[Đã xong] Dynamic Polar Array
Có cái Dynamic Array theo đường thẳng rồi, tiện thể e đi cóp nhặt thêm về cái Dynamic copy rotate theo đường tròn nữa, post lên mọi người xài chơi.
Cho phép tăng dần đối với Text (như bản Dynamic Larray)
Mời mọi người dùng thư giãn và thanks nhé ^^ hệch hệch
Preview :
Open Source :
;Polar Array @Ketxu 22-9
;CADViet.com
;Many thank to qjchen again
(defun c:par( / ang angnow gr oang p0 px px1 ss ss1 cc oldAng ans)
(grtext -1 "Dynamic PArray @Ketxu")
(setq m:err *error*	*error* err)
(command "undo" "be")
(setq oldAng (getvar "angbase"))
(if (and
 (setq ss (ST:SS->List-Vla (ssget))
p0 (getpoint "\nT\U+00E2m quay : :")
px (getpoint p0 "\n\U+0110\U+01B0\U+1EDDng c\U+01A1 s\U+1EDF ::")
 (grdraw  p0 px 1)
 (setvar "angbase" (angle p0 px))
 (setq   cc (_circle p0 (distance p0 px))
ang (getangle p0 "\nG\U+00F3c Array :")
s (/ (getvar "viewsize") (cadr (getvar "SCREENSIZE")))
 (cond ((ST:Check-Exist '("AcDbText" "AcDbMText") (mapcar 'vla-get-objectname ss))
(setq ans (strcase(getstring "Copy t\U+0103ng Text ? < K > :")))
 	(cond ((not (or (= ans "K")(= ans "")))
   	(or #num (setq #num 1))
   	(setq #num (cond ((getint (strcat "\nGia s\U+1ED1 < " (rtos #num 2 0) " > :")))(#num)) inc T)
(prompt "\nPick \U+0111i\U+1EC3m cu\U+1ED1i c\U+00F9ng :")
(while (= (car (setq gr (grread nil 5 0))) 5)
 (if ss1 (mapcar 'vla-delete ss1))
 (redraw)
 (setq angnow (angle p0 (cadr gr))
  g (trans (cadr gr) 1 3)
 (grvecs (LM:GrText (rtos (/ (* angnow 180) pi) 2 0) 3)
  (lambda ( r x y )
  (list
(list r  0. 0. x )
(list 0. r  0. y )
(list 0. 0. r  0.)
(list 0. 0. 0. 1.)
  s
  (+ (car  g) (* 15 s))
  (- (cadr g) (* 31 s))
 (if (and (< ang 0)(> angnow 0)) (setq angnow (- angnow (* 2 pi))))
 (if (and (> ang 0)(< angnow 0)) (setq angnow (+ (* 2 pi) angnow)))
 (setq ss1 (_copyCC ss (fix (/ angnow ang)) p0 ang inc #num))
 (grdraw:arc p0 (/ (getvar "viewsize") 4.0) (angle p0 px) angnow)
(entdel cc)
;(setvar "angbase" oldAng)
(command "undo" "en")
;;; by qjchen, copy ss according to the direction and vector   			;
(defun _copyCC (sslst n cen ang inc num / i obj1 ss xobj lst number)
 (foreach xobj sslst
(setq  i 1)
(cond ((and (wcmatch (vla-get-objectname xobj) "AcDbText,AcDbMText") inc num)
(cond ((= 'REAL (type (setq number (last (setq lst (ST:String-GetNumber (vla-get-textstring xobj)))))))
(setq  isReal T))
(T (setq  isReal nil))
  (setq isText T)
  ) ;Text Object
  (T setq isText nil)
(repeat n
 	(setq obj1 (vla-copy xobj))
 	(Vla-rotate obj1 (vlax-3d-point cen) (* ang i))
 (if  (and isText (wcmatch (vla-get-objectname xobj) "AcDbText,AcDbMText") inc num)
  (vla-put-textstring obj1 (strcat (car lst) (rtos (setq number (+ num number)) 2  (if isReal 1 0))(cadr lst))))
 	(setq i (1+ i) ss (cons obj1 ss))
 ss
;;; @Ketxu Make Circle Temp                                            	;
(defun _circle (p0 r / ent)
(redraw (setq ent(entmakex (list (cons 0 "CIRCLE")(cons 10 (trans p0 1 0))(cons 40 r)))) 3) ent)
(defun RtD (rad) ; converts radian to degree
(/ (* rad 180) pi)
);defun
;;; Check List Item Exist in Other List @Ketxu         					;
(defun ST:Check-Exist(lst1 lst2)(and (vl-remove nil (mapcar '(lambda(x)(vl-position x lst2)) lst1))))
;;; Selection to list  VLA @Ketxu                                      	;
(defun ST:SS->List-Vla (ss / n e l)
 (setq n (sslength ss))
 (while (setq e (ssname ss (setq n (1- n))))
(setq l (cons (vlax-ename->vla-object e) l))
(defun ST:Ss-Delete (ss / i)
 (mapcar 'vla-delete (ST:SS->List-Vla ss))
;;; grdraw circle arc                       					;
(defun grdraw:arc(cen r ang angadd / angdiv n)
(grdraw cen (polar cen ang r) 3 1)
(grdraw cen (polar cen (+ ang angadd) r) 3 1)
(setq n 100 angdiv (/ angadd n))
(repeat n
  (grdraw (polar cen ang r)(polar cen (setq ang (+ ang angdiv)) r) 1 1)
(defun ST:String-GetNumber (str / i j dau cuoi tmp tmp1 tmp2 num)
(setq lst (vl-string->list str) i -1 j (strlen str))
(list
(setq tmp1 (vl-list->string (reverse (while (not (or (<= 48 (setq tmp (nth (setq i (1+ i)) lst)) 57) (>= i j))) (setq dau (cons tmp dau))))))
(setq tmp2(vl-list->string (while (not (or (<= 48 (setq tmp (nth (setq j (1- j)) lst)) 57) (<= j i))) (setq cuoi (cons tmp cuoi)))))
(if (vl-string-search "." (setq num (vl-string-left-trim tmp1 (vl-string-right-trim  tmp2 str)))) (atof num) (atoi num))
;;; Error del selection @Ketxu                         					;
(defun err (msg)
(if cc (entdel cc))
(if oldAng (setvar "angbase" oldAng))
(setq *error* m:err  m:err nil)
(defun LM:GrText ( str col / c i l v y ) ;@Lee Mac
 (setq v
 	("\t")
 	("!"   45  45  65 135)
 	("\"" 104 134 107 137)
 	("#"   43  63  46  66  84  94  87  97 115 135 118 138  72  78 103 109)
 	("$"   25  35  52  52  43  47  58  78  83  87  92 112 123 127 118 118 135 135)
 	("%"   52  52  63  63  74  74  85  85  96  96 107 107 118 118 129 129  47  48  67  68  56  56  59  59 113 114 133 134 122 122 125 125)
 	("&"   43  46  49  49  52  72  57  58  67  68  76  76  79  79  83  83  85  85  94  94 103 123 134 136 127 127)
 	("'"  105 135)
 	("("   17  17  26  36  45 105 116 126 137 137)
 	(")"   14  14  25  35  46 106 115 125 134 134)
 	("*"   73  74  76  77  84  86  92  98 104 106 113 114 116 117)
 	("+"   55 115  82  84  86  88)
 	(","   34  35  45  46  55  57)
 	("-"   83  88)
 	("."   45  46  55  56)
 	("/"   52  52  63  63  74  74  85  85  96  96 107 107 118 118 129 129)
 	("0"   44  47 134 137  53 123  58 128)
 	("1"   44  48 124 125  56 136)
 	("2"   43  48  53  53  64  64  75  75  86  86  97  97 108 128 134 137 123 123)
 	("3"   53  53  44  47  58  88  95  97 108 128 134 137 123 123)
 	("4"   46  48  57 137  78  78  73  76  83  83  94  94 105 115 126 126)
 	("5"   53  53  44  47  58  88  94  97  93 133 134 138)
 	("6"   44  47  58  88  95  97  84  84  53 113 124 124 135 137)
 	("7"   44  54  65  75  86  96 107 117 128 138 133 137 123 123)
 	("8"   44  47  94  97 134 137  53  83  58  88 103 123 108 128)
 	("9"   44  46  57  57  68 128  97  97  84  86 134 137  93 123)
 	(":"   45  46  55  56  95  96 105 106)
 	(";"   34  35  45  46  55  57  95  96 105 106)
 	("<"   47  47  56  56  65  65  74  74  83  83  94  94 105 105 116 116 127 127)
 	("="   73  78  93  98)
 	(">"   43  43  54  54  65  65  76  76  87  87  96  96 105 105 114 114 123 123)
 	("?"   45  45  65  75  86  86  97  97 108 128 134 137 123 123)
 	("@"   34  38  43  43  52 112 123 123 134 137 128 128  79 119  68  68  65  66 105 106  77 107  74  94)
 	("A"   41  43  47  49  52  62  58  68  73  77  83  93  87  97 104 114 106 116 125 135 133 134)
 	("B"   42  47  53 123  58  88 108 128  94  97 132 137)
 	("C"   44  47  53  53  58  58  62 112 123 123 134 136 127 127 108 138)
 	("D"   42  46  57  57 127 127 132 136  68 118  53 123)
 	("E"   42  48  58  58  94  95  86 106 132 137 128 138  53 123)
 	("F"   42  45  94  95  86 106 132 137 128 138  53 123)
 	("G"   44  47  53  53  58  78  86  89  62 112 123 123 134 136 127 127 108 138)
 	("H"   41  43  47  49 131 133 137 139  93  97  52 122  58 128)
 	("I"   43  47 133 137  55 125)
 	("J"   52  62  43  46  57 127 135 139)
 	("K"   42  44  48  49 132 134 136 138  53 123  84  85  95  95 106 116 127 127  76  76  67  67  58  58)
 	("L"   42  47  48  58  53 123 132 135)
 	("M"   41  43  47  49  52 122  58 128 131 132 138 139 103 113 107 117  84  94  86  96  65  75)
 	("N"   41  44 131 132 136 139  52 122  48 128 113 113  94 104  85  85  66  76  57  57)
 	("O"   44  46  53  53  57  57 123 123 127 127 134 136  62 112  68 118)
 	("P"   42  45  84  87 132 137  53 123  98 128)
 	("Q"  134 136 123 123 127 127 112  62 118  68  53  53  57  57  44  46  35  36  23  24  27  28)
 	("R"   42  44  48  49 132 137 123  53 128  98  84  87  76  76  67  67  58  58)
 	("S"   42  62  53  53  44  47  58  78  86  87  93  95 102 122 133 136 127 127 118 138)
 	("T"   43  47  55 125 132 138 131 121 139 129)
 	("U"   44  46  52  53  57  58  62 122  68 128 131 133 137 139)
 	("V"   45  55  64  74  66  76  83 103  87 107 112 122 118 128 131 133 137 139)
 	("W"   43  63  47  67  72  92  74  94  76  96  78  98 101 121 105 115 109 129 131 132 138 139)
 	("X"   41  43  47  49 131 133 137 139  52  52  58  58  63  63  67  67  74  74  76  76  85  95 104 104 106 106 113 113 117 117 122 122 128 128)
 	("Y"   43  47  55  85  94  94  96  96 103 113 107 117 122 122 128 128 131 133 137 139)
 	("Z"  122 122  58  58 132 138  42  48 128 128  52  52  63  63  74  74  85  95 106 106 117 117)
 	("["   15  17 135 137  25 125)
 	("\\" 122 122 113 113 104 104  95  95  86  86  77  77  68  68  59  59)
 	("]"   14  16 134 136  26 126)
 	("^"  102 102 113 113 124 124 135 135 126 126 117 117 108 108)
 	("_"   21  29)
 	("`"  125 125 134 134)
 	("a"   43  46  48  48  52  72  57  97  83  86 103 106)
 	("b"   42  43  45  46  54  54  57  58  68  98  97  97 105 106  94  94 132 132  53 133)
 	("c"   44  46  53  53  57  58  52  92  93  93 104 106  97  98 108 108)
 	("d"   44  45  47  48  52  92  53  53  56  56  93  93 104 105  96  96 136 136  57 137)
 	("e"   44  46  53  53  57  58  52  92  93  93 104 106  97  98  88  88  73  78)
 	("f"   43  46  54 124  93  93  95  96 135 137 128 128)
 	("g"   13  16  22  32  27  97 107 108  66  66  96  96  54  55 104 105  63  63  93  93  62  92)
 	("h"   42  44  46  48  57  97  53 133 132 132  94  94 105 106)
 	("i"   43  47  55 105 103 104 135 135)
 	("j"   22  22  13  15  26 106 104 105 136 136)
 	("k"   42  44  46  48  53 133 132 132  57  57  66  66  74  75  85  85  96 106 107 108)
 	("l"   43  47  55 135 133 134)
 	("m"   41  43  45  46  48  49  52 102  55 105  58 108 101 101  93  93 104 104  96  96 107 107)
 	("n"   42  44  46  48  53 103  57  97 102 102  94  94 105 106)
 	("o"   44  46 104 106  53  53  57  57  93  93  97  97  52  92  58  98)
 	("p"   12  15  23 103 102 102  54  54  94  94  45  46 105 106  57  58  97  98  68  88)
 	("q"   15  18  27 107 108 108  56  56  96  96  44  45 104 105  52  53  92  93  62  82)
 	("r"   42  46  54 104 102 103  95  95 106 108  99  99)
 	("s"   52  52  43  47  58  68  73  77  82  92 103 107  98  98)
 	("t"   45  47  58  58  54 124 102 103 105 107)
 	("u"  102 102 106 106  53 103  56  56  44  45  47 107  48  48)
 	("v"   45  45  54  64  56  66  73  83  77  87  92  92  98  98 101 103 107 109)
 	("w"   43  53  47  57  62  92  64  84  66  86  68  98 101 103  95 105 107 109)
 	("x"   42  44  46  48 102 104 106 108  53  53  57  57  93  93  97  97  64  64  66  66  84  84  86  86  75  75)
 	("y"   12  13  24  24  35  45  54  64  56  66  73  83  77  87  92  92  98  98 101 103 107 109)
 	("z"   92  92  58  58 102 108  42  48  97  97  86  86  75  75  64  64  53  53)
 	("{"   16  17  25  65  73  74  85 125 136 137)
 	("|"   15 135)
 	("}"   14  15  26  66  77  78  86 126 134 135)
 	("~"  112 122 133 134 125 125 116 117 128 138)
 (eval
(list 'defun 'LM:GrText '( str col / c i l v y )
 	(list 'setq 'v
   	(list 'quote
     	(mapcar
       	(function
         	(lambda ( b )
           	(cons (car B) (mapcar '(lambda ( a ) (if a (list (rem a 10) (/ a 10)))) (cdr B)))
       	v
'(setq i 0 y 0)
'(repeat (strlen str)
     	( (eq (setq c (substr str 1 1)) " ")
       	(setq i (+ i 9) str (substr str 2))
     	( (eq c "\t")
       	(setq i (+ i 36) str (substr str 2))
     	( (eq c "\n")
       	(setq i 0 y (- y 16) str (substr str 2))
     	( (setq l
         	(cons
           	(mapcar
             	(function
               	(lambda ( a )
                 	(if a (list (+ (car a) i) (+ (cadr a) y)))
             	(cdr (assoc c v))
           	l
         	str (substr str 2) i (+ i 9)
'(cons col (apply 'append l))
 (LM:GrText str col)
  • Vote tăng 6
Rải trên cung tròn thì sao nhỉ. lisp rdt của anh Duy ko rải kín đc. cài này rải kín đc mà phải biết tâm.hiiii
Chạy tốt quá, thích nhất khoản rê chuột^^
OK,
Chạy tốt quá. Anh bổ sung thêm chỗ này thử đc ko anh ketxu
Ngay chỗ lựa chọn góc Array đó, anh thay bằng lựa chọn là Array theo góc hay theo pick chọn điểm. nếu pick điểm thì chọn điểm base point, rồi chọn điểm copy đến, nó sẽ quay theo tâm đã chọn. Nếu mình chọn Góc array thì chạy như lisp trên.
Thích nhất cái khoản rê chuột^^
Đã sửa, bạn có thể pick điểm hoặc đánh số. Vấn đề đau đầu nhất là góc âm hẹn đi du lịch về mình giải quyết tiếp. Khà khà
Preview :
Open Source :
;CADViet.com
(if (and
 (grdraw  p0 px 1)
 (redraw)
  (lambda ( r x y )
  (list
(list r  0. 0. x )
(list 0. r  0. y )
(list 0. 0. r  0.)
(list 0. 0. 0. 1.)
  s
(entdel cc)
 (foreach xobj sslst
(setq  i 1)
(setq  isReal T))
  (setq isText T)
  ) ;Text Object
  (T setq isText nil)
(repeat n
 ss
(/ (* rad 180) pi)
);defun
(repeat n
(list
(defun err (msg)
(if cc (entdel cc))
 (setq v
 	("\t")
 	("!"   45  45  65 135)
 	("'"  105 135)
 	("-"   83  88)
 	("."   45  46  55  56)
 	("="   73  78  93  98)
 	("_"   21  29)
 	("|"   15 135)
 (eval
 	(list 'setq 'v
   	(list 'quote
     	(mapcar
       	(function
         	(lambda ( b )
       	v
'(setq i 0 y 0)
     	( (eq c "\t")
     	( (eq c "\n")
     	( (setq l
         	(cons
           	(mapcar
             	(function
               	(lambda ( a )
             	(cdr (assoc c v))
           	l
 (LM:GrText str col)
Thank Ket đã có 1 lisp hay. Sướng nhất là biết được cái (LM:GrText) mà lâu nay đang cần.
  • Vote tăng 1
Preview :
Open Source :
;CADViet.com
(if (and
 (grdraw  p0 px 1)
 (redraw)
  (lambda ( r x y )
  (list
(list r  0. 0. x )
(list 0. r  0. y )
(list 0. 0. r  0.)
(list 0. 0. 0. 1.)
  s
(entdel cc)
 (foreach xobj sslst
(setq  i 1)
(setq  isReal T))
  (setq isText T)
  ) ;Text Object
  (T setq isText nil)
(repeat n
 ss
(/ (* rad 180) pi)
);defun
(repeat n
(list
(defun err (msg)
(if cc (entdel cc))
 (setq v
 	("\t")
 	("!"   45  45  65 135)
 	("'"  105 135)
 	("-"   83  88)
 	("."   45  46  55  56)
 	("="   73  78  93  98)
 	("_"   21  29)
 	("|"   15 135)
 (eval
 	(list 'setq 'v
   	(list 'quote
     	(mapcar
       	(function
         	(lambda ( b )
       	v
'(setq i 0 y 0)
     	( (eq c "\t")
     	( (eq c "\n")
     	( (setq l
         	(cons
           	(mapcar
             	(function
               	(lambda ( a )
             	(cdr (assoc c v))
           	l
 (LM:GrText str col)
Chào ketxu!
Lisp của ketxu rất hay, mình đã học được rất nhiều.
Mình hỏi Ketxu 1 vấn đề có liên quan đến GRREAD.
Đối với các hàm getxxx thì mình dùng initget để có các lựa chọn input khác. Vậy thằng Grread này có chức năng tương tự không ketxu?
Chẳng hạn như trong Lisp của ketxu, người dùng kéo rê chuột để chọn số lượng array; Có thể nào thêm lựa chọn khác để nhập, tỉ nhỉ bấm A để nhập góc tổng, bấm N để nhập trựctiếp số lượng ARRAY. Nếu không phải 2 lựa chọn trên thì kéo rê.
Mình nói rõ thêm là phương án kéo rê chuột ưu tiên không cần nhập Keyword, có 2 cách nhập kia mới nhập keyword.
Mình search vấn không có cách!
Chào ketxu!
Thấy bạn hỏi mà chưa thấy ai trả lời nên chém gió vài điều với bạn vậy.
1). Đỏ: thì bạn cứ dùng getxxx, đặt lựa chọn 1 và 2 là nhập góc và số lượng, lựa chọn 3 là nhập theo kiểu rê chuột. Khi lựa chọn 3 được chọn, chuột sẽ rê bằng grread. (Ket đã nhập đường cơ sở + góc, sau đó mới grread đó thôi).
2). Ngay trong khi đang dùng grread bạn cũng có thể nhập bằng getxxx, thậm chí gọi được dialoge. Quan trọng là có chút mẹo và rành về các var trong grread, bởi hàm này khá rắc rối. Tôi đã từng dùng, nhưng rất tiếc không up được.
Thân thương!
  • Vote tăng 1
@Hochoaivandot : Tất cả đều thực hiện được :) Grread bắt được sự kiện keypress, nên đương nhiên sẽ có lựa chọn khi đang rê chuột, bác nhấn 1 phím nào đó thì sẽ xử lý hàm theo cond đó thôi. Nhưng có thể làm code rối hơn, nên bác có thể để keyword ở ngay đầu rồi mới phân chia thao tác cũng được mà ^^
  • Vote tăng 2
Lại hỏi mọi người 1 câu nữa cũng liên quan đến cái (LM:GrText) ni. Nếu mình muốn text hiển thị trong hàm (LM:GrText) có kích thước to hơn thì chỉnh ở chổ nào nhỉ?
Trong hàm (LM:GrText) hay trong hàm chính. ví dụ như hàm chính của chính tác giả Lee dưới đây.
(defun c:test ( / *error* vl g s )
 (defun *error* ( msg )
(or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
   	(princ (strcat "\n** Error: " msg " **")))
(redraw) (princ)
 (setq vl  (LM:GrText "www.cadviet.com"  2 ))
 (while (= 5 (car (setq g (grread nil 13 0)))) (redraw)
(setq s (/ (getvar 'VIEWSIZE) (cadr (getvar 'SCREENSIZE))) g (trans (cadr g) 1 3))
(grvecs vl
   	(lambda ( r x y )
     	(list
       	(list r  0. 0. x )
       	(list 0. r  0. y )
       	(list 0. 0. r  0.)
       	(list 0. 0. 0. 1.)
   	s (+ (car  g) (* 15 s)) (- (cadr g) (* 31 s))
 (redraw) (princ)
Mình dùng qua lisp này thấy rất hay, Thanks ketxu
Sau khi chạy lisp này thì biến hệ thống LASTANGLE bị thay đổi, biến này không dùng setvar để gán lại được do nó là read only. Khi LASTANGLE bị thay đổi thì các text trước đó vần thầy bình thường nhưng vào properties của text thì thấy rotation đà bị thay đổi bằng với LASTANGLE. Các text được tạo sau này cũng bị quay theo
Mong Bạn hoàn thiện lisp tốt hơn
Biến Angbase mình thay đổi bạn ơi ^^ Lastangle luôn thay đổi khi có 1 chỉ số góc được nhập vào.
  • Vote tăng 2
em ko biết cái Dynamic Array theo đường thẳng bác ketxu giúp em với ! giả sử mình array 1 đối tượng chạy theo hình chữ s chẳng hạn ! giúp em với bác !!
thanks bác nhiều !
Đường thẳng và hình chữ S nó giống nhau hả bạn ơi :) Nếu cần theo hình đó thì bạn cài CAD2012 rồi array path nhé
Nhờ a Ketxu post lại lisp par.lsp ạ, em dơn load về nó không chạy ạ :
Command: par
undo Current settings: Auto = On, Control = All, Combine = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back]
<1>: be
Command:
Select objects: Specify opposite corner: 1 found
Select objects:
Tâm quay : :
Đường cơ sở ::
Góc Array :
Pick điểm cuối cùng :
Command:
Rồi đứng im :wub:
-Lisp không lỗi gì chạy bình thường. Khong nhập góc độ âm.
Bạn test chưa? Mình load lisp nó báo lỗi :  ; error: extra right paren on input    là sao ta :wacko:, Khi nhập :
Command: par
<1>: be
Command:
Select objects:
Tâm quay : :
Đường cơ sở ::
Góc Array :
Command:
Rồi đứng im :wub:....Mình xài Cad 2007 :(
