca 2.1)) (- (cadr dc) 1.0))); ***Tu 1m den 1.5m ***
        (setq ddtext2 (list (+ (car dc) (/ kca 2.1)) (- (cadr dc) 1.0)))
        (if (>= kca 7.5) (setq ddtext1 (list (- (car dc) 3.4) (- (cadr dc) 1.0))))
        (if (>= kca 7.5) (setq ddtext2 (list (+ (car dc) 3.4) (- (cadr dc) 1.0))))
        (command "text" dc #height 0 text "" "")
  );end if
  (setvar "osmode" 1)
  (setq p3 (getpoint "\nChon diem thu nhat/<Enter> for End: "))
 );end while
  (kthuc)
;--------------Nang Text 3D for SDSK---------------
(defun c:movet (/ ss ee e l k cd p)
   (command "UNDO" "begin")
   (setq ss (ssget))
   (if ss (progn
      (setq l (sslength ss))
      (setq k 0)
      (repeat l
         (setq e (ssname  ss k))
         (setq k (+ k 1))
         (setq ee (entget e))
         (if (= (cdr (assoc 0 ee) ) "TEXT")
                (setq p (cdr (assoc 10 ee) ))
                (setq cd (cdr (assoc 1 ee)))
                (setq cd (atof cd))
                (setq p (list (car p) (cadr p) cd ))
                (setq ee (subst (cons 10 p) (assoc 10 ee) ee))
                (entmod ee)
                (entupd e)
   (command "UNDO" "end")
;;;;Tinh cong don;;;;;
(defun c:ss()
 (setvar "CMDECHO" 0)
 (setvar "DIMZIN" 0)
 ;(setq pre (getint "\nSo chu so sau dau phay?"))
 (command "luprec" 2)
 (setq co (getreal "\nGia tri can cong them:"))
 (SETQ TH (SSGET))
 (SETQ QUANT (SSLENGTH TH))
  (SETQ INDEX 0)
  (WHILE (< INDEX QUANT)
  (IF
	  (AND(= "TEXT" (CDR (ASSOC 0 (SETQ A (ENTGET (SSNAME TH INDEX)))))))
     (PROGN
		 (setq s (entget (SSNAME TH INDEX)))
		   (setq otext (assoc 1 s))
		   (setq ot (cdr otext))
		   (setq ot (read (substr ot 1 )))
		   (setq nt (cons 1 (rtos (+ ot co) 2 2)))
		   (setq s (subst nt otext s))
		   (entmod s)
  (setq index (+ index 1))
- bạn up code dạng này ko tải để xem đc, nhưng nhoc đoán mò là, bạn xem trong lsp dòng nào có hàm (rtos (.....) 2 2) thì cứ chuyển số 2 cuối thành 3 là đc =>
(rtos (....) 2 3)
Cảm ơn bạn nhé, lisp như thế này ạ. vì nó nhiều lệnh quá.
gt (rtos (- (read gt1 ) (read gt2)) 2 3)
- Nếu bạn chỉ mún phép trừ ra 3 số thập phân thì bạn kím cái hàm này (laygiatritru),  sửa dòng gt (rtos (.......) 2 3)
- số cuối cùng trong hàm (rtos) đó là số quyết định số thập phân mún lấy bao nhiêu, nếu không có để số cuối cùng đó chỉ để mỗi số 2 kia thì mặc định nó sẽ lấy theo units bạn set hiện tại trên bản vẽ là lấy bao nhiêu số thập phân
- cái trên là nhoc đã sữa cho bạn lệnh trừ ra 3 số thập phân rùi
 một lần nữa cảm ơn bạn rất nhiều.
Ps diễn đàn hình như gõ tiếng việt bị lỗi thì phải, cứ nhảy lui con trỏ .
Cái này bổ sung thêm phần ghi kết quả vào 1 text có sẵn .
(defun c:tinh()
(initget 1 "+ - * /")
(setq ptinh (getkword "Chon phep tinh <+ - * />: "))
(cond ((= ptinh "+") ;;; cong
(prompt "\nChon text de cong:")
(setq ss (ssget '((0 . "TEXT")))
kqua 0)
(while (and ss (> (sslength ss) 0))
(setq kqua (+ kqua (atof (cdr (assoc 1 (entget (setq ent (ssname ss 0))))))))
(ssdel ent ss))
(princ kqua))
((= ptinh "*") ;;;nhan
(prompt "\nChon text de nhan:")
kqua 1)
(setq kqua (* kqua (atof (cdr (assoc 1 (entget (setq ent (ssname ss 0))))))))
(ssdel ent ss))
(princ kqua))
((= ptinh "-") ;;;tru
(setq sobitru (car (entsel "\nChon so bi tru:"))
sotru (car (entsel "\nChon so tru:\n"))
kqua (- (atof (cdr (assoc 1 (entget sobitru))))
(atof (cdr (assoc 1 (entget sotru))))))
(princ kqua))
((= ptinh "/") ;;;chia
(setq sobichia (car (entsel "\nChon so bi chia:"))
sochia (car (entsel "\nChon so chia:\n"))
kqua (/ (atof (cdr (assoc 1 (entget sobichia))))
(atof (cdr (assoc 1 (entget sochia))))))
(princ kqua))
(if (not ssle) (setq ssle 0))
(setq obj (vlax-ename->vla-object (car (entsel "\nChon text de ghi ket qua:")))
ssle1 (getint (strcat "\nSo so le <" (itoa ssle) ">: ")))
(if ssle1 (setq ssle ssle1))
(vla-put-TextString obj (rtos kqua 2 ssle))
Cái này tốt rồi nhưng bạn làm sao để mỗi lần mình làm nhiều lần nó có thể nhớ được thao tác mình làm trc đó làm mặc định được không? Cứ mỗi lần bấm 1 phép tính là cứ phải chọn lại phép tính " cộng, trừ, nhân, chia" thì hơi bất tiện xíu, thanks
Bạn thử cái này xem sao.
Đối với phép + và * bạn có thể chọn 1 lúc nhiều số, còn - và / thì chỉ có 2 số thôi.
(defun c:tinh()
  (setq ptinh (getkword "Chon phep tinh : "))
	       tong 0)
	   (setq tong (+ tong (atof (cdr (assoc 1 (entget (setq ent (ssname ss 0))))))))
	   (ssdel ent ss))
	 (princ tong))
	       tong 1)
	   (setq tong (* tong (atof (cdr (assoc 1 (entget (setq ent (ssname ss 0))))))))
	   (ssdel ent ss))
	 (princ tong))
	       kq (- (atof (cdr (assoc 1 (entget sobitru))))
	 (princ kq))
	       kq (/ (atof (cdr (assoc 1 (entget sobichia))))
	 (princ kq))
Bác có thể giúp em là lúc xuất kết quả ra text có sẵn thì khi chọn text nó sẽ thêm số lượng vào đầu text chứ không phải xóa dòng text đó để thêm số lượng vào,hoặc là xuất ra kết quả bằng thông báo được không. Cám ơn bác nhìu.
Vào lúc 7/8/2016 tại 00:03, vanhuyou đã nói:
Vào lúc 21/6/2009 tại 19:46, q288 đã nói:
(defun c:tinh()
	       tong 0)
	   (ssdel ent ss))
	 (princ tong))
	       tong 1)
	   (ssdel ent ss))
	 (princ tong))
	 (princ kq))
	 (princ kq))
Lisp rất tuyệt, nhưng các bác giúp em 1 việc là xuất toàn bộ các số hạng và kết quả ra thành đối tượng Text của  CAD được không ạ,
ví dụ: trên cad sẽ hiện lên dòng: 3+4+6+9=22.
em chân thành cảm ơn!
Chào mọi người, em là thành viên mới.
Em vừa tải lisp này về nhưng khi thực hiện phép NHÂN thì kết quả nó lại hiện ra số 1 là sao thưa các bác (Vd: 6*3 =1 ???)
Mọi người trả lời giúp em với nhé. Em xin cảm ơn.
Anh em nào giúp viết code cộng một số nhập từ bàn phím vào text có sẵn và thay đổi giá trí của text đó luôn được ko.
Ví dụ: có text +3.2/+6.8/+9.1
mình muốn cộng/ trừ  cảctext trên với 1 số nhập từ bàn phím ví dụ là 3.0
Các text sẽ thay đổi thành: +6.2/+9.8/+12.1
Xin giúp đỡ. Thanks các cao thủ nhiều.
1 giờ trước, huanutc90 đã nói:
Lệnh ZZ, chọn Text, nhập phép tính, ví dụ: -3+4*0.5 (phép tính từ trái qua phải, ko ưu tiên nhân chia trc cộng trừ sau)
Cong tru nhan chia.lsp
Có Lisp tính toán này, AE tham khảo: (nguyên tắc nhân chia trước, cộng trừ sau)
- Lisp làm các phép tính bằng cách chọn trực tiếp các đối tượng trong bản vẽ để lấy thuộc tính: Số - Chiều dài - Diện tích - Khoảng cách điểm
- Cộng trừ nhân chia với 1 hệ số
- Tính nhanh %
- Tạo link các Text tính toán
- Tìm các Text được link
>>> Link tải : https://drive.google.com/file/d/1bIeJiQD2xl8D0YyKP0g4ZVtHBVbiYcAf/view
> Link video tiện ích Tính toán :
Part 1: https://youtu.be/RD-mxun_KaU
Part 2: https://youtu.be/fTxGOnsbhBc
Part 3: https://www.youtube.com/watch?v=7CW2jU_kuoQ
Vào lúc 10/2/2010 tại 10:30, phvinhhpc đã nói:
dùng con này xem: http://www.cadviet.com/upfiles/2/ctnc.lsp
muốn cộng : +
trừ: -
nhân: *
chia: /
(lưu ý: trước khi load lisp thì đặt mặc định cỡ text : vd là 2)
cho em hỏi sao không dùng được lisp này nhỉ, chọn text xong không chọn điểm ghi kết quả được, xin giúp đỡ
