saukhoai
SỬA LISP
CHÀO AE. MÌNH TÌM ĐƯỢC TRÊN DIỄN ĐÀN CỦA TA CÁI LISP GHI SỐ LƯỢNG THÉP ĐAI THEO DIM NÀY. H MÌNH MUỐN NHỜ AE BỔ SUNG THÊM GIÚP MÌNH PHẦN GHI KÍ HIỆU THÉP VỚI.
VÍ DỤ CHẠY LISP NÀY NÓ RA LÀ 5%%c10a200, H MÌNH MUỐN NÓ HỎI THÊM PHẦN NHẬP KÍ HIỆU THÉP. VÍ DỤ KÍ HIỆU THÉP LÀ 2, THÌ SAU KHI CHẠY XONG LISP NÀY NÓ SẼ HIỂN THỊ LÀ  [2]- 10%%Ca200
Z1.lsp
  • Vote giảm 2
1 giờ trước, saukhoai đã nói:
ae giúp với
(defun C:z1 (/ giatri sokhoang ss)
(setq oldos (getvar "OSMODE"))
(setvar "cmdecho" 0)
(command "osnap" "none")
(if (null bcd)
 (setq bcd 150)
 (setq bcd1 (getstring (strcat "\nBuoc cot dai <"(rtos bcd 2 0)"> :")))
 (if (/= bcd1 "") (setq bcd (atof bcd1)))
 (if (null dkt)
 (setq dkt 6)
 (setq dkt1 (getstring (strcat "\duong kinh thep <"(rtos dkt 2 0)"> :")))
 (if (/= dkt1 "") (setq dkt (atof dkt1)))
(if (null khieu)
(setq khieu "1")
(setq khieu1 (getstring (strcat "\nNhap ky hieu thep <" khieu "> :")))
(if (/= khieu1 "") (setq khieu khieu1))
(prompt "\nChon doi tuong Dim.")
(setq ss (acet-ss-to-list (ssget '((0 . "DIMENSION")))))
(foreach enxt ss
(if (or (= (setq giatri (cdr (assoc 1 (entget enxt)))) "<>") (= (setq giatri (cdr (assoc 1 (entget enxt)))) ""))
(setq giatri (cdr (assoc 42 (entget enxt))))
(setq giatri (atof (cdr (assoc 1 (entget enxt)))))
(setq toado (polar (cdr (assoc 11 (entget enxt))) (/ pi -2) 300))
(setq sokhoang (+ (fix (/ giatri bcd)) 1))
(setq text (strcat "[" khieu "]-" (rtos sokhoang 2 0) "%%C" (rtos dkt 2 0) "a" (rtos bcd 2 0)))
(command "TEXT" "J" "C" toado 150 0 text)
Bạn kiểm tra được chưa nhé
3 giờ trước, huunhantvxdts đã nói:
(if (null bcd)
 (setq bcd 150)
 (if (null dkt)
 (setq dkt 6)
(if (null khieu)
(setq khieu "1")
(foreach enxt ss
cảm ơn bác, đúng ý mình r. chúc bác nhiều sức khỏe
