Học AutoCAD Online cùng CADViet
[Update] AutoCAD 2019.0.1
Bản update dành cho các bạn đang xài 2019 đây :)
- Link : https://anotepad.com/note/read/wd7qts
- Pass : icad
- Notes :
No update of AutoCAD 2019.0.1 Update in AutoCAD 2019 brings any new functionality , only fixes the problems found:
- No more unforeseen errors occur when loading the CUIx partial adaptation file after resetting the settings to default values
- The order of blocks when inserting some special drawings is displayed correctly
- Pressing the TAB key once successfully changes the specified distance by an angle when drawing a polyline
- It turns out correctly to hide the DataFlow buttons on the Quick Access toolbar (only in the 64-bit version)
- When you use the command to work with multiline text, you successfully create fractions with a slash and remove the leading space
- The path to the tool palette file, changed in the parameters dialog box, is saved after clicking the "Close" or "Apply" button
